- put my car to WOT, sometimes no torque?? wtf
- 3600 stall too much on stock LT1?
- factory sway bar size??
- about to purchase firehawk
- PCMFORLESS questions
- where to put cutout
- what's that oil smell???
- ANy one know this part? converts centerbolt ValveCovers to standard bolts pattern
- determining options on your car from factory
- Wheel backspace questions.
- 150miles to the tank....
- MSD 6AL mounting location?
- How much should a water pump cost?
- Anniversary SS Filter??
- where can i buy a just an air-bag (suspension)?
- Shoebox-->> Charging System Q
- oil
- MSD injectors
- TCI Convertor Part number help
- Leaded fuel?
- Derrick >>>>
- Rear Main Seal: Lube prior to installation?
- 3:73's or 4:11's?
- Tourqe specs for Weld Prostar XP
- Corsa owners....
- I have gas in my OIL!!!!
- Feedback, Opinoins on Speed Inc. in Il.
- My Jet hot long tube install also slps for sale
- Ignition Wires
- How Much????
- t5 5 speed trans
- lt1 to ls1
- Qustion??
- 3:23 vs. 3:73
- What is the stock stall on a 94 z28
- Ported Heads without porting the intake? How much HP will I loose?
- Underdrive Pulley's Good or Bad!!!
- A SIMPLE Quick Question
- Any Problems w/ CAI After Rain?
- Oil Pump HELP!
- 396 oil pan?
- Hydromatic
- anybody running true duals with longtubes?
- can i get 18in Nitto DRs? or BFG DRs?
- Next Mod Opinion
- LT4 Knock Module----WOW!!!
- Jet hot headers are wrong
- If you've changed plugs/wires on a dual cat lt1....HELP!!!
- Dynatech or hooker
- New ignition
- quick dynatech question
- which are better for racing
- 2000 rpm stumble tried it all!HELP
- technical pulsewidth/ignition question (Accel DFI)
- i think i messed up getting 18s
- HELP QUICK! Clutch fork: goes between t.o. bearing & square? or on input shaft...
- Difference In sound between 3" and 4" exhaust?
- Blew Head Gasket! Help?!
- tac wire for shift light, where is it??
- AC Delco Wires and Plugs - Need p/n's
- what does an lt4 knock module do?
- dont know whats goin on HELP!
- What fluids/ how much?
- 1993 4l60 shift kit problem?
- Quick question for those who bought the cmotorsports cam, rockers and springs
- Frt Sway Bar Quick Disconnects,anyone make em??
- Can anyone go WOT in 1st gear? What tires do you have?
- transmission mount Q???
- so if you break a bolt off in the head taking off the stock manifolds...
- Budget Catback
- Best price for FLPs?
- Houston porters?
- Installed Newest Canton Oil pan!
- 1.6rr???
- Mez wp in LT1 pump housing?
- why wont my valve springs compress all the way?
- Taking Alternator apart??
- Paging Shoebox--Oil Pressure Sender Question
- Which cam for my '93?
- code 45??
- Mod vs. Improvements list?
- Simple fan switch
- is the SLP pressure plate the same as an LT4 one?
- ls6 maf on lt1
- Ses Light
- is the LT4 pressure plate better than a McLeod one?
- Serpentine belt keeps getting tossed out thru the bottom of the car!
- 4" Mufflex w/ Spintech too big?
- 1st Time down track...
- LT-1 against a 700-R4
- Does anyone daily drive a th-400 or 350 down the highway??// what rpm??
- LT4 cam kit or 75 shot nx?
- 96-97 camaros with the Hooker long tube- O2 question
- Mixing oil
- 94 t/a a4
- Local Engine rebuild?
- Installing 1.6 rrs and LT4 valve springs?
- What mod to do next??
- looking for low mount alt. bracket
- brake light stuck on after a hard lockup
- Radiator fluid in oil pan? Rad. fuid leaking from pass. side head area?
- built 4L60E?
- MAC Headers question
- Help!!!!!!
- What plugs are you guys running?
- 4:10 or 3:73 from 3:42???
- dealing with AC on cam install....
- Valve to piston clearance with CC306
- Lt1 Edit Cable
- backspacing with weld wheels
- LT1 Block
- Drive through car wash - opti question
- Quick Fan Wiring Question!
- Is It Ok To Drive My A4 Home After 3.42 Gear Change Without Programmnig
- Cobalt Fuel Pressure..........
- Where can i get an LT4 knock module?
- Autozone or Custom
- Which head gasket? LT4 or Felpro 1074
- 95 with stock quad tips??bs?
- any thoughts on 4.56 gears with cc306 cam
- Anyone use Header Studs?
- code 34
- What Are Some Good Upgrades for LT1's That Can Be Had From LS1 Cars?
- hub ?
- BAD Torque Converter, killed my tranny
- Jet hot egr hook ups were wrong
- Street Twin.....will a stock master cylinder work?
- Freeze Plug? for Water Pump
- factory alarm / keyless entry
- PCM codes, deleted for emissions?
- easy lt1 mods
- will v6 guages work on a v8?
- XE 230/236 on the way, what heads though?
- Rapidfire platinum plugs
- whats my car worth
- exhaust question
- Updated my HVAC controls from a 94 to a 99 (lit nobs), need defrost wiring diagram...
- What size bolts for the mufflex ypipe?
- Guess my codes before I PCM scanned
- Sound clip/video of 383, big cam, FLP headers, borla or similar. Anyone?
- Blown Head Gasket
- Comp R lifters are in production again
- 6 speed gauge cluster in an a4 car???
- WOnt let me regester my z28
- what is the logic behind the AIR pump?
- RLB/LCA Help
- will having differential oil change help??
- Car wont run after stopping it while doing cam break in!
- Trans Mount Part Number?
- anyone know why heater won't come one?
- need answers quicly about diff. tires sizes front and back. ABS EXPERT inside pls
- skinnies up front
- What's this ghetto CAI unit?
- Electric Fuel Pressure Guage Install
- Where to buy a distributor for $300 shipped
- Installing an LS1 Master Cylinder, anyone do this? Having a Problem...
- Roll Cage
- Muffler/CAI Question
- Mech Temp Gauge
- How much tranny fluid does a T56 hold?
- cam surge!?!?
- mc cords website
- Shift knob
- the count down starts...help me b4 i do stupid....
- 383, 15 psi Vortech, how much power?
- question before i change my fuel filter
- Just pulled my engine from the top!
- Fed Ex Can...(LONG)
- Why NGK TR55's...Whats so special?
- ? about removing the EGR system.
- B&M Ripper vs Pro 5.0 my opinion(just switched)
- XE comparison
- A4 Question
- Who Would Win
- Headers
- Can we use wheels with standard offset?
- Yokohama's or Sumitomo's
- 94 coil upgrade to 96-96 coil?
- Two questions about optis
- AFPR - ideal PSI????
- valve springs
- LM and Hooker catback Question????(not normal question)
- Noooo!!!!!!!!!
- launching question
- Airfoil Help
- waht cai ?
- is there a way to disable the reverse lockout
- Homemade CAI Help
- LS1 Brake Upgrade. Please tell me what I need & need to know..
- TB bypass
- PCV question
- burning oil
- ppl with bbk headers for dual cat car's inside please
- Lost 3rd and 4th today
- ignition module
- O2 sensors
- Electric w/p question....
- water pump drive shaft o-rings
- Which retainers with these springs?
- vented opti swap\electric h20\cloyes questions
- more OBD II trouble codes
- hardened or chromemoly ???
- Can I use a cracked bellhousing
- Trans or ignition?
- How to tell what kind of pushrods I have.
- Listen To This
- Temp Gauge Not Working
- Trans brake or not
- plug recommendation for 383
- I Need to know the Length of my Z28 So I can Buy a car Cover!!
- cam is in
- Interesting question I have about tranny shifting characteristics...
- Need some help quick!
- Those who run KB hyperslugs....
- Ground clearance w/electric cut-out?
- need to confirm 1le bushing P/N's and pinion seal questions.
- installing new cam, should I replace lifters in high mileage car?
- TB dimentions?
- valve springs
- What driveshaft?
- Getting Hot
- Fuel Filter?
- Is it ok to use Mobil 1 0w-30?
- OBDI Conversion
- Hooker shorties quick question
- the best mod?
- LT1 Questions
- Will AIR! mod set SES codes on a 95?
- middle of opti swap. questions!!
- BHP vs HP whats the formula? Preliminary dyno run for my 396!
- BBK headers and what plug wires???
- Is the ceramic coating on headers REALLY worth the 200 bucks??
- Where to buy a MAF sensor?
- Damn it's big
- Question about automatic headlamps on firebird.
- Need some confirmation before reinstall
- Quieter after header install?
- Y Pipe
- LT4 Cam or LT4 Hot Cam
- LT1 edit questions with an already programmed PCM
- securety light???
- Sweet-thunder exhaust
- What else besides the CPU tells the trany when to shift?
- Wiper motor issues
- Going from OBD2 to OBD1, What all has to be done?
- traction control?
- stock exhaust piping or not??
- Good CAI kits
- Quick Question, need quick answer!!
- Questions on OBd1 conversion with mods
