  1. What is the duration when using 1.6 RR's on the XE 224/230 and 230/236?
  2. LT4 Intake Part # ????
  3. What is the strongest Pinion Bearing?
  4. Help me cleanup / 're-decorate' my engine bay...
  5. Need Full LT1 Gasket Set?
  6. How's my custom CAI look?
  7. Why the hell does my car jerk at 120???
  8. Best price on Hooker Catback??
  9. engine upgrade
  10. Tach wire??? for shift light???
  11. Should I update my ignition?
  12. Procedures/Parts needed for axel swap
  13. Going to change OPTI and lifters tomorrow, need some advice
  14. crank hub bolt stuck in crank
  15. MACs are here!! Single cat ones for my 96
  16. I have searched and looked....need somemore help.
  17. HELP, Car wont Start, Backfires, Smoke out the Intake
  18. Crane 1.6 Rollers ROckers on stock LT1???
  19. Dual Exhaust Pictures
  20. Roller Rockers
  21. Need some help with brakes
  22. Valve Covers
  23. CSI electric waterpump keeps blowing fuse???
  24. Planning on changing Tranny fluid... few Oil questions..
  25. Throttle Body bolt Thread/size?
  26. 383 stroker build up suggestions
  27. Clicking after MAC header install....
  28. performance chip problem
  29. Proform Valve Covers for 97 Z28
  30. 93' Hooker Shorty's
  31. Slippage after tranny rebuild? Help
  32. Exhaust Question
  33. Crane VS. LT4 rockers
  34. Video of my 224/230 112 - Hooker LT's - Idle/WOT
  35. OBDII to OBDI?
  36. Those that consider themselves a cam "guru" please come on in for a discussion...
  37. csi waterpump
  38. are RR's worth it?
  39. LT1 Scanmaster Users In Here Please
  40. Line Lock & "Brake" light on Dash on again.
  41. Unhooking AIR??????
  42. t56 grinds goin into reverse just swaped from auto
  43. custom exhaust question
  44. Crankshaft Position Sensor Help!!!
  45. Srt4
  46. electric cutouts
  47. SES Light when in 6th gear for 30 minutes or more
  48. Alright Everyone They're almost done.... Custom LED/Clear Bird Tails
  49. 3600 Stall killing me at the traps.
  50. Help me pick a Cam for this set up.
  51. shift bumpers
  52. No More Cats
  53. MAC header users (and other ?)
  54. Felpro
  55. Magnaflow for cheap!!!
  56. Is my starter suppossed to be like this?
  57. Difference in single pattern and dual pattern cams?
  58. Will I gain anything?
  59. other oil thread reminded me.
  60. What is the difference between the LT1 hotcam and LT4 hotcam
  61. Burning Metal Smell???
  62. Aluminum flywheel?
  63. So what are the latest, greatest, and most popular LT1 cams today?
  64. Any problems with roller rockers and stock springs?
  65. where can i buy the conversion?
  66. SD to MAF conversion
  67. i have 1500 to port my heads, what else should i do?
  68. lt1forum.com
  69. Another XE Cam question...
  70. name that connector
  71. SLP 2OTL custom idea
  72. Z05 Brake Conversion for rear brakes - possible?
  73. keyless entry FCC #
  74. Anyone else shred belts?
  75. Are all M6's the same?
  76. Whats this?? se pic
  77. Did anyone make it so their A4 will hold 1st gear?
  78. Wiper motor replacement/tools?
  79. SLP Loudmouth or gmmg
  80. Belt keeps getting chewed up
  81. 1 LE 4th Gen people, I need your help
  82. Spark Plug Wires
  83. Quiet Exhaust?
  84. ls1 brakes on moser rear
  85. most insane cam you would consider "streetable"
  86. Making the Wheels Wider!
  87. Washer fluid squarter thing
  88. Getting Spark Retard. Bad Knock Sensor?
  89. Clutch Problem
  90. t56 hard to shift only when running HELP!!
  91. AIR/FUEL ratio gauge helps and tips maybe inside ~~~~>
  92. 4 bolt mains?
  93. Emissions in the state of georgia... Some help plz
  94. drivable cam with A4
  95. Mods
  96. What hole in the back of the opti should I put the cam dowel pin in?
  97. I know I'm gonna kick myself when i find out
  98. Ok guys, i really need your help/advice on this one...
  99. Shoulda listened
  100. what would a procharger 3 core intercooled go 4
  101. What are you guys using for lifters these days...
  102. crankshaft question
  103. FLP headers on a 93?
  104. lt1 ls1 differences
  105. What is wrong with my wipers
  106. where to get exhaust
  107. Best spring/shock combo for a street/strip car?
  108. 700r4
  109. Diagrams, dimensions, or drawings...
  110. 30lb's or 37lb's
  111. Alternator Making a funny noise?
  112. window/door switch question
  113. Machine work required?
  114. intake oil leak question...
  115. BMR, great customer service!
  116. 4.56 too high?
  117. Starting problem. Need advise.
  118. Electric Whirring Noise?
  119. Heads/Cam A4 vs M6 Cammed Car
  120. First LT1 with experimental muffler :)
  121. Who sells stock length high flow y pipe?
  122. Overheating Problem
  123. Auburn rears
  124. 95 Z28 Wiring Problems ... Anyone with Pictures ?
  125. Tire help
  126. Update - Engine Rebuild
  127. injector question??
  128. 16x8 2002 firebird wheels don't fit 96 Z28? WTF?
  129. Stupid Question (Wipers)
  130. 1le or not?
  131. Can I launch any better with???
  132. I have noticed that ARP head bolts have a bevelled side on their washers!
  133. On a 396 engine, where do you put the timing mark on the harmonic balancer?
  134. T-top conversion
  135. reverse lockout solenoid
  136. Fuel Flow ?
  137. Optispark
  138. Need Help Removing Intake ASAP
  139. gm torqe conv.??????
  140. Wrong Pump???
  141. car wont start after radiator install..
  142. Ive been tricked. quick question.
  143. True Dual w/cats
  144. Brake Issues
  145. Torque specs for Pro 5.0 shifter bolts?
  146. cigarette lighter doesnt work.
  147. High volume oil pump
  148. white faces gauges.. 150 over 110?
  149. Why am I having clearancing issues with the CSI waterpump???
  150. Heads on Ebay:BS?
  151. Car won't go over 112
  152. Will Crane Gold 1.6 rr work with XE 224/230 cam
  153. Porting the intake
  154. can this cause detonation?
  155. TB bypass kit
  156. Question about true duals...
  157. Does rear end differential cover have gasket underneath?
  158. Last minute tips, advice, etc before starting new motor...
  159. blac3rdgen complete gasket set
  160. p/n for trans cooler line on 95Z
  161. Who here passed the sniffer test with no cats?
  162. trouble code P1416
  163. denting valve covers for alternator
  164. my wounded stock rear finally broke teeth...
  165. Combination Motorsports stage 1/1X....
  166. bottle brackets
  167. 1LE Intake Elbow
  168. How Much Is The Z Worth
  169. weird crank
  170. What would cause tranny to not shift into OD automatically, but will manually
  171. $400 to spend, help me go broke
  172. Bearing on the spider of the driveshaft...
  173. What do you guys think of these mods??
  174. Transmission mount
  175. Are the Trans Am's really under rated?
  176. headers
  177. Will a high performance clutch last???
  178. Pulleys or 4.10s?
  179. need some advice on rebuild of lt1/a4le80 built
  180. Anyone have problems putting on timing chain?
  181. about to rebuild lt-1
  182. What tools needed to remove seats
  183. opened my optispark
  184. tuning problems....
  185. SLP's take off tires
  186. injector size
  187. 285 horse
  188. AFR 190cc heads ported
  189. To anyone that has changed window motor
  190. bare block weight
  191. How is the SLP 2400 Stall converter?
  192. what could be wrong with my car?
  193. Broken poly trans mount?
  194. Best way to fix front dash?
  195. how to "gut" the cat?
  196. PLEASE help, car just shut off...
  197. Rev Limit/shift point suggestions for my setup
  198. Where can I get a 2OTL silencer cone?
  199. 1st gear grind.. what could it be?
  200. Low coolant light.
  201. 4.10 Question!
  202. getting headers on friday
  203. OK, my clutch is toast, what should I buy??
  204. Retard Roomates lol
  205. What are the differences between these two LCA's?
  206. locking or not locking (axel) that is the question.....
  207. How often do you do Brakes?
  208. Which are the better plugs?
  209. Cheapest place for a set of lifters??
  210. pcm service number
  211. 2 Questions, why is my keyless remote range so limited? and.....
  212. SLP SHORTY HEADER problem
  213. plug wire locations affectng performance?
  214. New....
  215. Rocker stud diameter question????
  216. port quest.
  217. Anyone with Eibach springs, HELP. Having probs with my struts!
  218. what headers
  219. Popping out of 1st gear
  220. quick question: CFM?
  221. Know any good tricks to get a rotor off?
  222. what trans fluid do you guys recommend
  223. T_top conversion ? anybody?
  224. Car leaning
  225. are the 700r4 and 4l60e the same thing?
  226. tire pressure??
  227. How crappy are BBK shoty headers?
  228. Spayed Main Caps- Which ones?
  229. All my problems are fixed after cam install! Opti...
  230. converter/trans question
  231. Auto Trans Fluid in an M6
  232. dumb question,are salad shooters aluminum??
  233. How long are coated Hooker long tubes lasting?
  234. Grinding when engaging clutch...
  235. Anyone have Part #s For LS1 brake Conv.
  236. Cam recommendation
  237. Would like to do a Heads and Cam combo write up, everyone that did it come with in!!
  238. EGR deleted, ok remove solenoid & vac. lines?
  239. Portland area mechanics
  240. self aligning roller rockers?
  241. Does anyone know what kind of Ypipe this is ?
  242. broken water pump or just a gasket?
  243. Spark plugs backing themselves out?
  244. brakes from 94 vette
  245. keyless entry
  246. Rebuild a water pump?
  247. No Power TO Radio 94 TA Lt1
  248. Pushrod Length?
  249. Pushrod length question
  250. are there any gains fro swaping stock injectors for 24#'s?
