  1. GM part# for O2 sensor
  2. OUCH!!! $600 for ceramic coated hooker LTs.
  3. Lt1 - Ls1 Light Conversion?
  4. True duals pics
  5. Where can I get a built 383 or 396 shortblock
  6. fans running alot?
  7. 1.6 roller rockers?
  8. 383 guys how much timing at WOT?
  9. Who makes the best street tires?
  10. Injectors
  11. Remedy for hatch rattle?
  12. New Clutch/Driveline Problems!
  13. Has anyones valve seats ever broke out?
  14. which 160 stat?
  15. Accel 140011 and MSD-6AL
  16. burning valves with open LT's?
  17. what is this boxy pcm looking thing?
  18. What does a stock clutch Weigh?
  19. Wondering aloud if a converter will actually slow my 1/4 times
  20. Which Cam for Stock A4
  21. stumble and backfire..after LT's installed
  22. traction and 410s what ta do
  23. code 32- egr fault. what should i do?
  24. Good-bye 383...hello 396 LT4!
  25. are front and back 02s the same?
  26. tranny mount
  27. MAC 94-95 headers
  28. z28 vs vette?
  29. LT4 Hotcam question
  30. Do you loose HP/TQ 1/4 times/mph with Mcleod Street Twin?
  31. 12 bolt, 9 inch alternatives?
  32. LS1 Brake upgrade/ What lines?
  33. Infamous vibration, I think I got it
  34. Help with LT1 fuel rail covers > Appearance questions:
  35. Dry shot Jet sizes? 75 and 100 what numbers?
  36. what causes burnt valves?
  37. Are optisparks really that bad?
  38. about how much for a new crossmember?
  39. tranny swap?
  40. Torque specs for rocker studs?
  41. Still not fixed!!!! I'm buying a Honda!
  42. Need part # for SOLID tranny and motor mounts please
  43. Question, what is Max Rec Lift mean in CC catalog?
  44. Will AC Compressor from 93 work on a 94?
  45. What is the procedure to matching a cam to heads?
  46. Electrical Problem, Need HELP!
  47. What is the best Catalytic Converters?
  48. On the cheap; where to find stall and..
  49. Direct water into Ram Air hood
  50. will these work
  51. A/C Delete and pollution control
  52. Lt1 realible
  53. Why is my car so rich? 10.5 AFR.
  54. Does Air Foil Work?
  55. Making a ram air hood?
  56. Ses Fuse
  57. McLeod Street Twin
  58. unplugged TPS= better running motor?
  59. Quick o2 question...
  60. Tranny guys inside----> Couple of questions on TCC
  61. uncle sam needs YOUR help changing his brake pads...
  62. LT1 Cam - is it a roller cam?
  63. Good friend dies this weekend in street race!
  64. just did a 383 rebuild and it pings.
  65. Pinging after opti install....
  66. Low colant light
  67. Do you work on your own LT1?
  68. Oil Leak, may be the rear main seal, have questions
  69. Did anyone here swap a 94 tranny in their 96-97?
  70. Cheapest place to purchase F.A.S.t.
  71. which crane ignition HELP!!!
  72. Can someone give me a heads up on the wiring of an MSD 6AL?
  73. Will it Work?
  74. What if I stripped my crank snout?
  75. Will C5 wheels fit on my TA?
  76. Best cam for advanced induction heads
  77. what can i do to allow my car to rev higher safely
  78. oil pan
  79. Another happy LTCC owner
  80. rotten egg or sulpher smell?
  81. ?? Question about undressing heads
  82. question on strut tower brace
  83. Buy my suspension for me...
  84. Opti on SBC
  85. Lowering with LT's?
  86. LT4 Valve
  87. Wicked Street Z ... Want 450-475 RWHP ... Any suggestions?
  88. 1995 lt1 dual cat headers?????
  89. 93 style slp shorties collector ?
  90. check out any car 1/4 mile - 0 to 60
  91. Dyno #'s SUCK! Ideas why?
  92. My dyno #'s suck!! Any ideas to help the not-so-knowledgeable?
  93. Just finished SPEC Stage 2 and Alum. Flywheel install.
  94. Changing pinion bearing, HELP!!
  95. PLEASE HELP! Car won't start...
  96. 52mm and/or 58mm throttle body
  97. Optispark
  98. 4.56's installed fri
  99. A little bit faster
  100. Cut out vs. Random Technology cat-back!!!
  101. Pacesetter shorties almost installed, plug problems
  102. v6 and v8 rears for lt1 and ls1 body styles
  103. 93 LT1 High RPM hesitation
  104. Axle end play specs?
  105. N E one have a stock lt1 DD2000 file
  106. Headers and stock exhaust questions...
  107. Engine install with Hooker longtubes
  108. Race flo vs Street flo
  109. hear/feel thump when auto tranny shifts at high rpm???
  110. LCA relocation brackets worth it?
  111. Poly or Poly/rubber for LCA's
  112. A4 to M6 conversion: part numbers, and wiring harness
  113. why do the brakes suck in the rian
  114. just curious......
  115. why am i misfiring?? please help!
  116. hotcam kit worth it without headers?
  117. Computer Tuning for Roller Rockers
  118. just gutted my cat
  119. Low oil switch. Go bad often?
  120. has anyone towed a f body with another f body?
  121. Synthetic fluids woth it??
  122. Intimate Advice?
  123. Is an adjustable LCA necessary?
  124. resetting the pcm?
  125. I need instructions...
  126. Need confirmation of timing marks on Cloyes double roller crank sprocket
  127. exhaust audio
  128. Nitrous on Stock Rear
  129. The slp pressure plate is not a LT4 PP
  130. Removing TCs on 95 TA > Anyone do this?
  131. Causes Of Misfire Code?
  132. Buying Recaro Seats?
  133. Spohn vs BMR, which is better?
  134. LT1 to LT5 conversion?
  135. Which sparkplugs?
  136. Car is running funny when cold?
  137. lcas binding up
  138. fuse box terminal prob?
  139. A few newbie questions.
  140. which clutch?
  141. Springs ok to use ???
  142. Help! Severe power loss after plug/wire change
  143. Trouble shifting into 2nd gear in my t56
  144. What Would Be the Best
  145. Still not fast enough
  146. how to open trunk without key?
  147. guys who have done a4 to m6 conversion
  148. .20 mill with 224 230
  149. Did I destory my ring and pinion
  150. Help with traction mods! (no tires)
  151. can I take off the mat under the hood of my car? any problems?
  152. "streetable", durable, clutch that will last AND hold 700+?
  153. egr valve how to remove it.
  154. Looking to LT1'ers for HELP! Broke stud on rear Drum(V6)!!
  155. Clutch pedal extention
  156. How to tell if Throw-out Bearing is toast?
  157. AS&M and Random Dual cat?
  158. New track times!
  159. Throttle body.. How much HP gain over stock?
  160. Can I drive with 4 of 5 lug nuts on?
  161. How do you post a pic???
  162. mufflex y-pipes SUCK
  163. Milling heads .03 with Impy gaskets
  164. Help, oil pressure question!
  165. question pulleys/belt
  166. Dual Cat header opinions and suggestions
  167. Racetronix fuel pump install...
  168. Shoebox inside please! cars starts with no key or clutch engaged!
  169. Have a lifter tick
  170. Will shortie headers help?
  171. What could cause
  172. V6 spring part number
  173. First time replacing front crank seal
  174. What gauge wire for LT1 starter solenoid?
  175. Eliminate FMU?
  176. 2-3 shift on 94 4L60E...
  177. I need new clutch...im a newbie...advice?
  178. Slightly annoyed with damaged goods from GMpartsdirect
  179. B&m
  180. front sway bar
  181. 383 Advice needed...
  182. C5 Brake Conversion pics
  183. What suspension mods will help me launch?
  184. Part# for ls1 brakeline->caliper bolt please
  185. An exhaust that will be good sounding and NOT obnoxious...
  186. Broke oil dipstick, where to buy new one?
  187. Need Advice
  188. RR's and 1.6 rods without cam?
  189. Combination Motorsports Valve Springs
  190. Stock 93 pushrods with guide plates?
  191. water pump install help
  192. best aftermarket catalytic converter??
  193. Differences
  194. Why can't I use wheel spacers with these studs?
  195. Billet Dynaspark Distributor
  196. Gauge and hvac lights aren't coming on
  197. gains by match porting heads
  198. rearend questions...
  199. Looking For An Lt1
  200. Emissions and CC305
  201. evryone who has weld prostars 15x8 rims what is the correct backspace for our cars
  202. What the hell is going on with my car? (datamaster files inside)
  203. uh oh... metal shavings on cam!! :O
  204. lt1 guru says my car will run way better with a muffler well wich one ?is this true?
  205. Magnaflow people inside!!!
  206. which shorter plugs with shorty headers?
  207. loudmouth resonating chamber like a gutted cat?
  208. egr valve- how easy should it be to move?
  209. Is there an optimum temp for the LT1 to run at?
  210. What engine oil to use???
  211. where can i find these?
  212. help
  213. pic of carbed 4th gen.
  214. Can you hear wires arching?
  215. Does anybody elses brakes do this??
  216. How to install trans cooler
  217. will a 99 steering wheel work on my 93?
  218. Why is my car over heating?
  219. OIL LEAK, need help!!
  220. Drivetrain Recommendations?
  221. tsb and recall information?
  222. Manual Fan Switch???
  223. good cam
  224. Good cam idle rpm
  225. what mods give you the best sotp feeling?
  226. What to get with my headers??
  227. how much for a cam
  228. What causes bucking and surging at low RPM in low gear???
  229. what coil wire to get?
  230. best drag radial for salad shooters??
  231. Who else's car jumps to 2k then drops slowly to normal idle when they first start it?
  232. Good LT1 FAQ's/Upgrade Paths/guides?
  233. mac midlengths
  234. New wheels = Need new gears
  235. Labor Hours: Head Gasket?
  236. Oil Pan problem. Need help.
  237. bushing or bad D.S causing crazy vibration?
  238. Fuel Mileage
  239. Stall converter
  240. ring and pinion gear ??s
  241. Fair price or how much shop time?
  242. Knocking From Valve Cover Area...
  243. Loud rattleing noise/hesitation at WOT??
  244. Spark Plug Wire Question??
  245. Fuel pressure woes...help!
  246. H2O Idiot.
  247. Free mods for LT1?
  248. hooker y-pipe fit jet hot lt's?
  249. brake line question...
  250. Removed A.I.R. system > What to plug manifold holes with?
