- EGR block off question
- fan problems
- Funny Smell??
- Bolting 94-95 headers on 97. ?'s inside
- LT1 in a 3rd gen??
- LG Motorsports subframe X-brace for LS1 ???
- Motive 3:73 question
- Where do you put the cutout?
- PRO 5.0 = awsome
- which gears do i have on my car????
- Header gasket ?'s
- sound clip of longtubes w/loudmouth?
- changing oil pan seal?
- Is my roomate getting a good deal?
- 93 kickdown question
- Misfire... Knock Sensor
- Need Help Please!!
- Cragar S/S
- power programmer question
- Who's Knows About Brakes/Calipers?? I'm Clueless On This Subject!
- 5.7" vs 6.0" rods
- Oh...the sounds of my camaro!
- Wierd Brake Lights
- help! just broke my arm rest console off hinges!
- Any of the cats from a dual cat car fit on a single exhaust car?
- Wtf?
- Cant get y-pipe off...
- Will this setup work...?
- What cam is this
- put in new 383, car won't start - help please
- Car smoked like crazy? WTF
- just a little help please...
- LT1 to LS1 swap
- Lowering the fans turn on temp??
- 30th Anniversary SS hood...
- M6 guys in here
- Seafoamed.. but couldn't get it to stall??
- finally ready to do the LS1 brake upgrade and noone will sell it to me
- How to buy a used LT1 guide...
- 2nd Pass at Englishtown Raceway...
- What size rods should I use?
- Opti rebuild problem...need help fast
- NEW front pads 4sale
- Whew! Passed...
- Help, installed heads backward
- Anybody happen to have Steve Ruse's Phone #
- How much power from a 355?
- QUICK! 2 second question!!
- OVC wire kits
- What is up with this site?
- Anybody wanna swap and $600?
- Dumb Warped Rotors!
- Wheres the best (cheapest) place to by nittos?
- car overheated 4 times in 2 months....
- cutout question
- Header noise????
- Best way to clean injectors by hand...
- SLP Fan switch pics
- Hi just wondering how much do u think my car is worth?
- Your opinions on ceramic brakes pad material
- Ses Gone!!!!
- Cooling questions
- car idles real sparatic then dies - what the problem?
- Fan 1 fault code!!
- LT-5 pics?
- checking the coil
- Will AFS Zr1 wheels match GM Zr1 silver perfectly?
- HOT Cam Kit came today, what else should I do while I'm in there?
- True Duels
- What length rod should I use?
- top speed?
- I just wanted to say thank you!
- Who has the best price on 30# svo injectors
- cutouts and cops
- T56 Tranny problem
- Distributor replacement
- Where to buy Taylor OVC Wires?
- What Exhaust Gasket to use with MAC Headers?
- AS&M TB, bigger injector upgrade
- Noisy Headlight
- Can 4L60E be shipped UPS?
- new dyno numbers inside
- Best A4 rebuild in SF Bay Area?
- What could be wrong, 93 Z seems bogged down in OD at all speeds
- How much blow by oil thru PCV is too much?
- Here's a Stumper!!
- Tips for starting car in Spring
- Retarded Timing?
- Which modified exhaust pipe diameter should I use
- How does SPEC Stage 3 feel when broken in?
- What Next????
- how to ajust calipers after reinstalling?
- 94 guys.... questions about HOTCAM and OPTI!!
- FLP users, i have a slight problem
- Are these Type R lifters or not?
- rear caliper pads installation????
- long piece off of intake elbow
- how do i change front coil springs?
- 'h' shaped shim in rear caliper pads!!! help please!!!!!
- Brake recommendations
- Edelbrock Cat-Back
- Car Wreaks!
- Timing retard. ?????
- Iac ?
- gas milage problems with hotcam'd T/A
- What is a Stroker motor?
- master cylinder question
- wires??
- When I turn the wheel all the way to the right or left my car goes up and down????
- stumbling problem solved
- My cruise control is not working????
- head porting poll
- radiator help!
- Best cams....
- adjustable clutch????
- Header Installation File
- Chrome Header Question
- Voltage Mystery
- Another question about doing !TB bypass
- new Door?
- how much head and cam gain
- painting headers??
- Cam in a 94 LT-1
- Dealer totally ***ked up my 97' Z28.. sorry my first post couldn't be more pleasant
- 94 Trans Am specs
- How do I fix a broken oil guage needle? The pin is still there
- ATTN: Rob/Shoebox - need part #
- Cutout, CAI, or 3" pipe. What would you do?
- Cooling Question.
- 93 tach wire
- Changed front brake pads, now CLUNK CLUNK from both wheels
- skinnies and handling???
- SS Suspention
- paranoid
- Hooker long tube users inside please.
- Where can I get a new 3" intermediate pipe?
- Anyone have Experience with accel DFI??
- Rear Hatch
- 1.6rr on stock springs?
- tranny mount sound-a-like
- Coating Headers
- tire suggestions
- Wiring Harness Question(LT1 in a thirgen)
- Will these valve cover breathers work?
- pushrod length
- Howling In Rear
- 383 motor won't crank properly
- Installing Headers - Checklist...
- need help ASAP
- M6 Tranny Fluid?
- no power in OD on the freeway, experts inside pls
- Which Header Bolts?
- First couple of mods???
- Can a knock module cause the check engine light to come on?
- Relocation brackets=Lowered??
- Making the ride nicer
- Choose your Parts Stores accordingly
- tranny work and clutch install
- SFC or LS1 brake up grade?
- lt4 intake
- howmany of you removed your rad to change the opti?
- RWHP gains from Elec. Waterpump and 160 thermostat???
- Headlight Help!
- Tuning experts please help on idle issue?
- Best place to buy OEM parts from?
- Need part # for impala head gasket...
- before applying gaskets...
- Internally balanced 355 LT1 what flexplate to use
- pics of fuel pressure gauge fitting
- Starter dead?
- Has anyone seen a Camaro like this before??
- What Is Cam Surge?
- Knock Sensor Test
- Someone Backed into me. Busted front corners
- Co-Worker just bought a 2003 Cobra...need mods...
- need help understanding the reading on some sensors
- Thoughts on Aluminum Flywheels?
- engine assembly lube=cam lube?
- Over the cover wires w/ BBK headers?
- roller rockers
- trouble codes
- improperly installed balancer - can this cause a problem?
- Shoebox--how to hook up Autometer Tach
- HELP PLEASE!! oil leaking out like water after heads/cam
- Coolant Guage Sensor?
- How hard is it for you guys to shift at high MPH
- could i keep with an LS1??
- K&N FIPK filter probs
- LT1 scanmaster hookup ?
- Edelbrock TES headers any good?
- Tranny rebuild by LT1Dave any good?
- Bolt tighing order for LT1 heads
- rocker adjustment w/out timing cover removal
- Poll: True Duels
- Help! 98+ls1 injectors in an lt1?
- New Magnaflow Sound Clips
- Converter advise is welcome
- accel 375+
- Any Experience With JET Shift-Plus???
- Bleeding after TB bypass
- oil pan for 383 stroker?
- Dyno numbers in! w/355 heads and cam
- Cut outs ons the y pipe?
- new way to plug w/p drive hole that looks good
- AC help.. evap temp sensor
- shoebox; yet another hub ?
- Bad power stearing pump??
- Need some part numbers
- with slp take out torsen zexal...do you add the additive???
- Removing A/C question
- Gauges pods
- where to buy street twin?
- Need Help Fast! Hydraulic Clutch Lines
- need advice to PCM
- using anti-freeze but not leaking
- Dead Clutch can you ID these ?
- pulley - airpump, problem????
- Quick Valvespring ??
- OK new problem
- How hard is it to rebuild a 4l60e tranny?
- Vacuum for cc306?
- Borla install
- Mass Air
- Does exhaust touching underbody=false knock??
- obd1 or odb2
- Rad Hoses
- Rod and main cap torque
- 3.4 to 5.7
- How much water?
- True LT1 Cam Specs
- yet another cutout question
- SLP CAI owners...
- Oil Change intervals after cam install?
- Unplugging MAF and car dies?
- 2 quick mod questions...
- Anyone get their FLPs slip fitted?
- Excessive Motorsports Heads Poll?
- random tech catback or cutout??
- cc305 and emissions
- New to manuals got a question
- Would you LT1 owners be interested in a PCM "Repair" kit?
- How much rubber.....
- Solid roller question
- Best Heads/cam Combo?
- Broke manifold bolt. How bad would it leak w/o it?
- Pictures inside.... Help me ID this BBK throttle body
- Cc305 Vs. Hotcam
- best transmission for 525 hp?
- Holy Mother of all evils, I stripped a banjo bolt hole!!!!
- My Stumble fix...High RPM
