  1. AFR 195's(street port) vs fully ported stockers???
  2. miss, miss, miss
  3. LS1 maf on a LT1 car???
  4. Launching on an M
  5. BRAKE light on dash
  6. How much trans fluid with converter change?
  7. Brake Job
  8. new z28 owner
  9. Tranny Question
  10. SLP Headers
  11. power loss and change in exhaust note
  12. Opinions on Tires??
  13. Looking for Sylvania GUIDE glass housings! cant find them
  14. cam and intake????
  15. Opinions on SLP Shorties
  16. Computer Programming for LT-1
  17. high flow exhaust on a budget
  18. Fans on constantly after programming
  19. gmmg
  20. Going auto and doing cam!!!!similar setups, what r u running?
  21. help!!!!
  22. New Z28 owner needs help!!
  23. Tire Size Question
  24. STB opinions
  25. Took my 95 T/A-a4 to Ennis (1/4mile), results inside.
  26. stock rear end strong enough?
  27. Mods for a LT1
  28. I dont have traction control, what can I do?
  29. Alternator header bolt???
  30. How tight for header bolts?
  31. Oil pump drive part number??
  32. Cam guys: what size injectors are you using?
  33. BMR relocation brackets???
  34. Fans still won't turn on!
  35. Wiper Return
  36. Stuck Valvesprings
  37. LT4 Cam Installation Question
  38. how much power will this give me?
  39. Borla bolts backing out?
  40. Diagnose this!
  41. Which Posi to Go with??
  42. Car Won't Start
  43. Has anyone used the competion engineering 3 way adjustable drag shocks?
  44. which plug wires? taylor or msd?
  45. Newly rebuilt engine, open long tubes possible to burn an exhaust valve
  46. What mods should I start with???
  47. Thermostat???
  48. PowerProgrammer and other Programming for LT1s???
  49. 383 Rotatin assembly question.
  50. Which Opti with new cam?
  51. Oil pressure severely high
  52. Couple of questions
  53. Question for people with TR OVC Wire kit
  54. Anyone know about Callaway Honker Intakes
  55. Emmisions Legal Headers for a '95
  56. Locktight or antiseize for header bolts..
  57. Jet hot lt s on the way
  58. PROBLEM - cam intalled, now......
  59. '96 M6 hard to start...
  60. 93's with 230/236 cam INSIDE.
  61. SES light on: MAF low voltage (what to do)
  62. What size are the stop bolts on a Pro5.0??
  63. broken electric water pump
  64. Will LS1 driveshaft work on at LT1 car?
  65. got whooped
  66. Radiator Plug F-ed up
  67. whats wrong with my brakes?
  68. Lowered w/Eibach Pro Kit - Alignment ?
  69. noob here, need help w/ optispark
  70. OPTI..94 LT1 Block 97 Harness and Computer. Plug and Play? LT1 Gerus inside...
  71. Stock LT1 Heads. Iron or Aluminum??
  72. Headers & Egr/air Question
  73. Gains from bigger injectors? SVO 30#?
  74. Update of LT1 FAQ- need all your input, install guides and links
  75. Monitoring devices
  76. 6spd conversation or get rebuilt A4???
  77. Power window!
  78. When should i repack my wheel bearings?
  79. is this normal?
  80. Over the valve Cover Plug wire? - Pics?
  81. Quick Help! Need Fuel Pump!
  82. Rear Brake ?
  83. 2 Release bearings in 10k miles?
  84. Rebuild questions
  85. Engine overheating and coolant not circulating but water pump looks fine?
  86. Rebuilding Transmission. Durability Questions.
  87. What CAI is the best?
  88. Need advice ASAP about heat shields on stock mnaifolds
  89. New Tires!!
  90. which sounds better?
  91. cc305 good for nitrous?
  92. results from header install...... come on in....
  93. part numbers again, coolant temperature sensor and low coolant sensor
  94. Need opinions on cutouts.
  95. Qtp Electronic Cutout...
  96. Idea how not to get opti wet when rr w/p
  97. purchasing from slp?
  98. Tilt Steering Column/ REplace and Turn Switch??
  99. Torque Thrust 2 Wheels
  100. quick ways to make power?
  101. Please help...PCM coolant temp sensor reads different from gauge
  102. Im going to have to cut my dipstick...
  103. 9.68 video in my 6speed is up on BMR's site!!!
  104. T&r?
  105. Best spark plugs and wires?
  106. Can fuel pressure be adjusted with programing???
  107. people with transgo shift kit
  108. glennxx1
  109. 1994 headers in a 1993 Z
  110. Is it bad to run without the maf pluged in
  111. HPPIII question
  112. OH SWEET JESUS HELP ME!!! my a4 is now an a2!!!
  113. Help!!!! A4 Is Now A2
  114. idle
  115. turn signal stopped working
  116. Solid roller cam specs
  117. Who knows ABS?
  118. how good is an eaton posi???
  119. Question about factory Springs
  120. My fuel pump...again!!!
  121. 600 dollars
  122. Please help with brake problems
  123. Ever hear of coolant in the oil because of a leaking head bolt?
  124. Best Porting for the $$$$
  125. Failed emisions: O2 sensor
  126. Finally Got Pics Of My Car!!!!
  127. Killed my tranny this weekend. 3rd & 4th gone
  128. BBK Throttlebody Question
  129. Clutch
  130. HP Vs. Break-in Miles **LT1 & LT4**
  131. Popping when rev engine
  132. Can you reuse head gaskets if you do this?
  133. Thermostat
  134. A4 power loss HELP NEEDED
  135. Stock CD vs. Bose CD: Did search, still have quick question
  136. cloth seat, replacement??
  137. Intake questions...
  138. Dyno Predictions?
  139. Okay, I give up .... Trans Dip Tube
  140. Is the ABS stuff the same on a 02 rear as a 94
  141. CAI or Ram Air???
  142. Acceleration Woes
  143. dead msd
  144. Has anyone kept the stock exh. tips with aftermarket exh?
  145. how to test the fuel pump ?
  146. How good is xe 230/236
  147. can you put an LS1 in a 93-97 fbody and vice versa?
  148. All the hoses for cooling
  149. Please help me!!! i need info!!!
  150. Skipping Gears
  151. Who sells LT1 bottom ends?
  152. Help emergency car wont start
  153. Running LS1 O2 sensors on LT1, will it work if you splice on the LT1 connectors?
  154. Solid roller setup
  155. Quick question timing ? from new guy.
  156. this winters mods finally done
  157. 95' Computer
  158. valve cover made by profrom
  159. shift light help
  160. non Z rated tires.....
  161. LT1 Catback/Muffler
  162. 93-97 brakes for moser 12 bolt
  163. SLP loudmouth or Flowmasters?
  164. e-brake questions..
  165. Best place to find exhaust clips??
  166. Doing DMS springs, follow the haynes way or someone else's?
  167. Problem after header install
  168. Damned Muffler...
  169. bad gas = white smoke
  170. distributor from postive of battery,can i use it?thanks
  171. Daily Stupid Question
  172. Brake light stays lit on dash...
  173. Need firebird headlight help...
  174. Throttle body idle screw question
  175. Do I need alignment after springs swap?
  176. 36# inj. on stock motor w/ stock programing?
  177. Fuel pump not turning on!
  178. Quick question on where to put boosta pump.
  179. 2 Release bearings in 10K miles?
  180. Evolution fast?
  181. KR at idle?
  182. Catco Catalytic Converter?
  183. Dielectric Grease on opti ends?
  184. About removing cylinder heads
  185. What are some good pistons for nitrous?
  186. LS1 rear in LT1 car?
  187. Please recomend a good cam for my combo.
  188. Goodyear hi-miler hose kit for 94?
  189. 9 degrees of knock from t56, need to disable the knck sensor for a while
  190. new springs?? or what?
  191. Feedback on JBA headers?
  192. Solid roller valvespring recommendations?
  193. Is it ok for my cooling fan to be on all times?
  194. Shift kit install
  195. ECU Programming
  196. Max effort street strip Hydraulic Roller?
  197. airfoil has nothing to screw into?
  198. which hose goes where?!?!
  199. Wiggle the connector and my car starts ?
  200. Tuning Program questions
  201. Axel part number
  202. Which Clutch to Buy?
  203. ? for those with Strange 12 bolts.
  204. Installing an AutoMeter A/F ratio gauge. which wire to connect to 0xygen sensor?
  205. N20 and Hotcam
  206. why is hub such a PAIN to get back on?!?!?
  207. Eaton or Zexel
  208. theft deterant relay
  209. does anyone know the part# for the corvette cover pins?
  210. bmr suspention or hooker catback?
  211. will the Richomond siix speed fit on a lt1 car?
  212. Can I remove the heads without taking the intake off?
  213. My 95 TA has six speakers??
  214. st count, o2s, and duty cycle all messed up.
  215. Shift Points and A4 Tuning
  216. LT1 heads and cam parts info
  217. M6 is making noise, help!
  218. OK i need a tranny rebuild
  219. Rear Brakes squeek ALL THE TIME
  220. 93 harness to computer hookups different
  221. Went to the track, what do you guys think?
  222. JBA headers
  223. underdrive pulleys
  224. rear gears
  225. Getting wheels narrowed
  226. new track times
  227. Cutting my cats out 97 z28????
  228. Cam Question
  229. What should I look for on scanning my Z?
  230. stumbling question
  231. vented opti conversion question
  232. Accel 9000 Extreme Wires
  233. ultra flow muffler
  234. LT1 head porters near Dartmouth, MA area
  235. 15x10??
  236. Help me spend $300....
  237. Post a pic of your ECM PLEASE!
  238. JetHot LTs & dual 3" after collector cutouts
  239. ICM cooling mod results
  240. Oil Wizards: is the new Mobil1 15w 50 ok?
  241. Valve Cover Gaskets
  242. 95 opti harness
  243. HELP! Car won't start suddenly!!
  244. NEED HELP!! Terrible noise from passanger rear wheel!!!
  245. Opinions on a clutch
  246. Unknown gear change before I got the car?
  247. Gauge Cluster Light Bulb P/N for 94 Cam
  248. midwest converter gains?
  249. best exhaust!!!
  250. Put engine back togother w/ a stainles ALLEN head bolt kit?
