  1. dumb cam/heads install question????
  2. Anyone have a Good Fuel Pump install guide?
  3. Broken header bolt
  4. Hooking up a switch to bypass Knock Sensor
  5. making OVC wires BLOWS A**!!!!
  6. Which heads to lower compression ratio
  7. these fit???
  8. cam on a v6
  9. Starter Options
  10. Cloye's double-timing?
  11. What does rod damage do to the engine?
  12. bad vibrations when turning at low speed
  13. How to remove a T-mission
  14. Dynoed the Car today, want 20 more HP!
  15. double roller timing set on 96-97
  16. Oil Cooler Help ~ Big Mess
  17. Converter Questions? 4L60E-700R4
  18. HELP questions on cam change, part replacement? yes or no?
  19. Dustless/ceramic brake pads??
  20. how short can i cut it
  21. Subframe Connector size
  22. 85 mph vibration????
  23. Would it be worth it for me to switch to the R lifters?
  24. 1st time
  25. Any way to delete VIN from LT1 edit, so it can be used on other car?
  26. Best place to WINCH a T/A From
  27. Vented gas cap
  28. What were your symptoms when the power steering pump went out?
  29. Okay lets try to diagnose this.
  30. Need high speed suspension. What to get?
  31. Who sells the pro 5.0 with lou's short stick?
  32. Question on airfoil installation? gasket?
  33. Dash popping? Steakes rattles? Subframe connectors?
  34. best cam 383 for daily driver
  35. Overtighten Pro5.0 Bolts ?
  36. Ripper Shifter??
  37. which exhaust??????
  38. think i can break into 12's with 100 shot??
  39. Aftermarket Wire Looms
  40. Anybody elses flowmaster catback not fit right?
  41. Speed limiter, and any way to change it?
  42. Accel 300+
  43. Where is the best place to buy AFR heads? Which ones?
  44. th350+3600 stall=10mpg?
  45. I need your guys help ASAP!
  46. HELP!!!!! weird shat happenin o2 question
  47. 383 stroker?
  48. Tire sizing question....Injuneer?
  49. Where to get touch ^paint
  50. someone tell me if i have the correct Stage8 bolts
  51. How hard is a cam swap?
  52. 245-45-18 tires on 91/2 rim
  53. Knock Sensor replacement?
  54. Optispark, intake and waterpump leak. Am I getting ripped?
  55. Replacement Front Brake Rotors
  56. anyone have exp with KVR cabon-metallic pads?
  57. AC Delco plugs - difference?
  58. ? Replacing headlight panel assembly on 93 formula
  59. Zo6 Maf Conversion on Lt1?
  60. pros and cons of SVO injectors
  61. Upgrade ideas while i'm there....
  62. Where to buy...
  63. Jet Hot Longtubes
  64. car is quiter after Mac header install?
  65. Plugs and Plug wires
  66. ABS Problems, Someone Please Help
  67. Jt595ta/ Alum. DS?
  68. Fuel Pump Prime ?
  69. Is this a part number 10216948 ?
  70. Datamaster
  71. DS Vibration or What?
  72. Am I going to need an off road pipe?
  73. Anybody have a write up on taylor ovc's?
  74. Blown Head Gasket? But no water in the oil
  75. How do I take the caliper slide pins out????
  76. I Need 30 More Hp...any Ideas???????
  77. AS&M Cold Air Induction?
  78. weird noise when starting car
  79. How and where do i get a door wiring harness?
  80. What clutch?
  81. LT1 Misfire problem...help please
  82. MSD Wires
  83. Will Muffler improve Cutout sound?
  84. Is my car working right??
  85. New Best
  86. Which "stage" port job for hotcam?
  87. z28 newbie with a couple of questions
  88. parts numbers needed please
  89. Where to get iridium spark plugs?
  90. '98 Rims won't fit on the rear of my '95 without slight grinding??
  91. Ignition coil
  92. could this be my opti
  93. How do you change out the short dialpin for long?
  94. 275/40/R17 tires for under $140 a tire?
  95. optispark problems (car died)
  96. What exactly is the optispark?
  97. Trans rebuild part list
  98. GMPP 1.6RR questions
  99. I just want an alt. overdrive pulley??????
  100. How did I make out?
  101. Help identify mystery box...
  102. Changing T56 rear seal?
  103. Can heads be ported without having valves and springs present?
  104. im stumped.......someone figure this out for me
  105. water pump gear
  106. B&M holeshot converters
  107. Anyone Have experience with prothane motor mounts?
  108. o2 extension length
  109. Gas gauge
  110. Rocker Stud Diameter for RR's on stock LT1 heads
  111. header gasket install tip
  112. Headlight Control Mudile???
  113. 17 by 9 1/2in rims could i fit 315s on them
  114. installing catback
  115. Opti Spark
  116. help me out with some alarm info?? (i'm clueless when it comes to alarms)
  117. droped a lifter in the oil pan.
  118. would a loose timing chain, cause pinging ??
  119. are the slp oil coolers better than the ...
  120. Any one else notice the new parts in summit?
  121. Question on LSA and using N20
  122. Boxed oem lca's
  123. Size of stock crank balancer?
  124. MSD Crank Trigger kit?
  125. Who has adapted an LS1 T56 to fit an LT1?
  126. compression
  127. valve sping locators in the way of head bolt
  128. Clutch problems!!!!! Help fast.
  129. Found Great Deal on Z-28 Rear, worth a swap?
  130. What differential fluid?
  131. No PSI Gains After Oil Cooler Removal
  132. Nitrous or S/C?
  133. What to use to get the pilot bushing out. ( I have grease, but what object fits)
  134. QUICK: need help installing shift light
  135. How do you know if your Opti is bad?
  136. computer chip
  137. Mechanic says LT1's have slight acceptable valve tap?
  138. Elcheapo Cutout? Suggestions..
  139. Trans stick rubber grommet(s)???
  140. rear brake problem. caliper needed?
  141. Can My LT1 Beat a '98 Cobra?
  142. Air Pump Fuse Blown
  143. is this worth it?
  144. Anyone got an IAT module mod?
  145. GREAT service from MAC!!!
  146. Maybe you guy's can help me with my little ford ranger ?
  147. Formula surges at red lights, HELP
  148. finally home...now what?
  149. K&N FIPK Instalation
  150. aftermarket wire looms from thunder racing
  151. 94 Z service engine soon light
  152. Honest exhaust question......
  153. Which heads are better?
  154. Oil Cooler Suggestions
  155. Hood question
  156. Recommended break in period for 4.10 gears?
  157. Removing my trans
  158. Please tell me about a 95 trans am?
  159. Camaro VS Iroc
  160. Problem installing injectors?!?!
  161. Will Z28 ever come back??
  162. cutout installation question
  163. HOW to drain/flush cooling system...
  164. new rear end cause traction and abs lights to come on?
  165. lt1 flexplate? Please help!!!
  166. Can My '95 model lt1 beat a 98+ mustang GT?
  167. Why does everyone ask.....
  168. Anyone running the Qwik Stick?
  169. Important ? (like aren't they all lol)
  170. Griffin radiators for Lt1......
  171. Muffler Suggestions to go w/ cutout?
  172. I NEED shoeboxs coolant flushing website asap
  173. Go steeper than 4.10's?
  174. How do I make a 12 second car?
  175. When do you lockup your TC?
  176. Torque Converter question
  177. Clutch Pedal Shakes
  178. OBD I Fastchip users inside.....
  179. who can align a dropped car?
  180. Clutch or Tire problem??
  181. Fuel Filter Replacement
  182. Rear Diff Troubleshooting
  183. Question about double roller timing on LT1
  184. chrome or polished oil filler tube ???
  185. Crap Bosch O2's?
  186. Where to mount the cutout?
  187. 92 Gas in Bay Area, California?
  188. OBDII Inspection ? and Free Mods
  189. Knock sensor/retard/PCM question...
  190. does resting pcm = undoing Programing???
  191. 94 Z/28...Which OBD used?
  192. Oil filter adapter question
  193. Fuel injector cleaner: Yes or No?
  194. Car keeps eating pilot bushings...why?
  195. Removing Throttle Body
  196. performance
  197. turbo 400 swap in gen IV
  198. It sounds like there's a rock in my cat
  199. How often do you clean your filter?
  200. Possible to mate a 4l80e to a LT1?
  201. G-Force T/A KDW vs KDWS
  202. top-end problems
  203. Rocker adjustment & idle quality issues
  204. How to put an image in a post
  205. AFPR and guage ?'s
  206. What is that sensor on yout elbow do
  207. Opti ?
  208. Rear Pinion Leak
  209. Cleaning a MAF???
  210. Where can I get a NEW Center Console?
  211. High volume oir pump or not?
  212. 60 Ft. times need help.
  213. WHere to take my car
  214. All 97s
  215. Proper Break-In for a motor
  216. Questions about switching to Synthetic on a stroker
  217. Shorties w/stock y-pipe?
  218. I removed my screen in my stock MAF...is that ok?
  219. Stuck on exhaust manifolds
  220. A/C not cold & hissing sound in vents from A/C?
  221. headers for 93z
  222. Pre 87 smallblock swap in gen IV
  223. Hooker shorty headers install ?
  224. ABS Inop light and Low traction light problems
  225. Stock Injector Part Number??????
  226. How's the clip on the A4 shift knob come out?!
  227. Brokin Exhaust Manifold Bolts!!!!!
  228. long tube headers and y pipe
  229. car pulling to left
  230. Tip for PPL with K&N's that fall off
  231. gears + rolls = what is better?
  232. LT4 conversion kit
  233. Cloyes timing chain install question
  234. i hate SES lights (please help)
  235. getting old exhaust manifolds out?
  236. Steering dead-on center?
  237. NEED HELP! Cross-Threaded Header Bolt -- What tap do I use
  238. PN# for re-usable Tranny pan gasket
  239. bought new car, what will it run?
  240. How to fix low IAC counts and rough idle?
  241. cc306 dowelpin
  242. shift kit??
  243. Can somebody tell me how to do the taylor ovc's?
  244. I lowered my coolant temp.
  245. personal preference.... A4 or M6
  246. what times should i be posting
  247. problems with taillights
  248. Ported LT4 Heads
  249. Finally got some dyno numbers.....
  250. Corvette VCs part #
