- What is that plastic hard line coming out of the fuel lines??? I broke it...
- Magnaflow Exhaust
- Removing Throttlebody shaft
- Racing 02 Sensor
- Msd 6al ?
- Installing new CAM in '93 Z
- Shoebox... Need Ur Help With This...
- LS1 brake upgrade question
- 2 questions relating to exhaust!!!!!!
- what does this head casting# fit 12551561 i need to know ASAP
- How to rebuild a LT1 to make....it fast LOL?
- Which shocks to buy?
- BMR LCA Relocation bracket Q's
- Scanmaster Repair
- now when i turn on the AC...
- Is a cast crank OK w/ n20?
- little metal pieces on bottom of head
- How many of you are using the stock tips with your aftermarket muffler/catback?
- Throttle body spacer plate??????'s
- 95 opti required for cloyes chain?
- sputtering
- What do think this car will run in the qtr.
- fouling plug #7 & #8 cylinders
- window leakage?i can see water comin down where the speaker should be
- clutch's
- Is this a trans or computer problem??
- Computer Question
- dirtiest lt1 ever! (pics inside) need advice!
- air induction?
- Anyone replace their Upper A-Arms?
- Plug & Wire Change, need help ASAP
- Vortec
- Throttle bodies
- where do I start making it better.
- Fuel Pressure
- Different timing gaskets for different years?
- Back from the track..new times..CC306 STOCK HEADS
- LT1 has no power and makes clacking noise
- serious feedback needed
- How much to get driveshaft balanced?
- 1LE elbow?
- what is the correct way to check trans fluid
- Need a motor
- what are the signs to get an engine rebuild?
- Drop the pan or flush?
- Anyone have a granatelli fuel pump for their LT1?
- i know which is stronger
- Help!! With timing cover install
- fuel level gauge
- Antifreeze Disapears
- LT4 intake - LT1 heads
- Siemans Deka Injectors any good?
- How do they Port Heads?
- Question on dropping the engine
- WHAT do you need to use to pull the stock rocker studs??
- what to get
- whats the problem?
- Info on tornado air
- Hotcam Info
- A.i.r ??
- Hotcam: To keep, or to cc306??
- Removing AIR System on 97
- Oil cooler???
- Now its time to say good nite to the Bad Guy, Need help with storing vehicle.
- tires
- Spec 2 or 3 clutch?,- if 3 then what kind?
- ideling in drive way and boom smoking bad
- Idle problem
- Impala Starter = Camaro Starter?????
- lt1 drivetrain swap
- What heads to go with
- how long does it take for the pcm to register?
- Please Read and comment with chugging problem at 1500-2000 RPM
- Need New battery suggestions
- Opti Question
- Stock Temp Stat & 160 Deg Stat
- infamous Low end hesitation problem.. now a dead LT1!!
- Need help with test questions (tech forum related)
- Hot Cam: before and after (READ!!)
- How Many
- Everyone with a CC306 come in!
- Flooded?
- Any difference between 93 and 97 heads?
- Heads are off ... How Can I Clean Carbon Off Pistons?
- First Time Changing My Own Oil?????
- Lucas Oil --- Good or Bad?
- timing order?
- port specs for the hotcam?
- Both of my headlights stopped working..wtf?
- Can you drive with rusted rotors...
- Will a LS1 drop right into an LT1 body?
- LT1 Corvette Question?
- Walbro 340 install
- BBK Underdrive Instructions
- Anybody have a part number for a pcm?
- water pump gpm flow specs
- what could drain a battery while the car is running?
- exhaust question
- Stock heads flow.........
- what's your RPM when doing 150 mph??
- Should this LS1 beat me by this much?
- Egr Block Off Bolt
- power door locks
- Setting pinion depth
- Hooker Long tube leak question
- What is the best traction mod?
- Dyno shows high rpm break up, valve springs?
- Deleted A/C, PS, what belt size?
- is anyone running the same et as a hotcam with a 306?
- Jet Hot headers?
- should I get a high-performance tranny rebuild or cam and accesories?
- Brakes
- How much are the rear rotors?
- What are my stock cam numbers?
- one low beam one high beam
- ok keeping the car gonna try and fix it all
- Powerwashing tranny ok?
- widest tire for 17x9 WS6 wheels?
- roller rockers
- Guys running in the 10's all motor, where do you shift?
- Wiper Blades
- Jack points
- LT4 with a LT1 computer
- For all you QA1 Hal Users...I have a question...
- Built 4L60E
- Surging and hunting idle after porting MAF
- What Headers?!?!?
- pin on cam help!!IMPORTANT
- Help please!
- Looking for sound clips of the Hot Cam, cc305, or custom grind w/similar specs.
- Nitto 555R Drag Radials Vs Road race tires ???
- Cams??
- Popping noise
- Plug in Engine Compartment?
- Grinding/Vibration from car when you accelerate hard!!
- question: LS1 brake upgrade problem
- Opti drive to cam bushing?
- 355,383,396
- Need Some More power 52 tb??
- Its Alive!! Thanks to All!!
- ASP 945100 - who to buy from?
- Anyone Using Exide Orbital Battery?
- EBC greenstuff not available, what's the next best?
- Cheapest place to get a Ford 9
- Replacing Convertible Top
- hardtop vs t-top weight
- 94' Corvette seats
- Installing HOT Cam and Opti Conversion, have a few questions....
- Headers - 1 Msd - 0 Where to find MSD connector
- Carbon on pistons...clean it off or leave it?
- Need ideas on tires??
- Water pump replacement
- fluiddamper vs. ATI?
- HVAC problem
- Swapping steering wheels, do i have to worry about my airbag deploying?
- on my 4th opti. they only last a week, why??
- Thought on Reversing Rotation of Directional Tires
- What cam for LT4 cc306 or LT4 hotcam
- cc306 in LT4... what do I need?
- 108 mph Rev Limiter...
- Open Loop, how does ECU know how much fuel?
- 3 different size head bolts or 2??
- Need opinions on weird oiling problem
- 5.0 sounding exhaust
- Where To Get A BFG Comp TA 275/17 Tire From?
- Fresh Z-28 Canvas
- A4 shifter trouble
- where to get opti?
- Can I get any more HP?
- Where to find Electrical Connectors
- Motive or Genuine GM gears? Help please!!
- INstallation of NOS?
- My MC went dry... how to bleed?
- Why are opti's so expensive
- tuning for a hotcam
- rear/front rims will not interchange??
- Fuel pump died today. Anyway to get the car back started and tips for a new install?
- Operating temperatures with Evans NPG+?
- Tuning with 93 & Long Tubes
- New LT1 harmonic damper from Jegs
- Port & Polish
- LT1 intake/hotcam
- New2 to the game....need some expert advice
- Cruise Control...
- 4.10 or 4.11
- In the middle of a clutch install and need help ASAP!
- New rear?
- lt4 knock module
- Should I or shouldn't I?
- centerforce df clutch, opinions please
- Transmission pulsation / vibration
- cheapest place to get uncoated LT's
- OK gurus, who could answer this?
- Will a third gen Torque Arm fit LT1 car?
- Ignition switch broken
- Update on the car
- Which head gaskets for a standard 30 over bore?
- Two Exhaust Questions
- SLP Transmission Improvement module for LT1 auto Trans
- Porting/polishing LT1 intake
- CC305 Idle Video! Yup, still playing w/the new camera
- I'm screwed, lost only ignition key, key made using VIN doesn't work.....
- Paging ShelbyZ28
- Why is it harmful to use a three-toed puller to pull the balancer off?
- underdrive pulley???
- LT1 engine file for dyno2000
- Has anyone done business with Speedautomotive.com?
- nitrous cam good or bad
- A/C Hose - Anyone know the GM part #?
- question for those who has a rev limiter in the redline
- Strange problem at 120 mph
- 2.73 or 3.23?? PLS help me decided...
- lil cam question
- Roller rocker and Cam guys inside!!
- lookinf for install guides on web..
- throwing a rod
- GTECH question
- 94 Vette A4 and 95 Fbod A4 interchangable?
- abs light
- Whats your 383/396 gas mileage?
- Oh man, hope my gears aren't jacked!
- Do I need new o2's?
- for a friend: a 383 or 396 with CC306 cam?
- Post Pics of your exhaust cutout
- My slow vert
- Moser 12-bolt folks; gear oil coming out of vent tube problem
- Car shorted out this morning
- More suggestions needed for rough idle.
- Intake Manifold Question...
- Engine's Out - Decisions On 383
- Suspension...what's first?
- 94 Z28 Hvac System
- Fastest 350ci LT1
- Which starters are you guys running?
- 93 to 94 and up Intake.
- Car is cutting out bad under load. . .
- Help Hot Start Problem
- Pics of engine bay without A/C and power steering.
- RK Sport adjustable shocks?
- Header burned heater hose.
- spohn torque arm and lowered...
- Question about the MAC header gaskets?
- looking to install CSI elec. water pump
- what is the widest tire i can run on a 97 ta
- Size of stock Intermediate pipe?
- What shift for 93 fomula?
- anyone here running a CAM MOTION cam?
- Where is redline on LT1 tach?
- DMH Performance
- 383 won't start - fuel fouling the plugs - PLEASE HELP!!!
