  1. Will removing airpump throw ses?
  2. Just had my Nittos installed, thoughts within...
  3. Head work quote I got today.
  4. Electric water pump wiring question
  5. Need lifter retainer part number
  6. Starts and dies after sitting for a few minutes, 2nd try fires right up
  7. Edelbrock Tubular Headers?
  8. anybody used the jet IAT relocator?
  9. whats the best pulley(s) set?
  10. Where to mount gauges in Camaro interior?
  11. bored TB's...any imput?
  12. open/closed loop question
  13. Code 67.....
  14. No Dampner on Underdrive Crank Pulley?
  15. I know this is a dumb question but could someone help me out here?
  16. CC306 is in!!
  17. Throwin a code (26) on my '93
  18. 1LE Intake Tube has been installed
  19. My car backfires at low rpms!
  20. need question answered about window and headlight motors
  21. ls1 superiority?
  22. Camaro waterpump different from Corvette waterpump???
  23. Fan Switch
  24. 58mm TB is not too big!
  25. can I test a cat (cloged or not) off the car-found one in garage
  26. "Turning" your exhaust into a catback
  27. throttle body sensor mod
  28. I think I found my heads!
  29. Need 304 sound file
  30. what size pipes to replace cats?
  31. m6 from a 93
  32. Just got a cutout, is this normal?
  33. Quick...need advice
  34. 4"-connector K&N filter for CAI location
  35. Dip Sticks
  36. fuel pump...
  37. Coolant in oil again!!!
  38. Funny things happen when you unplug the MAF
  39. what oil should i use
  40. SPEC clutch install help...
  41. Advice... help?
  42. took some pics
  43. change a4 to m6
  44. Stupid question, how to unplug the oil leve sensor?
  45. LS1 vs. LT1 spark plug wires, very important!
  46. Pulling oil pan!!!
  47. That's all she wrote!
  48. Baer rear brake install?
  49. Lean in Bank 2
  50. Belt squeek/Chirp
  51. Clutch Fluid?? Flush??
  52. Removed egr , now car is having trouble starting
  53. th400 conversion
  54. bleeding brakes??
  55. has annyone put dual cat exausht on a single cat car???
  56. My car died going 35mph in 3rd. absolutely no warning
  57. FUEL FILTER from JEGS, wrong one?
  58. just got back from the dyno!!
  59. need people w/ a 94 or 95 z28 m6 and 3.42s
  60. Any way to adjust idle?
  61. Advice For Mods Needed
  62. DEI HT Silicone Coating for headers
  63. Are Comp r lifters a must when swapping to an aftermarket cam?
  64. State Vehicle Inspections - help
  65. EGR Code Help
  66. Anybody got a good scan file I see to compare my freescan log?
  67. im not sure
  68. seat belt
  69. How to make first gear selectable A4
  70. 95' TA... Lack of power and backfiring
  71. Disabled VATS, now can I...
  72. Don't laugh........SNEAKY PETE
  73. Getting heads now what cam
  74. Are lightweight driveshafts worth the $
  75. worse gas mileage after programming
  76. 93 keyless entry
  77. LT1 PLug Wire Length
  78. what's your oil pressure at???
  79. squeek comming from the hood?
  80. How to inspect lifters, have car appart need help
  81. Weird Valvetrain problem
  82. Car dies while driving and hard to start...
  83. EGR valve removal, how to?
  84. Use of NPT Fittings instead of metal lines for head coolant?
  85. Z06 85mm MAF worth it?
  86. Stock Rockers studs and guideplates
  87. reducing knock sensitivity on a 93
  88. slp cai
  89. Need to find a place that sells the center console gauge pod...
  90. part numbers
  91. which mod to choose
  92. Rag joint eliminator kit installed
  93. Slp Cai...
  94. Best shock to run with Sportlines?
  95. Transmission 700R4
  96. where can i get a line lock
  97. Chirp when you let off of acceleration?
  98. build too loud 3" true dual exaust
  99. Super ram on Lt1
  100. Cam is in....
  101. which cam???
  102. Diagnostic test first or just replace optispark???
  103. does anyone here know anything about true duals and x pipe please help
  104. oil pan
  105. guys with 3.23 want 3.73 look first
  106. TCS removal?
  107. gasoline
  108. Headers were installed last week and now ONE plug wire is arching.... H E L P
  109. 306 or Custom Cam?
  110. Size injectors for a N/A 396
  111. Anothe Gas Gauge Question
  112. car starts fine 5 times in 4 hours....suddenly won't?
  113. push starting
  114. More LT1 products available
  115. Is this necessary??
  116. Cleaning your LT1
  117. 60' Times ?? please read
  118. Diagnosis Murder.
  119. Low Coolant Light still on!! What Now?
  120. how in the x#$@ do you get the tranny back in with the street twin????????
  121. LS1 Speed Inc is top notch!
  122. putting on new pads
  123. Will all the Gen1 1 piece rear main cranks fit the LT1?
  124. got some $$$, what should i do?? (cam people inside)
  125. Cleaning the injectors
  126. Need some cheap head porting. Who can do it?
  127. Weld draglite
  128. flow numbers on new edelbrock heads??
  129. dyno today..tell me what you think
  130. where to get one or two lug nuts
  131. Clutch question
  132. What is this????
  133. What is you normal operating voltage?
  134. car idles high when coasting to a stop
  135. T/A cover stud broke..where to get one?
  136. 1.5 or 1.6 RR's
  137. what is this
  138. OK, Changed my window motor, now have a slight bang. Please help with any suggestion
  139. who is this
  140. How can i balance a 383? Also will stock oil pan work?
  141. tranny only shift under 30% throttle, WTF??
  142. Can't get fuel line disconnected.
  143. Homemade CAI
  144. Pic of my Custom CAI
  145. 97 M6 dynoed today!!
  146. hesitation/stumbling from idle
  147. Mcleod street twin PP vs. LT4 PP
  148. How did you plug the air tube on jet hot LT's
  149. Omg
  150. people with an EGT gauge
  151. 315/35-17's?
  152. Does spec clutch cause "jolting" starts?
  153. Do Mac headers come with hardware?
  154. aluminum paneling after stripping interior?
  155. To all LT4 nay sayer....
  156. Is a 160 degree thermostat worth it
  157. mac headers
  158. Impala head gasket number?
  159. cure?
  160. New hooker LT ypipe in summit! any info?
  161. Wont go into 3rd gear without grinding and popping out! how much to fix?
  162. Whats the bets Cam for 94 z28
  163. Do I really need to mark where old shock is before taking it out?
  164. ABS inop light
  165. coolant temp. guage
  166. pulleys
  167. Rear End Gear Question?
  168. Need help quick!
  169. SLP fan switch worth the money?
  170. see if anyone can diagnose this!!
  171. Big problem with buddy's 95 T/A M6, will only shift into fourth!
  172. Optispark question
  173. Aftermarket ignition control modules?
  174. Tranny slipping??????
  175. Motive 4.10's whine only on deceleration! why?
  176. alternator bracket! where to buy i need it fast??
  177. trans probelm???
  178. Bearings on driveshaft too big?
  179. New belt with AC delete?
  180. Radiator looser now that AC is gone.
  181. How long before starting motor after intake install?
  182. another opti question
  183. H-bearings vs. Regular Clevite 77 bearings...street/strip...
  184. Dash conversion idiot lights?????
  185. Pics of Magnaflow...
  186. Brake fluid in the clutch reservoir, right?
  187. Questions on building a 10 bolt rearend
  188. Where can I pull power for gauge Lighting????
  189. Synchro?!?!?
  190. Fuel Injector????
  191. any advantages of having 2:73 gear ratio
  192. Moroso Oil Pan and Low oil light on
  193. LT4 Hotcam Install Page
  194. Pacesetter Headers
  195. need some help tracking down a problem
  196. Lt's w/ enough room for a cat
  197. Custom Y Pipe Cost??!!!
  198. Aftermarket heads?
  199. First time out this year, analyze my "Best" run please.
  200. 4L60E to a 700R4 swap have some questions?
  201. Fixed my 1500 rpm stumble
  202. tranny oil
  203. my car is acting weird, i dont know why
  204. any good performance shops in toronto?
  205. What PSI should I run my Nittos at tomorrow???
  206. SLP resonator exhaust?
  207. How do i have it to.....
  208. MPH down with Vig & 3.23's
  209. Fog Lamp Replacements....
  210. Plugged cat or ???????
  211. 160 Thermo guys...What temp do you run at?
  212. Mark Williams???
  213. Eaton Posi unit swap
  214. Need part number for...
  215. where to get rocker arm nuts (polylocks)?
  216. URGENT: 97+dash in 93 question
  217. New TB
  218. Slight tick from new CC pro-magnum rockers. Anything to worry about?
  219. Homemade CAI, Again
  220. Wiper problem
  221. Cheap Mods
  222. Cam opinions??
  223. What tires & size should I run?
  224. Holy bad 1/4 mile times Batman!
  225. Relay for keyless entry
  226. CC promagnum rockers and stock valve covers
  227. Everybody With 93/94 Hot Cam Kit- In Here! Help!!!!!
  228. LT-1 woes
  229. SDI or LTCC...need opinoins
  230. whats that smell?
  231. Will there be a noticeable difference!
  232. Power Locks stop working. Help Please
  233. Manual Fan Switch for 93
  234. lock up vs. non-lock up stall
  235. 12 bolt owners
  236. Spec stage II or III?
  237. Opti-Spark Question
  238. performance shift button in a 94 z
  239. Heating up and puking Coolant???
  240. Brakes
  241. MAP problem?
  242. XE 224/230 questions: There's 3 of them? etc.
  243. Car smells very rich after egr removal
  244. FINALLY got hotcam installed!!! Few questions though....
  245. Need Help... Which side of head gasket is up?
  246. SLP CAI, what size replacment filters? K&N?
  247. I drove her with no Y-pipe!!!!
  248. Is it possible for my temp gauge to be off?
  249. Replacing WP + Opti: Quick check on the parts list please...
  250. Come in for Gears!
