- Code 36! Help!
- Bigger oil filter ??
- Which Is Better HPP+ Or The HPP III For Our OBD II Cars
- Who has run a 110LSA cam in here?
- Oh God What Did I Do To My Baby?!?!
- Extreme Duty Timing Chain Question
- 95z problem
- Steering Problems...Need some help
- question bout 2.73s to 3.73s
- Oil Pan Gasket
- Over heating problems...
- Heater blowing cold?
- Question on an LT1
- SES on CHECk this out!!!!!
- ?S on Rocker Install
- Help!! How much for LT1 Engine?
- is LT1 great for a road trip car?
- LT4 Clutch disc
- Information on MAC headers 96-97
- Walbro Pump installation....
- SERIOUS company looking for feedback to produce the ultimate F-body turbo kits!
- I need some help here !!
- Sputtering/missing above 4,500?
- Bad Opti? How do I know?
- track results with the xe 230/236 cam and bolt ons.
- LT-1 removal
- everyone with a CRANE HI6-TR inside please :)
- What year did the LT4 come in the Z28s?
- Well, I'm back. Now that the holidays are gone.....
- cleaned IAC, now car idles at 2k....huh?
- Difference between low and high rise ta spiler hatches?
- Need info on a good low buget rebuild kit
- 2 quick ?'s for A4 + 3.23 guys
- Canfield heads
- 97 Clutch master,slave, or other problem
- My car is missing
- Pro's and con's of lowering my car (dms springs)
- Brent, somebody else selling your ideas!!
- Gas leak wont go away
- gearing??
- 95 Camaro With Dual Cats?
- Goodyear's GS-D3 vs nitto drag radials
- 1 problem, 1 question
- Which cam would be better for me? 230/236 or 236/242?
- attn: brent94z
- Bad NEWS
- Car died in the car wash...help
- LS1 Driveshaft Part Number
- Need cam advice
- A/C Compressor removal questions
- 93 adjustable fuel pres. regulator
- Need Help ASAP!!!!!
- Who's put 315/35/ZR17's on a 17x9.5 wheel???
- The parts list is finished! Check her out and see if I am missing anything.
- RPM's sticking!
- AS&M install questions
- Stock rocker studs ok with CC306??
- Looking at LT4 HOT cam kit and Hooker Shorties, have some ????s
- What size exhaust?
- Car eving to 6800, is this safe???
- weird noise
- How to convert MPH to HP??
- 315's on a lowered car
- No Back Brakes!!!!!!!
- Gains from 2.73s to 3.73s
- 160 thermostat
- For those intrested: Finaly cost of my cam job.
- Garage Pored Water on Opti!
- What clutch to hold 400+rwhp?
- nitto 555r
- Hooker Areochamber-Dynomax Bullet-Flowmaster?
- Gears which ones
- How difficult is it to replace the alternator?
- tranny temp gauge on a M6???
- T/A t-handle shifter in Z28?
- horsepower
- Lt1 396?
- 94 Cat Back v 96 Cat back
- what makes higher numerical gears weaker
- T/A A4 performance button in Camaro with TransGo?
- art car convertors?
- In the middle of a clutch install, need help
- A4?
- item on ebay!anyone seen this?
- switching to 95 timing cover... will my non-vented opti work?
- SES Light & Fans
- MAF problems
- Nitto 555 vs Nitto 555r?
- Will A LS1 Clutch Pedal Fit A LT1?
- Getting my tranny replaced, but whats wrong with it?
- Meziere wiring ?s
- What Mods Do I Need To Take This Modded LS1?
- Moving cat from stock location
- About 1-2" of play in the steering wheel in my 96z ... wtf?
- 3rd vs 4th gen repair costs
- How long to install a hotcam kit?
- How much gain from Hals?
- Reserching rockerarms and..
- heater core hoses replaced
- Found a new car today.. Advice
- where to get big tires
- 95 maf problems
- valve spring change
- Removal of PCM?
- Sensor that hooks to water pump? Identify its use
- a4 dissassembly question
- has anyone seen a 170 thermostat?
- header choice
- What does it take to get an ls1 exhaust to fit
- pcm for less
- anyone done the push button start mod?
- Blowing trannies - possible fix within
- Cam install w/o pulling motor?
- LongTubes VS Shorties???
- Why aren't longtubes emissions legal?
- some questions about over valve cover spark plug wires
- Which mods next?
- Anyone using Line Locks on an M6???
- need help please!!!!!
- Spark plug gap?
- OVC Plug wires w/ Mac Headers???
- Best converter for this setup?
- part number for relay???
- Anyone have probs installing 17x9's ?
- what do your lt1 heads flow #s
- best place for tran temp sender?
- SVO Injectors
- Part number for LT1 T56 clutch fork?
- Could I put a cutout right here?
- Dynomax Bullet bad idea for stock LT1?
- Gears- 3.90's?
- new headers for the Z!!
- Jordan Musser
- Who wanted those Throttle Body Plates from eBay!?
- Sollid Roller and smog?
- Vigilante torque converter with 76,000 mile tranny? Risky or not?
- longtubes for 93????
- Painting rims need HELP!!!!!!
- Opti
- nu-tek cyl heads what is said
- Opti going bad Need advice
- What is needed for OBD1 swap
- Few problems on 93Z28
- Coil glow?
- BBK headers
- Coolant Level ?
- Kmember install
- best shift point
- Stock Gauges and White Faced...
- Noise and vibration out of 1st
- 95 Trans Am 1/4 mile times
- How long to break in clutch?
- Dual Cutouts?
- Scanmaster work on 1993 Z28s?
- Pushrods
- Would this be suicide?
- Rack & Pinion noisy in the cold
- Rear Suspension Creaking - 96 Convertible Z
- Ignorant people and 1/4 times
- How to tune speed density?
- 26 or 28 spline axles
- 93 Cam swap and electric water pump with cloyes double roller timing chain question.
- Coil
- Oil leak questions
- Jet Hot LT Headers .... clearance issues??
- New dyno #'s
- any 1 with 17x11 tt2 wheels please come inside
- New Opti /No fire.....Help!!! ASAP
- Fuel Pressure??????
- anyone who has worked on power seat...come in!
- Reputable place in Greenville SC area to install Roller Rockers.
- Fuel Mileage questions?!
- SES Code P0412 - Air Relay Control Circuit
- can i use Ford MotorSport injectors in my T/A???
- Trans Am Seats in a CAmaro
- Blue Smoke....
- General questions on modifications
- Who is running a Nu-Tek Stroker & what is your rwhp.
- How much does a bare LT1 block weigh????
- Ordered me a new Trans and Verter!!
- Please Help With Chugging at 1500-2000 RPM
- What do these factory TA wheels weigh?
- O2 extensions on MAC exhaust
- ANOTHER as&m install? sorry
- Which SFC's should I get?
- Real quick question on Kenny Brown DD SFCs
- Car starts for a second then goes off then doesn't start? Opti/fuel pump help!!
- L99 Head Info
- Reuse Vigilante converter after A4 tranny has blown???
- What bolts do I need to replace doing a heads/cam/header install?
- Custom Firebird Guage cluster??????
- What ignition box are u running?
- IM Getting bent over (deleted by moderator)... Need info
- Who has spent the most?
- Exhaust- Did I do the right thing this time?
- Everybody with a rollbar in their car, about carpeting...
- '89 350 Z28 vs. '94 LT1
- Need help selecting parts (383)...
- How involved is a 4L60E trans cooler install?
- Car acting up......Opti?
- No cat + cutout
- Magnaflow Installed!:)
- Question about the coolant cross-over pipe
- tire and rearend questions
- can you use a 95 hypertech prog. on a 94?
- "SECURITY" light staying on and cant start the car
- Racenet Performance Power pack II
- LT-1 Intake Manifolds
- F/R Eibach springs, how much do they weigh?
- Rear sway bar diameter
- Have LT1, but have 98+ Front End, which Air Box to get for SS Hood???
- Calling all cam gods on the XE230/236 Comp Cam
- No oil presure
- best exhaust?
- Another place to get great, problem-based, info on our f-bodies!
- Water transfer tube removal... Am I asking for it?
- Can you see Hooker LTs hanging under the car?
- 450lb transmission jack ok for M6 removal?
- Saying goodbye for a while....I'm off to the sunny middle east.
- want to build 383
- removing drivers side wiper arm
- Best y-pipe for LT's?
- Water proof opti-spark?
- will a rear out of a 97 work on my 93?
- Need lugs for Konig Monsoons...
- hi iam new and need some advice
- Do I have to plug the Water pump gear hole for Meziere install??
- Trouble Code 84--Please Help!
- Rear Brake Rotor Job
- Want to run in the 10's all motor on pump gas.........
- Can anyone help fix my exhaust?
- 1997 LT1 Stumble/Surge/High RPM Miss SOLVED!
- what to use to lube cam
- MSD Digital 6 - Where to install?? - 1997 Firebird Formula
- Car KEEPS popping fuses.....
- What cleaning product to use for radiator flush
- coolant leaking
- 5.3 Heads On A LT1????
- got my bmr tubular subframes welded in!
- new clutch assembly?
- wheres harland
- Just finished 383 stroker project - now car won't start!!! HELP!!!
- low rpm stumble
- heads+cam= change headers?
- I need a copy of instructions for installing KB Double Diamond SFCs
- Anyone dropped their transmission without help or a trans. jack?
- Removing Rad
- Anyone got sound/video clips of the hotcam?
- What mod would be best for me next?
- Estimated cost of installing a cam that I already have? Not labor, parts
