- your opinion on this
- Where did you get your water pump, and how is it holding up?
- Someone answer this stupid easy question for me
- Found worn Cam bearing when doing cam swap, now what?
- Will a water pump leak show up under a presure test ?
- LS1speed.com
- Question about 2800 + stall TC
- WTF is wrong with my car. please help
- PLEASE help me with my steering problem!
- What valvecovers?
- Optispark install gone wrong
- Hows the G2 cold air kit compare?
- sensor related problem?
- RTV on water pump gaskets?
- Ohio E-Check?
- Do I need to upgrade my fuel pump?
- Looking for a stage 2 heads, what should I get?
- Spark plug gap
- Racenet.net - Maybe this will get your attention?
- were to get an EGR block off plate?
- Pwer Steering resevoir overflowing????
- Not able to install strut tower brace
- Code 72 VSS Loss??? But Speedo Is Working??
- Need opinions fast on opti for 95 TA
- Front Timing Cover Leak
- Hesitation @ low rpm???? What to do
- Error Codes... what do they mean?
- ARP head bolts:torque ?'s
- Bosch 30lb injectors
- Exhaust & Cat. convertor question
- constant metal on metal scraping sound - coming from alternator area - help!
- How much can I expect to pay to replace Cat in Cali??
- Consequences of leaving the coolant crossover tube off the heads?
- Need Help!!!!
- engine rebuild.........
- My speedo is off after motor swap
- can the alternator be painted
- How does everyone like their street twin for daily driving?
- Wiring Problem Pease try to help me :)
- intake backfire?? Help!!!
- Shift Kit/ Car questions.. PLEASE HELP
- any other companies offer "cam kits"
- * Consequences of removing a/c canister for polishing please help need info
- Question about a hose from the optispark?
- Want to supercharge...Please help.
- HVAC shorted to Ground.
- What exactly does an MSD 6AL box do?
- let engine idle for 5 minutes, and coolant dripping. is my new headers still ok??
- A newbie's nightmare changing the coil!
- Book pf part numbers?
- 93 Guys that have used this tranny give me your opinions.
- 4.10's broke, should I go 3.73?
- Engine block to chassis ground wire (shoebox?)
- no a/c
- Removing The Inktake - What to Do ?
- Where does the vented opti harness connect too?
- $1,000 to spend, don't know what to get
- Problem with 160 stat install. Just cracked the bolt PICS, ideas?
- Sensor On Top Of Rear End???
- Where did you get your heads ported?
- cheapest place to buy pro 5.0
- Buying an LT1 Z28...Need Advice!
- Just want to give a big thumbs up to combinationmotorsports
- Tranny leak
- Need help with car starting PLEASE!
- What symptoms with a bad MAF.
- head cc ######
- please help, convertor problems
- Turn Signal Flasher?
- Anybody know where to get o2 sensor from?
- Hotcam springs work w/ CC305
- Header install and $1k
- nov-vented opti to vented opti swap
- burnout question
- Door skin detaching from frame... any way to fix?
- CAR sputtering poping boging under full throttle!!!!!!
- Changing wires, need order on the opti
- Powerband on Aftermarket cams?
- Ever heard of this?
- Installing OVC Taylor Wires
- Good discussion on removing bumper supports..
- Will a 93 Intake Fit a 95
- Car won't hold idle!?
- car died out
- cheapest parts: Cromer or GMpartsdirect.com?
- Any power in this air delivery set up..
- My birthday next sunday, what should i get?
- Why Do I have Little Air Bubbles on Oil Dipstick????
- 95-96 differences? problems?
- Stage?# Heads and other ?
- Intake
- Anybody got directions on keeping the fuel bucket with a WALBRO PUMP????
- cant get last header bolt in!!!!
- Please dont laugh. Could a hole in my Reservoir cause my Rad to empty ?
- Ignition trouble
- Clutch disk question
- Anyone try these "Visa Visa VK-40G ZR" TIRES yet ?
- Crank hub is stuck
- Main gasket or too much oil?
- '96 Z with Hooker LT's: Should I use a 93-95 or 96-97 catback?
- T56 Rebuild
- what causes a miss at idle?
- LT4 heads chamber size?
- shorter length sparkplugs
- what size relay for electric WP??
- Car runs like crap
- Starter draws 240 amps?
- Need help picking a cam with ....
- Starting Issues......
- Stupid question about lifters?
- q's for guys with 396's?
- piston question?
- How do you take off the A.I.R. cross pipe?
- What is a good moderate clutch???
- PO100 and PO1641 DTC's
- thinkin about some tires...
- Why does a manual fan switch work??
- alternator removal, where to get !AC pulley
- ??? about O2 sensors
- power steering problem
- How do I hoist front of car up to pull the engine out the bottom?
- SLP CAI w/ K&N recharge kit?
- fuel economy
- warning lights
- What size bolts to block off air and egr?? Also gasket?
- Heads and cam suggestions
- Whats the difference in the mufflex y-pipes?
- sorry about all the ?'s but what mr.gasket collector gasket do i need?
- yanked my oil cooler
- What size lug nut for wheels???
- What Are The Best Headers For My Car?
- Can a decent 355 be built for under $3000??
- Torque Arms?
- Fuel pressure Question
- Where to buy lt4 km?
- trip meter does not work right
- Cam question...
- Help with tires
- Header gaskets?
- A/C Compressor, GET OUT!
- 4.10 gear installed...question
- MadZ28???
- History Code 43 Ignition Failure
- head cc ######
- check engine light came on at highway speed.
- Thread Sealant VS Thread Locker???
- Best Aftermarket Seats??
- Whats wrong with this thing?
- Slip-In Primary Leak Fix!!
- which way is up on this head gasket??
- ? on fogger kit hook up
- Another PROBLEM!
- Best fuel injector cleaner?
- Engine coatings!!!!
- SES light on/off
- Have you guys ever heard of this?
- Stock gears for T56?
- $$$$ w/!egr and !air
- How to replace the Crank Position Sensor...?
- How to reset PCM
- horsepower calculator
- Break in Question
- Red Light on the Left side of gear selector
- LT4 starter with Hooker LT's
- Trying to Change coolant, this is becoming a real pain
- Coolant Bypass Kit?
- need my PCM programed. where?
- Where do these go?
- is it my driveshaft or differential thats busted???
- SOMEONE get ahold of LT1DAVE for me please
- what does it take to do a auto to t56 swap
- Jet-Hot Headers on a 97?
- A few questions
- 383 and HOTCAM VS 383 and HT383 crate cam
- Hi-Res Failure when I plug in an injector box?
- Front Lower control arm bushings
- Track gains?
- Battery bolt size?
- did my heater bypass yesterday, and have some questions
- What gear to dyno in?
- can I shim my rotors myself
- anyone have instructions for power window motor R&R???? shoebox??
- SES Light came on in my 97 Z today...what to expect???
- code 44
- Heads and cam are in, my thoughts and a few ??s.
- Just had an engine rebuilt, seems like there's problems
- wheel sites
- keys stuck!
- Blew head gasket, going to do all gaskets in motor, help me decide
- Heads and cam or 12 bolt
- Dont know what mod to do next?
- 94' trans problem....not downshifting right
- Tips on Rebuilding/Upgrading a '96 up to 600 HP
- Where can I get rubber sealing washers?
- IAT sensor
- Does anybody have this color touch up paint??
- Reading Rims
- MAF probelm HELP! shoebox?
- Failed Emmisions
- Holley TB worth The $$ on a ported Intake?
- Breaking in a new clutch??
- what should i replace?
- What kind of 02 sensors
- Can't find just the Walbro 255lph pump (not w/wire kit) online?
- Going to build a 9", need some advice.
- Ltcc Help!!!!!
- Weird dents... should I be concerned?
- IAC number all over the place after installing TNT plate...
- car still runs like crap please help to list any and all causes.
- I need your opinion on a problem guy's
- Is this the right Part # for GM Header Gaskets?
- Rear control arms
- Time For PCM tune yet?
- anyone with TPIS long tubes?
- car only starts after long time and oil pressure
- Backspacing on skinnies
- poly/rubber LCAs.. quick question about install
- Check out the before and after (Head Work)
- car misses, smell gas please help
- How important is the LT4 knock sensor to get?
- Problem with keyless entry transmitter!!!!
- Pro 5.0 or SFC's???
- ignition problem
- Emissions numbers for stock engine
- Vacuum Hose Replacement?
- Service Engine Soon light
- the teeth on the gears broke on my car, what needs changing???
- Now what do I do?
- Tranny Question
- Exhaust and Header Help
- Emissions: Shorties vs. LT's
- Knocking, pinging, detonating, preignition, whatever...
- Car stumbles, bogs, then takes off like a rocket!?!
- O2 sensor removal issues
- Big Problem!!!!!!! NEED HELP!!!!!!!! PLEASE!!!!!
- Low O2s/ 1/4 times down Please help
- Bad EGR symptoms???
- Strange Cooling Problem (Please Read)
- Is RockAuto.com a crediable source?
- durability tips?
- Rotating Assembly is HERE!!!!! WOO HOO! Pics inside!!!
- Has anyone else had trouble with Eagle?
- Mac headers+offroad pipe = lots of rattles
- LT4 conversion. 425HP
- Beating up the cam question some more
- Can I rebuild my starter or am I screwed?
- msd or accel coil?
- Almost Blew Up Motor
- Couple of questions before header install. Need some help locating part #'s
- How to disconnect this battery? PICS!
