- fogs ok but not headlights in auto mode
- Torque spec for oil filter adapter...
- 3rd gen strange 12 bolt in 4th gen?
- Yet again another optispark problem maybe?
- 11.84:1 Safe on 91??
- SES code????
- Anyone in MA run Long Tubes and pass emssions ?
- Why do Bosch O2 sensors suck?
- highest flowing air intake...
- where to find automatic headlight conversion
- Drive light conversion on a 94
- cheapest optispark?
- 12 bolt question
- lt4hotcam or cc305
- part # for lt4 km
- 12 Bolt or 9 Inch??
- Need help with Torque Arm bushing....PLEASE!
- A/C line burst...
- Slight idle problem after Hot Cam install.
- Hedders-Fac. warranty
- MAC question
- Finally got word back on my broken tranny
- Help, courtesy fuse keeps blowing
- Taylor OVC setup can really test a persons patience.
- New LT1 Power Packages available!
- Handling
- Clutch Problem- stuck in neutral! HELP!!
- Still looking for noise
- OPINIONS needed - LT1 headers MAC or HOOKER
- I'm Tired Of My Brake Problem, Someone Help Me!
- Anybody with 4.10s on 10 bolt
- Is it safe to pressure wash a tranny?
- Anything I can do to save my tranny?
- BOSE CD Player question, is this where it goes?
- Cam dowel pin length on replacement cams
- ECT or knock or injectors? Where did pcm4less set your fans on point at?
- are shorties worth it (temporarily)?
- Where to get EGR block off plates?
- Attention shoebox, or anybody that knows wiring
- Found my leak.....Doesnt look good
- cc305 vs xe230/236
- After markett PCM`s and scan tools
- Brake line questions
- Need help ASAP
- HVAC removal: a HowTo
- ? About the WS9 RPO code
- Msd 6al
- Lt4 question??
- anyone with a 93-97 T-56 step in..
- 1rst gear
- Will Replacing Wiper Motor Fix...
- refinishing stock T/A wheels?
- Turn Signal Problem
- Where can I get a driveshaft for cheap
- Should i use a High volume oil pump or not?
- pcmforless question
- Guys With SLP LM Considering A Muffler- Here's What I Did....
- Lowering the Z
- 1996 trans am inconsistant performance
- HELP....cant get plug in all the way???
- ? for those running LT4 hot cam on stock heads??
- Roller rocker ratio selection as it realates to a single pattern cam..HELP
- Need suggestion
- This is the right Part # Correct?
- Turn Signal won't signal
- reinstalling PCM?
- The good and bad of Torco torque converters for a 93 4L60??
- Can I switch my shift knob with a Trans Am one?
- Hit a curb w/rear wheel Brakes rubbing and axle messed up? HELP!
- Whats the stock rev limiter?
- Car running rough. Any ideas?
- is my ps pump saying bye?(did search already)
- question about the fan
- Carb'd LT1
- Whats the extra cam lobe for?
- List for cam install
- question about part numbers
- ohm's of my injectors?
- Weird Clunk!!! Clutch? Tranny? Rearend? Help!!
- Using teflon tape on spark plug???
- a few questions about headers
- Injectors
- warped heads
- Gears whining after Diff fluid change.
- Holley Stealth ram manifold
- best tire pressure?
- jet hot headers for LT1s..in here
- Okay, so I broke my timing chain....
- LT4 Conversion
- What spark plugs do you use when running n20?
- Flowmaster sound problems
- Weight loss going to headers?? what is weight of stock catback to aftermarkets??
- corvette heads?????
- Removing AIR pump
- Passenger's Side Air Bar Removal Assistance
- High Idle/Rough Idle & High Oil Pressure
- Intsalling Impy head gasket...which side is up?
- Quick Mac header and offroad pipe install question
- If im selling my car, is it worth it to take my Hooker LT's off?
- Found oil leak....
- Volt gauge on dash....
- Problem with Holley TB's?
- fuel pressure at 35 psi??????? i need help
- HELP!! Runs bad when warm
- Radio stays on all the time?
- tranny
- Polished factory rims....
- why is 95 opti better
- Spinnin' My Tires
- 96 z28 tranny
- Easy Rebuild Question...Shoebox?
- Suspension
- Is my tranny bad?
- Gears: Series 2 or 3 Carrier
- why is obd1 better?
- another tranny problem
- fpr setting
- Cat Question
- Old gasket baked on to rearend diff. cover. What will get it off?
- Real bad stumbling, rough idle, Please Help
- Jet-Hot coat y-pipe or not?
- 1/4 mile times / dyno #s
- cam/RR vs N2O
- How many HP after those upgrates?
- Finally got to race a LS1 ram air TA
- anyone want to trade wheels?
- tb bypass
- I think I have a spring problem
- Torque Arm question
- Need help fast!! custom length wires!!!
- OK, just got $3,500...
- msd question
- Pice of crap tranney part 2
- What are these hoses?
- any moderators
- How many plates behind the door striker plate?
- ABS and TCS should not be on a M6
- Bad motor mounts?
- I may have ruined my heads porting them, HELP!
- Question about clutch install...
- What connector is this??
- LT1 Long Tube Headers
- Will exhaust leak cause me to fail emissions?
- Should I get a Scanmaster?
- Horsepower numbers low?
- center console question
- need advice on true duel set up
- Hooker v.s. magnaflow
- Tranny clean, now what? ***PICS***
- 4 " Glasstek Cowl hood????
- Could MSD box be causing problems?
- Cc-305 Cam
- how are LT1's??
- has anyone attempted to have their steel d/s balanced?
- 1.5 or 1.6 rr with xe 230/236 cam?
- I found some killer heads for my street combo....a little pricey though...
- Head removal, please help
- What's up with ultimatefbody.com?? Anyone else having problems??
- has any one used lock washers with stock header bolts?
- 1995 Z28 Coil and Coil Wire...
- Lazy start after 50# msd injector install
- anyone think this would be too loud?
- Changing radiator, green coolant? Few questions.
- anyone with 3.73's on the stock 10 bolt?
- 1 wheel peel cause? Low gear oil possibly?
- SLP---Traction Control
- how can i get in touch with lt1dave.com
- Lt1 guys in California in here please
- Where does speedometer connect to tranny??
- Stock heads, ISKY 235-D/1.6 RR's ????'s
- Worth Fixing??
- Went to Dyno Today
- lame question, removing the oil pressure sensor ('95)
- SPOHN Torque Arm - more strain on the drivetrain?
- scanmaster rpm?
- Front Shock Strut/Spring Assy ???
- Low Oil Pressure???
- Stock LT1 timing chain with cam/head swap ...
- Hhheeelllppp
- Using a thread chaser......Couple Questions???
- removing the dash
- Need measurements on TB Plate.
- Backfire problem
- Spark plug change and big arm and hands
- gears
- More Longtube question...
- pass seat belt latch broken...any sugg?
- resistor and diode question...
- SS Hood's Ram Air vs. SLP CAI w/ Ram Air???
- Mufflex Y-pipe to Borla?
- Anyone have a diagram of AC setup? shoebox?
- fuel pressures and WOT.
- ignition
- If you remove the EGR do you need...
- What thermostat to run??
- Intake Tract on a WS6
- POLY torque bushing/torque arm install problems right now, need help
- Oil pressure problems??
- LT4/LT1 intake swap
- accessory hardwire...
- need a bolt kit for the engine i'm rebuilding
- drain some coolant for stat swap?
- coil is lose inside the square metal bracket, is this bad?
- rockauto.com
- About to put in a new cam, do I have everything I need?
- brake pads
- bulb questions
- Car has a surge/miss ONLY when A/C is on, Please help
- torque arm; panhard bar???
- cam help asap
- Systems that get rid of optispark, one question!
- Where can I buy interior pieces?
- Does anyone remember this concept car?
- off topic but need help
- need a vacume lead off the fuel pressure regulator!!
- head coolant line torque spec
- Rad hoses collapsing
- ? about driveshaft
- Will NAPA have all the gaskets needed to perform the Cam Install...
- Add me to the list of people.....
- Opti or O2?
- need a new rad sensor
- Squeaky Brakes
- LOUD clunking noise! Need HELP!!
- where can i find an off-road y-pipe for 96 Z28?
- problems with new motor...low oil psi???
- I Got Scratched!!!
- INTAKE-can't decide which?
- so checked my fuel pressure and had 20psi, anything besides fp?
- Changed OPTI, still have problems
- HP Gains
- rear brake pad change???
- Hey Guys what you think?
- Fuel pressure problem, Holley or Granatelli's fault??
- LCA's without brackets?
- Whats wrong?, if anything
- Anyone got pics of the madman low mount alt bracket
- OVC wires to fit the Made-For-You looms?
- Who makes adapters to run old style valve covers on LT1
- Clutch disk options with stock Flywheel and PP
- New LT1 Double Roller Timing Chain Available FREE (joke contest)
- 2 part ? oil / gas mileage
- Stock fsn CFM?
- what should i do
- LT4 top end conversion, which cam for better HP than HOTcam, but for daily driver?
- Stock Cam Specs
- piston to valve clearence
- 1st time at the track
- Spark Plugs, can't decide
- How can I start my Camaro??
