- Vorteh elbow
- how do your springs feel (sportline, pro kit, drag launch, etc.)
- May have the wrong part number....
- my car shakes some
- should my alignment be THIS far out after LS1 brake upgrade?
- Asap!! Please Help Quick!!!!
- Need help getting catback apart..
- Installing hooker LT's , Having problem's installing around Vortech T-trim
- Popping, Misfiring in 95z
- Anyone ever see a optispark blow up internally?
- rocker arm install, crank turns which way??
- 90/10 Camaro Struts??????
- ran a 13.8 today...
- u-joint question
- What do you think about those SFC?
- Getting fuel lines off
- Gen II LT1 block...help ASAP!!
- VERY bad day at dyno
- Thread size?
- Trunk Measurements
- first day at track with 94z
- anti lock inop
- gear change
- My filter came off of my FIPK, please HELP!!!
- 300 RWHP possible with stock cam and stock heads?
- Cai
- How do you know when your master cylinder or booster is bad? help
- Ngk Iridium Spark Plugs For Camaro
- oil pressure gauge question
- SHOEBOX gotta question for ya...
- fuse problem
- Need help...
- Waterpump replacement
- Help!! Help!!! Help!!!
- L88 rat motor question?
- Fixing head gasket, need part numbers for all gaskets needed..
- oil leak puestion
- need help ASAP!!!
- Power loss 'caused by bad Opti
- LCA Relocation Brackets worth it?
- manifold porting
- need walbro fuel pump info
- price to change power steering pump
- Idler Pulley Noise?
- Post Storage Maitenance Questions
- possible exhaust leak. Muffler upgrade Options?
- new headers & y-pipe
- help me appraise this car
- opti O-ring seal, is it needed, ASAP!!
- Replacing C-Clip in Rear End
- cooler plugs for 11to1 compresion?
- are RR hard to install?
- Intake valve closing point of LT4 hotcam
- hard to start after fuel pump install
- How to....
- What tire pressure for skinnies?
- Cyberdyne boost gauge... how to install!!
- Is This Safe?
- the cheapest place to buy longrubes.
- Newbie coolant question...
- Heat sink compound for ign. contrl. mod.
- Jet Hot LTs are done!! Pics if you want em!
- What can I use to plug the holes on my headers?
- o2 and fuel filter
- Help I'm stumpped!!!
- Grinding 2nd gear, WHY?
- Want to be atleast in the 13's need help
- CAI makes a huge diff.
- 1998 Lexus SC400 vs. Z28 M6
- 383 dyno numbers?
- new intake idea
- ebay does it again
- Healthy Place for rev limit
- overheat at idle 94Z28
- what is wrong?
- Convertible Top Cleaning?
- My trans is making noise
- now why cant u have true duals coming out the back?
- Does anybody make this any more?
- enter all electical masters
- Car Popping When I first Start It.
- hp gain with hooker LT and cat back
- Number Cast onto Block??
- help.......just bought 1.6rr's
- Does anyone have a new web address or e-mail for SPEC (Star) Clutches???
- Single Cat Header Conversion Questions??
- reading obd1
- What color is the OEM opti in 94's?
- ZZ409 cam, LT headers, Hooker Catback...HOw will this sound
- Beware Of Inspection, Listen To This Bs!!!
- Just changed Evap canister...Still have gas smell!!!
- EGR Question...I searched first :-)
- Valve Cover Gasket Leaks after !EGR
- when to change o2's?
- Blinker short circuit
- Lowest profile 16" tires for 4th gen Camaro?
- Stuck in 4th gear
- Trans Mount on A4
- Part # for heated O2 sensors
- what does ttt mean on the sales board?
- !Air Conditioning
- Finding oil round base of Throttle body
- LCA Bolts?
- squeaking brakes!!
- used lt1
- I think my reverse lockout solenoid is out...
- Cheap Upgrades
- VATS and EGR
- Clutch Install, Question
- LT1 Engine Damage Pics (rods specifically) needed
- LT1 wont start while cranking, but pops after letting off key?
- Manual Fan Switch
- What do you think of my set-up???
- Stupid PCM question...
- confused :( (rear brakes)
- Some advice needed (programming, future mods)
- How about these Mods?
- EGR code
- washed engine, now it will not start!
- How far off will my spedo be?
- Replacement filters for SLP CAI?
- broke a stud off the ypipe...what now?
- LT4KM where can i get this and how do i instal it?
- K&N factory replacement filter
- Tire Size Question
- VFN hood... bolt-on or pin-on?
- LT4KM Worth it?
- Moroso CAI
- Should I mod my Hawk???
- Where can I buy a new 4L60E A4 transmission
- can i have my car vavumme tested?
- Gutted cats on a lT1, and exhaust question??
- SS Ram Airbox question
- Help Quick, I think its a bent 3/4 fork
- Iridium spark plugs worth it?
- shifting question
- anyone build their own sub frame connectors?
- Safety issues and body alignment regarding removed bumper supports + rollcage
- Motor Swap!!
- Cheapest price for a 94 Opti?
- aftermarket muffler fitting in stock setup??
- how quick is it to change the governor in a 700R4 (4L60) ??
- Air Gap Manifolds
- egr
- B&B Tri-Flo
- FLP lt's - what gasket??
- help me please......bad knock in engine
- Question on install of 160 degree stat.
- why so much
- opinions on hooker muffler?
- Car runs rough---need opinions
- what kind of gears
- Brought Car Out Of Storage: Brakes are Rubbing??
- Spare tire and jack question
- why does my ac keep breaking
- TB bypass for 1993 trans am
- This sound right?
- Why won't my left blinker work?
- Need some good looking valve covers to clear a studgirdle
- Spohn Torque Arm question, Need help fast
- Anyone Have A Bbk 52mm Tb?
- Off-Road CAI
- What is the best CAI and where to buy it??
- cheater cia
- front control arm install?
- Will fuel leak out if fuel pump ok?
- Hub is on,now all thread stuck in crank!
- What to do?
- where do these wires go?
- Picked up a Roller that was a V6 what is differnt for when I put a LT1 in it?
- Anybody got links to a dual gauge pod install???
- lt1 swap half way complete!!!
- where to buy slp cai for the cheapest?????
- A4 tricks?
- Help Me Please
- T56 conversion almost complete ---->M6 install questions
- I keep trying and something is still wrong!!!
- vibrating drivers sideview mirror
- shifter knob, Can anybody help?
- Gonig to the track for the first time ever!
- Trims/Options
- Need Suggestions for Non-Synthetic Gear Oil
- Rear main seal leaking oil
- stupid @#$# Sears valve spring compressor broke!!
- stock fuel injector size for 96 lt1
- Plugs&Wires=4hrs
- prepping LT-1 lower for forced induction
- Hella driving lights
- I THINK i might be VERY lucky
- SHOEBOX - Need Part Number
- Improvements with a 4000 stall on a 12.5 car
- need help with performance parts??/
- A4 to M6 switch?
- V6 rear end compared to a V8
- Auto tranny Shifting from Park Question
- Buying pistons need help!
- PB Blaster?
- Slight Thud or clunk
- Lifting Motor
- Stock alternator
- cam and rr?
- Anybody know the difference between the lt1 and lt4 damper/crank pulley?
- electrical NIGHTMARE
- Which brakes=low dust
- Your first Optispark Fix....
- Exhaust Leak
- Hollow Cat
- removing throttle body for teardown and cleaning
- Anyone in Houston that can fix tie rods?
- anyone done this?
- Fuel float on pump stuck?
- will it hurt performance to add lowering springs???
- WHats a good budget OEM or better quality brake pad?
- Trans temps?
- Looking for sound clips of small cammed 383 (LT4 Hot etc)
- leaky flange????
- Those with JetHot LT with emissions....I need help
- True Duals
- Does the fuel pump have a check valve?
- Reverse Lockout
- new headers and y-pipe pics
- Slow starting please help
- Whats thepart number for leather shift boot, 97-up style?
- Hooker LT's install TIPS
- What fuel pump to buy?
- Need part number...Shoebox ya there??
- What to use to remove crank hub??
- slp cai filters vs k&n replacements???
- Bs Flag!
- GP on clutch
- Fuel Pump
- Trying to remove Fuel Rail?? What am I doing wrong
- NE1 Have the P/N For...
- gains with cam.... and no headers??
- Plug Wire Install Help!
- Thunder Racing a good place to order from?
- Engine temperature...
- tv cable question
- Lca ????
- Those of you with obdII look here
- coils, which ones are best
- flex plate
- Now that OBDI conversion is complete how do I read codes
- LT1 intake porting for t.b. like a single plane
- Would a V6 Cat fit on a V8
- LT1 vs. LS1... here we go again
- O2 sim question
- Can the cutch pedle come off????
- HELP!!!! how did you rout the passenger wires?!
- backing lights not working
