- Posi question??
- Think I missed a gear on spray, how can I check for any damage?
- How to keep my motor/tranny alive for a loooong time?
- Where to find GOOD TA seats?
- How many did the vent mod on their 93/94 style opti?
- quick cai question
- Tuning
- Hawk Racing Cranks
- my POS is driving me insane! pt.2
- Stroker guys. Please post your timing tables.
- Leak between the...
- Something is not right with this picture??? Shoebox??
- Does the Taylor OVC wire set from thunder come with.....?
- Are NGK tr55 G-Power plugs any good
- symptoms of a loose MAP?
- Will I see any gains going to AS&M from BBK
- Help!!! Big Piece Broken Off In Engine!!
- oil leak????
- What else is done to A4 to shift harder
- McCleod clutch issues......
- Must... lure.... shoebox....
- Too late for heavier Mods ????
- 15X8 wheels
- where to get a CSI or meziere WP??
- OBD 2 in a 95 Z?
- MAC or HOOKER
- RS Style Ground Effects.
- A/C delete Vac lines question
- First mods
- Which mod
- Tech question about VATS
- Push rod
- Clutch Questions
- Engine turns over but will not start
- URGET...should I get heads or heaers?
- no oil pressure
- head experts, need help
- Whats the price Jason Kromer sells the optis for ? I need help fast
- Cutouts?
- Fuel Filter/Opti?? Need Help!!
- stutter on take off...???
- Anyone use conventional oil in their high mileage lt1?
- Will I be able to use S/A rockers with Crane 10308 springs?
- anyone who has fabricated a CAI...come in
- lt1 head gasket
- Aftermarket Mass Airflow Sensor
- New Rear ?'s
- Is the HPPIII worth $250.
- weird problem when the z warms up...
- Did anyone port there stock heads?
- gear Change
- vented vs not
- I wanna take out my ac stuff, any advise??
- New fuel pump causes tons of new problems
- Which 1 of the TC do you suggest?
- GM parts direct part no. please
- Hooker LT's on a Single Cat - I need a Y Pipe
- Can't pull error codes from connection under dash!!
- Anyone running LT headers that have lowered their car?
- What is this Part?
- GOt some heads flowed, what do you think?
- Anybody have a spark plug that leaks and keeps coming loose after you tighten it???
- adjusting brakes after rotor/pad replacement
- Paging Shoebox(Trans Pan question)
- RAM heavy-duty clutch/PP, Part#88516
- Rebuilding a T56...I need help!!!!
- Re-upholstering seats.....
- vented opti
- slp manual fan switch
- lt4 knock module
- Gauges
- Best cam for carbed LT1
- Car Wont Start!
- a4 w/ Cutout and CAI Times/dyno results
- Dual cat SLP headers vs single cat SLP headers?
- help, can somebody explain the PCV system to me?
- CC 306 Running real rich....
- Put on my hooker...
- using alcohol to clean injectors!!
- When I hit the brake gauges go wacko
- Eibach Drag Launch kit and now my rear is twisted.
- 2800 Stall
- Hooker LTs
- Strange Electrical Problem...please help!!
- Can you remove the Intake Silencer?
- Injectors
- Never Assume!! & Always go to basics!!
- Problem Code # 101
- Valve Lash Problem See Inside PLEASE!
- True Dual X-pipe question
- Is anyone using the Edelbrock torque arm?
- LT1 edit question
- Dyno result -
- doing opti plugs and wires this weekend anything else?
- billet short stick noise solution
- rim size confusion
- Costs of DYNOS
- What should i do with my lt1.... heads and cam?
- New Pro-Magnum rockers sound like a sewing machine?
- SES light, egr valve question
- Vortech elbow and air foil really smoothed out my engine
- OK, got allottttta questions... please oblige me the best you can..
- Pushrod Lengh Question
- Impala Head Gasket Question.
- i need tires!!what should i get??
- Wheel Bearings Accessible?
- need to know differences between 94 rear and 97 rear
- Would low voltage alternator cause low fuel pressure?
- emissions/headers question
- Roller Rockers and .600+ Lift?
- reluctor ring/gear install question
- What's wrong with my car? Is my torque converter broken and hurting my power?
- how to get speedo to work with th350???
- I already tried this on the Nitrous forum, anyone?
- Help!! Car refuses to pass emissions
- Idiots guide to belt and spark plugs
- LT1's problems
- Mobil 1 ATF
- Any difference between 98' LS1 and 99' up LS1's
- Last minute prep for the track, help me out please!
- Does it mater where the sprockets are?
- O2 Sensor
- LT4 KM Ques.
- calling everyone with CRANE HI6-STR and TRC2 box
- is there a way to verify a lifter is ticking?
- Can you Rebuilt a water pump?
- A.I.R. Recall, WTF
- pro comp r lifters
- pcv was unplugged
- 99ss shifter
- whats the lowest price on 18" tires
- Macs to Stock manifold swap
- oil pressure?
- Heed help :) How to recognize is 1.6RR are to tight?
- fuel pump access door install in a conv??
- Granatelli torque arm a good idea?
- Mac exhaust tick tick tick???
- Slick 50 and other oil additives ?
- High beams in low beam place
- Jordon or anyone; part # for K-D LT1 hub installer
- Rear End ?????
- quick fuse question...
- THUMP THUMP THUMP under HARD accel..
- 02 bung/ oil pan leak
- Thread sealent for Head Bolts?
- If this is the oil pressure sending unit, then what is this?
- Rear brake shim install?
- Piston Rings?
- lower front control am install?help
- Fuel Injectors arent firing
- Knocking sounds in my back end Help!!
- wheel hop?
- How Hard Is It To Replace Starter Motor????
- Doh!
- Dead battery and Security light
- 93 M6 Hypertech Chip Owners Inside
- Engine Missing
- What Do LT1,LS1 & LT4 Heads Flow??
- engine dress up
- Header decision - what do you guys think?
- Back from the strip w/ new headers
- How much does it cost to port & polish stock LT1 heads?
- Running Rich pics..
- Freescan & Schrader Valve Size
- Taylor Opti-Spark end terminal kit?
- ****! What is wrong with this damn car? Starting problems....
- Under the Hood?
- Newbie to LT1s...
- A question about Nittos..
- Help with dyno graph.....
- Which fuse is this?? (Picture)
- need a balencer!!!! this any good
- Stumped!
- Redline Line Water Wetter?
- Hey Injuneer inside please!
- car died outta nowhere, getting no spark
- HELP PLEASE!!! Those with street twin clutch!!
- Auto Tapping results!
- Software for Laptops for Diag,Info
- Need immediate assistance...
- Shift Skip?
- Cam with stock converter and 2.73s
- Went to the 1/8 th last night
- Anybody Ever Noticed This
- What is this part
- bad crankshaft position sensor (?)
- intake manifold passages
- Anybody know this about gears, good info
- what would cause this?
- Heads? Where to get, what kind
- True Dual Setup???
- can i still save my opti??
- What Size Injectors?
- Dyno sheet for stock LT1?
- Best gaskets for slp dual cat headers
- New #s!
- Parts needed for replacing lifters??
- What 7/16 Studs are the way to go?
- DIY LCAs?
- Dynatech vs. Hooker Longtubes
- How to get stock exaust off?
- New user, and Firehawk owner
- Cant get ABS line off for line lock
- those with offroad pipe plese enter :)
- installing cat back exhaust
- How to fix lifter tick??!!
- need to know... Coil and the module.
- minus muffler
- Anyone have exhaust sound clips ?
- LT1 block casting numbers?
- Oil Filter question
- AIR Pump & cold-start stumble
- Raising Rev Limiter
- My A.R.E. installed 3:73s are getting louder
- Car is taking longer to start or almost didn't.
- how to align windows ?
- Anyone have a EST (electronic spark timing) control mod...
- Massive Surging!!!!
- front end wiggles at low speed
- tranny
- Poping out of reverse T-56
- code p1133
- weak 4th gear in 4L60E
- What weight of oil will serve me well?
- Bolt for oil dipstick tube.
- How do I bleed the brakes?
- Anyone know what's goin on?
- How do I.......
- Gears finally going in....
- Why is there a weap hole on our waterpumps?
- Difference in HP between stock plugs and 2 heat range lower plugs..
- Urgent my new motor won't fire up
- Pro Kit versus WS6 springs
- 1997 Z with 5L?????
- Question about coolant fans...
- LT1 TPS Wiring?
- Help, mating engine to bellhousing
- rear defroster
- Does yours ses light come on when the pcm picks up 11 degrees of knock?
- Thinking about getting a cam, need help!!
- I got it going! no SES then the tranny started slipping and SES
- could someone take a look at the times I'm running
- Bleed all wheels after line lock install?
- IS this a WATER PUMP PROBLEM???
- Magnaflow is on....
- How to adjust 1.6 rr when the car is running...
- what should I get first?
- camaro with C5 Vette Wheels?
- Overheating
- Cai and 1le
