- tranny shop
- Tach Light??
- help!! lt1 gear swap
- How Long does a stock clutch normally last?
- Ford 9 Inch for 1000? Where? WHo knows About this?
- dumping exhaust before axle
- Which Clutch should I use?
- TPS code PO122?
- K&n Cai?
- Poll: What's everyones choice for a 6 speed shifter???
- Cutouts
- Part# for EVAP purge vacuum switch?
- Slipping Tranny?
- Hit the dyno today
- ? Proof ? Mufflers
- Solved my stumble
- Exhaust ?
- Went for inspection; Blew motor.
- Ignition Coil Question
- Installed ES Poly Trans mount, now another noise???
- gear swap??
- Wtf goes in this hole Huge oil leak
- SLP Headers What's Wrong?
- Tranny Cooler
- Need some help on part #'s. Doing a cam swap on a 97 TA.
- need help with my moser 12 bolt
- Got the money to do a cam swap. Did i make the right choice?
- I'm bolting them on... GTP's..
- top speed of a Th350/3.23/26.5 tire?
- which cam for this setup?
- Which Gears to go with?
- Don't gut your cat..
- How do you test sparkplug wires?
- Have A Transmission Question.
- What does the Combination Motorsports "Cam package" Consist of, and where are they?
- Alright I need some more opinions on my headlight problem...
- What is this black box on drivers side, underneath the hood alignment post?
- rim size
- Hooker Catback
- How do you change your oil?????
- Welding cylinder head intake ports
- headers and emmisions
- Installing gear?
- Th400 vss question
- Fast Toys
- Is 450 rwhp possible?
- Backpressure kills performance?
- How much effect do RESONATOR TIPS have on exhaust sound???
- How do I adjust and test my TPS?
- !!!read Here!!!(why You Shouldn't Use An Lt4 Km)
- heading to the track for the first time
- Difference between air/no air cats?
- SLP Headers Plug Access
- Muffler in series?
- Alright guys, A track Virgin Here.What rpm do u 3000 Stall guys launch at?Hal Settin?
- clutch slave cylinder
- Opti help...fixed it or not fixed it?
- afgs*1.1=rwhp ?
- What Are The Symptoms Of A Bad 02 Sensor?
- Need help on changing plugs and wires
- Heads and cam guys...
- Can the Opti do this
- 350 RWHP would it equal low 12s, depending on the driver of course?
- Dyno Graph for CC306
- pruge valve
- radiator? shoebox
- Deep Throaty Exhaust?????
- Lowered Cars...New LCA needed?
- how do you buy tunercat
- Knock sensor. AC or DC ?
- need help poping through the exhaust.
- Oil Pressure Sender-93Z
- True WS-6 Verification
- Help!! Heard pop
- DTC 29 and 32 - EAS electrical system failure??
- o2 sensor replacement
- Part #'s for OEM springs
- Accell plug wires
- any predictions on dyno #'s please
- flowmaster sounds bad
- Where to get just a clutch disc.
- Set me up with a clutch! (did a search)
- 93 timing chain?
- Need cam suggestions for a stroker please
- advance timing
- Chip for 93 T/A
- EGR two wire connection question?
- Which Clutch???
- What kind of ramps should i buy?
- Ever a 400BB
- What brand gear do you run?
- Cam Help !!!!?????
- High RPM's on stock bottom end
- How many teeth on a stock 94 flywheel
- bfg drags
- Ive about had it with this TPS and TB!!!
- Heat shield ?s
- Who makes a Tall center bolt valve cover
- part number for belt for mac underdrive pulley
- How long did you wait to do wot after cam install?
- tranny problem
- i need someone to run a carfax for me
- Whos familiar with stock 96 SS Exhaust?
- Need a M6 Tranny in California
- Strut removal 93z
- fel-pro gasket #2001
- rebuild help needed in dallas/mesquite area
- 93 vette LT1 ...gen1 or 2?
- Cam Install, change oil pan gasket
- Disconnect the clutch master cylinder pushrod? HELP QUICK!!
- XE 230/236 anyone got numbers with this cam??
- TB coolant bypass question
- Anyone want to try out some heads I'm porting?? there free, you just pay shipping
- How hard is a 3.8L to LT1 swap in a 98
- What mods to do next?
- Holy ****! This Has To Be By Far The Worst Thing Racenet Has Done In A While
- Part numbers for 1LE fog light delete kit?
- running rich! how much does it affect...
- ordered 2800 torque converter
- $300+ to spend
- need some tuning advice!!
- Its Fixed
- What To Do For A Rear?
- Dome light wont go out????
- Whats the best cam for me?
- HELP! Just installed 52mm throttle body and it's constantly reading 1% throttle?????
- Quadrant Driver???
- Can you all look over these data logs?
- mileage on H and Z rated tires???
- 3.3 degrees of KR at idle...
- help!! exhaust
- HELP! 4l60e???
- What guages should i get
- projected HP
- Average / Best STOCK LT1 Times
- Transmission
- SLP flywheel owners please read.
- $2000 to spend on speed
- Anyone ever experienced this with their Tranny?
- Head liner sagging
- Do they make a Y pipe for BBK shorties?
- car dies everytime passanger front wheel hits water puddle
- LCA relocation after SFC install?
- Placed internet order 3 wks ago, no word yet, what should I do???
- Break In Procedure
- Long black support along side the driveshaft?!?
- Power Steering diagnostic
- header longtubes and inspections
- Hal QA1 Front Adjustable Shock Problem??
- what causes rear brakes to click
- Have a stupid question about a good topic
- How to drop this damn driveshaft?!
- O2 Extensions w/ Mac Headers or not?
- Question regarding the Canton oil pan for the LT1
- Part Number Question
- Tranny tech question?
- Why is my car feel slow out of the hole??
- Valve cover gasket question
- Oil leak question....
- ATTN: Guys with 'verts...
- Best Electric Water Pump
- Help Quick!! Couple of questions before dropping the tranny out of car...
- Blue smoke now...
- Car still overheating after new radiator...
- Bought a camle for OBDI and need some software...
- Someone HELP
- Just got my 96 z28
- Cant get the tranny loose to drop it!!
- Looking at a 94 Z28 A4 have question?
- Smog Pump
- BANGING Valvetrain Noise
- i got a new block today
- coated intakes
- BMR tunnel brace first impression
- True Dual - ers INSIDE
- What's the most HP and Torque for a stock steel driveshaft?
- Hal users, What settings for the Track?
- Price Of Timing Chain Set?
- Bose Amps?
- 97 Z/28, ABS INOP shortly after header Install???
- How much Power ...
- What modifications do you have to do to valve covers for Roller Rockers
- Need help ignition problems?
- Bad Optispark
- Opti CRAP problems again
- HELP!! Car overheating and SES light on!......long sorry.
- Any Street Twin owners have trouble with pilot bearings????
- Wiring into the computer
- car would not start
- Got a Dynomouth system made today (pics)
- Starter... HELP!!!
- Subframe Connecter install Question
- ET Streets on 10-bolt?
- electric water pump guys inside
- Does anything in the throttle body change when the car goes from "on" to "start"
- How to check EGR valve?
- Rattling In My Tranny???
- Do air foils really work?
- Electricians.. I need your help please
- Best, cheapest place to get a 12 bolt??
- Oil leak -- Front cover
- wheels
- Firebird Headlight Problems!
- stock radio question
- What should I do with $1500? I thought a cam, but...
- White smoke at start-up
- Could I have 3.73s???
- Another high RPM miss thread!!
- Header bolts
- My car won't start
- lets drop off a few tenths
- Problems with '94 Vette. Opti? ICM?
- MSD problem
- New project...How hard to put an LT1 in this.......
- LT1 underdrive pulleys
- Major VIbration issue!!?!?!?!????
- Need clutch
- ac delete and computer help
- Vibrating shifter, only in 6th gear?
- Horsepower Problem, Scanned Car, Observations....Need Expert Help!!..Long!
- Opti ?
- how to change the idle with TC
- replacing water pump
- Can I make the 4 channel ABS work on my 95? Need to!
- Paging shoebox
- Z coming along great!
- Blown Header Gasket Removal
- Cost on Jet Hot coating on Hooker LT's!!??
- Stereo troubles need help please!!
- lt1 block casting number?
- securety light??? car wont start!!!!!!!
- I'm impressed with the Borla Cat!
- Can worn shocks cause alignment probs?
- is there any good 12 bolt donor cars?
- How hard is a 4L60e to T56 swap
- Length of pipe after muffler
- Just ordered lt4 top end conversion
- Remember my other thread? Now I KNOW my car is slow!!
- Clutch won't engage!!
- Radio/Power Windows Problems
- bosch o2 sensor wire question
- SPEC problem?
- lt1 bottom end weight
- 383 finally running!!!!
- ZR-1 Specs
- How to install comp R lifters
- When will us A4 guys get to have a REAL shifter
- Why does the hpp3 suck?
- ok, 2-3 clutches were replaced and the problem still isnt solved
