- loose header bolts, any ideas?
- How To Make An ADJ Fuel Pressure Regulator
- Download 93-97 Firebird / Transam parts manual
- Ring and Pinion - How long to break in?
- Ignition Problem PLEASE HELP!!!!!
- Accel 300+ wires?
- Ford 9"
- To all with jet hot headers
- New to 4th gens, a little help please
- dual exhaust with long bullet mufflers?
- can't get motor to come loose!
- How should I work this? (Upgrade path advice..)
- Skip Shift Eliminator: Where is white connector?
- Shifter bounces and moves when shifted hard
- Anybody have this cold air kit?
- oh yeah...she's grumbling now :)
- summer is back, car runs hot again
- Cmotorsports Heads, Questions
- header bolts on lt1
- What’s that metal piece that bolts between the two frame rails?
- Should I increase my stall with my set up?
- Camshaft Install$$$$
- Rims Wont Fit!!!
- 19 Degrees Of Knock Retard
- Hesitation under acceleration
- McLeod clutch help !
- changing shifter
- Y-Pipe Question
- Can custom cam make 450+rwhp w.AFR heads
- Anyone ever have their air compressor go?
- What year heads will work on my 93?
- hooker catback with catco cat size question
- plugs and plug wires
- Panhard rod
- Anyone have a how to guide on pulling the motor out the bottom?
- scanned codes. got code 32 egr system fault.
- What should my next mod be?
- POPING Noise coming from Pass. side!!
- Will 20X10.5 rims fit on the rear of my car?
- clicking noise
- '97 SS info. needed
- Next mod, and which brand
- Watching out for dead outta the box optisparks
- What valve springs are you running with your high lift cams?
- 1/4 mile times with 3.73's
- Trip odometer
- Whats this I hear about OBDII not being able to use a Double Roller???
- what are "baskets"? relating to brakes
- buying lt4 conversion kit but want more power
- how can i tell if it's a PM rod
- Does anyone know?
- Did Pep Boys Screw Me?
- OPTI question attn Engineer & Shoebox
- Trans, please help
- Those with rollbars/cages within!
- OBD-2 TRICOM help fast......
- Best place to get GOOD tie rods and ball joints?
- High Temp after Cam install
- odd noise when i shut off my car...
- First races with new set up..do these times suck??
- Wet outside...car misses badly..opti?
- car shoots blue flame
- rev limiter?
- Quick header install/EGR question
- Got this in a good deal
- Fuel Rail Covers
- Where to buy Torx driver for hatch struts?
- SLP CAI filter question
- Use AIR as vacuum pump?
- pro 5.0 and stock shift knob ?
- They old what should i run thread
- LS6 in 1994 camaro?
- Where to get cage for a convertible?
- Ported and polished MAF ends, will they help?
- broke engine? bad gears? broken tranny?
- Tuning- When?
- FLP Long Tubes
- My Hotcam Dyno #'s
- ZZ-9 idle clip?
- cost for cam swap gaskets
- ET Streets for 16" rim, any tired them?
- My diff is noisy after 4.11 install
- Umm.. WTF whats the world comming too?
- LT-4 Knock Module
- MSD Ignition Control
- 96 Convertible to 98 conversion.
- why are my blocklearns 115?
- Changing oil pan
- Replace just belt tensioner pulley or the whole tensioner?
- trans am front end conversion
- How hard to install tranny (auto)
- ET streets vs ET drags
- Whats the Best Muffler to use if you don't have cats that will sound good!
- Spark Plug & Wire Installation Help
- as&m or slp headers
- Best Spark Plugs/Plug Wires
- o2 sensor replacement
- Is XE 224/230 good for daily driving?
- $399 Headers
- Your opinion on the XE 224/230 cam
- Why dont I get a 3d face instead of these ;)
- where to buy manual fan switch?
- Which 58mm throttle body
- How do I check the pinion angle?
- LS1 brake upgrade...where can I get one?
- What are my stock rear gears?
- Differential Cover
- xe 218/224
- Can someone put me on a weight loss plan??
- Getting after market SLAVE CYLINDER
- caprice MAF same as Camaro?
- my electric fans run all the time on LOW...
- Pushrod questions
- Where can I get Mac-True fit headers?
- Gains from 1.6 rr and headers
- VP and car getting lean
- need something...
- FTFORCE.com a.k.a. - Racenetone.com sucks!! (LONG RANT)
- Fuel Ran Low...Gonna have fuel pump problems?
- Can someone prove to me that longtube headers are better than shortys??
- Removable tube on Hooker LTs?
- Best Cam for my setup?
- clutch question?
- Troubleshooting Fans and Starting problems Guide
- got engine codes
- Ignition problem? Help...
- how much can elevation hurt ETs?
- Banks Power Systems exhaust
- Stroker noise and RPM questions
- stall, cam, fluctuating rpms?
- What the bad part about having 3.73s
- Help with pics please!!!
- Lose Tranny Mount?
- Need help ASAP alternator related
- LT1 Tuners??
- Torque on thermostat bolts?
- attn: everyone who has weld prostar 15x8 rims please help what is the right backspace
- headers
- need part #
- i need a a muffler for my wide open exhaust cause i think i lost power which one?
- those with 320-340rwhp inside. Post your times...
- ignition problem?
- Questions about Competition Motorsports!
- looking for an lt1 edit guru
- Cam in a 93 ??
- Newbie needs more info...
- did some 180's now steering is stiff..?
- 1:6 Roller Tip Steel Rockers
- roller rockers
- Roll Bar
- pressure problems
- best way to screw up a TC
- just killed 2 opti's in less than 150 miles (long, but please help)
- Happy with my LT1
- Wiring diagrams
- Big Problems with McLeod S/T, NEED EXPERTS!
- It's almost alive.. questions inside
- Changing Auto into Stick
- headers and stock y-pipe quesiton
- i want to run 11s
- need help troubleshooting A/C clutch compressor hook up
- optispark question
- Need Clutch Advice (did a search)...
- ?? Adjustable Lower Control Arms ??
- Would a Local Auto Parts store have exhaust manifold bolts?
- Hotcam 1/4 Mile times - Stock Motor
- need help
- Ticking sound? What is it?
- Seals sweating.. Problems to come??
- What makes them cheaper?
- Tire Question??
- Easy question...Check it out
- Hooker Catback...(Sound Clip Inside)!!
- 224/230 and ported heads?
- LT-1 Timing sets...
- In-tank fuel pumps...
- Swap finally done, just need help figuring out whats wrong
- Is it worth putting SFC's on a hard top?
- Compression ratio and octane requirements...
- Anybody ever use Racenet.net?
- Has anyone Put LT4 RRockers on an LT!????
- Alti'nador brackets, just a pain in the ass...
- hesitation off idle and under load when hot
- Help me with my compression calc plz
- what all does a higher stall convertor do
- Lifting motor to install header question
- Those with Corvette FRCs
- heads cam combo package ?
- Still can't get into the 12s!
- Tips for Rotor Swap
- AC Removal
- where can I find one of these?
- 2nd time my car wont start! But only after it's rained!!! And I need the car!
- Fans and Hypertech Chip
- Size of Autometer oil temp. sender?
- what lb/hr injectors should i buy?
- underdrive pulleys?
- QUICK!!! Help needed(starter removal)
- how do I find out if my valve seals are leaking?
- stock spring diameter
- people w/vibration problems
- ? about elec. WP's and reliability.
- T56 Weight?
- Jet Hot LT's and ???? exhaust
- How much lighter with M6 than A4?
- Any random LT1 knowledge out there?
- hookerlong tubes and stock catback
- Shortys or Long Tubes?? Hmmmm...
- T56 ?
- Tranny help
- code 36
- OBD-II to OBD-I Conversion
- 97SS M6 Launching Techniques
- ASR and Fog Lights
- Could this have just been a wet opti?
- Spec star III
- Trap speeds all over the place, false knock maybe??
- Couple of LT1 Questions
- My car stalled out twice last night
- intake gasket
- over heating Q's???
- What kinda vacumn shoud we be getting?
- Guys whats wrong with my car? I'm about to cry
- I need your opinion On what I should do
- Why do my headlights flicker sometimes?
- my car is pissing me off!! please help
- Cam install - in progress...
- Sportline springs and stock shocks?
- Cooling Temperature SOLVED!!!
- How do I turn off the SECURITY light, that's on the instr. panel?
- exhaust tips?
- AIR BAG light
- Please help me(cooling fan related)
- Need 3 Lt4 VALVE COVER BOLTS
- Help! Cam bearing gone bad?
- Pulling heads due to blown head gasket
- Charged air radiator owners please help me out.
- Who knows SI valves?
- I have never heard of a 3 point Strut Tower Brace Before
- Are aftermarket MAF sensors worth the money?
- Mysterious Torque converter.
- Very happy with LT4 topend conversion kit
- Air Bags-Replace or Remove
- Cheap Strut Tower Brace STB
- After bolt on's........thing runs like $#%^
- odb-1 guys with converters.....
- service enging soon light
- HOW OFTEN should RADIATOR Be FLUSHED
- Fasterst STOCK LT1 ET?
- GM part# for O2 sensor
