  1. CC 1.6 RR set screw backed out at high rpm! 2x!
  2. Guys runnin 12's inside.
  3. trying to track down coolant leak..
  4. Stero Wiring Diagram for 1997 Camaro
  5. I'm about to kill my car!
  6. Bad Feeling....
  7. Why isnt my #1 exhaust lifter compressing?
  8. Source for Longer Wheel Studs
  9. How much would I gain with LT & X-Pipe and bullet mufflers
  10. headers
  11. NO EGR on a 97???
  12. All Valentine One owners come inside.
  13. Please HELP! I'm Lost. All TECH Guys Inside!
  14. need quick answer...pressure test related.
  15. MAC Headers are owning Me....
  16. found some pics of my welded intake
  17. Fuel pump recommendation
  18. Engine light coming on in 6th gear, any idea what's wrong?
  19. Replace Dual cats on a 96?
  20. How to disable THEIFTLOCK ON RADIO?????
  21. Gas coming out of gas cap
  22. plugs arching
  23. Can I just put water in the radiator?
  24. Please help ! $600 later and the same problem is still there...
  25. part number for passenger side wheel hub
  26. have you guys ever heard of zMAX?
  27. Best underdrive pulley?
  28. Part # for (front) PFC brake pads. ..
  29. Changing gears need info
  30. Please Help: Convertible True duals
  31. obd 2 codes
  32. Orientation of flywheel / TDC????
  33. Need Help, Getting the Fuel Lines Off
  34. need advice on putting my new AC compressor on
  35. header wrap.. in a different place
  36. Stinky air vents - help Im dying
  37. Bigger Valvesprings from the CCA-986-16
  38. How to install 02 sensors?
  39. Need quick help!!!!!!!!!
  40. disadvantages of taller tires ?
  41. how to remove fuel from the tank?
  42. What will the nittos take first??
  43. Drove Without Maf!!!!
  44. 1.6rr with stock springs debate
  45. cat making funny noises
  46. Horn Problems
  47. quick question
  48. whats the best rear end for the buck?
  49. Suspension tunning???
  50. Is it a bad optispark??
  51. Throttle body airfoil for LT1???
  52. slp shorties
  53. ripped oil pan gasket
  54. Got my 1LE elbow, questions??
  55. Hmm does this really give the gains it promises????
  56. What is this code trying to tell me?
  57. No clutch pedal after tranny install
  58. sounds like im turboed...but i'm not...
  59. ? about Roller Rockers
  60. lt1 recall ????????
  61. Help I am idling at 1200rpms
  62. true duals
  63. Has anyone had a Comp Cam dowel too long for a vented opti?
  64. ET for 108.44 trap speed
  65. ? about Roller Rockers
  66. Edelbrock T.E.S. Headers?
  67. Hey Shoebox, update inside
  68. HELP...car stumbles low RPM's
  69. Guys w/Hooker shorties come on in.
  70. Is there a company that makes a bronze gear for the oil pump drive, that actually fit
  71. Is there a site on taking out engine and installing new crate engine?
  72. 94-95 headers on a 97???A few ?'s
  73. Which one of these LT1's should I get?
  74. Best place to mount Trans Cooler.
  75. Where can i get 315's?
  76. Most affordable place for 12 bolt
  77. what is needed to swap 94 rearend into 97?
  78. Where to buy LT1 Edit?
  79. Trans Am door ??
  80. crane gold 1.6 roller rockers ?
  81. whats a good rpm for idle?
  82. A/C not working????
  83. Do you have to cut the wires from your 02 sensor??
  84. Question about too much oil on the engine
  85. Best Replacement Transmission for 96Z?
  86. wtf... all my gauges are off
  87. dowel pin?
  88. Damn LT1..... Hardcore Stubleing and Not running right! PLease need help bad!!!
  89. cam 4 n2o
  90. What is the motor mount
  91. Help With Cam Swap Please?
  92. Surges during Accelation between 2k-3k Rpm
  93. Dont really know where to put this....
  94. New Times on 224/230 XE
  95. iac dead?
  96. the black dot on the left
  97. doing a tune up
  98. Solid roller too aggresive for stock PCM and stock bottom end?
  99. Ordered a billet cam from comp cams, need a bronze oil pump gear drive!
  100. pro 5.0 shifter dust boot question
  101. What kind of wheel balancing weight on chrome?
  102. What does it take to get into the 11's
  103. Still confused about Royal Purple in M6
  104. Jet Hot Headers
  105. Replace oil pan gasket with cam swap??
  106. 97 gauge cluster
  107. what year had the most power for LT1
  108. I need new Exhaust Manifold Bolts, what size????
  109. How to bold Motor Mount
  110. will 2.05 1.60 fit in stock lt1 heads??
  111. Quick Dumb Question.......
  112. Waterpump weeping: replace pump+opti+timing chain?
  113. Fuel
  114. TH350 conversion: speedo signal hookup
  115. 3.73 Install
  116. Rear Main Seal
  117. Passenger Headers
  118. CMMG style exhaust question
  119. LT1 MAF Sensor..GO or NO!?!?!?!
  120. How wet can the opti get?
  121. im new here, need opinions please!
  122. what fuel pump to get
  123. Headliner woes- need new or redo?
  124. Got a bunch of free 12 bolts... now what
  125. Tranny
  126. pcm prog-VATS??
  127. leave my heads alone or not?
  128. Jet-hot/Hooker LT guys inside please
  129. NEW LT1 products from Summit Racing
  130. Hard Time Shifting at 5,000+ RPM
  131. lt1 vs ls1
  132. Will Jet-Hot long tubes work?
  133. Difference between F41 sport and FE2 touring suspension.
  134. So who else has rust on their Jet-Hot coated headers?
  135. any body tried a nascar select ignition coil ????
  136. Looking for diagram or pic of exactly where vacuum lines go for OPTI
  137. who converts heads to reverse flow? Head Porters Please enter!
  138. idle relearning
  139. oops... now what was this grinding noise?
  140. Big problem! Did I fry my TPS!?
  141. gas smell question...
  142. those who know there automotive wiring please help
  143. tire size
  144. Fuel Pressure Gauge help
  145. LT1 intake block change
  146. PCM/Wiring Harness/Engine what goes where
  147. Drive shaft
  148. Gasket for MAP?
  149. Rubbing noise when driving slow
  150. Who is running a billet material cam with a factory oil pump drive gear?
  151. URGENT: Tire suggestions needed ASAP
  152. Can you make 94 opti harness work on vented opti?
  153. What fuel system upgrades will i need? (if any)
  154. HELP 95+ opti harness into main elec. harness problem????
  155. Accel Ignition Questions
  156. Jason Cromer's Contact Info
  157. Rear hatch rattle, help!
  158. OMG HELP, this is really bad. A4 Trans Related.
  159. Car Is Acting Crazy!!!
  160. MAGNAFLOW exhaust systems. Comments Fellas...
  161. Turn motor half a revolution then stops, whats up?
  162. BFG Drag radials- What PSI on the street??
  163. How to install Taylor Opti ends on Accel wires???
  164. performance shift button stuck?
  165. Guys who port heads
  166. Performance Trans Mode
  167. Manifold leak(?)
  168. Free mods for C4's??
  169. Pulling My Lt1
  170. Car died on way home today! Help.
  171. Hypertech PP3 Deprogramming?
  172. Plugs and Wires
  173. Low top end power, rough idle
  174. Serious Help - Rebuilding My Engine!
  175. Fuel Pressure low
  176. Movie - XE230/236 cam & GMMG Idle
  177. Can I use this block?
  178. T-56 gurus please come in and help me out......
  179. anyone with true duals please help
  180. anyone who knows about o2 extensions and simms please help
  181. If I block off the EGR on the intake...will I pass emissions?
  182. Having a hard time getting cam dowl out????
  183. Buying a camaro, bit of help
  184. where do I buy seafoam from???
  185. Anyone got pics of welds or centerlines on their cars?
  186. Check out my airbox...
  187. Putting a used engine in anything I should do....
  188. Do lifter need to be "pumped up" when setting valve lash?
  189. How can I calculate what spring height I need for my new cam?
  190. Where can I find fittings for a Rad?
  191. Anyone ever replace a window REGULATOR or sping before??
  192. Opinions on Nitto 555 Extreme
  193. Got a problem with a Z28 at a friends speed shop. Need your opions
  194. How much hose do i need w/tranny cooler?
  195. Brodix-headed monster came to life!
  196. Quick SES question
  197. 160* stat... worth the install?
  198. finally completed v6-lt1 swap
  199. Lean condition with new Cam?
  200. Car wont Start!!!
  201. Leaking tranny
  202. Car wont start
  203. K-member bent! Where to get new one?
  204. Weep hole tube?
  205. car crapped up on dyno....need help
  206. ATI mod
  207. Radiator Fill Runthrough, (need someone to read through this)
  208. Pice of crap tranney...........
  209. OBDII Programming Released.
  210. Hard start and stumbling problems, please help
  211. theoretically..
  212. Lt1
  213. How hard is it to remove the front sway bar?
  214. MAC hi-flow cat and 3" i-pipe? hiflow cat owners inside please
  215. stock fuel system till???
  216. AC will not blow???
  217. HOT Cam folks, How loud are your Rockers??
  218. Tornado performance
  219. Fuel pressure question.
  220. Porting heads by yourself?
  221. Looking for a clutch part.
  222. Unregulated Fuel Pressure??
  223. Quick help needed, car won't start
  224. Timing gears?
  225. Falken GR Beta FK-451
  226. Sounds like marbles in the trans case??
  227. What Clutch to buy?
  228. Please Help. Procedure for filling up on coolant.
  229. accel dfi system
  230. Part # for LT4 KM?
  231. Online Tire Dealers
  232. I got my old opti out! Im almost positive this was my problem!
  233. Those that removed the splash guard inside
  234. 355 vs 350
  235. Fuel Pump removal through trunk!?
  236. Part numbers for front 02 sensors?
  237. Things I'd like to do while heads are off
  238. Gas Cap
  239. Installation on new vented Opti....PLEASE HELP
  240. LT1 reliability...(both drivetrain and interior)
  241. Transmission Question
  242. High Octane Fuel and Performance (or lack thereof)
  243. Need to find 14 sec civic post
  244. Upping the Ante
  245. Roller Rockers
  246. Stock valvespring seat thickness?
  247. Rough idle, high iac counts, rich, hesitation
  248. werid ?
  249. underdrive pulley wont come off
  250. Bullet mufflers and Loudmouth
