  1. 2 bolt or 4 bolt splayed caps?
  2. Autozone.....PFC Z Rated Pads
  3. aftermarket optispark
  4. hooker cat back of flowmaster american thunder catback??
  5. Proform 1.6 rocker arms on ebay - $169. 00 - any good?
  6. Rubber bushing grease, what type?
  7. 383 vs 396
  8. Do I really need 02 SENSORS
  9. Reverse pops out
  10. God i hate my car so much.
  11. Had cat removed
  12. Q-Tech headers. any one try them
  13. Hooker catback people inside.
  14. Stock lifters
  15. Code 29 eas electrical fault???
  16. Abs Inop
  17. opinions on this cam please
  18. 97 Ss
  19. If I received a new "HOTCAM" that was ground...
  20. thinking bout porting heads, who to choose?
  21. My Tranny!!! Need urgent help !!! Belhousing
  22. What heads?
  23. 61cc heads with 58.2cc pistons. What problems?
  24. is there a fuse or relay or fusible link for the...
  25. what would cause an alternator to ...
  26. replacing torque arm bushing
  27. Ls1 4l60e ??
  28. What Tranny Do I Replace it with????
  29. throttle body problems
  30. Whats Engine Core required mean?
  31. Differences between SLP CAI and K@N FIPK ???
  32. Question about light weight battery..
  33. Spring install - Open end towards front, or what?
  34. can I change the waterpump seal with the timing cover still on
  35. AC questions
  36. Any "gotcha's" on center console removal?
  37. If I have a little bit of play in the steering wheel, what needs to be replaced?
  38. Loss of power...Please HELP!!!
  39. car wont start, and shooting flames from the Y pipe after opti and waterpump install
  40. Possible Injector Problem when hot?
  41. Link or phone # to cable from computer to car
  42. cheapest price youve seen on window motors?
  43. miss under load at idle
  44. Help me push over 320 hp.
  45. hot cam and nitrous questions
  46. SLP traction contorl switch
  47. Might be buying used cam, questions inside
  48. A stupid question...
  49. Who has best prices on Spec Stage 3s?
  50. Does anyone use rotex brakepads
  51. fuel rail schrader valve
  52. Settle this once and for all
  53. skip shift eliminator
  54. Brake or Bearing ?
  55. security light randomly comes on can't start until it goes off
  56. SLP Fan Switch
  57. 383 Engine and Exhaust Sound Files...
  58. Popping At Idle
  59. Door coming apart...
  60. I mangled my brake line.
  61. High output alternator for LT-1
  62. widest tire on stock rims?
  63. Need help with Timing chain and/ or Egr valve?
  64. Jet-Hot Header review?
  65. Anyone have a sound clip of a Borla?
  66. selling my car... please read
  67. Couple Questions on N20 vs Blower??
  68. valve adjustment..
  69. How do you check what gears your car has?
  70. Hot Cam/Heads....in here!!!
  71. valve cover removal?
  72. Injector size question
  73. Need a new tranny, WHICH ONE SHOULD I BUY?
  74. Is it my imagination? Ground clearance!
  75. Head Gasket Intructions
  76. i need a few part numbers.
  77. Someone please tell me what this 112lsa means as far as cams go
  78. is it worht building a 355?
  79. the hell???
  80. need some help here...
  81. WHy won't 98+ steering column fit 93-97?
  82. Are 24" O2 extensions long enough for my Jet-Hot LT's?
  83. Is it possible to install factory theft deterrent system in a '95 T/A??
  84. Part for K&N CAI missing...Suggestions?
  85. slp headers, will 3/4" bolts work?
  86. oil gage stays up at 80
  87. opinions on dyno numbers
  88. Got low oil pressure? I got the solution!!!!
  89. Front end alignment ?
  90. What kind of puller do I need?
  91. Racenet Heads-anyone use em?
  92. xe224/230 or cc306
  93. what motor to go with?
  94. Anybody use these tires?
  95. One problem fixed, now another.
  96. VATS repair
  97. Where's the best place to buy header gaskets 1 3/4?
  98. spark plug suggestions
  99. good price on used Trans AM
  100. Cam Questions
  101. ! Please Help ! Hesitation
  102. cam install question
  103. flatspot when i get on the gas
  104. Price and parts needed for LT install?
  105. If I deck the block .025-.030, and Mill .006 off heads, What about the intake?
  106. Anyone heard any feedback on Edelbrock Coilovers?
  107. a/c problem??
  108. guys sorry bout another exhaust thread, changed my mind!!!
  109. How to get oil and rust stains off...
  110. What is ideal coolant temp range for a modded car?
  111. Any 10 second heads/cam LT1s??
  112. Will 94 shorty headers fit and hook up to a 93?
  113. the 383 LIVES!!! woot
  114. Need help
  115. PCMforless?
  116. Do I need O2 Extenders for the fronts when I do MACs on my 96
  117. Will a T-5 tremec work with the LT1?
  118. I have officially gotten 13.9
  119. gear ratio question
  120. stumbling and pinging
  121. Is the GM Hot Cam the hottest chevy makes as far as hydralic roller
  122. xe 224/230 and lift number question
  123. Finding Valvetrain Geometry?
  124. Type of fuel injectors on a LT4 96 Grand Sport corvette?
  125. stupid spark plug wires.
  126. Has this been tried yet
  127. eibach springs
  128. Before buying new opti
  129. what happen to the cadillac cam
  130. Cam install prices..What are you paying?
  131. 93 custom fan switch diagram????
  132. Subframe connectors
  133. Who needs a cutout?
  134. brake cylinder seals and dust boots
  135. Guys running MAc headers, what kind of power increase?
  136. LT1 MAF eliminator kit???
  137. Good muffler shop in Chicago area?
  138. 11s N/A for under 3.5K
  139. Need some RWHP predictions, Going to dyno tomorrow!
  140. Programming..
  141. !!!!!!!!!!!all Camaro28 Members Please Read!!!!!!!!!!!!!!!!
  142. Old school vs New school
  143. lt1 dave
  144. Best Nitrous Plug and Gap?
  145. Are MSD coils any good, or should I replace with stock?
  146. which flow's better LS1 air lid or LT1 K&Nfipk
  147. ET Streets and the Highway
  148. LT1 Cam Question
  149. Wireing harness swap
  150. Replacing Valve seals.
  151. Those with lots of tire experience, help me choose?
  152. Problem after cam install
  153. Coolant Magically Disapears ?
  154. Forged 327
  155. Compression question?
  156. Flow #s in....how are they?
  157. my car does have a 16 gallon tank right?
  158. QUICK Help Please, Removing Oil Cooler?
  159. Need help, passing emissions!!!
  160. Avoid Canton Race Products At All Costs!!!!
  161. Should you use the stock gap on a worked engine?
  162. Side mounting plug wires with AS&M Headers
  163. help on choosing a fuel pressure regulator
  164. A/C Removal
  165. front control arm bushing?
  166. G-tech Competition
  167. 4 qts. of oil for 6spd...correct?
  168. Black rubber strip that runs along bottom edge of window..
  169. Temp guage stopped working?
  170. Rear end whining?
  171. Reasons for dropping oil pressure?
  172. Oil Pump Replacment?
  173. Just installed Opti ... now car is screwed up - help!
  174. cooling problem 94
  175. could I replace my catalytic with a small muffler? and some exhaust Q's...
  176. Steps In Converting a Series 2 Carrier into a Series 3
  177. Mail order or tunercat?
  178. what is wrong ??
  179. Should I get an LT4 Knock Module
  180. Anybody running LT headers with a stock exhaust/cut-out
  181. 3.42, 3.73 or 4.10?
  182. Loctite On Spark Plugs?
  183. Need T-56 3-4 Synchro asap. Who sells them?
  184. going from 2.73's
  185. stupid question probably
  186. What kind of o2 extension?
  187. How many teeth on my flexplate?
  188. Another thumbs up for Lloyd
  189. Remove traction control?
  190. how many Gs can a stock LT1 pull, 0-60mph?
  191. MSD 8.5mm wires.......are they an OVC setup or not?
  192. SLP headers
  193. What size injector for this set up.
  194. Want some engine building tips. Prolly not your regular cam, etc questions
  195. a little plastic ring behind the waterpump. do i really need it??
  196. 12 Bolt Questions
  197. Stumped
  198. 96 Automatic - CAN I PUT IN 3.73 GEARS?
  199. People with Tubular A-arms...???
  200. Basic automotive knowledge lacking. Please help
  201. Fun Problems Shoebox Help Me Please
  202. Guys with milled heads, problem with head locator dowels?
  203. Where can I find a suspension package?
  204. Average Price To Pay For Gear Install?
  205. How do I do a Proper Pre-oil before initial Startup?
  206. Seat belt light?
  207. O2 simulators
  208. The guy who widens the rims!
  209. air bag + security light questions...NEEd HELP!!
  210. Resurfacing stock flywheel - quick question
  211. Stock heads and BIG lift inside (GM847 cam)
  212. Courtesey door chime
  213. hooker long tubes
  214. Afr Heads
  215. street twin????
  216. Best hooking tire for 17X8 rim?
  217. cheap mods
  218. fuel injector clips
  219. What are the cylinder #'s on the optispark?
  220. guys who had problems with the icm overheating-come inside
  221. Question on future exhaust setup.
  222. Embarassing Ques: how to install 160 stat? :)
  223. I can't decide
  224. ABS INOP, Low Trac, ASR, and Brake?!?!?!?!
  225. What HP level are the stock injectors good for?
  226. Which fuel pump????
  227. Had new muffler put on...
  228. Name this hose!!
  229. Doing a Torque Converter, Stall Speed
  230. I am back with a formula
  231. Strength of stock parts?
  232. Anyone considering buying the LTCC in the near future, inside please!
  233. GMPP roller rockers
  234. Need help completing shopping list!!!
  235. Anyone have a list of parts/part numbers that recently did a HEADS/CAM swap?
  236. Still have a stupid oil leak...
  237. is there such a thing?
  238. Flowmaster muffler results...
  239. checked fuel pressure at rail and got 34 lbs with vacum line attached good or bad?
  240. o rings on end of opti shaft broke off, does this matter
  241. Dyno Tune
  242. the difference between wet and dry sump oiling?
  243. Disc to DRUM!? Crazy? Anyone done it? Heres my reasoning!
  244. Help! Anyone who owns or has heard an SLP 2OTL
  245. rubber deterioration in intake elbow
  246. Any body Rip out the washer tank for air flow?
  247. Ceramic Coating the intake?
  248. missing at down low rpms!!!!!
  249. Anyone know where I can find a "How To" on intake gasket change?
  250. 52mm TB and MAF ends?
