- lt4 question
- A4 to M6 SWAP ???
- hotcam
- Smoke Coming Out Of New Value Cover Breather!
- True Duel exhaust pics inside
- How much hp with rr
- leaky oil filter
- How do I get 330-350rwhp cheap?? Cam, headers??
- What do you think about these LCAs?
- How about this?
- Valve Lash Adjustment
- Foot pounds to inch pounds of torque help??
- Best way to store crank?
- headlights are possesed
- SLP LM's ?
- fuel injector harness clips? Can they be bought separately?
- Can I ditch my power windows?
- What should I do first? 1.6 RRs or the MAC Headers, I have them both here
- K&n Fipk
- Transmission Cooler Install for M6 to A4
- Mechanics In Decatur Illinois
- Mac Torque Arm source?
- smoke after cam install
- Two different map sensors listed for '97 LT1...??
- Does this wear look normal? (PIC)
- can i do low 12's
- Looking for pic of stock clutch vs spec...
- SES Light
- G12 327 what does that mean?
- Fuel Filter
- Slp Totl
- Need part #s pleaseeeee
- Will this work???
- Will Hooker LT's clear BMR K-member?
- Best Clutch for mid-high 11s
- Raptor2x 2800 PATC(box says Midwest)ANYGOOD?
- clutch
- Lack Starting power...?????
- Intake Heatsink? CPU Style
- How Do I Remove Dash about Gauges?
- Heads/cam problems Freescan results
- What would it take for mid 12's
- What is it worth - 94 TA?
- What does the new Hemi Dodge run?
- Is 14.0 possible on street tires?
- LT1 Edit or Autotap or??? OBDII
- First time at track, very pleased
- Throttle body Differences
- quick question
- Starter Solenoid...where can I get one?
- 4-bolt main
- 383 stroker, low output, need suggestions
- Bad weekend :(
- slp cai
- door wiring harness
- Header Studs ? How tight?
- How fast should my modified car go
- Annoying
- if i just added.....what kinda gains am i lookin at?
- Clutch Price Rip Off?
- does porting ur intake do any thing
- Would I be able to take my buddies '99 trans am?
- fuel pump going, what to replace it with and from where.
- FLP headers - Rattle?
- If you run rich, can that ruin performance?
- How often should the Fuel Filter be changed?
- Gas: 87 vs 89 vs 92
- Second time this code has appeared!
- Is the LT1 Hot cam kit the same thing as LT4 hot cam kit?
- my chances against a 2003 mustang gt?
- Automatic gears getting mixed up
- BMR Drag-Race X-treme Duty Sway-Bar on the Street?
- How & where to get a LT1 shortblock (without cam or timing chain) for under $2,000 ?
- Cat Removal?
- What mod should I do next
- Any drawbacks from removing AC system?
- Annoying Noise! (Shoebox??)
- maf mod, is it worth it?
- LT1 intake a 2-peice intake?
- Made In Mexico.......
- Heads gasket
- Rear main seal, hard?
- stumble what do you think
- just dynoed car- questions
- How hard is it to?
- Low Trac Light
- Engine installation
- #2 Carrier Gears??
- Power Programmer Plus
- May have a fuel problem, can someone help me on this one?
- passanger side plug wires?
- What are the fastest 60' times you've gotten on stock radials?
- Electrical problem! Please help
- another EXHAUST question
- 93 icm compared to 94-97 (shoebox)
- 1le intake elbow
- Will a 4th gen exh. fit a 3rd gen
- bolt torque on belt tensioner
- URGENT: RE: JetHot header AIR fittings
- Solid roller lifter question
- Some feedback please
- Just installed the slp LM today have one ?
- Just ordered...
- Little help please, starting issues
- Tan Leather
- Are the AIR fittings different from 95-96?
- Cam experts inside (396 Solid Roller)!
- Whats the cheapest way for me to run 13.0?
- Drive shaft weight???
- Loud pop and car died going down throughway.
- Whats the cheapest way to run 13.0s
- gear change
- Stall/Rockers or stall/gears?
- thermostat gasket?
- any loss with leaving cutouts closed?
- Dumb auto tranny question
- pulled intake cant see obvious bad lifter
- Stupid Freaking Turn Signal
- Break-up at 6000rpm! Is it MSD BTM TIME?
- Lt1 TB bypass and coolant line problem INfo needed
- Cam install Help Please!
- Where can I get 2" / 1.56" valves?
- JBA headers
- trick to installing a stock or 1LE intake elbow
- What happened to my power?
- finally broke 14's...
- Less Power w/ Cutout? and Exhaust Question
- best mufflers for dual exaust setup
- loss of power
- what clutch
- Who has used pcmforless.com?
- Oil leak
- best cut out size for stock 94z (getting hooker soon though!
- Not too impressed with pcm4less
- anyone have bigger injectors for the 224 xe?
- cheapest 15x10 rims
- Cheapest place to get ac delco 02 sensor online?
- low oil sensor
- what would happen
- Long Tubes= loss of torq?
- 2000 Corevette Help
- Suspension suggestions??
- DTC 65 - oxygen sensor location
- is snapping the rear a REAL concern with the xe 230/236?
- Installed Headers, Now bad idle/ low RPM Stumble
- Fuel Injector Install
- m6 transmission noises..........wtf
- fuel ???
- homeade cai?
- Argument over what MPH i should TRAP??
- What is it?
- I haven't talked to anyone who hasnt broke their MAP harness!
- brand new AC Delco part went bad ... can i return it to any GM dealer?
- For those who need programming for their 93 LT1....
- PoPiNg at 80
- Advantages of using LT1 Edit on an OBD2 VS and OBD1?
- Hot cam and emissions/smog test
- oh my god... im about to jump off a bridge
- camshaft help please!
- please help me fix my A/C...I'm this |...| close
- Gasoline smell at startup??
- t56 changeover
- Funny Rev When you stomp on it
- 93 Z28 Headers
- Oil PSI
- What a day
- 4L60E taking a dump??
- Are all Chevy 4L60E interchangeable???
- Light show under hood
- Oil Pressure
- Part #'s for coil and header gaskets
- Friend just asked to go legally road race
- Stopping SLP Shorty header leak
- Tuning
- i'm confused, suspension alignment q's
- auto to six-speed
- Tranny/Clutch Problems
- Help me hit 12s please...
- HELP. Loud banging and bad vibration this morning
- Is the J 37043 Parking Brake Cable Release Tool
- how hard to take off Heads??
- PN for coolant temp sensor
- broken rocker arm stud
- looking for sun visor's without mirrors?
- What sort of power should I make?
- What happened when your opti died?
- How much of an increase with a valve job??
- Top end cutting out
- New Corsa tip design!
- Oil Cooler???
- Grinding down dowel pin.
- How does someone do a compression check on their car?
- MAF screens???
- LT4 gaskets reusable?
- Cam install
- Folks with roller rockers, inside please...
- DANGEROUS? i think its the wheel bearing...
- What stall?
- Anyone know the part number or the correct part for the rear main sea?
- Which 230/236 cam for a 383?
- Ok this is my problem... PLEASE tell me its the solenoid...
- no rev-limiter?
- Switchign from D to N while driving.
- where can I get my TC
- I only need a 400 balancer and my stock flexplate for 383 balance right?
- What size injectors for 383?
- A/C compressor
- got new clutch ,but no instructions
- AC question
- Is this clutch ok?
- Price of stock clutch set up
- Appearance Question
- please help!!!
- 94 auto. speed limiter and 110 mph speedo - BOO!!
- some opinions
- Jet Hot Cleaning?????
- 93 rear end on 94, ok???
- Part# for MSD wire change?
- 95 Z28 help needed
- rear end gear switch
- +1, +2, +3, +4 ?????????
- Engine builders need help w\ piston to valve clearance
- ? about stock heads on a 97z
- Spark Goru's
- autozone (melling) pushrods hardened?
- are my leather seats screwed
- adjusting valves with bigger than stock cam?
- Any aftermarket parts available for 96 chevy caprice?
- Noob question, stall speed?
- 383/396 owners...how does your combo run?
- trans temp ?
- more oil leaks rear main?
- valve spring instal question?
- A question about 3.73:1
- part numbers
- ***Need help with timing chain***
- What size injectors should I use for my 383?
- ball park figure
- part number question
- failed emissions - help
- Just got a Vig. got a few questions..Vig. Users inside...
- before i change my fuel pump....
- Engine builders piston to valve clearance HELP..
- Torque spec for oil pressure sending unit fitting?
- What is the part # for cloyes true double timing chain?
- cam question which one to go with
- SES - P1361 Help!
- What does this pulley drive?
- car wont start when it's hot?
- What STR are you running?
