- Heater Core is BUSTED, anyone know how to bypass or replace???
- Need Help From Gutted Cat Guys
- Turndown right after hooker shorties?
- 13.2 horsepower
- 383 Runs very very poor
- Oh My God!!!! Please help me!!!
- 93 formula - GM Dealer installed alarm? Odd problems..
- BANG from driveline when smashing accelerator pedal. U-joint ?
- I think Edelbrock heads are now available for the LT1!!
- 97 Stock Injector size
- Tranny Cooler questions, where to buy, how to install?
- GRRRR Brake light/turn signal problems(shoebox please help)
- QA1/HAL shocks and spring install.
- New 3.73's for me
- Pan gasket and timing cover
- ok stupid question, but need help.
- P0300 Misfire
- Need Help. Car Died On Me! 8 Codes On Scanner.
- Need some spark plug Help
- anyone ever use a POWERBOND balancer ?
- tires
- fluid out the top of the dipstick?
- oil pump drive gear?
- bearing in the a/c pump
- any rebuild 4l60e that is reliable??
- rebuild price
- Which setting do I put the cloyes double roller crank sprocket on???
- Problems continued...
- which RR's do i want
- If you still have the gas smell step in...
- fuel pressure safety switch
- Help K&Ncold air intake ?????????
- engine shuts off when it reaches 180*?
- New Y-Pipe?
- Helix Style throttle body spacer
- Anyone running an aluminum flywheel?
- balancer off by 15 degrees .. Vibration ?
- Use stock key in crank for cloyes double roller crank sprocket??? ASAP!!!!
- Low Coolant light
- who sells AS&M headers?
- Holy crap, major clue! My headers were glowing a bright bright red!!!
- offroad pipe & LM
- *Confirmation* - Spun a bearing!
- 1LE intake elbow part number
- my car is skipping/bogging/acts like no gas is there
- Lunati Timing Set.. OEM Replacement???
- Muscle Sounds
- Side exhaust?
- hatchback
- Wow!!!!
- 4.10 or 4.11 which is better???
- GOT THE T/A Running! But WTF?
- ack.. 80+ psi oil pressure after cam install..
- Are these problems severe
- Electric water pump swap / original drive gear removal question
- 2001 WS6 vs 1996 Formula LT1
- Car gets hot, hard to start, etc
- a/f gauge wiring ??????
- 3.73 questions
- weird sound under the car?????please help!!!
- weird noise
- Is My Rear End Trashed? Help!!!!
- are thread lockers the same as lock washers?`
- Accel Adujustable Fuel pressure reg.
- car leaking fuel
- Driveshaft CLUNK!!
- help !!! no heat
- Noise with the clutch in
- How Do I Remove The Balancer Pully?
- How to tell if a LT1 is a 350 or 265
- Vacuum Controlled 4L60E???
- Does anyone else have a professional XE 224/230 tune?
- Exhaust stud placement?
- stutter, please help
- coil?
- edelbrock headers
- Why Cant I Sell My Car?
- What needs to be plugged after AIR pump removal?
- Stock heads/intake or no?
- Oil Sender
- Who has the most miles on their Z28? Any problems thus far?
- too much fuel
- Part # for springs
- The 224/230 is finally in and running.. initial impressions and questions.. :)
- What do you guys think about 4inch exaust tips?
- Flowmaster 80 series "TO BE OR NOT TO BE"
- I need shocks
- Reused stock WP gear instead of using new Extreme Duty gear.. am I screwed?
- checking for a bad lifter??
- Shoebox....Could I Get The Part# For That Puller?
- what do u think mildly ported and polished heads with my mods in sig (no cam)??
- Need Help Fast!
- 95 lt1 prob
- Rattle Rattle
- Problems with closed loop............
- OK I've got a fuel issue for you
- NGK TR55 - Summit part #?
- M6 Clutch Install - what parts are necessary??
- TB bypass
- intake elbow- 1LE?
- fuel pressure gauge ?
- Can anyone tell me where the fuel pressure regulator is..
- bleeding coolant
- Suspension - When do you need new springs?
- best sounding exhaust
- Transmission Leak
- Results about Converter Lockup vs Non-Locking..
- Question about Optima battery fitment
- LT4 help
- Buying a Z today, need opinions
- Hey Shoebox........
- Opti and MSD (do they mix?)
- Traction/Suspension Mods!
- cost to install a 6/8pt roll cage
- Transmission Replacement
- weird gas mileage
- This might sound stupid, but I need to know
- Got my car running, need advice on changing rear end
- '95 Chip swap?
- What's it take to get a 94 T/A M6 in the low 13's/high 12's?
- How do i hook the computer up to the engine???
- LT1 GlassPack Mufflers
- How many miles have you put on your heads/cam setup?
- Top Engine Cleaner
- Heads/Cam Car, slow, & Fuel Pressure Problems
- Need Advice, buy AFRs or have my heads ported.
- ~How much $ to clearance block for 383? Max overbore on these LT1's?
- problem with my t56 (rattling)
- Missfire After Cam Swap!!!!!
- COnFUSED
- MSD Digital-6 Plus Ignition Control, need help...
- What type of plugs??
- TA vs. Z28
- Please help with SLP CAI install on 97Z >>>
- Headers or computer tuning?
- Torque Converter
- Valvoline Atf in m6?
- Camaro Z28 Needs Help!!!!
- k-membered cars and daily driving?
- Quick Throttle Body Question.
- How does the Spec Star Stage III drive for you?
- If Iam going to run 28*10.5*15 tires, what size rim width do I need?
- Dal v/s Jason
- What the differnce from 95 vs 96 in spark plug sets
- Almost lost the Z over the weekend.
- Squeaky console and dash - How do I seal it?
- Low water temp; fans stay on
- Bad O2??
- weird sound comming from tranny(m6) when press the clutch its gone???
- Oil ALL through my PCV system!
- Driveshaft problem?
- Where to buy a Water pump and Opti?
- Best ignition module?
- Any affordable widebands available?
- fuel pressure regulator??
- Trans guys inside please
- Spark Plug Bum Rape?
- OBD2 guys with big cams: missfire codes?
- New Offroad Y-Pipe for LT1's!!
- MAP unplugged while running = no change in idle?
- Speed Limiter Removal Only
- wheres the track around rochester NY again?
- How to tell if these a worn out.
- bad gas?
- Got My Lt's Today
- 4.10's on stock rear end
- Just finished a clutch: horrible noise
- Too many miles?
- before/after results with PCMforLESS tuning?
- noise please help
- Need Dual Exhaust Help
- Relocating batter Need ideas on kill switch
- 3/4 cam??
- At what # should I gap my plugs at?
- how long will these engines last?
- Another 2000 rpm stumble....tried everything Need some help
- spun 3 main bearings
- Front Timing Cover Leak
- I got it! And I'm crossing my fingers!
- Engine noise while cold
- What to do next...
- Need bolt size! HELP!!
- t56 longevity
- Help Please!
- Cutout size
- lt4 starter installation
- Mechanical Autometer Guages
- Tuning with DFI or FAST
- battery cable
- Funny Hiss Click Thing
- Reliability? 400hp stock bottem end
- sfc and rear end fuild
- Mac, BBK, RK Sport, Pace Setter???
- Anyone????
- T-5 tranny rebuild?????????
- Freeze plug question
- hi rev
- Any tips on installing shocks/springs?
- Weird Tranny prob
- what kind of 60' times should i be cutting?
- HELP got car scanned...codes?
- whats the thread pitch for this bolt
- Spohn TA users, need help fine tuning adjustments
- Diffrence in Header size
- Problem with a BMR control Arm! Help!
- Best fuel injectors????
- 94/95 MAC Headers / o2 Extenders?
- wiring question???
- '88 TPI Vette vert vs. '93 Z...who wins
- overheating 94
- where to find tall valve covers that would fit my 1.6
- 17*11's
- what to look for when checking out 95 Z
- T-56 Transmission Question
- Questions on adjusting RR with motor running.
- lucas injectors?
- Really starting to regret the Nitto's
- looking for used cam from LT1
- Who else sells opti's
- Is a stall converter needed for an HotCam install?
- SES Light came on
- cut off cat...lose power??
- Do underdrive pulley kits actually do anything?
- Need info on brand known as G2.
- T56/Centerforce Cluth Help???
- Vented Opti Swap
- Fuel injector size.......How is this figured??
- Opti wiring harness connector questions
- help need pilot bushing part # for 96 ta
- jet-hot long tube guys inside, NOW
- Grinding/rubbing with front suspension travel-What is it?
- Anybody ever install a 95+ LT1 into a 93 Camaro?
- P0336 Random Mult. Missfires
- How much and where to cut exhaust?
- Ceramic coating on ypipe Gone!
- TB bypass=broke engine?
- couple rebuild questions
- Vortech elbow installed!
- Cobination Motorsports Heads/Cam packages
- Ignition Question - 97 LT1
- volt gauge takes about 30 seconds to come up after startup ?!
- Efect of more lift on Emissions?
- how can I get to the radiator reservoir tank?
- What am I doing wrong?(intake leak related)
- 383 stroker components
- wiring help asap!!
- Remove EGR
- Jet Hot vs Hooker LT headers
- exhaust leak in rear how do i find it??
- HORN problem...of all things
