  1. Guys who've changed pads without resurfacing the rotors
  2. Need help with SFC...HELP!!!
  3. Is Carsound better than Catco Cats?
  4. Anyone have a 58mm TB they haven't installed yet?
  5. fuel pressure regulator worth it or not?
  6. Which would be better Hotcam kit vs. CC305
  7. LT1/BIN file for 95 Z28 M6 with HypTech Power Prog.
  8. some electronic problems
  9. How hard is it to install new Plug wires and Coil/Coil Wire.........
  10. Tranny goes bad once again!!
  11. fuel pressure regulator worth it or not?
  12. 24-2600 Stall 94 Z28
  13. Lt1 timing question?
  14. WTF... sticky throttle!?
  15. Plugs and Wires..What kind?
  16. how do i pull ses codes?
  17. Factory fuel pump, Where is the fuse?
  18. Strokers with high stall dyno numbers?
  19. Something Is leeking Oil
  20. V6 springs on a 96 z28???
  21. Where did the end of my starter go? (FUBAR pics)
  22. Jason Cromer is the man!!!!
  23. So what would have to happen to explode a Sun-shell (tranny )
  24. Keyed hub and damper??????????
  25. Shifting question
  26. 4.10's in 396 w/4L60E ?
  27. Best headers
  28. 93 z rpm jump untill warm ?
  29. guys with bmr weld in rlc brackets inside please....
  30. Voltage across Battery?
  31. cam
  32. water pump removal?
  33. after repairs
  34. 383 rotating assembly balance
  35. Hold gas to floor to start, why?
  36. Ordered my cam :) XE 224/230
  37. Pcm?
  38. lt1 swap will not shut off
  39. Sounds like a hill billy till its revved out.
  40. roller rockers and valve adj.
  41. Free mods questions
  42. C5 brakes upgrade question!!!
  43. Just RR's and no cam!
  44. Question about Flywheels
  45. Spohn Adjustable Torque Arm
  46. cam?
  47. Help with LCA'S!!
  48. Got A Question About The OPTI
  49. Hooker Aerochamber review
  50. LT1 Rebuild
  51. what tire pressure should I be running?
  52. SES light after a new muffler
  53. 52mm throttle body good enough for a 396?
  54. Theft deterant and starting problems.
  55. Brake bleeding ?'s...help please
  56. LTCC users check in here
  57. Question about my computer
  58. header question
  59. CC305 or XE 224/230
  60. I need some traction!?!?!
  61. TB bypass problems??
  62. 383 Building ?
  63. new clutch
  64. Which gaskets to get for heads/cam install?
  65. What is necessary to run CLoyes 3145 chain on 96/97 timing cover?
  66. Cutting hole for fuel pump install
  67. Are there two different length crank hubs? What works with what if so?
  68. Hotcam Cons
  69. aftermarket tq arm with true duals?
  70. Besides a head gasket, how else could coolant get into oil?
  71. Quick Cam question?
  72. bad o2 sensor
  73. '94 z28 fumbling lots
  74. porting for 58mm TB w/o removing intake
  75. Timing chain options
  76. What brand should I get and where to buy injectors for cheap?
  77. Cam guys: pls post your gas mileage!!
  78. Driveshaft?
  79. What are the high HP guys doing for a timing chain?
  80. What changes with gear changes
  81. Can I use this bearing???
  82. CleaNing Engine Bay?
  83. Guys w/BMR tubular SFC'S INSIDE
  84. recent pics of GTP stage 2 ported stock LT1 heads
  85. speedometer going crazy what could it be ?
  86. lt1 oil leak
  87. opti spark replacement?
  88. water pump
  89. ah crap
  90. What size tap to chase threats in O2 fitting in pipe.
  91. car runs hotter on the highway....
  92. good price on opti and water pump
  93. Drive Shaft length
  94. My oil pressuser seems to low need help?
  95. changing valve springs w/ heads on car?
  96. Exhaust Idea......input please......
  97. m6 issues
  98. DCR vs SCR and power-adders!
  99. Anyone ever cut this plastic piece off?
  100. Bad pinging...help!
  101. RE-use TB Gasket?
  102. Whats a good drop-in valve spring for an LT4 head?
  103. got the cable....but i have another problem...laptop doesnt see pcm
  104. Cheap Tires?
  105. i need numbers
  106. After market A4 shifter that fits a 95??
  107. Engine is DEAD~! HELP~!
  108. Power Steering bypass, How to?
  109. Is my rear sway bar the same as the panhard bar?
  110. Help Need 97 and up stock five stars
  111. Backspacing on 18/9.5 Z06 rims to fit all corners?
  112. Anyone have these exact cams? 236/244 or 230/236
  113. B&B Exhaust install
  114. Ls1 Nos Kit on an Lt1
  115. Brodix heads for LT1...just maybe
  116. Anyone know what the LT1 intake flows in CFM??
  117. Need a PN# for T-56 clutch Fork PIVOT TEE
  118. Head gasket to raise compression?
  119. A special thanks to all the members that helped along the way
  120. Comp Cams roller rocker ... etc.
  121. 1.6 rr's
  122. Stock length driveshaft with 9"????
  123. if i tellya what happened just an hour ago, will you help me?
  124. BMR vs PA Racing
  125. GRRRR electrical problems...
  126. Everyone using GM Extreme Duty Timing Set - Please Read!
  127. Will 3inch cats fit underneath the car ok with LT & 3in ypipe?
  128. Why does my shifting act like this?
  129. ? for those with '95 Macs on a '96-97
  130. LT1 Reluctor ring?
  131. T56 conversion question
  132. Punched Hole in Cat - what went wrong
  133. Could someone please explain head flow numbers to me?
  134. Question about intake elbow and optispark?
  135. my car burns oil, please help
  136. Fuel pressure regulator
  137. My Tips for those installing shocks, knuckles and brakes
  138. 4th Gen rack and pinion
  139. Who makes the best intake gaskets for LT4 heads?
  140. Cat back
  141. what is the advantage of an...
  142. Intake Manifold ? About Anodizing
  143. Cc305 Vs Hotcam
  144. One more optispark question?
  145. Procedure/techiques for adjusting Spohn torque arm?
  146. What kind of oil is best?
  147. Mod opinions please....
  148. 1le trany mount
  149. Finished oil pan gasket today, but now bigger problem
  150. theoretical question about painting stuff
  151. Lifters
  152. MAS Can i Take it off
  153. Can't separate T-56 from Bellhousing...
  154. Fans do not turn on... and headlights are on when not supposed to.
  155. tranny/computer?
  156. How much horsepower do you think I will have?
  157. torque converter question
  158. Knock Sensor relocation
  159. Hooker long tubes Left #1 primary
  160. SES Light in Caprice
  161. o2 sensors keep failing
  162. quick capacity ?
  163. When to adjust rockers??
  164. looking for pics of SLP line lock..
  165. Hypertech programmer changed....
  166. track testing the hypertech
  167. Plug access on edelbrock shorties?
  168. Long tubes and dual cats
  169. MidWest Torque Converter?
  170. Car won't crank (sometimes)
  171. Part number for shorter belt BBk pulley
  172. important cam ? need to know tonight
  173. USED SLP install (with primary already welded)
  174. Custom catback?
  175. installing log tube headers
  176. Flowmaster vs Edlebrock exhaust.
  177. Got my car today
  178. Makeing first gear selectable on a 2.73 car
  179. lights on dash
  180. XE 224/230 112lsa??
  181. z28 lt1 or corvette lt1
  182. cam shaft choosing
  183. can i use stock rockers with this??
  184. fuel pressure gauge
  185. Whats the widest drag radial I can run on pro star 15?
  186. Decent Price?
  187. How much HP will I make?
  188. How difficult is changing the rear main seal?
  189. Engine Problem? ... help needed
  190. Anybody have long tubes and a single cat?
  191. Strut/Shock tower thread size
  192. help with Low Traction light
  193. Starting on my heads/cam swap later today, here are the details!!
  194. Gear Swap
  195. Will these tires fit a 93-97 Camaro
  196. need sam smith's # for new opti
  197. cat back install -please come in!!!
  198. DID they make a 16x8 Firehawk rims?????
  199. 1995 95 with OBD II
  200. new injectors?
  201. Where to install water temp. sender for Autometer water temp gauge?
  202. stupid car won't let me win and not racing
  203. Is something wrong with my car?
  204. Is it bad to go big with injectors?
  205. can a 98 Z28 and 94 Firehawk swap rears?
  206. Anybody know the length of the bolts needed for Spohn TA?
  207. Question about the GM 847 cam
  208. Spring cleaning
  209. Rough Idle HELP!!!!!
  210. Z28 Reliability, Show My Dad
  211. car feels weak
  212. Need some pic of welded or bolted sfc...Thanks
  213. Fuel Pump Problems--help needed
  214. CS-144 or Dual Rectifier Alternator
  215. Hard to start issue
  216. My LT1 sounds like a sewing machine
  217. part list cam/heads
  218. removing alternator
  219. Shoebox do you have an exploded view of..
  220. car value
  221. tiny exhaust leak on collector of AS&M y-pipe, is it hurting me?
  222. Electric WP
  223. WTF...tranny mount?
  224. help my tranny is slipping
  225. Help Me Please
  226. Help!! Throwing cdes 41, 42, and 51
  227. Thin Cats
  228. csi wiring que
  229. test pipe
  230. Lower price on LS1 brake kit...
  231. Fuel Line disconnect tool??
  232. Curious happenings with hydraulic lifters...need insight please
  233. My car is trying to overheat when I leave it running....
  234. 2200 stall + A4 + BFG drag radials: should I worry about rear end??
  235. will 95 hooker headers fit on a 96 camaro?
  236. Gears 4.10 or 3.73?
  237. Will these rims fit???
  238. is my solenoid going bad or my tranny is getting ready to blow up??
  239. Quick! Wiper blades!
  240. Borla with Mecham tips, will tone or purr differ?
  241. Open,Closed Loop, and TP sensor questions
  242. Air bags.....
  243. Grrrr...scoggin-dickey problems
  244. How the heck do I do a coolant flush?
  245. Elec water pump conversion question
  246. First Dyno Reults! DynoJet!
  247. Anyone ever break a LPE ds?
  248. rear-battery troubles!!
  249. Fix annoying popping sound with borla
  250. Where to get set screws for roller rockers?
