  1. Argument needs settling on torque converter
  2. oil pressure when the car is dead cold??
  3. Its good to be back!
  4. Please help....car is running like crap.
  5. ses woes
  6. So what's the secret to working with valve spring keepers?
  7. Will a rattling ypipe give false knock?
  8. I messed something up w/ TBbypass!
  9. More than1 way 2 gut a cat?
  10. Error Code 29 AIR pump LT1
  11. stall
  12. clutch bits in filter
  13. header bolts
  14. gears
  15. A4 to T-56 conversion?
  16. Blew a fuse while scanning it??
  17. DTC 43 - Help me !
  18. Heater Core ?
  19. Oil Leak..Still can't track it down!
  20. Difference Between 12" and 18" Bullets
  21. lateral G's
  22. Mass Air..96 caprice to 97 Formula?
  23. driveshaft length
  24. JET-Hot I'm calling you out
  25. Hooker lt's y pipe nightmare
  26. rev limiter
  27. need good comp ratio suggestion for 93 oct
  28. thoughts/sound clips on selding muffler directly to Y-pipe?
  29. Should I Reinstall Jounce Jumpers?
  30. Problems With EVAP
  31. Cut-out location with hooker catback
  32. Broken timing chain....a couple of questions
  33. Anyone know 'test light' voltage?
  34. Power Steering Pulley Removal
  35. Canton Oil Pan Problems..??
  36. Serpentine belt with UD pulleys??
  37. Holley TB question
  38. What shifter did you use with your TH350?
  39. shifter knob size
  40. Wiring directions for CSI WP?
  41. install on bmr struttower brace???
  42. What years have the same timing chain and cover as 97?
  43. Oil dipstick install with LT's
  44. battery hold down brackets?
  45. ticking sound coming from front of car, seems to get faster with higher rpm
  46. Going on a trip: Oil change time
  47. SES Light, Hesitation, Car Shuts Off
  48. Car smells like coolant after driving a while
  49. is this normal?(gas consumption question)
  50. Problems bolting a stock LT1 intake to AFR 220s
  51. Is there a way to disable the SES light?
  52. Dual -> Single Cat Conversion...
  53. Is there a cam in this thing?
  54. Replacing O2 Sensors....
  55. 4.10's to much for an A4?
  56. what to get
  57. How tough is the LT1?
  58. Really need help guys!
  59. quik ?, what way does brake bleeder face?
  60. Need to move ABS module, have a few Q's.
  61. B4 I get an off-road pipe,.. i have a police ??
  62. 335/45/17 tires out back... will they fit?
  63. Custom Headlights?
  64. 93 Exhaust manifold Air tube thread size?
  65. Driving on slightly bent rim
  66. Let's all play name this piece. Attention Shoebox you'll probally know!
  67. OPEN Vs 3.0" Vs 2.5"
  68. cheapest place to get a 700R4 for a 93 Z?
  69. Whinny fuel pump noise when gas gets low
  70. engine rebuild
  71. A4 maximum HorsePower handling?
  72. guide plate ?
  73. How many F-bodies built in a year
  74. Newbie has some ignition questions
  75. Cracked Radiator ???
  76. anyone help!
  77. Any Dif performance wise???
  78. Help from those that do thier own bodywork!
  79. Anyone use the Crane Cam 210/224?
  80. v6-lt1 conversion help please
  81. Need Some Expert Trans Advice
  82. Distributor Help!!
  83. Rough idle and poor gas milage
  84. 16x7 rim, what backspace?
  85. 1.6 rr?
  86. What Are Signs of a Bad Injector?
  87. LT1 To 383 Stroker
  88. About to change thermostat. ????'s
  89. anyone converted a LT1 to carb? what kinda HP is made vs FI
  90. Broke HARD...never heard of this happening before
  91. 383 in Califronia... Well it pass smog???
  92. Which shocks.. kyb agx or bilsteins?
  93. guys with over 75,000 on the clock what oil you runnin
  94. Flushing Heater Core??
  95. Having a hard time getting the balancer hub off, any suggestions?
  96. put 1.6 rr on, need help
  97. Stock.. Paint or Powder?
  98. Hooker LT question about O2's!!!
  99. Should I get a bigger TB?
  100. Pro 5.0 install
  101. What gears? need advice.
  102. ZZ-9 on stock motor?
  103. 160 deg theromostat intall?
  104. Dyno graph interpretation please
  105. FLP Level 4 Trans & 3600 stall
  106. crack in the radiator
  107. Cat delete
  108. Gas smell
  109. anyone port their throttle bodies?
  110. Help After Hotcam Install
  111. Do the LT4 valve cover have to be modified to fit?
  112. LS1 brake upgrade???????
  113. How do I do a complete coolant flush?
  114. AC trouble and under drive pulley...
  115. ls1 fuel tanks in an lt1 car
  116. Can I have the MAF programmed out.
  117. Shifter with th400
  118. Anyone melted their stock corner markers?
  119. Synthetic Oil
  120. Electric fuel pressure gauge install??? What do I need?
  121. Looking for a location on a LT1
  122. Firing Order
  123. People with the K&N FIPK
  124. How much coolant to put in LT1 cooling system?
  125. Where is the best place to get some good shocks
  126. Vibration at highway speeds
  127. Anyone use the Hurst th350 conversion kit?
  128. Should the reserve coolant tank be filled?
  129. screaching noise coming from my mufflers
  130. How much coolant is needed to fill the system?
  131. Dyno2000 file
  132. PLEASE help me figure out why my car is running bad!!!!!
  133. Motor
  134. Do air foils work?
  135. Cheapest place to get Loudmouth?
  136. New engine, what oil to start off with
  137. 436 rwhp/418 tq. ... shootin' for high tens on motor!
  138. HELP! What Type Of Sealant To Use On Gas Line/Finttings??
  139. fuel pressure regulator
  140. Low MPH???
  141. wow...item on ebay
  142. putting Ice bags on my intake
  143. Removing Rivits off old Ignition coil mount
  144. A4 lost 1st &4th
  145. sounds like there is a cricket underneath my hood
  146. exhaust hangers
  147. First Time doing Window Motor Question
  148. Sfc
  149. borla problems
  150. Messed up Threads on Exhaust Bolt
  151. Will these wheels fit?
  152. Convert engine from MAF to SPEED DENSITY
  153. What to do with this line with vented opti swap
  154. Optispark
  155. tires for my formula
  156. what does a major exhaust manifold leak on both sides cause?
  157. Loudmouth or Borla????
  158. Low coolant light. New radiator has no spot for it????
  159. What to do first?
  160. cam only dynos
  161. vapor canister
  162. 160 deg t-stat?
  163. little help please!!
  164. spark wires configuration on opti?
  165. Dipstick and 4 bolt splayed cap (oliver) question
  166. Knock Module & Coolant Drain Plug Removal
  167. 4L60E are all years interchangable????
  168. sensor in the driver head???
  169. Would I see a gain from bigger TB
  170. Which Balancer Should I Get?
  171. 4L60E to a 700R4
  172. Looks like I'm pulling the motor...
  173. ?passenger plug wires?
  174. power lock proublem
  175. Wiring switch for fans on a 93?
  176. Grotyohann y-pipe??????
  177. LT1/4 balancer hub
  178. what spark plugs?
  179. Can JB Weld seal a hole the size of a pinhead on my A/C line???
  180. How did you seal you leaky y pipe???
  181. Please Help Me!
  182. Got a cracked rim...
  183. HELP: Rough idle and VERY bad gas mileage
  184. jenny craig?
  185. HAHA Odometer Idea, read
  186. will i smog with these mods??
  187. help-replaced h2o pump,no fire @ coil?
  188. suspension and computer tuning
  189. pro 5.0 shifter with hurst nob?????
  190. question about takin gcat out and sound with flowmaster
  191. is slp cai gonna help with mpg?
  192. spintech exhaust
  193. next part
  194. What kinda of HP numbers with "insert cam here" and 100shot of N20??
  195. GM C5 front brake brackets?
  196. 700R4 to T56
  197. 13.0's with stock manifolds....anyone?
  198. offroad pipe
  199. o
  200. t-56 owners
  201. AS&M shorties, what kind of gains?
  202. Difference between 306 and 305 tuning?
  203. removing front swaybar.. pros/cons?
  204. Where to get headers coated in Dallas
  205. How much should I ask for my car?
  206. Edelbrock headers? and and air foil?
  207. What brand flexplate w/ 383 and th350?
  208. Lock cylinder R&R
  209. Alright I want some headers..
  210. need help with rebuild stuff
  211. what intakes?
  212. Advice on 383
  213. Is this gauge swap possible?
  214. car acting up, need advise
  215. How do i know if my SLP 2OTL has a silencer in it????
  216. LT1 Motor Mounts
  217. Where to get neutral balanced flexplate
  218. Ball Joint Question
  219. jet injectors cleaned?
  220. 1997 Camaro SS RK Sport edition?
  221. Need Help! Car Wont Start!
  222. Those of you with stutters, shakes, and hesitation under light throttle...
  223. Et Street Problem!!!!!!!!!!
  224. car starts but not on the frist try
  225. banks 1 and 2 lean condition
  226. Taillights Melted!!?
  227. Problem With Z
  228. cheapest cats that fit for true duals/longtubes
  229. Oil presure '94 Z28?
  230. Where can i find it
  231. Thinking of buy a vette
  232. Dyno Numbers on my LT1...
  233. which mobil 1 formula
  234. Whats wrong with my long term fuel?
  235. I need help and fast!!!!!!!! Please anyone!!
  236. No Tach or Speedometer
  237. 2otl
  238. Is this a good deal on z28 need advice
  239. SES Light...
  240. Removing dash panel
  241. U-Joint size for a 95'
  242. Vss wire ?'s A4-M6
  243. gear input
  244. Best LT hedder ?
  245. mac installation problems
  246. Car Totaled
  247. Fel-Pro Header gasket Q???
  248. Header Question...NEED HELP QUICK!!!
  249. car wont start on first crank after it sits
  250. NASTY sound...like marbles in the intake, TAKE A LISTEN, Help please!
