  1. Keyed hub
  2. Scanner battery voltage readings?
  3. So whats your opinion on coil overs?
  4. asdf
  5. Question on Air/EGR
  6. Should I be concearned?
  7. Those with dynatech longtubes
  8. help me pick a clutch!!
  9. Dynoed car today and some white smoke seeped out of tailpipes on decel?
  10. Longtubes with Emission Hookups
  11. Severe hesitation/stumbling problem
  12. harmonic balancer removal question
  13. heads hp gain?
  14. 150 shot. What kind of times can I turn?
  15. Bogging at over 1/2 thottle
  16. Exhaust and Rear end
  17. Is the LT4 HOTCAM upgrade kit worth it ? ...
  18. 2.73 gear swap
  19. If you don't clear your codes???
  20. Need help QUICK!!!
  21. It's Alive!!!!!!!!!!!!!!!!!
  22. Check Out The Ride!!
  23. Wrench size on Hypertech AFPR
  24. Friends car having problems...
  25. injectors
  26. Tick when warm, fine when cold, WTF?
  27. Anyone with loudmouths notice?
  28. cars with K&N FIPK....
  29. Really..Really stupid question...
  30. Auto Shifter removal
  31. post for SLP LM 4 297
  32. Dyno numbers for my heads/cam 236/242!!
  33. Which Timing chain to Get
  34. Coolant Flow Restrictor Valve
  35. where can i get an obd1 pcm?
  36. plug change from the top
  37. will the obd1 pcm from a caprice work in my 96 TA?
  38. The Next Step......?
  39. Polyurethane Torque arm mounts?
  40. cam idle
  41. whats a safe shifting point???
  42. what shifter to buy for M6
  43. !newb question, how to drain brake fluid?
  44. Head gaskets install (grease it or no?)
  45. Fuel pump change now flames under car!!!
  46. !EGR, did i do it right? (pics)
  47. Transmissin help
  48. I am changing my Fuel pump and going in from the top any suggestions?
  49. Running rich and rough at idle
  50. 1LE tranny mount still exist?
  51. Flushing the rad
  52. lets talk tranny fluid!
  53. What could this be
  54. where's my rev limiter
  55. Who did your PCM tuning?
  56. How do these mods sound?
  57. tire ?
  58. Name that clunk... Rear or trans
  59. How loud are roller tiped rockers supposed to be??
  60. FLP Long Tube header (emmisions) question...
  61. Hesitation/Stumble Theory: Let me know what you think!
  62. Not a normal hotcam question!
  63. Would RR'r CLACK Louder with Bigger Cam???
  64. Is My WP Shot???
  65. News on Mosers' Death
  66. HELP, NEED Y-PIPE for LT's by FRIDAY!!!!!
  67. Stumble at highway speed in OD, please help
  68. freescan how-to?
  69. gload brace torque arm mount ?'s
  70. Do stock throttle bodies from the factory come with an air foil?
  71. Are all stock fuel pressure regulators the same?
  72. Is Superchips programmer worth the money?
  73. Paging Shoebox??
  74. G2 TA Girdle, stud sheared off!
  75. 4.10 gear in an A4??
  76. quick question
  77. I have a problem
  78. Suspension: How long?
  79. This is It, Car Wont Start, Backfires, Changed Since Last Time I posted
  80. How do I remove the foglight?
  81. Cracked Dashboard
  82. OBD conversion
  83. Break-in procedures for torque converter
  84. installation of HOT cam kit
  85. good clutch????
  86. Good times?
  87. Pics of your magnaflow exhaust
  88. Simple question about Pushrods, just need someone to clarify
  89. Gasket vs Gasket Maker????
  90. can mismounted front shock screw up alingment?
  91. idler pulley options,..
  92. Suspension Question? Help!
  93. Need immediate help... Car wont start.. wont even try and turn over
  94. Track results finally...problem though
  95. Leaking coolant
  96. I'm a bit confused with programming.
  97. A little off
  98. dynomax???
  99. Can I use 94 95 headers on my 97?
  100. Can a faulty harness to the air pump cause not to start?
  101. need help with components
  102. burning plug wires
  103. Which Tranny Cooler???
  104. OK guys, what is the best carrier to run in a 10 bolt ???
  105. Good cam/rr install site.... I lost mine and couldn't find it in search....
  106. problems with my 4L60E, help please...
  107. Loud Poping noise comeing from left front????
  108. what would my car sound like with hooker headers, highflow cat and cutout?
  109. Do I need tuning? What can i do in tunercat?
  110. SES is on, but I pulled no codes...help
  111. What is the best Cam/Head street setup?
  112. cutout installed! also fuel pump question
  113. PN for intake manifold bolts
  114. Still haveing problems with window.....
  115. cutout=gas smell?
  116. anyone else have problems geting crank hub off ?
  117. what kind of sound difference are we talking here??
  118. Coolant rushing into "overflow" after car is turned off....
  119. any advice
  120. Panhard Bar
  121. Car misses only when hot?
  122. Torque Converter
  123. Catback right for me?
  124. Funny smell
  125. OK... finally got the money... need to know what constitutes a rebuild or new tranny
  126. Battery exploded!!! Need help diagnosing a no start condition.
  127. SLP's speedo recalibration part #? (I searched)
  128. Low RPM Stumble and Knock
  129. cam+stall= no overdrive
  130. Need help from TC/Trans-Go guys
  131. Low end question for High end people
  132. How much or will it work?
  133. rattling noise
  134. Ignition woes, changed everything imaginable
  135. cut-outs
  136. i-pipe & crossmember rattle
  137. Anyone ever figure out the problem on an OBD1 car with a 3000+ stall?
  138. z28/SS
  139. Recaro Seat Brackets 93Z28
  140. Need quick spark plug help
  141. XE 224/230 and pushrods
  142. Possible for valve covers to leak?
  143. I have firebird parts book I'll post if someone can host it.
  144. What to put on intake gaskets
  145. T56 tranny problem...
  146. DFCO in tuner cat
  147. Gmmg Borla Or Corsa
  148. Anyone in the Dallas area know where a GOOD transmission shop is?
  149. fire sleeve concern
  150. rear end cover options?
  151. If the SES light has been on for months non-stop...
  152. Hooker or Loudmouth?
  153. Went over some bumps and my opti ate something
  154. Rear End Damage? HELP!!
  155. t56 trannie
  156. How much lift can the stock springs handle? I already tried a search
  157. Split-lock Mechanical Header Bolts
  158. Before and after dyno #'s of XE 224/230!
  159. Limitations on Stock Internals?
  160. Tapping bolt threads
  161. got an SES light while driving after removing EGR on OBD1??? wtf?
  162. Intake delemma
  163. Might As Well Ask The Experts...
  164. backspacing and bolt circle for skinnies
  165. Noise normal?
  166. crank, crank, crank, no start
  167. $355 to re-install stock flywheel
  168. Freaking top speed limiter
  169. what do you think ill dyno at and run
  170. Air/Fuel ratio gauge
  171. What plugs and wires do you suggest?
  172. Changing differential fluid to synthetic, questions...
  173. canging doors
  174. How to make the stock 10 bolt stronger
  175. how much HP is a stock clutch good for?
  176. Ground Clearence on Hooker LT's?
  177. SLP CAI Users - Rain Guard CutOut Mod
  178. Best place for hooker catback?
  179. Cam & Head Package for LT1
  180. Removing traction control
  181. ? about TH350 swap
  182. remove cat
  183. auto headlights i dont want them.
  184. AFPR and gas mileage
  185. valve springs for gm847 and 1.6rr
  186. matching cam to heads?
  187. Are 3.73s worth buying?
  188. What sixe fuel injectors??
  189. what to do with air pump lines?
  190. Non-vented opti install guide?
  191. O2 not responding??
  192. Thermostat Mod
  193. Will a timing chain cover off an LT1 Impala fit a LT1Camaro?
  194. Brake problems
  195. New Dyno Numbers
  196. How bad do a4s W/ et streets punish the factory 10 bolt
  197. HELP #'s with LT headers
  198. GUys with BMR K-members and A-arms, Help please
  199. Swapped rear ends... need help with TCS and ABS
  200. Need some tech help, lifter and pushrod
  201. Need help with intake mainfold
  202. help, what should i do...
  203. Engine Rebuild Dyno Numbers
  204. Loud pitch screaming noise when I start the car..
  205. Car still tuggs or pulls at low throttle...
  206. just ordered hooker catback!!!
  207. best cat back??
  208. How long to foul plugs...
  209. SES light went on while driving, then never re-appeared... how long is it stored?
  210. Trans Am GT package?
  211. blinker lights
  212. HELP ASAP! Why does my throttle stay barely open when the car is running???
  213. Is there supposed to be resistance...
  214. Dyno with longtubes & CAI
  215. Muffler Series???
  216. Cheapest Hypertech reprogrammer?
  217. Will the factory I-pipe come out in one piece?
  218. Installing rear end gear ratio
  219. Car is jerky under 2K
  220. tranny turmoil
  221. Engine Rebuild?
  222. Remove and Reposition Steering Wheel?
  223. Guys with KYB or Bilsteins Or both Input here:
  224. Zz9 Vs. Lt4 Hotcam
  225. what hi-flow cat to get?
  226. Sway Bars from 3rd gen to 4th gen???
  227. Sealed Beam Conversion for 93-97 cars??
  228. ignition coils?
  229. hp ?Cmotorsports head/cam kits
  230. QUICK! Help with heads!
  231. Clutch Ignition Safety Switch help- Shoebox!
  232. Guys with no cats..
  233. LT4 crate engine availability
  234. Major LT1 Pre-Build ?'s Heads ,Cam, Bottom
  235. Need a new starter were is the cheapest
  236. Rear gear ratio question.
  237. High Temps, Low coolant light. Need some help please.
  238. Help ... Stupid distibuter question
  239. Every person who has had a high RPM hesitation break up around 4800+ share with mePLS
  240. Brakes
  241. Shifting point WOT on A4
  242. checking piston to valve clearance
  243. Help! unknown vibration!!!
  244. b&m shift kit
  245. fuel injector wiring ?
  246. What else needed?
  247. Split BLMs & KR at idle...
  248. Trans Temp gauge
  249. Speedometer not working
  250. Lowering??
