- ran a 9.006 in the 1/8..
- HELP! Will an LT4 head gasket fit an LT1 head?
- Need Answer Quick!!!
- Electrical connectors on M6, which one is which?
- Cai?
- LS1 driveshaft?
- Hooker LT's and BMR K member clearance
- Power adjustable seats not working
- Oil level sensor wont back out
- Cutting MSD 3-step wires
- those with cloyes conversion in here!
- weight of chromoly pushrods vs regular hardened pushrods
- Fuel Pump Fuse?
- Brakes
- Need help...with grayish smoke
- Car wont start when its above 40 degrees out
- roller rockers
- 383 stroker guys...?Questions?
- Anyone Know how to fix TA headrest problem?
- I lost one of the clips that hold fuel injectors in place
- Hooker Lt's 2231 , y-pipe or not?
- valvetrain noise
- help me figure out whats wrong with my lt1
- Heater Core Removal - Write-up/Pictures?
- VIDEO of POS! Any thoughts or ideas?
- Those that know their brake rotors.... have questions.
- Good LT1 Diagnostics tool
- starting problems
- Ability to edit parameters of V6 engine?
- Car dies when I pump the gas
- Lost oil pressure today...help.
- Would tuning help this???
- IAT Sensor
- Good street H/C combo?
- Trans Prob
- Cross threaded header bolt
- Where can I buy a 4 bolt main block in CA, ASAP?
- HELP, SES code driving me insane
- F-Body noob needs some advice
- 561 heads
- can a 93 take the LT4 KM?
- man ...what did i do now!!!!
- XE 230/236 ?'s regarding stock fuel system and 3" exhaust...
- what is the quietest and best flowing cat back
- TCC valve for tranny where to get it
- Why don't more people try for 11's?
- Grrr!! TB Bypass Help Needed w/n
- Need to know ASAP will factory salad shooters fit on a 72 Camaro?
- Help! quick question!!!!
- Firebird guys w/ headlight motor probs
- Automatic Trans. Problems
- 3.73 Gear Help
- Electric Water Pump Reliability and CAM choice
- Help!
- quick audio wiring question.....
- What Octane do most people use?
- Anyone have trouble with 91 Octane
- Anyone ever use Castrol Gear Oil?
- anyone replace they PCV valve? need help
- Opinions on my engine project!
- proper way to change or add coolant??
- 5 Codes??? P0100, P0141, P0400, P1641, P1642
- LT4 KM in.....results
- Borla install withOUT a Sawzall. Need suggestions.
- All that have taken their engine's out...
- Posi Rear
- Will a car even turn over if the PCM is dead?
- Clutch/flyheel recommendations?
- easier to cut cag wires instead of pulling them??
- Removing The Oil Cooler?!?!?
- Guys Please Help My Car!!
- WOT Air/Fuel Ratio
- How many of you burn plug wire #5 with long tubes???
- Need harmonic balancer hub installer ASAP!
- Can I run Weld Pro Stars on the road legal?
- quick speedometer question
- Where could I get my hands on a roll bar for a 95 Convertible?
- Timing chain ?
- Car won't start
- Look at my homemade intake
- Firebird owners with K&N FIPK
- Jet Hot LT AIR hookup size???? HELP!!!!
- Installing Jethots on m6
- Reinstalling rear main seal housing onto block, need RTV?
- What is slowing my car down......
- please help! how do i know if thermostat is broken?
- Stock plug gap size?
- gtp heads
- Anybody paint there engine bay? What paint did you use?
- LT4 KM necissary?
- Gear swap question...
- Why is my AC/HEAT only blowing at my feet?
- power window not working
- mac headers - unavoidable leak on driver's side collector?
- Cam is in and it is tuned.
- Borla Installed
- Which is colder, Autolite 103 or 104? What one range colder than them?
- Coolant overflow tank and battery tray one assembly?
- Anyone have sound clips of Slp2otl&Lts
- Those with Elec. Cutout~>opinions please!
- Brake Upgrade?
- dealing with Jim Winn
- Who does the best head work?
- Cam
- Gotta serious problem!!!
- this is getting so old!!! OVERHEATING
- What does a New pilot bearing go for?
- What makes oil turn black?
- Stage 8 bolts, 1" or 3/4"?
- Water pump intermediate drive unit: a replacement item?
- healthy RPM range???
- T/B bypass
- 1.7 60' on Lowered m6 with nitto!
- Low Oil Pressure!!
- Please Please Please Help
- Battery Tie-Down?
- Taking off oil cooler
- Autolite 605's???
- OVC wires and ASR "box"?
- Camshaft Endplay
- Change in Pushrod length
- update on low rpm miss/surge/lunge
- lt1 swap question
- spring tuning
- anyone running a crane 222/230 cam?
- Resistor for OBDI
- cc306 at idle video or sound clip
- got my dynaspark in!
- Got the trans out
- Transmission clunk....please help!!
- Converting Speed density to MAF
- Leaking taillights
- Looking at a 94 Camaro Z28
- thinkin of buying a 95 z28
- Injector size for a 383 solid roller
- Which fuel pump?
- Clunking Gears.
- Stupid Question #2: Degreeing LT4 hotcam??
- Stupid Question #3: Reinstalling the Opti
- Intake Hiss on project car
- Transmission cooler lines leaking on 93
- Tips or Hints on Timing set upgrade
- Girdle and drag radials?
- Best exhaust system under $300?
- Are 12.6xx's respectable times for bolt-on only LT1's?
- Anyone have stock dyno chart for LT1?
- throttle cable????
- 94 LT-1 wiring codes for swapping into a 94 Blazer
- Which wires for the dome light under the dash?
- Replaced Opti - Out of time
- hole in fire wall for wires??
- Iac
- Clever lil code, but what does it mean? - MALF 11
- PCM 4 Less/Madz28 - Now or Later?
- Need a new exhaust for my heads/cam car, which one???
- TA Differential Cover and Stud Install Guide?
- Clutch hooped after less than 20,000km... comments please
- need a lil input
- cam and heads intsall and now car won't idle.
- Need help quick T56 ???'s
- What kind of ZIF socket for PCM?
- feels like car is missing
- crank bearing clearance
- STB in....stupid suspension ?s.....
- what to adjust in stock valve covers to clear 1.6rr's?
- Rocker stud problem. Not sure what to do.
- Need a link to the LT1 vs L98 differances
- Anybody done a LT1 swap into a non-LT-1
- Rear end grenaded, what to get and where?
- Need help fast plz :D
- how can i take the brake pads out to paint my caliper?
- Whats he going to run?
- Lower A Arms?
- Need ASAP, cam bolt thread sizes?
- Tunnel Brace
- Installing vortech supercharger on 118,xxx LT1?
- Header leak and O2 sensor
- Need help with valve lash adjustment
- Is this an Intake Manifold Leak?
- wierd z??
- Blackouts?
- ignition switch replacement
- Need Help!
- Help !!!!!!! Car will not start!!!!!!!!!!!!
- Connecting rods
- Pcm4less where do i send my pcm
- replace egr, map sensor, o2 sensor?
- Best sounding exhaust for a S/C'd 383?
- Is anyone doing the PCM chipping and recovery?
- Nooooo!! I think I broke that little plastic thing that goes around the shift boot..
- tuning questions
- 6 speed and 4.56's (urgent)
- Oil In Coolant
- 94 4l60e into a 97 camaro
- O2 extensions....
- Bye bye Loudmouth...
- Whats different between F-body and Impala LT1(wiring, computer, accessories)
- proper cam break-in procedure?
- Just took off the Air
- will it fit?
- How hard is to pull heads out?
- HELP!: Knock sensor
- Looking at a used car.
- How Good Are These Ported Heads?
- Eibach Drag Launch Springs
- I need a tunercat file for xe230/236 and ported heads
- opti
- th350 swappers look inside
- piston install question
- How hard on a clutch?
- Car not running right after hotcam install
- dampner fit seems loose? advice
- FLP headers question
- Turn key, no crank
- Air Foil = Electrical Problems!! Why??
- Oil cooler removal?
- Z06 Calipers on an LT1?
- slp long tubes.
- model paint
- Help
- FPR bolt stripped. What to do?
- URGENT help required.
- URGENT HELP REQUIRED. Working on car now.
- Which valve covers to use on LT4 w/ 1.6 RR
- What Is An LT4??
- Cradle Bolts?
- New coil suggestions
- 561 Head Question
- good quality inexpensive streetable stall
- Headers and wires
- Emissions question. Porting w/o RR or CAM.
- do the stock ext tips?
- Help me to name these pieces.
- Need help ASAP: Car wont start-filter, pump, computer?
- Fog Light Out
- SES and fans come on randomly
- New alternater staring rough
- Why an airbag in pass rear spring?
- Fixed 1/2 of the huge problem i had today, need help for the other...
- 96-97 Slp headers
- What bolts should i do next?
- WTF! Driver side is higher than pass.
- underdrive pulleys
- What the hell just happened???
- Jet hot LT on 1 inch drop??
- What does a high Stall torque converter do to your dyno numbers?
- how much hp does corsa put down???
- 4 real... how loud would gmmg w/hooker LTs be?
- Easy horsepower...
- My car thinks i have a door/trunk open..but i dont
