  1. checking ses codes-ses light off when ground??
  2. Rough Idle ????
  3. well, i too have the gas smell but...(long)
  4. Got the car started.....kinda
  5. Wiring for A4-M6 swap
  6. Bilstein BTS suspension package...
  7. 94 T/A turn signal trouble
  8. Top End?
  9. Code 11 ?
  10. quick question about coolant levels
  11. opti ?????
  12. replaced tbody set ses light
  13. fuel question
  14. Can I get a 98+ T-56 to fit my 93?
  15. Drive shaft vibration????
  16. Simple M6 questions
  17. surging
  18. A little help Please
  19. ? about carbed lt1
  20. Comp LT1 timing chain
  21. Quick Rocker Question
  22. Shifter Question
  23. Knocking noise explained inside help
  24. How do I calculate my inj duty cycle???
  25. Coil problems..HELP!!
  26. SES light on stock car
  27. valve size
  28. Few Question on NOS and a rebuilt motor with a CC305
  29. LS1/LT1 Y-pipe ??
  30. Hardened Pushrods in 383
  31. HELP! dropped valve partially into motor :(
  32. Advancing/Retarding LT-1 camshaft
  33. Water pump question
  34. Would this be a problem with VATS?
  35. PBR calipers, C5,LS1 calipers
  36. OMG Cant Drive Car!!!!
  37. jegster torque arm? anygood
  38. 9.1 1/8 = ??? at the 1/4
  39. Turbo Request Today
  40. FelPro vs. ARP Head bolts?
  41. where can I get the rear bumper for my LT1
  42. steering column
  43. installing svo injectors?
  44. How would this sound BBK Headers with Borla exhaust and maybe cutouts!
  45. People who did m6 conversion inside please!
  46. Cutting rear springs!
  47. Coolant light comes on...
  48. How much and what kind of forged pistons....
  49. Moroso Install on 97z28...help!
  50. What do all the wires to the heated oxy sensors do?
  51. 50/50 weight transfer front-back...how close are we?
  52. New LT1 owner
  53. Best place to buy Borla??Please help!
  54. 355 build ????
  55. pulling motor
  56. moser good : ) ????
  57. Magnaflow vs. Dynomax exhaust question
  58. How much $ to run low 13's?
  59. Mod's Needed To Beat LS1???
  60. exhaust hanger at end of trans. wont fit !!
  61. H/C setup?
  62. Need some feedback on my Ported heads
  63. FreeScan Help
  64. Spec Clutch!
  65. Government Cap?
  66. Air Dam
  67. What are symptons of a bad wrist pin?
  68. Oil leaking at block....
  69. SES, code 26, HELP ME !
  70. Tach just went crazy!!
  71. A4 Shifter Knob
  72. car finally back together onw question??
  73. Will I need lifters?
  74. Where does this wire go to.....
  75. signs of failing maf
  76. SUbframe connector install help...
  77. i'm new here..=) and i have a question..
  78. left turn signal??
  79. stock exhaust size
  80. Dyno Techs or Thermo inclined people IN HERE PLZ
  81. not your average opti question
  82. Trans-Go shift kit
  83. Question on Kumho's 265/45/16 tire?
  84. How does a MAC muffler flow?
  85. 17" Rim on Convertible?
  86. My Camaro get's hot
  87. Need Help, Seek Opinions
  88. Torque Converter lock up switch on the dyno?
  89. Goal...0-60mph in less that 5sec. Help!!!
  90. Can someone decipher these Alignment Specs?
  91. Tach help...
  92. some sort of leak
  93. rear main seal direction
  94. Maximum valve lift on 350 LT1
  95. how much torque does the starter put out?
  96. What should i get for my birthday?
  97. Hooker 1 5/8" shorties?
  98. How much cooler with new rad?
  99. Which FanMod Wiring is Correct for my Car?
  100. Seafoamed a few days ago and have hard cold start...
  101. Spark Advance
  102. Those who run 396 solid roller, what dur. are you all running out of your camshafts?
  103. Parts list for conversion to 95+ Opti
  104. Any Idea on my Power?
  105. TransAm doors on Camaros Question
  106. Header Installation
  107. can i run 245/45/16's on stock wheels
  108. starter problem...NEED HELP
  109. 160* thermostat????
  110. tranny problem????
  111. Converter Troubles??
  112. turn signal and blown fuses
  113. Questions on a 383 Stroker
  114. SLP shorties! Help!!!!
  115. Anyone have cutout pictures?
  116. What shocks to run with Eibach Drag launch kit?
  117. 93 T56 Owners w/Gears
  118. Failed Emissions any ideas
  119. Great service at Thunder Racing!!!!
  120. Need Help quick with Power window!!!!
  121. Want some new exhaust any advice?
  122. differences between years
  123. Freescan will not work with 95Z
  124. Loud screech noise after car is turned off?
  125. dimensions of SFC's?
  126. abs inop?
  127. Will 255/50/R16 rub up front?
  128. 17x 11's worth it?
  129. Anyone with
  130. headers or cam
  131. Anyone use the rear brake caliper shim to stop the squeak???
  132. AS&M Headers
  133. H2O pump w/ opti?
  134. Top dead center / timing mark is off ...?
  135. what kind of horse power should i see
  136. Question about Jason Cromer and need a part number?
  137. Car wont Crank...very low voltage
  138. Electric Water Pump and routing the accessory belt
  139. How many hours does it take to take out and put in a new tranny in a 96 A4?
  140. O2 Simms......
  141. question about starting car after HOTCAM install!?!?!
  142. just got screwed by autoshop
  143. 3:73's making noise while coasting
  144. Optispark!!!!
  145. Need Help on heads I am thinking about buying
  146. SLP headers any good????
  147. Help! ANyone have sound or video clips of 383 w/ @224/230 dur. cam?
  148. Dyno Results
  149. Comp Cam defect
  150. which headers to buy
  151. Dyno Tuning on my 93 Speed Density LT1, what options?
  152. Dyno Results - Heads and GM 847cam
  153. Quick Question Bout Balancer Pulley
  154. cnc lt4 heads at pace parts for 2100
  155. seafoam too often?
  156. Question for those who've removed their front swaybar.
  157. CC 242/248 vs. 248/254
  158. doing cams, what else should i do?
  159. Anyone Ever Encounter This Problem.
  160. Problems Running System Diagnostics
  161. Where can I find this cam????
  162. no more cats
  163. Went to the exhaust shop today...
  164. 4L60E troubles
  165. HELP! eXHAUST IS SPITTING OUT WATER AND ANTIFREEZE
  166. CSI install, temp sensor wires wont reach
  167. Need Your Opinion! Cam or N2O?
  168. Help!
  169. Plugs mess up performance a lot?
  170. Reliable? Expensive?
  171. AS&M headers or LT?
  172. CM heads
  173. LT1 heads, aluminum or iron?
  174. Whats with 2000 RPMs?
  175. Will lower control arm relocation brackets really work?
  176. how many optis have you guys been through??
  177. Trans slips in in gear (A4)
  178. Can I reuse water pump after vented opti conv?
  179. rear gears
  180. LT4 XTreme duty water pump gear... help!!!
  181. car wont start
  182. Link on how to do ls1 brake upgrade?
  183. Fuel Pressure Question?
  184. SES and the electric fans
  185. HELP: How to get top and bottom bolts of steering knuckle off(have searched)
  186. Can I make this work?
  187. My car is running....
  188. EGR block off question
  189. WTB:LT1 Edit used. Got a few questions first.
  190. HELP!! How hard is ti to remove crank hub????!!
  191. Cheapest Place To Get GEARS???
  192. LT1 to LS1 Brack Conversion
  193. Question about water pump drive gear??
  194. Corvette wheels on a camaro.
  195. cam swap...now car runs like dog poop, help!
  196. LT-1 Fuel Injectors for 94 Camaro
  197. GM Extreme duty timing chain question??
  198. Borla - LS1 to LT1
  199. lt4 extreme duty timing set
  200. Catylic Converter broken?
  201. any luck with toyo tires
  202. Another stupid wiring question...
  203. New LT-1 Owner...please help me out!
  204. 17x11s Pic please
  205. will a 96 rear end fit on my 93 TA?
  206. Jegs balancer
  207. Oil leak....I've replaced numerous things and STILL can't sort it out; ideas???
  208. Fresh Offf the Dyno - Hotcam #s
  209. Where can i find 875-16 lifters?
  210. oil type for 94 Z
  211. Big Problem
  212. Where to find torque specs for steering knuckle?
  213. headers, worth it???
  214. MSD 6AL: How hard to install?
  215. Bolt sizes
  216. Is there a formula for finding seat pressure?
  217. Strange Leak-Going Raditor
  218. Help My Ride-Formula 96
  219. Symptoms of...
  220. Brent Franker's Head Light Gears Rocks!!
  221. head&cam package
  222. Need link for online parts salvage databases
  223. Heat soaking causing random misfire
  224. these 1/4 mile times seem right?
  225. Good Head and Cam setup?
  226. Suggestions on Dual Exhaust
  227. Octane booster=Service engine soon???
  228. T56 conversion finished!!!
  229. Power window to manual???
  230. need some simple info.
  231. Which Cat should I get
  232. flp headers #5 spark plug
  233. SLP Lvl 1 Suspension
  234. Carbon Fiber Drive Shaft
  235. Finally got to drive my Z with my new headers!
  236. Pix of Hella Driving Lights
  237. what's the biggest cam I can go with
  238. Help with Air
  239. Ahhhhh, she is healty once again!!!
  240. Brake Break in Procedure
  241. Raven Mufflers
  242. 224/230 worth the extra money over hotcam on stock heads?
  243. 3400 stall = no traction
  244. th350 problems HELP!!
  245. hey guys if you have an extra $20 GRAND come register this site
  246. Looking for sound clips/video of 383 with 230 dur. smaller cam
  247. Rear ABS Unit Sensor
  248. C5 Caliper Adapter
  249. Universal Joint and Strange 12 bolt yoke
  250. a few questions
