- Here's some pic's
- 02 Sims and no Cats. just got SES light and stumbling???
- 4L60E suopse to go into OD@WOT
- lt1 swap question PLEASE help!!!
- v6 lt1 swap question.. please help
- LT1 block; different from a regular 350 block?
- is there a csi elect water pump for a 96 if not should i go meziere
- LS1 trans mount for my 94Z A4 doesn't fit. Different part # for auto vs. manual?
- Is it worth to buy used gears?
- Any guesses?
- Best sparkplugs & wire combo
- Anyone else with an m6 pop out of 3rd gear?
- please help! stuck on tranny removal
- Which year LT1 will this BBK throttle body fit? Pics inside....
- Starter Help
- Anyone with Long Tubes on a Convertible??
- Sunoco94 experiences good / bad?
- help! easiest way to put door panel back on!
- Descreened MAF today got some ?'s
- stall question
- Quick Question about rockers...............
- Redline or Mobil 1?????
- shoebox, you rule.
- plug wires
- Time for summer upgrades
- Coolant Temp. Sensor
- Dynomax catback installed today
- part number
- HELP! Air Conditioner Drain Clogged
- cluster replacement questions
- LT1 crank keyway question????
- Turn signal won't blink
- Where is the cheapest place to get nitto's
- Could you have a CC305 ground on a 112??
- Just sold my Eclipse GS-T
- Cheapest place to get GM 3.42's and install kit??
- I took some pics, are my headers bending?
- Broken Brake ! Take a look
- shoebox; opti test ?
- SLP Dual/Dual
- what seals to replace when doing cam swap??
- looking for a good 383 hyd roller cam
- Gears on a CC306??
- What do you think about AS&M headers
- its always somthing
- Removal of Crank Hub
- Hooker LT concerns...
- Holley 52 tb or BBk????
- Help finding header
- I'm sick of searching catback?
- changing clutch fluid
- any seen these subframes
- SES light
- again offroad pipe?????
- Could This Possibly Be A Bad Coil?
- 3/8" studs w/ solid roller?
- Summit LT1 Rebuild Kit??
- which dynomax muffler is best for me?
- is there a website that has different exhaust sounds?
- new motor, no oil pessure!!
- H E L P 94 scan tool?..have SES LIGHT
- LT1 to LS1 injectors
- Are the spark plugs different from 1995 to 1997?
- Drive shaft BUY or have Made
- Hooker LTs... should I still do true duals or just a cat-back?
- pro 5.0 -1'' or short stick?
- Need part # pleaseeeee
- Hard to turn wheels out of reverse
- easiest shorty headers to install
- AS&M throttle body
- Is my Opti causing this !!!
- t-56 not wanting to go into gear
- coil; get from dealer or is autozone ok
- a4 wont shift out of park
- Help !!! cloyes install
- LT4 intake part #?
- 3.73 or 4.10
- Need help with valve spring install
- Throttlebody boring
- LS1 TQ on LT1
- Anyone have pics of the ls1 brake upgrade?
- Emergency - Rear Brakes
- Need help about headers
- trans problems
- why is there no aftermarket for the 10 bolt?
- MSD6AL have internal fuse?
- 02 sensor install q
- what should I set my shift points too with my mods?
- Can I use Crane 10380-1 kit with stock rockers and cc306, and do 1.6 rockers later?
- cc305 and cc503 ?
- ABS plug/wire relocation with long tube headers
- electric fans
- went to the track sat
- Need to know the bolt pattern and tq. # for intake and head bolts ASAP!
- how big is the difference in the vigalante 2800 and the slp 2800?
- brake locked up?
- Pull engine with condenser & compressor in egine bay?
- Question about installing head/intake gaskets...
- Need help finding turn signal relay on 97Z
- Which Plug to use with Hot Cam?
- Mpg
- 1.6 rr's
- It Runs !!!
- HELP, LOUD Knock coming from Exhuast underneath COLUM
- if i buy a K&N air filter
- Rough idle, unplugged TPS and its a performer
- Fan Mod for '94?
- New shifter install?
- Opti conversion
- th350 part question...was posted before, cant find it now
- Rearview Mirror
- Removing Intake and Fuel Lines
- COAN stall question
- Could "very loose" rocker arms cause loss of of horsepower?
- Alternative to LT4 Hot Cam Kit
- 95 tranny in a '94. Any wiring issues?
- U-Joints
- Opinions on Dynatech headers....anyone have them?
- Double Brakeout results in Runner-Up at 2003 Spring Break Shoot-Out
- Torque Limit on LT1
- pics of polished slp cai installed?
- is this normal?
- stock or not?
- first mods on 94 z m6 48,xxx miles????
- Cheapest Adapter Kit for 93-95 LT1 for SLP Loudmouth
- Vibration I can no longer stand
- Mystery sensor? Any clue?
- Installed torque converter today, my thoughts and a ??
- Is it possible to pull the heads without draining the block?
- Anyone have before/after bigger TB?
- Couldn't make ET streets stick today
- What is MALF 16: Lo-Res Fail
- Rebuild Lt1 with more power
- Header Gaskets
- people with bmr lca's
- SLP linelock question
- Info for those who claim their Flowmaster "Drones"
- weird vibration
- Questions about 2 large elec. plugs near pcm
- I'm doing my intake gaskets and I need a little help
- What MSD Coil Replaces The OEM Coil?
- Shift kit questions
- what is your solid roller grind and how streetable is it?
- Not enough Air in the Air Chamber with CAI ?
- Oliver 4 Bolt splayed caps problem...
- Switching to OBDI - Which fan mod to use?
- Need a ZR1 17x11 repaired - slightly bent
- Help build up my motor w/ me, ideas welcome =)
- went to town with armor all
- Will a 4th gen sending unit fit 3rd gen tank?
- Clutch Noise - Help
- Brake Inquiry
- Questions On 383 Stroker Parts!!!
- tpis longtubes
- What to expect w/ my new mods
- Shoebox! Can I get a part number????
- What causes a spun bearing?
- Too much play in steering wheel
- Are all replica wheels the same?
- Not your typical header gasket ?
- Spohn TA and LPE DS
- those that have removed AC evaperator and/or heater core>>
- Want to "wash" engine, what besides Opti to be careful around?
- Valve spring question.....
- do you have to bore the block for a 355?
- LT1 Slight stumble/and stalling problem--any ideas??
- throttle body help
- What's the best radiator for autos?
- Question on jegs rad. hoses.
- strange noise from spec stage 3 clutch...
- header hardware questions??
- FluidDamper dampner or ATI Dampner?
- Oil Pressure
- 6 Speed = atf trans fluid??!?
- 16" T/A Chrome Center Caps
- [Engine Pulling] Your preffered method? Drop bottom or out the top?
- ? about Lt1 Mods
- rear seal is leaking on t 56!!!
- Stupid guage question...
- New Spark Plugs - 3rd Time!!! Argh... this can't be normal! Misfire???
- question about practicality of re programming
- what is involved with changing pistons, rods, and crank?
- Hooking Up The "Harlan" Shiftlight Question
- Cant Hit Reverse
- Bypassing Oil tube that goes from Valve Cover to TB?
- Clutch/Flywheel zero balanced?
- True duals 2 1/2 or 3 inch pipes?
- How Are My Numbers?
- filters
- Pacesetter Shorties? Good or Bad?
- DOT approved aftermarket driving/fog lights?
- Where can I find a bolt/rod to install crank hub.
- companies for 92'ECM reprogramming ?
- GTP-6 cam or similar questions.
- NEED HELP with a power window motor!
- exhaust question
- Engine Miss-Fire
- 14mpg???
- Valves 16/32/8 ?
- what clutch disc/LT4 PP combos work?
- LT-1 Problem
- can i re ring and install new mains on my LT1
- ? - Using self aligning rocker with guide plates?
- Need cam part number!
- Brake Pads
- rain
- Header bolt thread size
- Tip - Gasket Removal
- Taylor Fire Sleeves help ASAP
- fuel injector o-rings
- Front end feels loose
- How many splines does a 4l60e have?
- ignition gremlins killed
- Where to mount tranny cooler?
- What mods to do with the engine pulled... ? ?
- Which gears are the best in your opinions?
- compression #'s??
- bell housing
- Question about functional Ram Air Hood??
- 17"x10" rear wheel. what tire?
- Flywheel - buy new or resurface old?
- corbeau seats
- What type of fluid does the T56 use?
- can i put control traction on a 94 z?
- Flex plate wobble?
- Anyone put and LT4 block in an F-body?
- 93 z28
- Post your dyno graph of your hotcam please.
- suncoast creations ram air hood
- slave/master cylinder and lines all come together
- POLL...10 bolt failure record?
- bad idle
- Help
- cai
- Backfiring through intake.
- Shoebox part # please!!!
- How much RWHP will this set up make and what should it run down the 1/4
- Hit a sort of wall while accelerating through lower gears
- Wheel Question?
- heads
- Where's my cat?
- What is the rectangular metal piece under the intake manifold?
- stuttering?
- Hooker catback?
- Help ! LT1 stalling - EGR ?
- cc305 cam question + valve springs
- New ET's w/ Lloyds Heads
- GMHTP LT1 Vortech install issue?
- Tips for removing driver's side drain plug?
- How can I tell if I need flat or square connector for O2 sims?
