- SS Ram Air Box Not fitting.......Please Help
- Changin plugs and wires
- Replacing Rear Bushings?
- Knock retard
- Who is using a lower Alt. bracket
- Where can I buy coil over kits?
- Need help ASAP, please.
- non vented to vented opti?
- PLEASE HELP!! Tranny Problem With Overdrive....
- I have my scanmaster
- t56 rebuilt guide....i need one.
- ses after PCMforless tuning
- I have a ?
- Getting the hub on to the balancer?
- Anyone done 335/35/17's
- carries
- overheating and cant get enough coolant in
- can a bad fuel pump cause blue smoking?
- broken pushrod guide plates
- Why does my transmission NOT kick down when driving on the freeway? 700R4 people in!
- Aftermarket valve covers
- Anyone running this drive shaft, in here???
- Please Help My Car!!
- need help with relocation brackets!!!
- Tranny Question
- Does this should like the Optispark?
- question about a leak?
- Can i smog with long tubes??
- electric water pump or back to stock water pump???
- what other mods can I do? and also running rich?
- cam help please
- checking valve to piston clearance
- TB Plate Question!
- Suspension "stuff" to check
- i need a part number
- locater needed on bottom of v/spring?
- how much hp for hot cam kit???
- Hotcam track results!
- tires
- 4L60E Question
- most beneficial bolt on?
- Need help fast ABS adj. ? on a Strange 12 bolt.
- Anyone have the full specs on the LPE 211/219?
- Gone through 3 opti seals
- 1.6 rr's
- Straight Boot plug wires will they work OTVC
- Quiet Exhaust
- Alarm installation, power door lock help!
- 93 hot cam dowel pin
- valve stem seal help
- Any guesses on my horsepower or 1/4?
- Help!!! car wont start!!!!asap!!
- Shift points on a 93z?
- 99 corvette rims
- any posi left?
- Trany
- I need a GM part # for a Front Seat
- Would a Yank 2600 be good for me?
- Which exhaust gaskets for AFR heads??
- Electric Waterpump Durability
- Those with corbeau seats come on in...
- Bad lifter???
- Vacuum needed to opertae A4 tranny
- Were there any LT4's with Automatics?
- th400 transmission swap
- T56 CONVERSION QUESTIONS !!Gurus enter!!
- How hard to remove intake manifold?
- CANT GET MY AUTO TRANS OUT. How do I get these bellhousing bolts out.
- A.I.R. Recall?
- 87 octane vs 91 on my car!!!
- Cam swap @ 140K
- Working on car now. Spark problems
- "Engine Sensor" fuse blown.
- SLP intake and vortech elbow...
- having some issues....PLEASE HELP
- why does DFI (accell and FAST) use one o2?
- POLL: Console Lid is a POS
- oddball question
- possible causes for hissing/pulsating noise under load?
- Nitrous & advanced timing..
- Head Gaskets
- Cant shift into 2nd
- replacing starter on '96-'97 LT1
- Combination Motorsports heads???
- "Engine Sensor" Fuse. What is it.
- Will tuning fix my popping?
- What catback would sound the best with Mac headers??
- all the stupid little crap that breaks on a fbody
- BMR K-member + Stock A-arms :-/
- Thoughts on VGX pads and powerstop rotors?
- runs fine then runs rich and rough
- Damaged bell housing, oil pan... pics inside.
- Valve Covers W/Compcams Pro Mag SA RR
- ICM relocation
- Things to check before cam install??????
- Voltage
- BMR tranny mount??
- Need 3" OD 304 Stainless 90 Deg. elbow
- 4-2 and 3-2 shift
- Converting coolent back to dexcool
- How to prime the oil pump in a LT1 engine
- brake light stuck on...
- Moroso CAI install Hard or not??
- Adjusting rockers after cam - how to get to TDC
- Cheapest place for the CSI electric water pump?
- Centerforce Clutch ????
- Dynotech Distributor over the Opti-Junk
- 97 LT1 starter or neutral safety sw.
- dead car
- Screw Down Injector Port !!!! Help
- Are my rods worthless now??
- sometimes i hear a clicking noise????
- BMR SFC, Tube or Box?
- O2 Sensor replacement question.
- ATI super Damper Install question
- gts front blackouts where to get the mounting hardware?
- which electric water pump needs modified?
- Do not want to splice Scanmaster
- Just got my TES headers in...
- Help~! Engine Is Pos~!
- Security light on, car starts?
- gas milage
- Lt4 Starter Motor Part #??
- Magnetic CB Radio Antenna
- Help...car wants to idle at 2k rpms
- Hotcam HP gains
- thunder racing cam swap gasket sets?
- Rims
- Gas Tank Drain?
- real quick question
- kyb-agx shocks come on in!!!
- Part numbers needed, oilpan+bellhousing
- Exhausting INFO.
- Resetting the Theft Deterrant
- People who have installed LT4 starter (shims)
- How much air pressure to hold valves up?
- Arlington Motorsports (AMS) is stealing $3100 from me
- Adding Muffler: Flowmaster or Dynamax??
- abs and e-brake light
- Sound clips of true duals and longtubes
- Complete Valvletrain Rebuild
- How would this sound???
- valve spring questions
- performance opti?
- Installing Oil Level Sensor
- Broken Bolts!
- 3500 Vigi on stock car
- XE or CC306 for an LT4?
- Tunercat users please chime in
- Overheating while car is parked idling
- Intake options for speed density setup
- Stock HP of lt1's
- T-top conversion pics inside!
- Help on installing Hooker LT's
- Cam questions, please help
- check engine after cat back.
- strange noise when key turned on than haed start.
- car missing
- Could bad Valve Cover Gaskets Cause Oil all over the Engine Bay?
- Question for LT1 folks in Memphis area...
- EGR block-off
- Attention: badgta
- srupid lt1 question
- Ceramic coated or Jethot coating?
- Two Piece Timing Chain Cover
- What solid roller lifters do you us.
- tell me what you think of these cams.
- True Duel Exhaust Pics for Hooker LT's
- Just Need A Little Advice From Some Experianced People
- Break out the Vaseline......
- FIXED OPTI, now it sits flat + harness problems
- transmission compatability?
- PPL with dual exhaust?
- Ignition problem!
- Anyone got an idea of why Im breaking torque arm......
- Odb1 connector!
- why are ls1's so much better than lt's?
- headlamp coversion
- Anyone else have the same problems w/your hooker longtubes?
- Tailpipes make water steam after long usage ... is this normal??
- Another MSD Digital-6 ?, what to do with extra wiring???
- Are shifters for ALL T56s the same?
- What to buy first Upper or Lower A-arms?
- What Cat-Back Exhaust should i go with ?
- Need solution to Squeaky Clutch Pedal..
- What Plugs and wires to use
- HELP! How do I remove fuel pres. regulator from fuel rails
- What brand 17" tires to buy
- anybody try the dynaspark yet?
- Basic mods to beat a stock Cobra
- Where to get a electric die grinder for a decent price
- removing plastic on the sides of the rear seats
- Why Does The A4 Idle Lower Then The M6?
- WOuld an exhaust leak make more power?
- Cut out with a RPM Switch... Anyone???
- Oil inside TB ???
- rocker arms first, then cam later questions... and 224/230 or 230/236?????
- Wheel/Tire size ?
- FINALLY finishing hooker lt install, now a couple more questions
- what cheap 15" rims would fit 4th gen f body
- Drag radial tire wear ?'s
- putting together motor, which gaskets to use?
- Cutout?
- Codes 36, 41, 41. But car feels fine!!!!
- Noisy 1.6 Roller Rockers - Normal??
- How long to install Optispark?
- Harmonic Balancer
- Have a question about the year of my car??
- ¿?¿blowing Fuse¿?¿(help Me Please)
- Gears or torque converter?
- Camshaft retaining plate question
- Beru SilverStone Spark Plugs??? R they worth it?
- combo motorsports vs nu-tek?
- Anyone have a BIN or LT1 file for a XE 224/230 112 LSA w/Ported heads?
- LT4 valves vs Manley Race
- Are Taylor wires the only OVC wire set out there?
- NA/Nitrous Guys with DFI/Fast
- self alighning and non self alighning rockers
- Anyone Tried the DynoTech Distributor?
- Code 84?? What's it mean??
- Which CAI?
- Fixing intake manifold leak, what all do I need?
- Voltage Regulator Replacement
- Pinging - stumble on part acceleration and idle\ SOLVED!
- LS1 Brake Conversion
- are NGK TR55GP plugs ok>?
- Does a 93 have any problems with the high stall converters?
- Stainless lines for LS1 brake swap
- removing egr
- LT1 and LS1 K-Member
- timing set?
- .bin or .lt1 file for 230/236? anyone have one?
- --part # question--
- Crane Cams ps-91 review
- Stroker kit Question
- Aftermarket coils?
- Comp Drag Shocks in the back?
- I need help....quick....
- Ohms of OBDII knock sensor
- LTCC box is up and running!
- Crank Hub
- What kind of coolant to use after replacing optispark?
- just got a moroso air filter
- these guys saved my a$$
- wierd flashing lights in car
- Brake line specs for the 3 Rear lines
- True Duals or Catback
- Dyno results!!
- Car running wierd
