  1. Horse power question??
  2. Question about longtubes and OBD2
  3. removing air pump
  4. MAP Sensor Questions (relating to my starting issues)
  5. Piston rings, what are we running here with strokers??
  6. Mutherfrikin hoses
  7. Need of relocation brackets on lowered M6, quick question??
  8. Should i do a 383 stroker or not?
  9. A few part #'s needed
  10. OPTI rebuild kit ~ does it exist?
  11. TEA heads
  12. People with Mods in here
  13. Cam goes in, Rear end goes out- Need advice
  14. I need a part number
  15. Part # for 1LE intake elbow?
  16. Rollbar install complete...Interior reinstall ???'s
  17. grinding 2nd ...........what's the deal
  18. 1LE intake elbow
  19. AV Gas
  20. How to clean tb??
  21. billet vs cast cam
  22. ZZ4 Cam Identification
  23. Best place to get stock parts online
  24. Engine quits at random times and wont start up again for an hour...
  25. What size Cut-out?
  26. buy new or rebuilt??
  27. MSD 32129 (OTVC) Coil Wire ?
  28. Is this opti symptoms
  29. 95 camaro z28
  30. Drive Shaft Questions???
  31. Installed new comp cam, now the exhaust valve is hitting the piston!
  32. Can I buy single ARP head bolts ?
  33. pic of my destroyed rear end!!
  34. Cam Install
  35. OEM SS Part number 93 97
  36. Will I pass smog?
  37. Frustrated
  38. optispark
  39. Rear end gears/differential- How hard to install for first timer?
  40. Just put in my K&N FIPK
  41. it has been a horrible night... there is a lifetime warranty on opti's, right?
  42. will LS1 flowmaster fit LT1?
  43. opti apart, shows signs of arcing
  44. shoebox would you happen to know??
  45. AHH can't decide!!!
  46. did a tune up
  47. 93 and 95 valve covers???
  48. security light on while driving
  49. car pulling?
  50. torque for head bolts?
  51. Tire size question?
  52. Speedo gear change in a 93, in car?
  53. Another fuel pressure question.. Does FP drop or rise when you rev?
  54. 383 Balancing ?'s inside...DON'T WANT MALLORY! Please advise...already searched
  55. What is wrong with my car????
  56. epoxy on port floors?
  57. Heres the wheephole "safe the opti" mod *pics*
  58. Throttle Position Sensor
  59. Completely lost in the sauce on this one
  60. electrical problem
  61. First time at the track.....
  62. Rhino Ramp Clearance
  63. Any 400rwhp or close to it running stock ignition?
  64. 94 Z M6 7 1/2 1/16/3/4" ring gear?
  65. Our Side Mirrors...
  66. About This Lunati TIMING SET Summit Is Carying Now?
  67. 94-95 Y-pipe on a 97???
  68. Could 93 octane cause this??
  69. What to spray exhaust with to keep from rusting??
  70. Noisy rockers?
  71. oil pump ?
  72. any ideas for new mods?
  73. 98 Rearend in my 96
  74. Best exhaust for 93 Z: Borla or Corsa?
  75. Tight Valve Covers
  76. Car lower on pass.side,and fishtailing fixed.
  77. what ory
  78. Jet Hot Long tubes finally installed!!!! (pics)
  79. Coolant leak by starter? Help!!!
  80. True Duals on Stock Motor. Torque Loss/Power Loss??
  81. Rear spring suggestions
  82. transgo kit
  83. cool tip for trans cooler install
  84. what next
  85. Heads, Cam, Blower or N2O. Anyone running on stock bottom end?
  86. Slow.....WHY?
  87. Hesitation and backfire, only when cold
  88. where to put cutout on my z?
  89. BFG DRs
  90. Used Power Programmer
  91. Car is on the road after HOT cam install!
  92. AAHHH! What the "heck" is that? (SES Light) (edited by moderator)
  93. Help! Broke a wheel stud...Need help with replacement!
  94. firing order
  95. crank/ hub problem
  96. fuel pressure?
  97. cc306 cam for sale on ebay..
  98. Header Question
  99. Transmission trouble
  100. For those who have pulled an A4
  101. Tranny pressure problems...
  102. Best Header+Exhaust Combo?
  103. What timing cover neededto run 94 crank hub and 95+ style Opti?
  104. Getting rid of REAL Knock Retard???
  105. where to find dash cover94z(the big plastic one w/vent for defrost)
  106. 1.45" Diamater sprgins.. which ones are the best and which valves?
  107. Where do I get this from?
  108. Please help me with an electrical problem! QUICK!
  109. Shoebox, HELP
  110. 2 ????? I did a search but didn't get the answer I was looking 4
  111. Where to get Transmission Yoke for LS1 aluminum Driveshaft?
  112. zero lash?
  113. slp 2otl exhaust whistle? would a cutout be worth it?
  114. Lt1 Dave
  115. how many Horse powers?????
  116. STB install probs
  117. How good do flowmasters sound?
  118. Swapping from 93 PCM to 94 PCM?????
  119. LT4 knock modual
  120. computer chip?
  121. Best Gaskets For MAC Headers?
  122. Fuel Pump Not Humming!
  123. Anyone Get Their Rotors Zinc Washed Recently??
  124. pin hole leaks... OMG
  125. went to dragstrip today and bad things happened need ideas!!!!!!!
  126. Here's a tip when trying to change 02 sensors.
  127. quick stereo Q's
  128. Low Fuel Pressure
  129. How to strengthen the rear end?
  130. oversized valves in stock heads
  131. SS Replacement Rotors
  132. Noob tranny questions
  133. LT1 running rich
  134. A4 to M6 How much $$$ we talking
  135. t-56 rebuild question
  136. another hp estimation
  137. Thump when I stop hard????
  138. cam packages
  139. 8k rpm???
  140. dynomax ultraflow
  141. VERY bad gas milage, and a whoosing/sucking sound on acceleration
  142. "pink" rods factory in '93 LT1
  143. need help w/freescan ver 2.07
  144. help new owner
  145. Brake Pads???
  146. trans vibration
  147. Horsepower/torqe Am I Making?
  148. Need help with lights ASAP
  149. Just dynoed my 97 Ws6.
  150. How happy are you with your NGK Plugs?
  151. muffler diamter
  152. After Cam Swap Dyno Numbers!
  153. WS6 or a clone, how can I tell?
  154. What are symptoms of a psychotic MAP Sensor?
  155. spark plugs/wires?
  156. Fule Injectors
  157. Installing the pilot bushing...
  158. Help Car Wont Start!!!!!!!!
  159. O2 Sensors???????
  160. different LT1 heads from GM???
  161. shift light pics
  162. opinoins for spark plugs
  163. Best CAI?
  164. SES light comes on with fans
  165. Collapsing lifter - How much spring pressure?
  166. vortech elbow
  167. rebuilt lt-1?
  168. smog pump
  169. broke alternator bracket!!!!!
  170. rebuilt a lt-1 what parts
  171. Gas gauge question
  172. Little Vid of My 224/230 XE Formula
  173. 95z about to be shot...
  174. Videos of my car FINALLY started, and a few questions
  175. First mods to do to the LT1 motor....
  176. Need torque specs...
  177. New coolant head temp sensor?
  178. 28inch tall tire
  179. Alternator squaking...can i fix it?
  180. Who has installed a Be Cool radiator, mounting ?s
  181. IAT Sensor Help????
  182. Strokers and emissions
  183. Starter problem this morning...can you name this sound???
  184. aftermarket radios???
  185. Fuel filter
  186. Can someone locate mods?
  187. need help
  188. Wheel Studs BROKE!!!
  189. Denaturated Alcohol
  190. Squeeking From Drivetrain/brakes?
  191. fluctuating battery gauge?? PLEASE HELP ME!!
  192. Ugh, slow track times, timeslip inside, help PLZ!!
  193. tapping in pass. side valvetrain
  194. Manual Steering Racks
  195. How does a adjustable fuel press regulator help an LT1
  196. How hard is it to change alternator fan/pulley
  197. New Rotors or Resurface old??
  198. guys with !ABS inside please
  199. Doing some work and need some info
  200. Triple Gauge Pod Available?
  201. Cooling Fans Still Malfunctioning, Help!!
  202. Anyone know of a Dyno Day
  203. Need a part number
  204. Battery keeps dying after being idle for more then 5 days
  205. Dallas area transmission shops
  206. Burning Plug
  207. New Tires
  208. Will not tick over
  209. questions about 30# injectors
  210. Car Books
  211. 97 WS6 dyno predicitions
  212. Is it possible to change the front of a 1997 to the 1998 body style?
  213. Header Bolt Question
  214. Cutout Before the cat?
  215. l98 vs lt1 weight
  216. What's this in my trunk?
  217. Wil my plugs and wires pick me up any!?!
  218. Mod. List
  219. Working on my car
  220. cams,cams?
  221. 5 star `97 and up wheels made in different sizes??
  222. Window button
  223. Temp Guage ?
  224. Blocks disassem. any tips that can get extra hp?11s for 2800 Including price of car!!
  225. Keyway on Crank - TDC??? Keyed Hub?
  226. guys with MAC headers inside....
  227. Hooker shorties owners inside please
  228. How can I perminently bend my headers?
  229. are all TH700-R4 transmissions the same?
  230. is there a way....
  231. Which Cam?
  232. possibly bad opti?????
  233. Engine Overheating
  234. My car runs too hot!!!
  235. anyone have pics of moser w/spohn RLB
  236. Is something wrong??
  237. how many daily drivers are running a C306 cam? any coments welcome...
  238. Help me choose a cam 224/230 or 224/236?
  239. Switching to a turbo 350....computer question...Injuneer??
  240. What the heck is going on with my M6 tranny?
  241. whats grinding/clicking with my brakes?
  242. Installed springs shocks, rotors...and now loud squeeking noise
  243. Clutch&Pressure Plate Reccomendations
  244. TOO lower or not too lower my Z?
  245. Do 17x11's fit on a stock 98
  246. Funny smell...come inside
  247. best street performance mods?
  248. rear end
  249. Clearance valve covers for Pro-Magnum rockers???
  250. Help! steering column
