  1. LT1 swap
  2. Trans gurus --->T56 conversion almost complete, have some important questions
  3. roller rocker arms
  4. Stock Motor Mounts, how much HP can they handle with an A4?
  5. why am i getting like 200-230 miles per tank?
  6. times question
  7. First runs of the season
  8. Eibach pro kit, hows the ride?
  9. Fan switch write up??
  10. back to the 99+ fuel tank swap = anyone actually done it?
  11. Can I beat...
  12. Cam and lifters?
  13. Thanks a million combo motorsports
  14. How hard would it be to convert LT1 to carb?
  15. low coolant sensor
  16. How do I rig a switch to manually lock my TC?
  17. Just put in my headers..
  18. PCM question
  19. New to the z28 and need help
  20. shifter for an A4...
  21. Z06 85mm MAF
  22. Living with the low speed stumble.
  23. autorx or seafoam???
  24. lt1 edit vs hypertech
  25. HEAD and CAM LT1 OR buy LS1 Car?? HElp me decide
  26. Regaining momentum after 1st
  27. cc305 vs. cc306
  28. Use GM fuel filter?
  29. Vibrations...
  30. Installing HOT Cam, how much more trouble to pull heads??
  31. High Flow cats...
  32. how do you take the vents out
  33. Posi Rear
  34. Thank You
  35. After 4+ years, I finally did what should be the first mod
  36. Clutch Chatter
  37. surging at idle
  38. Spark Plug Wire Routing
  39. Why won't my rear window defrost stay on longer than 30 secs?
  40. jet hot lt headers vs straight plugs
  41. Getting LT4 Hocam, Do i need LT4 TIming Chain?
  42. Changing Diff Fluid
  43. Cant Make A Churp 1st into 2nd
  44. Steering Stereo Lights Out
  45. 93z bad miss and stalls
  46. help with setup
  47. What Bolt-ons am I missing?
  48. Starting the car in the morning
  49. jackhammer noise from rear after clutch ... wheel hop?
  50. 3.73 Gears question
  51. Dumping my steed, gettin a Z28.
  52. A4 guys with 4.10s
  53. Cab the EGR valve be removed all together???
  54. how do i remove back seats?
  55. Tranny flush?
  56. 700r4 question
  57. Is this car worth fixing?
  58. Bleeding my brakes.. Need to make sure im doing it right.
  59. How to find year and V.I.N on an M6???
  60. QUICK! PB Blaster OK?
  61. FX5 Shocks?
  62. HP gain from Hot cam with stock manifolds
  63. Quick, easy question about taking off calipers
  64. HELP! Installing Airfoil!
  65. Difference between X and H pipe?
  66. Need help w/ my wheels/tires
  67. 97 LT1 4LE Trans Bolts is there a Removal Trick?
  68. Those with True Duels: inside please
  69. Y-Pipe to Headers bolts!!!
  70. Hub install tool - make my own?
  71. What is this, and what is it's purpose?
  72. Fuel line connections
  73. what push rods and lifters are good?
  74. Got slp clutch do I need new flywheel ?
  75. is this 2 much 2 pay for a lt1 30th camaro?
  76. need bolts... please help
  77. Need Engine Building Tips/Advice
  78. tranny/clutch problem
  79. All 1994-95 must see!!!!! Easy way to fix C.A.G.S!!!! FREE!!!!
  80. advice anyone?
  81. Thoughts on cam and help with motor... Solid roller 244/244 .611/.611 112lsa
  82. Diagnostics...Codes...????
  83. LT4 Clutch Identification
  84. Found your RPM stumble
  85. anyone see goodyear F1 GS-D3 tires in action
  86. who has the best price for fuel pumps
  87. Buget Heads and Cam?
  88. PCV valve replacement
  89. It wasn't the alternator......Now what???
  90. anyone w/SS with 17" wheels
  91. Looking for muffler between an ultra flo and bullet (loudness)
  92. I Might Be The Coolest Guy Ever....
  93. Need bolt sizes (Shoebox?)
  94. How are O2's connected?
  95. Anyone who has ever done a shifter for an A4 inside...
  96. MAF vs. BBK??
  97. TRANS Fluids for a m6
  98. Help
  99. couple q's
  100. TH400 and a Gear Vendor.
  101. Firebird on front bumper of TA...I need one!
  102. Was thinking of losing the Borla for something more "Exotic", any suggestions??
  103. Endurex Lifters
  104. msd question
  105. what causes code 154?????
  106. Lt4 Km
  107. new engine setup...what do you think..
  108. Electrical problem help please
  109. Quick mass air ?
  110. How big are the combustion chambers on LT1 heads?
  111. will these 3:73's fit?
  112. Where can I get a genx1 and genx2 wet kit?
  113. O2 Sensor wire question!
  114. EXHAUST RATTLES!! (Borla)
  115. Fuel injector questions for 383???
  116. SLP Loudmouth
  117. Cc305 Cam
  118. Sound clip of my heads/cam XE 236/242/112 with open headers!!!
  119. A4 guys...quick question..how do you shift outa parK?
  120. M6/4.10 users...inside please.
  121. weight diff. formula/TA
  122. can i use seafoam then autorx?
  123. removing passanger front o2 sensor
  124. What kind of Tach to get??
  125. LT1 in a 1998 GMC Jimmy
  126. PCMFORLESS questions...
  127. bad miss/stumble above 4000 rpm
  128. Hoping to have prob fixed 2morrow
  129. Cooling Fan operation-Technical question
  130. Which LCA's
  131. Overhead consoles in a 98 Z28
  132. 350 rwhp
  133. Thrush Mufflers
  134. 4 anyone interested in SLP LT4 clutch....inside
  135. LCA terminology
  136. Got her in
  137. cost of auto tranny rebuild?
  138. My window is stuck....
  139. o2 sensor locations
  140. Whats a good muffler
  141. BMR TrakPak
  142. Thanks Rob (Shoebox)
  143. Parking lights flip flop to be make them brighter?
  144. Long Tubes
  145. Stiff Stick!!!
  146. Edelbrock LT1 Heads...
  147. Honda ATF in 6 Speeds
  148. Upgrade and questions, please help
  149. Mac headers, 224/230 cam and stock heads...
  150. Exhaust piston to valve clearance problems :-(
  151. Anyone with Hooker shorties...help needed
  152. Best LOW budget cat back
  153. LT1 air intake silencer
  154. Help Me Chose Guys! Brakes Set-up!
  155. Anyone running long tubes, catless ypipe and borla exhaust
  156. edelbrock exhaust any good?
  157. Quick header question
  158. power steering leak
  159. How to get rear calipers off?
  160. Difference between 700R4 and TH400?
  161. fog light
  162. Headers??
  163. Anyway to retain the CPS with a double roller?
  164. Funky Noise Inside!!!!1!!
  165. sometimes car is quick, sometimes car is slow!!
  166. I'm putting on exstended studs. Need part number
  167. Car died on highway
  168. Heavy miss at WOT
  169. Newbie Questions
  170. Need quick answer...ordering parts now!
  171. performance gains to be had with MARCH pulley set?
  172. final question (I swear) before I do the LS1 brake upgrade
  173. car is running like crap
  174. LT4 head gasket boost compression?
  175. LT1 Edit, PCMforless, or Dyno tune for LT4 Hotcam tune?????
  176. Where can I get a manuel or book on porting heads?
  177. Sumitomo HTR+ tires?
  178. Dynatech LTs, Are Over-The-valvecover Wires needed???
  179. Which of these tires would you buy?
  180. where can i buy just the fuel pump for my 96SS
  181. Removable rear glass theory!
  182. Squeaking alternator pulley
  183. Running Rich, Where to start?
  184. Just install new Borla
  185. Question about A/C blower motors...
  186. 97 Y-Pipe ??
  187. Ok, getting kinda frustrated...still have driveline vibration>
  188. Installing Hooker LT's . Any helpful hints is appreciated
  189. How do I get ahold of Llyod Elliot?
  190. New Mods on: STB/SFC/Corners/Corsa!
  191. Why would the car shift normal in 3rd and not in OD??
  192. Need an electric CSI waterpump with core?
  193. How much HP /w this 383
  194. Collapsed lifter?
  195. I have some cool ideas for a power inverter!!
  196. Optima Red Top owners please?
  197. reverse solenoid install
  198. Price to change muffler
  199. idle
  200. Which coolant level sensor do i need? anyone w/ p/n?? 94Z
  201. tech line products
  202. LS1 WS6 Front Sway Bar 32mm?
  203. abs question
  204. Opti problems
  205. Next mod: headers... need some advice!
  206. forged crank or not?
  207. Bleeding Brakes 96 Z *ABS Traction Cont * ????
  208. balancing motor after rebuilt
  209. head porting materials
  210. Low Oil Light after replacement of unit.
  211. 18" How fat?
  212. Regular Wires
  213. Just got my Pro 5.0 and I have some questions....
  214. What driveshaft loop
  215. Quest for 11's with bolt-ons, runs into a wall..
  216. To run Freescan or similar software, can I use a desktop PC?
  217. Alot of OIL stains please help
  218. Ac
  219. Whats the best RVT to use?
  220. Can an LS1 cat back fir a 93-95 single cat car?
  221. Shift Points?
  222. What are my options for after market timing chains
  223. Running rich/lean
  224. Hypertech Users info NEEDED
  225. problems with longtube install
  226. How do you get the console out of a '95???
  227. IDLE-2K STUMBLE w/ a twist....NO ANSWERS
  228. TB bypass
  229. Draglite sizes?
  230. obd1 cable and pay pal
  231. Reuse 2 month old head gaskets?
  232. Do I need an installation kit? (loudmouth)
  233. dowel pin ?s
  234. Help me out here! A.I.R. issues
  235. Not just another opti question
  236. 160 degree thermostat controversy?
  237. How do I REALLY flush the rad?
  238. Is there a safe way to pressure wash the engine bay
  239. Quick Question -> MAC Headers
  240. Thoughts, Ideas, Coments, Concerns...head pics inside..
  241. Insulator under hood
  242. Converting from 4L60E to 700R4
  243. HELP: reinstalling crank and rods
  244. BBk chrome headers
  245. ques. on adjusting the clutch linkage
  246. MSD Part / injector number
  247. oil leak fix
  248. No Lockout for Reverse with new M6??
  249. TireS???????
  250. high rpms through every gear
