  1. Transmission Problems
  2. Machining costs
  3. 230/236 or 236/242 in a daily driven 383?
  4. Is it my Opti-Spank???
  5. another optispark solution
  6. To Anyone who thinks it may be the Optispark!!!
  7. O2 sensor question
  8. Help with LT1 stroker....
  9. Is there any known PROPER way to port/polish MAF's?
  10. Sound
  11. predictions for me......
  12. Y-pipe for 97 WS6 dual cat
  13. Crazy ass SES light, plus a few codes
  14. another bolt size!
  15. 1/4 mile times?
  16. Crank Sensor Plate?!?!
  17. Need help! I have a couple of things goin wrong with my z
  18. Adjusting Roller Rockers?
  19. non vented opti to vented opti, whats required?
  20. LT4 Hotcam and an A4...
  21. were to mount ZEX box???
  22. Rebuilt engine, started it tonight, blew oil everywhere, oil filter adapter to blame?
  23. Another freakin' stumble problem..
  24. Searched and I still have an !egr ?
  25. ABS removal question
  26. automatic shifter
  27. Pushrod length and compression question...
  28. Finally got to weigh my beast.
  29. Hotcam P/N needed
  30. Transmission
  31. lt1 thermo vs regular sb 160 thermo
  32. 383 Dyno Results
  33. 383 Stroker kit?
  34. Best place to buy...
  35. afr heads on ebay, new...
  36. Dipstick Solution
  37. Oil pressure ?
  38. car runs rough after it gets warm
  39. diff. between powerforged pistons and forged
  40. Valve Cover Breathers
  41. E.T. and HP question
  42. 2 Quetions: About to Install new cam.
  43. Tire rim and tire ?
  44. Adjusting valve lash
  45. How much refrigerant to fill A/C?
  46. 10w40 ???? got a case of it can i use it?
  47. Post any engine swap tips you know!!!
  48. What valve springs for 383?
  49. If I dynamat my whole car, will my cutout still resonate in the cabin???
  50. Flashing SES, now it stopped (Already did a search)
  51. O2 Sensors question
  52. SLP strut tower brace
  53. Will a 97 dash work
  54. Has my opti gone again
  55. newbie question
  56. EGR valve
  57. Got my valve BACK UP... now how do I find TDC?
  58. 396 or 383 which one and why?
  59. a/c quick question
  60. clutch sensor giving me problems....how do i bypass?
  61. HELP ME!!! still stuck....with no money for the dealer to fix it
  62. How do I remove oil pan while engine is still in the car?
  63. What Does Jason Cromer Charge For The HotCam Kit?
  64. front upper control arm install?
  65. Cam recommendations for 396 solid roller?
  66. I'm Stumped!! My Starter is possessed!!!!!
  67. What size is the plug above the oil cooler?
  68. Dyno tune in CT area!????
  69. Re-installing M6 Trans
  70. Installing a CSI Pump have a ?
  71. air pump removal Q's
  72. RR question
  73. lt1 cam in ls1??
  74. The LT1 is going in this weekend. Just a few quick problems I need to resolve
  75. Dynomouth to loud for highway driving?
  76. What do stock (or very close) LT1's put out on the dyno?
  77. Quick question about pulling the heads...please help
  78. 11.77 in 1/4 all motor???
  79. New z28 owner what would...
  80. Electrical Problems: Need help FAST!
  81. adjusting 1.6 SA RR
  82. Small bufu in engine reassembly... Need some part numbers #
  83. Possible issues with 1.7:1 rockers on LT1...
  84. need a little help here
  85. Replace anything else with headers?
  86. any way to make my power windows have more hustle?
  87. hotcam + headers = fun fun fun
  88. security light
  89. Newbie has optispark questions
  90. headlight fix problem
  91. What gears do i have
  92. Opti alignment question
  93. Is my frame bent ? (pic inside) .. car is lopsided
  94. Starter trouble :(
  95. 95 Ta
  96. How do you calculate Gross Valve Lift, using different ratio rocker arms?
  97. Cheapest place for Drag Radials?
  98. input shaft wont turn in pilot bushing
  99. Yokohama or Firestone?
  100. Got 200$$ To Burn... Name What I Need...
  101. v6 spring users inside please i have ?'s
  102. Best mods
  103. my car runs like a 6 banger! WTF
  104. Good track day, bad drive home
  105. cai
  106. Flow Master
  107. Anyone have some GM diagrams of the wiring?
  108. HELP!!! melted my clutch reservoir
  109. Where is Driver side Kick Panel?
  110. HELP! air bag light is on and stereo buttons don't work
  111. trans mount whats a good one??
  112. What do I do with the traction control button?
  113. How to do a t-top conversion?
  114. Stuck heater core hoses HELP!
  115. 1LE elbow
  116. cc 230/236 ok to spray?
  117. e-cutout undercar wiring
  118. anyone seafoamed their LT1?
  119. opti spark question
  120. where to buy optispark?
  121. Lost wheel key, what options
  122. Best shifter to get
  123. CC306 Question
  124. M6 Transmission Experts, Please Help!
  125. D or OD
  126. Battery relocation kit
  127. Amazing new times!
  128. Temp?
  129. Car wouldn't start?
  130. timing chain
  131. buddys 94 Z has a 110 mph speedo??
  132. Whats the easiest way to change the rear end fluid?
  133. Gain with duals over catback..
  134. When installing water pump..
  135. Where to find fuel rail covers?
  136. two questions
  137. Anybody have a pic of inside of T56
  138. Head Legality
  139. Anyone have pics of Z06 rims on a 93-97 Z?
  140. Ported Throttle Body...
  141. HELP...Can't get the front shock off the top mount
  142. Wp
  143. 14.5's for a LT1??
  144. fuel economy
  145. Guage cluster/odometer information needed - broken needle
  146. when 10 degree valve locks vs 7 degree?
  147. Is it really important to flow match the inj?
  148. Research over opinion
  149. 93 Z28 no start
  150. More questions on LT1 383..PCM, heads, Etc.
  151. Where should my WP Drive shaft seal be?
  152. TUNING SPEED DENSITY??? What Options do I have?
  153. Starting Issues If Car sits More that 24 Hrs
  154. pushrod length checker
  155. Broke stud and pushrod.. what fun
  156. what times to expect with these flow numbers and hot cam kit!
  157. Head Porters inside!
  158. Changing Cam Springs...
  159. Help Guys I Need A Clutch Reservoir
  160. Where can I get my brakes cheched out
  161. Aluminum Flywheel is in!
  162. msd superconductor 8.5mm
  163. problem with the idle
  164. New power stearing pump!! Help!!
  165. Mystery Misfire
  166. Using a B&M shift improver kit ?
  167. Adjusting Values..please help
  168. is it just me, or do LS1's make much more power than LT1's with less total money?
  169. lt-1 cams
  170. Sent for lt1 edit today, how long
  171. need a cam
  172. Any word on Edelbrock heads for LT1?
  173. what next??????
  174. few questions about SLP header install
  175. Am I a factory slug?
  176. New rocker studs needed for CC 1.6 pro-magnum self aligning rockers?
  177. Air Pump Questions...please help
  178. Do I HAVE to do the vented opti with the cloyes?
  179. LS1 o2 sensors on LT1?
  180. Oil in vacuum line from vc to tb????
  181. I need a new block, Where can I get one cheap???
  182. The best tires out there
  183. What are the most common problems with the T56????
  184. LOL haha look at this performance part!!!
  185. PART No. for 1 Silver Plastic cap that goes Over the Lug Nuts on 10 Spoke SS Rims??
  186. what's the difference between the z28 and WS6 or SS springs
  187. Fuel Pressure with 30# injectors
  188. Send me your MSD 6AL instructions!
  189. What Next?
  190. Trans/speedo ??
  191. Headers
  192. Need "help" Picking Cam :)
  193. Get Bent
  194. Timing advance and retard.. could i do it manually?
  195. What the heck is an F1?
  196. Please HELP! Trying To Decide What To Do With $3k+????
  197. What is the difference between b-body and f-body lt1 engine?
  198. HELP! I was driving just now...and all of a sudden...
  199. What exactly is a 383 Stroker?
  200. Hookers any good???
  201. Lining Up Hub/Balancer to #1 TDC
  202. cam install done;ran fine for a day, now wont start
  203. Dyno #'s and Converters???
  204. need help w/ driveshaft
  205. Hood supports took a crap
  206. Fan comes on while city driving
  207. braking in new cam
  208. Whats CAI
  209. MSD 6AL Install....
  210. Change in Thermometer
  211. Moser 12 bolt whine!
  212. Will 6speed car bump start even with VATS broken
  213. race fuels
  214. Low dyno numbers with headers
  215. header plug up?
  216. low coolant light?
  217. 94 Z28 A4s with factory 3.42s ??
  218. Stall converter
  219. How do I bleed my clutch?
  220. Which of these two sizes would you get?
  221. Open headers
  222. Retorqueing Heads Necessary
  223. What am i looking at?
  224. Td Performance Oil Sandwich Adapters
  225. Is my combination going to work?
  226. ****ing Egr
  227. Anybody know the weight of the factory seats?
  228. AS&M header gasket ?
  229. need help in some kind of lowering spring/shock combo?
  230. Misfire issue still persists
  231. Can I buy a LT4 KM at a dealership, or Autozone/Kragen's???
  232. Will these tires fit??
  233. ricer clown is CRAZY
  234. Just got my page up!!
  235. exhaust cutout
  236. Whining and vibration Problem in my 10 bolt
  237. Questions/gripes about AFR 210s
  238. Is It Possible To Get A 94 Opti 180 Off?
  239. Experts with tts data file
  240. a quick rust question!
  241. Trapping
  242. Are they the Same?
  243. 210/224 or powermax 2033 power production
  244. How do I plug EGR fitting on MAC passenger side header???
  245. Autotap on an OBD 1 car?
  246. Help with off-road pipe!!!! Please help!
  247. uhhhhhhh no..please tell me it ain't so!!!
  248. Motor mount bolts question..
  249. How much diff between 3.42/4.11's
  250. Magnaflow Bullets?
