- Lowering CR on stock LT1 head
- The notorious LT1 water pump
- Speaker Size?
- Those that have purchased GM water pump and opti o-rings seals
- why are FLP headers so expensive?
- Fuel Problem-Despirately Need Help
- Quick question: Wiring harness and ECM?
- 2-series posi in 3-series rearend?
- rear end whining
- Can opti just suddenly die??!
- correct speed on gauges?
- hard to start
- People who like to look at pictures
- Give me some idea's
- placement of bullet mufflers?
- Fuel pump harness 96 Z
- Bose Cd player cost
- Oil on a plug...Low Oil Presssure?? Whats going on!?
- Valvetrain rebuild/work and 1.6 rr
- OBD I and OBD II
- Answer to starting problems!
- Ok Ok Now What Do You Have To Say About 4.10s In The Snow
- fuel lines need help fast????
- Bad PCV Valve > Oil in Intake
- slp dual dual or GMMG?
- lt1 question
- Changed the plug/wires now won't start
- Magnaflow outflow 2OTL???
- Guideplate height differences....is there really an advantage?
- Lightweight Flywheels.. question on streetability
- What extras do i need for a cam swap?
- Is it possible to use just a cloyes chain?
- P0100/p0103 1997 Z/28 Threw Codes
- Need help ASAP, is this Toulene pure/"virgin"?
- My Header and Dual Exhaust Design...
- Rounded off lugnut
- Tranny temp guage problem..can ya help me?
- 95 A4 Flywheel
- Guys who run skinnes up front everyday?
- Borla sound? how to generate it?
- High idle after relashing valves...vacuum leak?
- legal headers
- Header Wrap
- Throttle linkage cover PN
- brakes after hotcam?
- Need Urgent HELP, crank hub is stuck on bad!!!
- Going to Dyno
- Demand Identify Camshaft
- changing fuel pump today, one question......
- Need new Brakes
- Need Experienced Opinions ASAP !!!
- Fuel Saver Pro
- Please email me all your Dynocharts and Track times with aftermarket cams!!!
- New times. Comments?
- supercharging a stroker
- Anyone running Hoosier Pro Street Radials
- Amount of gas used during WOT?
- Raytech Solid Pinion Spacer?
- Air Dam!
- roller rocker/ valve spring install
- Ngk Tr55 ??
- Who has a definite fix for the PARKING BRAKE RATTLE???
- Plugs?
- What size fuse to run with MSD ignition??
- Check engine light flashing.. what's up?
- Opti bad or the sending unit before it?
- Who has used a billet core cam on a LT1?
- best prices on AFR?
- Okay guys your Fav. Plugs...I think Im changing them soon so need 8
- Sound or power
- Is it possible to get drivers side header in w/o removing the oil filter?
- Problems with wax!!!! HELP!!!
- Dyno Results
- 1993 Trans AM need info
- MAC headers installation
- A/C compressor delete belt size?
- Headliner
- 97 SS: What does she put down?
- IL inside
- Which muffler??
- Anyone have the XE 230/236 cam? Questions asked...
- Trey thinks theres something wrong with my car
- header install...egr question..
- Valve Lash to tight??????
- air pump removal?
- lt1 stumblems after resetting computer???
- Dyno and Track Results 230/236
- Last ditch effort....cd player power advice please!!!
- cut out or straight pipe
- SLP Loudmouth....
- Cutouts
- may be dumb but why 327cid???
- very desperate, out of ideas. PLEASE!!!
- Hot Cam idle speed
- 396 cubes?
- coolant
- timing set install???
- LS1 vs. LT1
- Removing hatch plastic/vinyl
- Coolant in my oil!!!
- Paging Mindgame
- What parts are required for OBDI conversion
- to crank engine without starting..... only remove coil plug??
- antyhing else needed?
- Yet Another Question on my Car Problem
- TDC for #1 cyl: timing marks aligned??
- Of EGR, Air Pump....
- writeup for A/C removal
- SES Problem
- Anyone with cam and stock heads trapping 110mph+ with stock 3.42's??
- broken manifold bolt!!!!!
- Rear Wheel (In Honda)
- LT4 Hot Cam Install
- How much for a LT1 to take a LS1
- Port and Polished???
- Those of you Firebird/TA owners with headlight issues, inside here..
- High stall shift problem
- Look at these heads, what do you think?
- Trans Am Door Emblem Part # ?
- Current status on my car (Also need oil pres sensor part#).
- glove box codes
- Please list all items needed for a cam swap...
- Your opinion on a cam set-up. Which ever gets the most votes for I will do that cam!
- It's always one problem after another...need some advice
- throttle body question???
- 2.73's or 3.23's???????
- What Headers used with Lowering springs
- Problem with wipers, Need your help!
- Combination Motorsports
- Important Timing Question
- Any fix for left turn rearend squeal?
- Could someone host my dyno sheet from DynoJet yesterday?
- Weird problem with rear hatch
- how much coolant needed?
- Just ordered vigilante now i have a question
- where do i jack at, there is a spot
- LT1's and Magazines
- Question about my blown head gasket?
- help needed my car wont start please help!!!!!!!!!!!
- Squeky cluth pedal, where to lube?
- 97z idles fast? HELP
- I think I just about crushed everything today....
- Lowering the Z
- Idle drop...
- Fuel gauge doesn't work?
- I neeed speedo gears..!
- quick question on my h/c lt1
- Camaro C346??
- Performance mufflers whistle
- Need Advice...93 LT1 rebuild or...
- Just hit 50k miles on my 97 Z28, gonna get some SVC done, got questions???
- HEADS/CAM car is ALIVE! XE 224/230
- Belt screeching under WOT???
- please read... about engine bay
- need help with heads ASAP
- Adjustable Fuel Pressure Regulator
- Problem since plug change...
- Need some help on this
- if my car starts after a while of being dead could it be the opti?
- Cam bigger then CC306...?
- O2 sensors and closed loop
- cam experts in here
- anyone know where i can find one 17x8 chrome eagle alloy 077?
- GM High-Tech Readers.. Sell me your old magazines.
- 1/4 mile times, ran today 94Z Auto
- Help me spend $600...
- Does this look like normal wear??
- Serpentine Belt
- intake manifold leaking?
- Difference between Z28 and SS
- whats the diffrence between the lt1 cam and a standard sbc cam?
- A4 wont shift at WOT? Please help.
- I need the help of oil leak experts
- A4 to 6speed conversion? anyone done it?
- kinda strange?
- longtube headers
- catback exhuast
- Need Help ASAP!! Oil pressure problems!
- dont flame me for a stupid question
- Torque Converter ?'s Lots
- what year did they begin 6speeds?
- New engine? Rebuild
- M6 conversion, do I need my flywheel balanced?
- Green Top Injectors
- FIX: for scanning and tunning with no serial port
- !994 LT1 Problems
- Ring gap locations on pistons
- 1 3/4 shorties
- Which Headers
- How long will a cat last without the air pump?
- is this normal
- whats the stock rearend geer ratio??
- Just got 396...need help
- how to reduce fuel consumption?
- Questions regarding V6 springs
- Screeeeeeech
- what takes away vacuum with big cam-LSA/overlap
- Manaul Temp Gauge
- Oil pump install???????
- ABS light Question
- pull timing!!!
- v6 lowering springs on lt1
- tubular K-members and A-arms?
- my times
- quick lt1 swap question
- Took my z to the track today
- air box
- NA stock bottom-end ET record?
- whats the disadvantage to low rearend gears?
- yet another stumbling problem...
- '98+ brake calipers from Autozone (reman), should I?
- 1-3/4 or 1-5/8
- Cloyes part numbers...
- Did I get a good price on these heads?
- Opti Upgrade? Any write-ups?
- Overdrive not working?
- Anyone running DynaTech cone inserts or Car Chemisty inserts?
- new waterpump or electrical?
- wheels
- Gears for CC306
- How far are you guys pushing your Scat 9000 cranks?
- 1/4 mile time difference goin from stock 16in to 18in rims??
- Hesitation, confusing symptoms help
- Quick Question
- gas mileage..
- Tranny Fluid
- hub
- cutout in front of the converter?
- which of these shocks are better?
- how to modify fuel rails for more GAS ?
- 97Z with LM question???
- need measurement on longtubes
- question about transmission service
- Changing Alternators
- i NEED brakes!!!!!!!
- Repair costs on a rear main seal for the engine oil?
- AC compressor locked up for a 2nd time
- A few tech questions.. please help
- 3" Cutout VS Catback Kit
- catback question.
- Dana 60?????
- LT4 KM and GMS MAF sensor. Holy crap!!!
- auto vs 6speed manual
- Another o2 question
- Need fuel info for LT1...
- Where can I get the "Early LT1" Comp Cams timing set?
- b&m trick shift
- Bad miss in my Z?
- A4 and M6 whats the diff?
