- 4 Tires to Choose From
- Someone dinged me, ideas for fix?
- which plug is better ngk tr6s or autolite 103s
- Anyone Run dynatech 1 3/4 step to 1 7/8 headers
- horsepower diffrences between mustang and dynojet dynos
- Those with LT4 Hot Cam and auto tranny, how's your idle?
- what the ****, now the car wont idle in closed loop
- what should i run
- Electrical ? - Courtesy door light for window controls
- Pilot Bearing
- Clunking on downshift?
- Lacking Power
- Possible on/off switch for pass air bag?
- where is the ignition coil on this car
- went to dyno today...
- Many Problems Need some insight Please
- Check out my Datamaster File....
- 3 Angle Valve Job...any HP gains?
- what suspension mod for rough ride.??
- indiglo gauges power supply?
- Driveshaft question
- where to get strut mounts,fast?
- Trey - Got a question for you from about a month back
- where 2 buying headers monday
- Went in 1st instead of 3rd!
- Seriously aggitated
- Dyno people: Get in here!!!
- How do I get my hooker 1 3/4 long tube headers in easily
- EST 1/4 mile times?
- Best set of wires for OVC
- Thanx
- brake light
- Shocks...what kind?
- what could cause code 154?
- Passenger side LT from the top?
- tranny, clutch? I dunno
- Electrical problems when raining
- 94 F Body Suspension Setup
- Cat converter 93Z quick question
- Where can i get an overdrive Alt. pulley?
- Best price on LT4 conversion , source?
- 96 formula running bad
- tci 2800 stall
- Diagnostic Plug on Swaped Datsun 280z
- Water Pump Replacement Guide
- Line Lock problem
- y coated headers
- Battery relocation questions
- fuel injectors?
- SPEC e-mail or web address?
- Hypter tech, Worth it?
- Cheapest place for nitrous bottle?
- Another Exhaust Question
- Wht The ****!!!!!!!!!!!!!!!!!!!!!! Opti And Ignition Module?
- I need a new battery...... What one?
- headers were glowing red last night
- Couple Power questions
- Differences between a DynoJet and a Mustang dyno?
- Do strokers REALLY run quicker?
- installing air/fuel gauge
- how much freon and oil to put in my car?
- Need help with codes I have.
- Anyone want to look at my autotap file?
- Need Help Installing An In-Line Fuel Pump
- '96 SS pcm different???
- So, I go to the track friday night....
- guys with TCI Vacum modulator(OBD1)
- My Hotcam Kit........
- What Switches Do I Need??
- new gauge cluster?
- Autotap advise please...
- Fuel Pump?
- E-Mail Address for DAL
- HELP suger in the gas tank
- SLP "Ultra-Flo" exhaust manifolds
- remote start ses light
- Breaking in an Engine
- i need to know where i might find some afr heads for a LT1??
- how bad is it to run a car on 7 ?
- Is this my shift fork causing this?
- Hooker Cat Back HP gains??????
- wheel hop..
- 13.74 in a bone stock 95 Formula!
- I've been reading Trans-Go kits are bad???
- Parts need for header install?
- Leak in the A/C, any ideas?
- Best tires for <100/each
- Everybody with aftermarker or replacement CATS!
- car is running lean I feel.
- removed coolant restrictor valve thing on heater hose
- I need a new starter
- Antoher New Best Today
- coolant problems
- What applications require pushrod guideplates?
- Got the car dyno'd yesterday
- needles on gauge cluster?
- how can you tell if there's water in the oil?
- First lt4 mod
- getting service engine light(code information inside)
- Auto Trans issues. Whats the problem?
- Do Fluidamper's come w/ hub also???
- Installing motor from top with inake on???
- Air/Fuel Ratio
- Is my 4000 stall too big or too small
- is this just a waste
- Faulty Camshaft?
- Need part # for stock LT1 timing chain
- Will a 15x6 draglite XP fit the front of my Z ?
- Flashing SES?
- Thermostat ?
- Bangs rattles squeeks.. argh!
- Raising RPMs
- 396 guys inside
- With my mods, how much hp should I see from these heads?
- Moser, brake fitment ???
- Air/Fuel Ratio
- Radiator Hose connected to the throttle bottle
- 355 numbers
- lca's?
- SLP vs MAC headers
- It died and Im getting 20 psi of fuel!
- Optispark Disassembly, need serious advice
- Inline fuel booster pump question
- Fired up my new 383, now it has a weird clutch problem
- How much does it cost to fix driver side power window
- Mickey Thompson Et streets
- Bad fuel pressure regulator?
- 1.6 RR guys , more oil in the TB?
- LS1 Brake Question
- Thump! under shifter
- Valvetrain Noise and Adjusting 1.6 RR's
- T56 guys.... How easy is it to accidentally tap it into R instead of 5th??
- Quick... Hooker will directly bolt up...
- Connector on back of manifold broke???What is it??
- will this plug wire fitting fit my LT1??
- LT4 Hot Cam prices?
- what is the temp when the fans turn on?
- Lt1- 5.7l,mfi,ho
- What to do with starter wires in LT install
- power window conversion
- LT1 383 crate in summit!
- I think I blew a head gasket; did not retorquing my ARP head bolts cause it?
- Pretty damn severe high rpm miss, feels like the rev limiter but isn't...
- Every Hear Of South Side Machine Sup Kit ?????
- Dyno numbers on my almost stock 97 A4, these good?
- Cam install question
- can i use a .....
- Question about SS hood??
- Comp. Eng. Shocks
- Mr. Shoebox = Mr. Master of Part Location... question!
- Does anybody make these wires??
- Mechanic Baffled!!??!?!?1
- Subframe Connectors
- LT1 into 93 Jeep wrangler
- hans feustel contact info?
- Getting rid of AIR .......completely
- Will I need a Y-pipe?
- Stainless Steel Brake Line Install?
- Running temp\bleeding the system??
- LTCC set up
- 9 hrs. work STILL CAN"T GET THE TRANNY OUT!!!! PLEASE HELP
- Gas tank possibly sugared, what to do?
- I'm So Excitied!
- Best Place to buy a Yank or Vigalante converter
- Electric water pump, I have a question.
- Fuel line Question
- Part # for Fuel Pump?
- Electric WP not running for 5min....damage?
- Speakers
- Which FREE mods are worthwhile ?
- steering noises and more, please help
- Could a hole in the muffler ruin dyno and 1/4 mile times?
- Question Concerning The Water Pump Seal???
- I don't speak obd-II,can you translate
- Went to the track, kinda happy
- Seatbelt light will not go off!!!!
- Hydrolocked Motor - Do I have a leg to stand on?
- 94-95 intake manifold different from 96-97?
- Steering wheel volume/cd lights don't work
- Platinum plugs with MSD?
- EGR intake question
- Where can I find ceramic coated 1-5/8 Hooker LTs?
- New tranny and same problem...help!
- **Transmission parts on floor, not in car**
- Anybody willing to help me do a transmission/engine install in Dallas, TX?
- mod's
- Is this a Lifter Tick? *Video Clip available*
- FLP headers any good
- Confused about this cam
- Header install questions
- Over camming?
- RK Sport FX5 adjustable shocks any good?
- mac headers
- Blinker Won't Blink?
- Anything else?
- She's missing!!!!
- Header question?
- 96 LT4 Corvette M6
- how to replace coolant sensor
- installed rear, now i have a clunk only under certain cinditions, help
- Camaro>>Corvette accessory swap
- Car has a weird wheel hop?
- VERY! wierd prob, smoke from underhood and no start (long)
- Paging Any Convertable Owners With Sub Fram Connectors Installed
- Power window motor
- help with electrical
- Replaced Cap and Rotor No Help
- I think my valaetrain is timebomb!
- what years are the best lt1s ta buy used...
- what gas?
- Will this setup fit?
- johnson rods are breaking, should i use the black mambas???
- Are there any bad gas stations?
- Question about OVC Kit: Crimping Tool?
- clutch\transmission problems
- Still dont get it...
- Missing? Rough Idle...
- Help me choose the right plug wires
- AS&M headers
- Evap system removal
- o2 sensor issues.. HELP!
- New top end question
- how does aftermarket shifter install w/ reverse lockout?
- Comp Cam XE 224/230 on stock heads!
- Transmission
- need auto transport
- where is the rear o2 sensor on a 97 z/28 drivers side?
- Stock LT4 flow numbers?
- LS1 Intermediate pipe
- Didn't put gm differential additive am i in trouble?
- Header Time Check List
- making the passenger window auto
- what do you guys think about the Power Stop Rotors?
- Flow #'s
- I know its been covered but 306 or 230/236?
- How to clean EGR, and will it last?
- 1.6rr, oil cooler and gears=13's
- exhaust question
- Dropping the motor out the bottom....
- Stupid tranny mount install question.
- Anyone want to help with Clutch install
- !egr ?
- Having trouble with reverse lockout...
- LT1 burning oil?
- running the car without a battery?
- Are LCAs worth it?
- Exhaust size?
- How can I determine if my MAF is bad or not...
- slp Torque Converter
- Help i think my trans just went
