- Swapping to LS1 brakes, how to remove steering knuckle?
- Increased shift firmness bad or good?
- **HELP** Opti just went out - car screwed up, need price list for parts!
- Can I remove these?
- is there a way to check for messed up lifters?
- porting MAF?
- Do the front calipers slide on the guide pins?
- lights on in interior wont go off
- 1993 Corvette LT-1 Help!
- Seperating the tranny from the motor questions
- Dex-cool or not ?
- Interesting find when changing rear end oil
- Ignition question?
- whats louder, lt1 or ls1?
- is it a big deal using tap water compared to distilled in the radiator??
- Where did you guys mount your tranny cooler?
- How many MAFs have you blown up???
- is it time to replace my clutch
- Don tlike how the cars fron lifts up when you punch it!
- 94 1LE LT1??
- Rims?
- how to store a motor???
- huge..huge.. dilemma
- 396c.i. LT4 parts list update
- New Z28 owner..have few questions
- ran out of gas now..
- Help...Banging noise coming from rear of car
- Stumbling?
- Left turn signal does not blink????
- How long does it take to find out you have a head gasket leak?
- suspension
- POLL: LT1 - C5 Brake Conversion ...
- Ignition woes
- Bad wires? or ?????????
- true duals quieter than cutout?!?
- If you have installed headers help me.
- Installed Hooker Cat Back
- Pic's of my new headers.
- Do you have to get the cpu programmed when doing lt's??
- Clutch Chatter driving me crazy. help
- If you have done a headswap in car, question for you!
- Whats wrong with my suspension/rear end
- What's the homepage for the company that makes "Strange Gears"?
- somebody please, why is my car still missing
- Hooker or Jet Hot Lt's??
- Taller Tires on the Back?
- Magnaflow exhaust pics
- What gaskets are needed to do cam install?
- I know it's been asked, but what parts do I need for a TB bypass on a 97?
- 95 vented opti drawing alot of moisture?
- coating on RK Sport headers
- For those of you with the CC306
- How much pressure should gauge read at fuel rail?
- Headers aint worth a "darn" (edited by moderator)
- New opti seal with new opti?
- aerochamber vs. 80 series
- Lower control arm bolt sizes, quick question.
- Single plane intake for LT1...
- Getting rid of traction control....
- Anyone with PA tubular A-Arms...
- Is my alternator done???
- Wiper arm removal...help!
- What do you think i will run?
- Dip Stick Leaking, How to fix? Please!
- seat belt light.....
- long tubes?
- 95 lt1 in a c1500 pickup
- White plugs.... possible causes?
- Which stall?
- anybody with the gm 847 cam ported heads and stock bottom end with auto inside please
- how do you put fuel pump back into tank
- Can't get crank pulley/hub off, what am I doing wrong?
- Will any Pontiac Key FOB work?
- out of balance rims
- Looking for good brake pads
- @!#*)@ lower a-arm bolt won't come off, need help
- How do you clean the MAF?
- Order of intake bolts
- Has anyone bought an engine from Golen's?
- LT1 "interchanging" with a 400 small block
- non vented opti question
- Sound proofing undercoating. Anyone try it?
- lights flicker??? help
- Removing T56
- ABS INOP light and charging issues
- Need advice on buying a used engine....
- Exhaust leak..Please HELP!!
- Will a 4L60E from a 94 bolt right up to my..
- wiper arms
- Do gears help 1/4mile times?
- Should I run an aftermarket coil with my ignition box and N20?
- rebuild kit for t56
- 1 5/8 or 1 3/4 primaries
- Mufflex Y-pipe?? Yes? No?
- The truth about the motor.
- V6 Springs???
- 1&2 synchro
- will a 98+ hatch fit a 93-7 t/a?
- well can you imagine that.............stumbling/hesitation FIXED!
- cam package... gp... good idea???
- Head Lights
- Adapter to hook tubing together for gauges?
- Valve lift question?
- Turn on the radiator fans using a switch on an OBD1 car while the car is not on?
- Name that wiring connector!
- PPL with a forged 355 inside pls...
- secondary air injection system malfunction
- Need part numbers for ARP driveline bolts
- low oil presure
- Replacing the WP driveshaft?
- Gas Milage
- any of the vendors make a guage pod where your cassete tapes would go
- Tailshaft bushing T56, need help ASAP
- cheapest place to get a scanmaster for my 96??
- How many miles per tank are you getting on your 95-96 Lt1
- What to do with $1,000???
- Help clutch promblems !!!!!!
- Need A Tune Up, Bang/Buck Best etc...?
- auto to a 5 speed swap
- Can a 4L60E harness be spliced / soldered to work with a T56?
- help!!! Whats wrong????
- Roller Rockers
- I think my 4L60E is taking a dump...any ideas?
- whats a good price for mac install?
- People with CC 218/224
- Reprogramming the computer
- Anyone with underdrive pulleys on LT1
- AC refill
- Question on LT1 edit
- O.E. Concepts replica wheels?
- need scatter shield for 6spd lt1
- What Heads go best with a CC305 cam????
- Wiring in a Qtec?
- engine swap tips
- Drag Launch kit and poly bushing ?s
- Squeeky brakes
- Head Games
- Where to purchase TCI stall?
- Hesitation gone: replaced fuel pump
- Automatic Tranny Problems, changed fluid and now it slips!
- Who has had this problem??????
- Mixing [distilled] water with coolant
- changing oil pump with motor in car
- Those of you with Lou's short stick...
- Hooker longtubes over the hooker shorties i have now??
- what should my times be
- Balance the 383? external or internal?
- Exhaust Suggestions please
- Steel or Chromoly LCAs?
- Cam for me?
- CC 306 Cam with Stock Heads?
- Help me turn off this warning light!!
- Tires...what do u have?
- Exhaust Cutout
- WTB v6 coil springs?
- Is this stroker kit good??
- Who's builds STRONG 4L60E's for cheap?
- War story of my own
- Paging Brent94Z
- lt1 edit work w/ Mac?
- Please help Finished LT install today noticed MAJOR problem
- Turbo in the rear of car??? WTF???
- over heating problem
- Review: MSD Wires/Looms
- Electrical Issue
- Sealant on Head Gasket?
- Anyone make 10mm x 3/8'studs to use LT4 RR on a sbc?
- Quiet Exhaust
- What will I run!!!!!!!!!
- if you have SLP headers..
- scanmaster on a 96, will it work??
- Tailshaft bushing on T56, need help ASAP
- What should my O2 readins look like?
- Anyone using this HUD unit
- New Tranny Mount
- Ok I am looking for a new motor, where and how much?
- low fluid in clutch resivor
- FLP Long Tubes
- security light will not go off
- Arizona Auto Masters?
- whirling and hesistation
- Will a 700R4 that was in a 77 350 truck fit up to my LT1.
- Timing Chain Parts
- Turning Rotors ?
- air dam with ground effects
- Clutch is talking
- Secutiry Light won't go out
- installing edelbrock TES headers, which sparkplug wires to get?
- oil pressure gauge
- Rattling coming from Rear Passenger Shock.
- The little shaft that drives the opti...
- Exhaust tick
- are Torco torque converters and these others OK?
- Running stock exhaust on a Stroker/Blown Camaro. Bad Idea?
- which cam
- What would cause my car to never go above 6375 rpm?
- Going to be pulling heads, any tips, tricks, or ideas?
- where to get o2 sensors??
- 96-96 hpp III
- need a/c help
- First post
- Do you have to remove the dipstick on a longtube install?
- Anybody with jet hot lt's have the mufflex y-pipe?
- Good deal on a stall?
- What exactly are "Claimer" Rings, and should I use them?
- part number
- For the most part I think I fixed one oil leak, now anoter is just pouring!
- Engine Assembly
- Video Of My Hooker Catback and race w/cobra
- Will 18's make me slower?
- 1995 TA i blew the motor i am replacing it with a 1994 motor what to do with opti
- AC delete fan belt
- Oil pressure low and tranny problems along with SES light...are they all related???
- Ac Compressor
- SLP Differential cover
- Uh oh! Oil!
- Motor Mount ?
- Dynatech Questions
- Problem with Cloyes True Roller for 94 Z
- looking for links
- Maybe getting a LT4 intake and Hotcam
- Bolt Pattern on Camaro?
- How to test O2 sensor
- Will these rims and tires fit???
- Mezierre WP failed
- Heat transfer greese/dielectric greese
- Shifter moves freely from P to 1st
- LT's, exhaust, and lowering
- throttle body bypass now not starting?? Help!!
- Clutch Swap: Pilot bushing or bearing?
- If I want to use a Double Roller do I need an Elec. WP???
- tire rubbing problem!
- Radiator Question
- Cam Swap.... DONE!
- Problems to look for when buying a used LT1?
- factory alarm question........help
- Zo6 or C5 rims?
- most comprehensive spark plug guide?
- can a bad tranny cause knock?
- Few Header Install Questions
- Need Help: Car loses power after 4k rpm
- 5 speed Z28 convertible?
- How do you like your poly motor/tranny mounts?
- What shocks?
- fuel rail leaking
- any thoughts on what this knocking may be???
- Questions???????
- calling all CC306 owners
- was anyone in wildwood nj for the may car show?
- Would this shift light work?
