  1. Coil ??????
  2. Problem with Brent's SKIP SHIFt mod, no GRAY WIRE!
  3. HELP FAST PLZ with my ES tranny mount.
  4. would this work?
  5. keyless entry alarm question
  6. Cam endplay ???
  7. Is nitrous SAFE???
  8. BBK TB Gaines???
  9. does anyone have sound clips of this???
  10. Is there an unused power wire somwhere?
  11. dynaspark replacement for optisark
  12. Can someone please help me find the correct part #'s?
  13. link to site black z28 with nascar exhaust?
  14. How much of difference would a Ported Intake Manifold make?
  15. How much HP are Scat 4340 Forged I-Beam rods good to?
  16. Relocating IAT(incoming air temp. sensor)?
  17. Would like a part # off a GM schematic
  18. Longer exhaust valves....setting lash???
  19. Porting Intake
  20. Knock Retard Woes...
  21. Lot of difference between 245 & 255 on 8" wheel?
  22. Those of you who got WOT (only WOT) dyno tuning....
  23. dynotune prices???
  24. Question about trouble codes
  25. hot cam kit and what else?
  26. Hypertech 160 Thermostat?
  27. Holley Air Foil?
  28. Question 'bout Oil leak
  29. Longtubes on a lowered car?
  30. how do I test the knock sensor?
  31. tire question
  32. Cam and Lifter Choice
  33. Solid roller guys
  34. Pushrod Length?
  35. No change in ET after H/C install?
  36. flow numbers on well ported AFR LT1/4 castings?
  37. T-56
  38. Buy used rear with brakes vs new brake hardware and gear install later?details inside
  39. How long to do a T56 swap
  40. Chrome Emblems
  41. camaro z28 mods
  42. Would like your experince with the following engine ideas
  43. Can I use an LS1 clutch with an LT1?
  44. Used automatic tranny adding a shift kit
  45. lt4 knock sensor=bad?
  46. Canton Oil Pan
  47. Which heads and cam combo for 383
  48. 85mm ZO6 MAF conversion???
  49. Clutch question
  50. can someone look under their hood for me?
  51. Key FOB
  52. Exhaust
  53. MSD Placement
  54. Opti's and timing sets
  55. ARP Main Studs location question w / Windage Tray
  56. LT1 Block
  57. problem with intake install, need help
  58. Will The 26x11.5x16 Et Streets Fit In Fender???
  59. Any write ups on Crane HI6R ignition hook up?
  60. longtubes
  61. stock rev limiter for m6, 5800 or 6200???
  62. Muffler/exaust preferences
  63. Spare tire rims as skinnys
  64. TB and Filter give 25 HP on HP TV
  65. Those with Nitto DR's that drive Street please
  66. What's the point of a windage tray?
  67. Relocating the alt. but keeping PS and AC
  68. Converting ODBII to ODBI Speed Density
  69. putting engine back in: have a few q's!
  70. NGK TR6 part #
  71. monkeys at gm dealership or not?
  72. Intake gasket, what about oil press. sender?
  73. Pushrods. What size are they???
  74. ? on Trouble Codes
  75. I need help bad!
  76. What are some good sized sway bars to buy???
  77. Crane HI 6R install problem with in. PLS HELP with the white wire.
  78. can a water pump leak for a bit and stop
  79. What can i expect?!?!?
  80. 383 or 396
  81. need help with LT's
  82. Free scantool for OBD2?
  83. Need to drop oil pan, should I add HV oil pump now?
  84. Synthetic ATF in Auto; What's the Final Word?
  85. Engine Swap advice --- LT1 rebuilding
  86. For those w/ Xtreme Torque Arms
  87. best way to wire a csi electric waterpump, I see several.
  88. What mods next?
  89. lca
  90. Best Bang for the buck?!?! "SLP Clutch Kit or stock OEM"
  91. Real bad miss
  92. Help! Fans Won't Come On
  93. Street Twin work with stock flywheel?
  94. Long Tube question
  95. heater bypass poll
  96. Is It possible???
  97. LT4 Intake Swap ?
  98. what size rocker arm studs go into LT4 heads??
  99. Nasty hesitation/stumble in closed loop...
  100. Royal Purple... interesting real life data within...
  101. Hot Cam too tame?
  102. Offroad pipe or something similar for a 97' Z28
  103. Post your STOCK dyno sheets...
  104. Kevlar or Carbon Disk on SPEC STAGE 3 LT1 Clutch Kit
  105. Air Pump Fluttering Noise
  106. nasty vibration
  107. Which Head Bolts go through the water jacket?
  108. Troubleshooting A/C system, please help.
  109. May be moved butt.... Ford motorsport wheels on 94 TA????!!w/in....
  110. Beep Beep Beep - ARGH!
  111. Retaining ABS on ASR Delete
  112. LT1 with LS1 Heads?
  113. help me....
  114. Will this rotating asembly work?
  115. Weight Reduction
  116. solid motor mounts
  117. Does the Magnaflow sound like the hooker catback?
  118. Will 3.73 work better with CC306?
  119. How does everyone like their HAL setup or Koni/Bilstein Setup?
  120. short block
  121. another thumbs up to lloyd-numbers inside
  122. What to buy with $200?
  123. Dynotuning in bay area???
  124. Is Master Cylinder Mated To Slave Cylinder
  125. vented opti conversion
  126. Best SFC?
  127. shift knob removal?
  128. Brakes
  129. Part number for oil filter bracket
  130. which elbows fit slp cai?
  131. My starter is going out
  132. Oil Pressure sending unit
  133. Engine Eating Oil
  134. Cheapest subframe connectors
  135. Anyone used the ypipe from summit for the hooker LT's?
  136. WARNING about LT4 KM
  137. New Exhaust???
  138. clutch pedal had different feel
  139. thermostatic switch for electric water pump???
  140. coolant question
  141. lowering the car...
  142. Prob stupid question
  143. differential cover/ girdle
  144. What to do with $600
  145. 3.73 on a stock rear?
  146. Rocker Arms
  147. CC 306 Video's inside
  148. Clutch woes...Take a look.
  149. another quick question
  150. Spark plugs with heads/cam
  151. 3.73 Install what fluid to use?
  152. Old question...but i'm a newbie
  153. Is someone on that can help
  154. Looking for feedback on 1LE/LS1 driveshaft
  155. Dyno numbers for Bauer 383
  156. Wideband O2 Tuning After the Cat Possible?
  157. Adjusting the timing gears...no chain
  158. Worth replacing 110K mi Opti since it's already off?
  159. Vented gas cap after removing EVAP system??
  160. Still not in the 12's yet
  161. What makes a lowered car not handle bumps well???
  162. Ok last try, anyone with Crane Hi6 come inside. PLS
  163. where can i get a/c delete pulley?
  164. best heads cam setup
  165. Chilton's or Haynes, that is the question
  166. Atkins diet for my car?
  167. TPIS heads???
  168. engine bogs
  169. XE 224/230 Cam Questions
  170. Are speed pro forged pistons pretty good?
  171. Driveability Question
  172. what clutch should i get?
  173. Service Manual on CD any good?
  174. GM or Fel-Pro rear main seal?
  175. Slot car racing LCAs and PHB
  176. 11.7-12.2 volts when cranked (Max)
  177. Car is misfiring pretty badly...
  178. Transmission problem
  179. Power Steering flush..question about the "4th gen tech articles" web page...
  180. Should I just cam it?
  181. What shift points? Stock 125k bottom end, HOTcam, heads, bolt ons..
  182. I need a new opti, where to get it and how much?
  183. How do you delete the ASR?
  184. FLP LT's. What Gaskets?
  185. Blown Head Gasket
  186. LT1 "Hot Cam"
  187. 95 Y pipe in place of 97 y pipe
  188. Pro 5.0 Shifter and B&M Ripper, which has the shortest throw?
  189. weird grinding/growling noise from trans
  190. Idles rough
  191. M6 disassembly question
  192. Why not just use Nitrious?
  193. Battery wont charge HELP!!
  194. Stumped (long thread)
  195. Will vert. mount looms work with existing wires?
  196. quick head ?
  197. How do you make an FFI SS hood functional?
  198. Wiper Blades same as 98-02??
  199. $400, sound about right for.......
  200. Something is wrong, either I have a blown head gasket or i need a new opti
  201. installing a double roller timing chain....
  202. Doing rear brake pads, have ?'s
  203. Burning Smell
  204. M6 Stuck In 4th Gear At 105mph?
  205. what valve covers will clear 1.6rr's?
  206. DTC PO1441 on 96 T/A
  207. Passed Emissions with a 230/236 Cam
  208. Engine Re-build
  209. Engine Re-build (2nd thread)
  210. can i force car to run in open loop without O2's
  211. stuttering after lock-up
  212. Idels rough
  213. who has used honda atf in M6
  214. Which fluid for my new tranny and TQ?
  215. How many O2 Sensors does a '94 Z28 have and where are they located?
  216. Are lightweight flywheels worth the $
  217. whats best to use on battery to keep from corroding
  218. headlight relay
  219. grill
  220. Just got my flow #'s
  221. Question about my needle bearing?
  222. Is Motive the best brand of 4.10 gears to buy?
  223. car not cooling right, STILL!!!
  224. Fuel related problem Need HELP FAST!
  225. Vented Opti Problem
  226. Need 12 bolt purchase feedback ASAP!!!
  227. idle problems after roller rockers?
  228. Need Help!
  229. how could i tell if my opti is dead?
  230. MAC header owners, please help!
  231. how to test MAF sensor?
  232. GTP body control module Problem
  233. What sensors differ from a 94Lt1 and a 97LT1?
  234. autolite 104, is it one heat range colder than stock??
  235. how many people have broken stock main caps?
  236. is a adjustable torque arm needed?
  237. Roller Rockers, is this the normal sound?
  238. SFC's
  239. doors shut with a SLAM!
  240. How bad will my handling be?
  241. foil tape on spark plug wires
  242. Don't let people fool you, CC306 can pass emissions easily.
  243. Whats wrong?
  244. Question about gear install kit and rear end cover/girdle...
  245. RPM gauge and shift light
  246. in reguards to 1.6 rr's and pushrod length
  247. cags & resistor done...just a few ?'s
  248. GOLEN engines
  249. hotcam ?
  250. egr! cause really minor stumble?
