- Why is it that some people need an O2 ext. and other don't?
- Where is the heater inlet hose? (pic inside)
- THOSE WITH BUILT 7.5 10 BOLT's INSIDE!
- Need value train help
- When 02 Sensors go bad...
- EVAP purge solenoid check...
- Air/Fuel Gauge quest.
- AUTOZONE can't scan my car!? WTF!?!??!?
- check engine light after heads/cam
- Is this my starter?
- Smaller, lighter alternator options?
- Has anyone bought an LT4 Timing set from Jason Cromer?
- which exhaust ?
- Dissapointing Times! Please Help!
- WHtas wrong with my brake light?
- Which cam should I go with?
- My A/C is acting up, whats wrong?
- Should I freshen suspension bushings @ 113k?
- Why is 1 side of my DRL's on my 97 Z dim after changing BOTH bulbs?
- Did chevy ever make rr that look just like the lt4's but in a 1.5
- Has anyone used the Scan Tool They Sell at Sears?
- 97 LT1 Comp Ratio
- Which MAF is better for a 383 with hotcam and heads etc etc
- ES Trans Mount is Aweful
- How stupid
- What to use to heatshield wires using hooker LT's
- HTC coating on MAC Headers any good??
- Manifold Gasket Recommendations
- O2 extensions for MAC headers on 97Z???
- Magnaflow hi flow cat?
- engine continues to overheat
- MAF malfunction and running lean
- LT4 Pressure plate
- What do you think of this time?
- could head gasket cause 0 oil pressure?
- Anybody using Trickflow heads?
- Jumped curb!!! messed up steering!
- Bilstein PSS for 93-02 F-Bodies
- Value adjustment
- ASR Removal
- Cleaning/fixing IAC?
- Low Coolant Light
- How long to swap springs/shocks?
- thoughts on adding a spacer to run 4 series gears on a 3 series carrier ?
- 306 cam
- Any need to Degree CC305
- Electric water pump ???
- Anyone with Hotchkis LCAs?
- 2.73's to 3.73's
- questions about block and components
- has any one used one of these stroker kits??
- question on porting & polishing heads
- Best sounding exhaust
- Mud???? In radiator....
- What members on here do head porting for a good price?
- power steering temp. disconnect
- 3 inch cutout question
- bottom end buildup
- Heater/AC doesnt blow much air! Know how to fix it ?
- is this a doable type of exaust, or I am dreaming?
- Ok, my car is really pissing me off!
- !Cruise Control?
- what color paint could you get on an SS?
- pics of Mac shorties anyone?
- Have 3in CAI, wanna go bigger, what options?? (homemade)
- tranny cooler
- N e one with hooker aerochamber catback? just a few questions
- describe knock...
- A4 Shift Points for XE 224/230 112 LSA cam?
- more Dyno #"s
- tire shopping time!
- Check engine triggered by catalyst code
- hotcam
- New GMHTP; how can this be done?
- Part Number Help
- What's your engine's temperature while idling?
- Anyone here *not* get their headers coated?
- What length o2 ext. for Hooker LT's?
- "tape" thread sealant or "liquid" thread sealant??
- 4L60E Questions
- New valves
- quick lt1 conversion question
- New Times Why Is My Car So Slow?
- Can I get Old Codes?
- Where did all my torque go?????
- Does your camaro whine?
- All Inside-how To Spend $6,000
- Cheapest price on BFG DR's
- Car died....need help
- can't get passesnger side header bolts in!!!!
- Cam
- anyone know weather my t-56 will bolt up to a sbf 302?
- Problems with 95z
- ABS light
- Hooker dual cat shortie headers
- would this engine work on my Z??
- Whining noise when turning key - starter?
- polyurethane bushings
- what are the signs of a starter going bad
- Backfire Problem, Please help
- Donky Dong On Cai?
- Six Speed Conversion ?
- Found an Exploded View of the T56
- Stroker guys what lb injectors are you using?
- LT1 Cutaway
- HELP~! I NEED SOME ANSWERS on OIL PRESSURE
- Techniques for launching Nitto's
- High RPM Miss/Dealer trying to F@#k me HELP
- WS6 TB to MAS air boot?
- Not a REAL problem, but curious
- Stall Converter Question???
- What would cause the tranny to shift differently?
- Charging problem.
- Ran a 6 speed LS1 and new Cobra.
- How much more can I squeeze?
- I need some advice
- Pics of Race Prep AFR heads
- what and where is the crank seal?
- Is the Mcleod clutch too strong???
- 160 deg. therm. change
- A4s with 3.42s which shift point set on HPP?
- LT1 oil pans?
- Reliability of highr mileage lt1s? What to expect to go wrong...
- Cam and header swap...Parts/tools nessesary?
- Uprgading Brakes-What should i go with?
- new symptom
- I HAVE to disable VATS by tomorrow.
- keyed hub or stock hub replacement?
- Locktite vs. Antiseize, and timing cover q's...
- Deleting Torque Managment on a 95. Shifts hit Rev Limiter.
- New best time, dyno tuning + track results
- Need Help ASAP(car on stands)
- Richmond gear users???
- stage 2 heads
- Common EVAP problems?
- Gear and Clutch install!? $$?!?
- How To: wire up a manual fan switch?....
- timing cover bolts
- Need pics of "vain" on the Vortech elbow
- K&N air filter for 97 SS?
- TNT WET kit
- Are stock pistons forged, cast, or hyper?
- WS6 timing problems...AGAIN
- new A4 shifter
- URGENT! I'm leakin oil all over the place!
- dampener hub bolt
- Head work and rebuild questions.
- Will a 96 LT1 Camaro 4L60E bolt pattern fit a 95 Silverado?
- help with ac/heat blower fan
- LT1 blues
- Any tricks to changing the Water pump oil seal?
- Torque converters. how do they work?
- Taylor wires
- Heater only comes out on the floor
- Underdrive pulleys
- Is it bad to run a stock TB even though the PCM is tuned for a 58mm?
- Magnaflow Muffler/Catback Owners!
- quick question
- splayed 4 bolt mains?
- Cheapest Place To Get Moroso CAI?
- which tire to get??
- POS plastic cover on e-brake handle replacement ?
- What size tires should I get?
- MSD coil
- Quick ? about tranny fluid
- High Performance Opti???
- Black Smoke ????????
- Anyone recommend NOT trying cam install myself?
- Stage II LT1 cylinder head by Edwards Motorsports...how much power this worth?
- more ? about engine components
- Arcing At Coil
- Hydraulic lifter problem???
- T56 CONVERSION- half way done
- i need ac help!!!!
- Question for guys with AS&M headers
- question
- LS1 injectors fit LT1 car?
- Those With A Vortec Elbow AND SLP CAI..Question...
- Wanna hear Hooker LT's through a Hooker Catback? Click here :)
- how can you tell if you have bad lifters?
- Size of pinion nut on Moser 12bolt?
- salvage 94 z28??
- Wheels and tires
- any guides or pics for the water pump drive seal
- I want 110mph+ traps until i get some ported heads. Which cam with 3.42's??
- tips for pulling an A4??
- need help with first do-it-yourself project
- Descreened MAF?
- where's the popcorn?
- Project Heads/Cam 236/242 is complete, its ALIVE and Running!!!
- Car temp
- Need Street Twin Torque specs please...
- What's a good "first" clutch?
- LT4 hotcam grind number?
- valvetrain
- Electrical problems suck
- car is still messing up, please help
- oil leak
- Delco CD Changer question?!?!
- Spec Stage 3 Clutch??
- FP change with walbro 255lph???
- SPEC Stage 3 Ceramic 6-puck clutch in!
- 1LE Drive Shaft best to get?
- Need to quiet down the ride..
- Since there isn't a transmission forum (T56 question)
- To those of you with BMR panhard rod...
- Computer needs to run scanning and programming software?
- I really need a definite answer, no maybe's here
- Mufflex Y-pipe and Driveshaft Loop?
- 93 Speedo
- Head gasket thickness and cam selection
- tapping at idle
- Car On Last Breath? Need Help!
- Can I run with.......
- THe engines done now a few timing questions
- Felpro gasket kit same for Impala and F-bod??
- Fuel pressure problems
- radiator removal question
- Which Cam ????
- LM with hooker aero chamber muffler???
- not sucking in seafoam
- Picture Of My Car Leaving On My New Best 60FT- 1.7!!!
- Z06 MAF, 4 simple questions
- SES light
- people who's in mid to low 12's with a stock heads, inside please
- Bone Stock 13's? Post Your Slips...
- All power in the car dies after turning the key
- Change ABS reluctor with gear install?
- 383
- LT1 head question
- Which clutch/flywheel to get ?
- What's some good springs that won't lower my car?
- I have about wheels and tires
- Help, Car is running like crap!
- ZR1 Wheel Back Spacing Question
- Gears
- Stupid question. I don't need guide plates do I?
- SFC In Canada???
- looking for 1.6rr install guide
- What kind of 1/4 mile times w/ hotcam
- Ported heads for free!!
- 305vs306. 305 wins it hands down!
- just bought lt1 & tranny... good deal?
- 315-35's and a line-lock
- broke exhaust manifold studs leading to y-pipe, how to fix?
- PCMforless OBD1 conversion
- Need Help blew clutch?
- Anyone who did DIY 02ext in here.
- Gas smell help..
- Gear question?
