  1. Help me out with my idea...
  2. squeaky rotor
  3. What O2's
  4. bolt on car question
  5. what does a 97 Z28 dyno at bone stock?
  6. Did I block the EGR the right way?
  7. 94 cam in 95 car... possible?
  8. Help me Find the Corvette servo
  9. Installing valvespring
  10. Fuel line clips?? part number??
  11. How much timing retard with 100 shot??
  12. Not LT1 Related...but need help ASAP!! I almost blew my truck up!
  13. Non F-Body Help (1996 Aurora)
  14. Looking to buy Exhaust tips for a 97 TA need opinions and places to get them...
  15. What is that noise when you shut off you car?
  16. little help!!!
  17. Shift points for 224/230 112 LSA cam..
  18. Talking about the ThunderChicken Formula
  19. I need opinions!!! Please help!
  20. b&m ripper shifter
  21. Stuttering? need help
  22. Removing ASR
  23. Some please help me with accessory bracket.
  24. Wow is pulling the heads ever a pain!
  25. K&N FIPK VS K&N FIPK Generation II
  26. Mechanical or Electrical Oil Pressure Guage?
  27. B+M Shift kit opions?and install?
  28. rps with 4.11 m6
  29. Drop Top Rattles
  30. Need Help....blinker won't work!?!
  31. 3200 stall TC
  32. symptoms of a clogged cat??
  33. Guys w/ BMR K-member...Need tips ASAP
  34. installing cats for true duals/longtubes soundcats best to use for clearance
  35. Why did I pick up 14 whp with cutout?
  36. NO!! what's wrong with my car??
  37. Well ran my first 12 on motor
  38. Would bad tuning make your car misfire?
  39. Anyone know the felpro part number for a full gasket set?
  40. what transmission oil do you guys use in M6?
  41. Next mods....
  42. ATI TH350 Owners !!
  43. 94z heads and 97z heads questoin
  44. If you could
  45. Hmmm
  46. installing the electrical oil pressure guage
  47. STUMBLE/SPUTTER fixed!!
  48. LT1 Head weight?
  49. What timing chain in an ODB II setup.
  50. Chips: Is Jet the best one out there?
  51. Power Loss at high RPM
  52. 98ls1/94lt1/004.6
  53. LT1 Polished Alum Valve covers??
  54. Where can I get a cable and freescan for a laptop?
  55. What else is needed to install gauges?
  56. fuel pressure?
  57. Cai hp?
  58. Where to go for fuel systems?
  59. Gasket needed for EGR block off??
  60. Cam Motions?
  61. will i feel a difference with HOTCAM???
  62. whats wrong with my times?
  63. Dual exhaust... OUT THE BACK!! Everyone inside!
  64. hmm
  65. Installed MSD 50# and now car is mega lean offsets???
  66. Fuell pump going out again
  67. LT4 starter bolt into LT1?
  68. Quick question about pulling the heads...
  69. AIR fittings on Hooker LT's
  70. how much for salad shooters
  71. lifter recommendations?
  72. 93 Z-28 just shut off going down road.
  73. Another question about pulling/installing the heads..
  74. Car died, was jumped, ran like crap!!
  75. What to do next?
  76. What gauges are important?
  77. Any info on Dynospark optis would be appreciated!
  78. door window outer felt guides questions (shoebox??)
  79. Stock LT1 track times
  80. How hard to change pads and rotors???
  81. is the air pump needed to keep the cats alive, some say yes, others no?
  82. Just a heads up...Comp R's are now available straight from Comp.
  83. any help?? ovc install...
  84. fog lamps
  85. what size bolt on back of head for coolant line
  86. Anyone running a 3.5" shaft and the SLP DS Loop?
  87. Vaccum leak that can't be found, Please Help?
  88. lt1 intake elbow/ air duct
  89. T5 vs T56 Transmission... what's the difference?
  90. Anyone know how to use FreeScan?
  91. How to check if my EGR valve is bad?
  92. Jack Stands - Where is Safe????
  93. What do you say is the ideal lift on a solid roller cam for a 396 stroker?
  94. Odd Window Motor Question
  95. Fog lights / Aux lights
  96. Wheel Alignment after LS1 Brake Upgrade
  97. optispark
  98. JB Weld on exhaust manifold ?
  99. Anyone have pics of stroker clearancing
  100. what happens when the TPS sensor is bad?
  101. First impressions of my z28
  102. lt1 94 z28 clicking when trying to start
  103. rusty wire???
  104. NITROUS or HEADERS for next mod??
  105. 94 Camaro Z28 Ss(clone) For Sale In Minnesota
  106. how bad is it not to change the PVC valve?
  107. Few questions here, please help!
  108. Another question about removing heads...
  109. tb bypass
  110. gutted cat?
  111. Questions froma poor man.....
  112. problem with parking brake light...alwys on, i am stumped
  113. 11 Degrees Of Knock At WOT!
  114. slp header install
  115. Weird headlight problem; causing voltage gauge to dance
  116. What catalogs are available?
  117. CC305, What kind of Headwork??
  118. yank torque thruster with 2.73's?
  119. How much would it cost to...
  120. Throttle not opening all the way, 93 TV cable related
  121. What should I run with Corsa exhaust!?!
  122. what is louder, ultra flow or hooker?
  123. gears?
  124. Exhaust Help...Need to MAKE up MIND!!!
  125. Need help quick....
  126. swirl meter, tumble fixture and port flow analyzer, do they realy work?
  127. Help please....
  128. Where to put cut out?
  129. Is a SHIFT KIT worth it if you've already raised the line pressure?
  130. obdII timing cover
  131. what else could it be.......? [Car won't stay charged...]
  132. Need help
  133. smokin
  134. Header install, q's about what else do do at the same time
  135. Mod help
  136. Gear Ratio?? I am lost What is the Formula?
  137. oil pan leak
  138. Difference in cc305 and extreme 224/230?
  139. cc-305 and cc-306 sound files please!!
  140. Slave cylinder upgrade??
  141. Will 02sims off of a 2002 work on a 97T/A???
  142. anyone get detonation after header install?
  143. loudmouth/hooker lt's
  144. Can I Use The XE224/230 Cam With.....
  145. True dual part numbers
  146. Warning: Bad Deal With Advanced Induction
  147. NE1...SLP Suspension Kit worth it???
  148. Starts and then dies
  149. Timing Chain...options and opinions
  150. People that have done the opti conversion, how much did it cost?
  151. Hot cam vs other cams
  152. Header gasket and bolts
  153. 8.5" 10 bolt swap
  154. were to get hot cams
  155. Cam and valvetrain break-in/common practices
  156. Considering a CSI water pump, questions need answered
  157. Got Hotcam questions? Click here.
  158. differences in a 93 z? as to a 94 ->97
  159. TH400 dipstick question
  160. I'm stumped....
  161. DOT approved ??? need help
  162. gas mileage
  163. need info on Eldebrock headers
  164. Street Twin setup??
  165. how to check timing?
  166. Did you run cooler after an electric water pump?
  167. Still maxing out injectors
  168. Buying a Spec Stage 3, what else do I need?
  169. DTC 48 - MAF problem
  170. Clunking/squeaking from the rear
  171. Tow Dolly
  172. Any dyno numbers from the XE 218/224?
  173. Any good Salvage sites for f-bodys?
  174. Driving / Fog Light replacement
  175. Jet Hot LT Owners inside
  176. OK, Need Help With Which Aftermarket A4 To Go With???
  177. Tools for brake install??????
  178. removing solenoid when removing erg/airpump
  179. Car doesnt seem to have the power anymore, anyone have some ideas to check for?
  180. XE 230/236 Times and Dynos only plz....
  181. 10% Bogart drag rim price INCREASE
  182. XE 230/236 VS CC306 for my daily driver!!!!
  183. LT-1 to LT-4
  184. OK...Where is my WP drive shaft seal???
  185. LT-1 to LT-4
  186. Mileage question
  187. How long to drop in motor
  188. stock lt1 gas mileage
  189. What causes...
  190. New motor in, but have some problems (shoebox??)
  191. Part # for 1LE drive shaft, and is it a direct replacement for a 96 Firebird?
  192. Why rebuild engine?
  193. How hard is it to replace an AC check valve?
  194. $300 for SFC install?
  195. pcm info
  196. Decisions, Decisions--New Vette or Stroker
  197. 95 z28 or 96 z
  198. Part # for brake light socket
  199. cc306 or Lunati Custom Grind or GTP-6?
  200. Door switch/power to radio not working properly
  201. Now I am worried...
  202. Little Passenger side engine bracket (Not AC) where does it go?
  203. Dummy Light ?
  204. How many cfm do the stock fans flow?
  205. vigilante 2800 converter
  206. Longtubes and X-pipe
  207. Any quick guidance on block/head prep before reinstalling the heads?
  208. Tips for Jet-Hot(Hooker LT) Installs?
  209. 6 speed installed need help
  210. LONGTUBE header 1/4 Gains??
  211. Another question on installing the head bolts...need answer ASAP!
  212. Anyone running Eagle F1 D3 Tires
  213. Think I can do this all in one day???
  214. valve spring install hight question...
  215. B+B Triflow Q's
  216. missed a 2-3 shift now something is wrong with 3rd gear. Help!
  217. Gmhtp Shootout Participants Picked
  218. Should I???
  219. who makes the best midlength header?
  220. What cfm would you need, to make 450-500hp NA 396 Stoker!
  221. How much would I benefit going from single exhaust to dual exhaust?
  222. Starter - Stock or Aftermarket replacement?
  223. Driveshaft help!!!!!
  224. Car wont start again
  225. Maf
  226. Puff of black smoke when getting on it? Running rich?
  227. Can't get my new vortech elbow to fit correctly.
  228. Anybody else having problem with their flps longtubes?
  229. Does the hooker catback come with the muffler??
  230. How hard to change wheel studs?
  231. need TB help!!!!
  232. schrader valve thread size
  233. What plug wires should i get??
  234. !cags lockout question
  235. Installing a Pete Jackson gear drive on an LT1
  236. Pcm?
  237. Front susp. rattles after shock/spring install
  238. Who runs a XE 224/230 with stock heads?
  239. single or dual cat Y Pipe?
  240. who has boared their block .060 over?
  241. Do Flowmaster exhausts come with chrome tips now?
  242. very frustrating blinker turn signal problem
  243. 97 motor in 95...need quick help
  244. Need Help Asap
  245. Pulling Engine thru top: What did you do with POWER STEERING & A/C ? Alt Brkt stuck
  246. good deal?
  247. radiator leak?
  248. lt1 edit
  249. Trick Flow LT1 elbow (great product!)
  250. do i have an obd1 or 2 computer
