- installing 160 stat
- cant decide
- The waterpump debate, electric or stock.....
- Abs Inop????
- Transmission Help Please Help Me
- tranny problems - HELP!!!!!!
- where else to mount gauges on a 93-97 camaro !?
- 3.73 shift points
- Stock weight of 97 T/A
- mccleoud twin clutch info needed
- Bocsh O2 extension ?
- is it safe to take this part off?
- Flowmaster Muffler Question
- Why do you 1.6 rockers keep coming loose?
- Those with tunercat, what 2 files do I need?
- What to do w/ EGR/AIR/sensors w/ Hooker LT's?
- Help oildipstick
- Winshied Fluid Nozzle/Window Motor Problems
- Goin to the track for the first time tonight
- How does spark plug gap effect temperatur of the plug? AFR Heads
- where is the brake booster?
- Sensor on back of intake manifold??
- resevoir question
- New Maf???
- Heaglight motor wont turn off
- Hatch speakers ... how are they wired up??
- One wheel peel???
- new cam =blowen motor
- Brakes Dragging until brake petal hits floor
- Extreme Duty Timing Set Crucial?
- Help Identify these valve springs
- Brakes after CC305
- Speedo Recalibration
- Have a lifter tick, what to do??
- HELP before I burn my car to the ground. (Long)
- Hooker LTs and duals done
- Will MAC headers fit stock I-Pipe?
- Show me your engine bay with !AC !EGR etc..
- Free Mods For Lt1
- LT1 ignition probs
- Videos of the 383 at Idle and Revving...
- Removing A/C unit near firewall......
- free mods QUESTION?
- engine light
- Any places sell a Complete top end kit??
- buying first mod
- s
- Got my flow numbers from Lloyd
- Super Quick Question!!!
- I have tried everything and Nothing Works!! Help with a 93.
- Best suspension upgrade for street use?
- 10 bolt longevity
- Alright, so what kind of engine coolant do you use?
- SLP Loudmouth vs. Hooker Catback
- 94 LT1 fuel injectors into a 93 ??
- Thank God For Superior Automotive In Anaheim Ca.
- will the cc306 work 4 me
- Where to put cut-out?
- what gears for a head & cam daily driver?
- Summer Time is here and Need to keep engine cooler!
- Here's a thinker for you (re: rearend)
- electrical problem somewhere??
- Price of rockers that come with the LT4 hotcam kit?
- Can tranny make speedo go wacky?!?!?
- Can I use Comp BBC 1.7 ratio rockers...
- Replaced Opti and Water Pump... What a difference indeed.
- What ignition Crane/MSD
- Pushrod guide plates, are they created equal? Pushrods too...
- Is anyone running BF GOODRICH COM F-FORCE TA KDWS TIRES What do you think of them???
- Help with install of LCA's and panhard bar.
- Look good to you?
- NEED HELP:will these 4.10 gears fit??
- Torque Converter ??
- cheapest place to buy LTs.
- LOUD noise comming from engine.
- Explain F-body check digit to me (VIN)
- Wiring
- GOD hates my car!
- HP mods that do not affect gas milage and are CHEAP
- How bad do gears affect gas mileage????
- Moser 12 bolt Yoke question, what series u-joint for standard yoke??
- My Z Tuned for Hot Cam but not Heads... What should I expect?
- What suspension components do I need?
- transmission problem???
- Trouble Installing 410 Pinion
- Valve float and dyno sheet...
- Does a big block hood serve as cowl hood also?
- Different Plugs affecting gas milage?????
- Need Help....
- LT1 Rebuild questions?
- stock cat or high flow... NEED OPINIONS
- Longtube Question???
- The smartest thing to do when the engine is out??
- Anyone know proper procedures for flushing LT1 coolant
- Injectors
- another tc question
- hotcam and RR ratio
- After timing cover seal replacement, distributor drive shaft seal leaks oil. Help!
- 224/236 cam head porting
- Tired of ****ed up wires
- engine assembly tools
- 3.73 gears are the way to go you say?
- Help me out....sway bar install
- Beehive springs on LT1 heads
- air/fuel gauge
- Tranny Problems
- fuse question please help
- MSD Digital 6+ plug for coil????
- Intake porting really required?
- Anyway of determining which version EGR valve my car has?
- Max tire size '95 z28?
- Air Bag light will not go out!
- Major Problem Need Help (is it a mis??)
- Just got a catback.... is a cutout worth while?
- Optispark ?
- Mustang guy inquiring about a WS6....
- How accurate is it to tune off an EGT?
- Guys Who Have Installed MACS - A few tips for me
- meziere water pump
- 3.42 or 3.73 on 383 stroker
- changed differential fluid...problem is still here.
- How about this for exhaust flow?
- SPEC phone#? Does the stage 3 come with pilot bushing?
- wipers won't work sometimes
- OBD-2 progam help please
- doesn't start - no spark
- Car runs like crap after rebuild/hotcam/headers/catback...
- What to check for when buying LT1 car?
- New style turbo kit
- starting problem
- taking out headlight motor
- Need advice on car towing...
- did opti plugs and wires still stutters and surges?
- brake pads
- Throttle body bypass???
- How do you get the little black clips on the brake lines off?
- Reliability of the opti when paired with an MSD box such as the 6AL or Digital 6
- Bolt For A.I.R?
- need help fast, miss or hesitation? bad o2's? how to tell?
- God hates my car too!
- Help! car wont idle
- Unhooked AIR for LT's, fans won't shut off
- What Do You Guys Think About This Tool???
- Cam and heads pro install question?
- Rattle
- gains between long and short tube headers??
- LT1 hotter when AC is on...
- popping sound in the back
- Tailpipes POP and fire is actually coming out!!??
- 383, Stock Radiator, Street Driving
- help kertong identify this mystery part
- Need contact info for Dal or Jason
- Botched up threads about misfiring…[logistical rant]
- FINALLY Fixed Front Cover Leak!!!
- Torque Converter Vigilante or Yank
- 9.60 @ 141.52 @ Bowling Green video is up!!!
- What did I ruin? Starter ran 4 minutes straight!!!
- quick opti question
- Water Pump Seal or Cam Seal???
- Got a ?
- Hello all :)
- 986 springs on LT-4 heads / standing height?
- Why am I running lean after 2800-3k?
- New Eaton posi and 3.42 in today but..
- Comp cams 987 Springs?
- Anyone with a Spintech Muffler?
- jimmy 1995 lt1 engine no idle
- best plug wires for LTs
- Knock Sensor Troubleshooting
- part # question...
- Airbag removal?
- vibration in 1st and 6th??
- how easy to jack up motor for LT install???
- Anything to look for when buying Lt1?
- squeaking noise at wheels and it's not Brakes
- Just a few Loudmouth questions...
- Headers Install Question
- 4L60e and some tunercat
- Lifter explosion??
- Hello All, brand new and have a few questions
- Why do a TB bypass?
- Driveshaft and Rearend ???'s
- Replacement Catalytic
- External trans cooler, through the radiator first?
- New "How-to" page for LT1s
- Valve cover breather install...
- Stuck left turn signal
- Buying used cam?
- How do MAC mufflers flow compared to...
- Problem??? (adjustijg 1.6rr)
- SLP Cold Air
- Tips on installing a Hooker exhaust???
- Hook up Freescan?
- How do I make a front clip?
- Pictures of installed SLP CAI
- oil leak HELP!
- after opti change
- Any table to help diagnose my car?
- dyno tuning
- What do i do with the master/slave cylinder when dropping the t56?
- Need some gear advice and info needed.
- Need help fast, pilot bearings which way in?
- looking to step up from 306
- Something Strange
- Hooker Cat Back installed
- Easy question----do LT1's and LS1's have 4 bolt main caps?
- difference between lt1 ss and z28??
- MADZ28.com
- Anyone in NYC area w/ LT1 Edit???
- Com. Motorsports Email?
- how hot do headers really get?!??!
- roller rocker ?
- how to change pass side o2?
- Best Clutch/short throw shifter
- need help, those who downloaded parts book
- middle hose coming out of charcoal canister?
- Whining new fuel pump? like as loud as some superchargers
- broke into 13's last night
- Need brake help ASAP
- Automatic or Manual?
- Reliability... (both lightly modded/heavily modded)
- CSI waterpump
- gear brands question...
- Knock Sensor problems
- Dang...pissed...
- Maintence on an LT1, everyone inside?
- What is the difference between a throttle body for a '93 as a '97?
- Mechanix Gloves review!
- Best place to buy the LT4 knock module????
- Info on removal of Emissions systems....
- lt 1 randonly overheating
- 3000 Rpms @ 65mph w/ cutout n cai
- rear gears stock sizew
- I can't believe my eyes!!
- how to tell if you have an exhaust leak?
- my car died at the track!!! help please!!
- MAF ends vs. granatelli MAF???
- CC305 Dyno Numbers
- Where to get stock replacement fog light for 1994 Camaro?k
- What roller rockers w/lt4 hotcam
- THATS IT! ive had it........someone come blow up my car
- Any problems with D&D's customer service?
- where to buy an LT1 Rebuild kit ONLINE?
- Ported heads
- Intake and stock TB question
- water plugs
- How hard is a gear install...
- Clunking when I shift into first when not moving?
- Feeling vibration in throttle
