  1. Please help..Brake question(I dont wanna die)
  2. Anyone know how many knock sensors a '95 Formula has?
  3. bumpstop
  4. Strange smell after TB bypass and exhaust
  5. JET fan switch
  6. help needed!!!!
  7. sprayed lube now security light is on HELP??????
  8. tranny
  9. need help
  10. Are ram clutches any good?
  11. I heard this is great
  12. Comp XE 224-230
  13. lt1 4 bolt vette block?
  14. P1416 is back but 0410 is with it
  15. Rebuilding did not Help Tranny!!
  16. 58mm z06 maf
  17. 15x10" draglites with 26x12.5-15 M/T
  18. Advice of changing parking lamp/turn signal bulb
  19. Heads/cam might be fixed!!!
  20. EGT Guage readings...Whats normal..
  21. Where to buy parts for making ORP?
  22. Got my electric cutout!
  23. Where do stcok heads make no more flow? At what lift?
  24. hooker catback
  25. Magnaflow slashed or round...need feedback
  26. Typical range of oil temperature
  27. Jacking from the rear
  28. how can you tell if your rear is bent?
  29. Air foil question? just got it as a b-day gift
  30. AC on during defrost???
  31. 93 Z-28 fuel level gauge
  32. Difference in Dextron III Trans Fluid?
  33. Simple intake question...
  34. LT1 camaro Vs LS1 camaro (steering wheel) airbag
  35. best factory parts?
  36. Peeps w/ the 6spd conversion..How long did it take you???
  37. m6 having some difficulties
  38. Roller Rocker Questions Inside, someone please chime in!
  39. Pics of hidden shiftlight install w/in
  40. One last dowel pin grinding question...
  41. Electronic Cut-Outs Pro/Cons of Brands
  42. Order of operations...
  43. how to hook up a shift light??
  44. Tranny Problems
  45. SVO 30 lbs injectors
  46. sfc install paint
  47. Borla Y-Pipe 93-95 LT1 w/stock manifolds, WORTH IT?
  48. Car doesn't like to start after it rains
  49. vibrations above ~4k RPM
  50. I'm a moron! (transmition related)
  51. What to do next?
  52. SS airbox foam
  53. Stock Stift Points
  54. Can anyone recomend place to get subframe connectors welded in in SC?
  55. any estimates on price??
  56. anyone have one of these grilles?
  57. Xe 230/236
  58. Help! Had car towed today!
  59. Does everyone's car actually shift where you have it set to shift at?
  60. Cam + Emmisions
  61. SLP headers and EGR tube
  62. Whats the average HP?
  63. ABS light comes on under acceleration
  64. Plug related (I've searched) Quick! :-)
  65. i have cam installed, but i have no tuning for it.
  66. Q re: short stick noise fix
  67. Help on Choosing a POSI
  68. How often do you change your....
  69. Will I exceeded 100% injector duty cycle??
  70. Getting the intake right the first time...
  71. ANy tips on replacing the pinion seal?
  72. Changing fuel pump. Need How To
  73. How to go Faster?
  74. been adjusting RR's, but everytime lash comes back
  75. Dual exhaust with cut-outs?
  76. Underhood Crud
  77. Flowmaster VS. Hooker cat back.....
  78. Anybody know where to find aircraft switches?
  79. SES Light Help
  80. Brakes on 95-z
  81. Fuel Filter change questions?
  82. Few spark retard questions
  83. Now i am mad
  84. Need fast response to flexplate question
  85. cam/chip question
  86. Well, I think I need new injectors (XE 224/230 112 LSA)
  87. where to get rims
  88. need help clearing up minor issues on older 700R4 into a 93 Camaro...
  89. Polly Locks?
  90. can this be done
  91. Heads cam manifold etc.
  92. what is a floating valve?
  93. will 17x11s fit
  94. just installed manual fan switch
  95. How to stop heater hoses from leaking coolant?
  96. What kind of power difference?
  97. Uh O, I got...
  98. Need a part # for TA dash LT1
  99. Used LT1 Heads
  100. part number for knock module
  101. Are the Borg Warner and Tremec trannies different?????
  102. Spark Plug Wires (type)
  103. sound question - gut cat/high flow cat
  104. Help how do you remove the sensor off the injector
  105. Bodywork help needed: door rubbing
  106. I need to know a little about the 1997 Camaro SS
  107. What would you do first
  108. Need an Odd Part Number
  109. Headers or Exhaust
  110. just installed slp cai 1 prob!!!!
  111. Tazzo VPC?
  112. coolant leak?
  113. tips for buying used lt1
  114. X or H pipe for Hooker LT's
  115. paint job on my t/a?
  116. Hypertech 96 and 97 the same?
  117. Opti Help For Putting Back On Block
  118. cant spin the tires? 94 z
  119. Oh Shi! I dont think that was suppost to happen!!
  120. Hard start problem! HELP!
  121. TPIS cold air intake?
  122. cutout worth it with a slp 2otl exhaust?>>>
  123. will these polylocks work with gmpp 1.6 RRs?
  124. Power stumble after restarting????
  125. CSI/Meziere Elec Waterpump and Timing Chain ??
  126. hot cam kit with stock 1.5rr?
  127. Why does my RPM climb to 1700 when i start it????
  128. EGR valve question ASAP
  129. 94+ intake on a 93
  130. Shoebox, here is the update to the IAC problem...wanna take a look
  131. Crank Hub Help Needed!
  132. Quick injector question..
  133. maf smaller then slp cai????
  134. 4L60E shifting
  135. Mac Offroad Pipe???
  136. engine swap
  137. Time to rebuild the T-56
  138. looking for new rims or a place to chrome mine
  139. Dyno results are in!!!
  140. Thoughts on my Hooker Cat-back
  141. MAC muffler baffle loose...anyone else have same problems?
  142. 1 burnt plug wire, do I have to buy whole set?
  143. help wanted!!!
  144. Dyno Results & A/F Ratio
  145. Finally took a look at the opti and got some measurements.
  146. What's this clunking noise?
  147. Torque specs again...
  148. Cam Shaft Swap
  149. DIY: Gear swap?? Did you do it yourself??
  150. Everyone with SPEC problems in here!
  151. ??? for Spohn torque arm users
  152. ***Do I need to modify valve covers for 1.6 rr?***
  153. donkey dong
  154. To replace rack and pinion or not to replace...
  155. Intermittant electrical problem
  156. What tuneup items for new used Z?
  157. true duals?
  158. If I were to stumble across $8000-$9000
  159. LT1 Edit on basically stock LT1
  160. Tranny Problem
  161. Who sells the LS1 Brake setup?
  162. glaze on windshield
  163. Need part number for oil level sensor..
  164. clunk
  165. #2 Carrier Motives??
  166. just out of curiosity
  167. custom cai?
  168. Screw the Lt1 or not?
  169. converter size
  170. @WOT - Do O2 Sensors come into play ?
  171. '93 Guys with hypertech chip...take that POS out
  172. 3.73s and stall....How much can I expect it to knock off my 1/8th et?
  173. Will a 95 tranny work with a 97 engine?
  174. Racenet Intake Manifold
  175. Pulling T56 from T/A tomorrow, everyone give their 2 cents!!
  176. Rear end experts, need suggestions really badly!
  177. complete LT1 rebuild
  178. Fuel Line replacement
  179. O2 simulator?
  180. Head Gasket Question
  181. Odd location for a Coolant Leak
  182. Questions about some parts
  183. BMR K-member question
  184. Who has the best prices on McCleod Street Twins?
  185. new lt1 crate 383 in summit?
  186. Anybody use these wires?
  187. Cleaning T/B, need new gasket??
  188. What are 30# SVO injectors?
  189. first opti install tonight any tips
  190. AC compressor differences?
  191. When the A/C is ON, the car heats up a bit
  192. Stupid vortech elbow question.
  193. cc 306 and 1'6 rooler rockers
  194. Could my A4 be starting to go?
  195. Clutch pedal softer now
  196. 2 questions Brakes and muffler
  197. Is something wrong with my tranny?
  198. exhaust manifold leak, whats more common?
  199. Best guide for replacing opti?
  200. 4L60/700R4 Operating Temps?
  201. Torque Specs for bolts????
  202. Will a 98+ dash pad fit a 95 T/A?
  203. Need to decide on 4.10!!
  204. URGENT!!! Stuck while pulling tranny from bellhousing, NEED HELP!
  205. Timing chain questions
  206. Exhaust Option?
  207. 383 rotating assemblies
  208. Tire Size?
  209. will paint hold to rusting ceramic-coated headers?
  210. suspension build-up
  211. Is there adjustment that can be made in the rack?
  212. Possible transmission problem
  213. Horsepower
  214. need help with fuel pump install
  215. How do I get the Windshield Wipers off the arms?
  216. Help me understand my O2 readings and BLM's
  217. *PICS* Undercoating car with Por-15
  218. Can the Street Twin be rebuilt?
  219. how do you know if you have bad motor mounts? and how to install new ones?
  220. Hot cam in 94 with newer opti ?
  221. Ram Air or CAI?? Whats Better?
  222. can't get the car to cool off
  223. I can use stock rods/ pistons with a 383 crank right?
  224. high miss w/ cutout open!
  225. how much hp estimated?
  226. High flow cat--flanged or not flanged
  227. How do you remove injectors
  228. Driver side window moving around
  229. high mileage LT1
  230. Voltage boost for fuel pump?
  231. Need some help guys (Temperature Gauge)
  232. 94-97 opti-gurus
  233. Do headers and a cam justify a 52mm TB?
  234. Help! car won't shif into park
  235. what size (thread pitch & diameter) for AIR plugs?
  236. 93-94 and 95-97 Difference in Starters? Its showing 2 Diff Numbers
  237. What kind of clutch is this? (Twin Disc)
  238. How do I know if I have a MISS???
  239. Lubricating bushings, will it help the weird sound I get when going over bumps?
  240. Do those main/rod bearings fit to LT1 engine?
  241. need help in replacing ac hard line
  242. MAF Translator
  243. Weird problem on 95Z, ignition switch?? Help plz
  244. Airbag Question
  245. lt1 intake only good to 6000rpm
  246. opinions on 1/4 ets
  247. M6 question
  248. Huge power difference between open loop and closed loop?
  249. Desensitizing Knock Sensor?
  250. Head gaskets
