- Nitto's!!! What PSI at the track??
- new exhaust set up needed
- 12-13mpg on a bolt on car wtf. Fuel effciency question within?
- Attn: Fred
- best suspension mod to stop wheel hop?
- MSD Ignition, what spark plugs to run??
- Any one have any tips for removing my $#@%^$&$%^ oxygen sensor? (edit by moderator)
- Axle and differential problems
- What Flywheel and Clutch are u using on your T-56?
- Oil temp gauge....Where to tap?
- Knock Retard
- Where to get Opti Sensor?
- Difference between 95 & 96 sensors, ect
- What do you guys think of this
- Tubular front k-member
- Spintech muffler ?
- a4 trans problem HELP!!
- removing traction control
- best cold air intake slp?moroso?k&n?
- Flow Numbers and pics of home ported heads!!!
- Removing air pump what to do with empty holes in headers
- 17x9.5 zr1 rims..spacers? lowering springs?
- fuel rail covers
- What should I set the Fuel Pressure to on the 355??
- headlights
- Symptoms of bad Opti?
- piece of copper pipe glued in bbk tb?
- Pushrod Guideplate
- How do you clean injectors? Do I need new ones?
- Cat clogged, need exhaust options inside...
- Pushrods
- What kinda hp am i making...
- Headers from dual cat to single cat
- Cruise Control + DR's + Rain = A Change Of Skivies!
- Think I Lost Alot Of Power With Exhaust!!!
- OptiSpark Seals
- Valve Seals
- 1993 EGR and Airpump intergrated question.
- OBD1 diagnostic tools sold at what stores?
- Need analysis of repair/sell/part-out situtaion
- can sloted rotors be turned?
- SLP PP with a SPEC Disk?
- Pushrods
- those resistors people are selling on ebay as performance chips
- What gears?
- Is Bryan awol?
- 17x9.5 ZR1 rims spacers? lowering springs?
- valve covers to fit 1.6 rr's?
- Do these calipers look right?
- 96 SS and gear question
- Pulling engine questions
- Engine running warmer after TB bypass??
- favorite suppliers?
- Why does my new clutch setup engage at top of pedal throw?
- motor quit no mil lamp?
- Best Frame-ties
- installed first mods today
- That Damned Slip-fit Primary!!
- Need M6 stuff part numbers..
- McCleod Clutch
- Rear Lug Bolts Loose???
- track times
- 4.10's installed yesterday!
- calling all STRANGE owners, how do i know what series carrier i got?
- HELP, Header question - steering linkages removal!
- Driving Me INSANE!!!
- Passenger side plug removal
- What do your bolton LT1s Trap???
- got a video of my car tell me how it sounds
- power locks
- possible short? check guages
- Borla XR-1 and LM Exhaust?????
- Firehawk and ws6
- LS1 top end vs. LT1
- weight deductions
- Has anyone ever seen a WS7
- fuel gage reads incorrectly
- anyone ever put a STOCK MUFFLER on a Heads/Cam/Longtube car? (video clip inside)
- shock
- Bosh 02's
- Hitting rev limiter with 2800 stall!!!
- Make my friends 30th aniversary beat me
- Engine Mechanical Specifications LT1
- Fastener Tightening Specifications 1997 LT1
- ? on removing Air pump
- What size valves can you safely fit in the stock LT1? Who makes them?
- Pinion Angle ?
- Too many problems
- Best fuel injector cleaner
- All down hill from 80K?
- G Force KDW Tires
- Where did you buy your hotcam kit????
- Detonation!
- why do the stock pistons have a nipple
- Fuel tank removal and Evap Emisions line Q
- Checkin transmission fluid
- The free mods you can do to your car yourself
- what hp should i be at?
- UPGRADE fuel injectors????
- !!!Please help me with this!!!
- EGR and AIR block off plates?
- 94 Firehawk exhaust/emissions questions
- Specs for LT1
- The dreaded "Service engine soon" light
- Lt-1 heads
- 94-95 headers on a 97???
- What is the cheapest adjustable fuel pressure regulator?
- TPS% runs smothly to 100%,then hits 4% w/last 5% throttle travel,/??????
- What size front rims??? What tire choice???
- LT1 Tech
- resetting the pcm
- Need PN External Clutch Slave cyl
- HELP! steering linkage hits headers after BMR k-member install!!!
- What would be easier, long tubes from the top or bottom?
- Coolant Loss, Possible Head Gasket Blown?
- Best Ignition Upgrade?
- changing plug wire your self...any instructions??
- TH350..Which Dealer makes the best tranny ??
- Transmissin I/D question...
- $600 from SLP
- Troubleshooting help needed.
- Squeeking noice from rear LCA's after Boxed BMR Install
- MAC headers
- Where does the pipe plugged passage in the intake lead to?
- Automatic Headlight sensor problem
- Suspenion Rebuild
- A.I.R. pump quick question
- Breaking in new engine
- Whats it gonna cost to have my wipers fixed?
- egr!
- header gasket question
- Nitrous + JE ultra-lites = BOOM?
- $250 to spend on heads for clean up/port is it worth my time
- bare header question!
- Can my mechanic do this?
- lost power to the fuel pump
- MAF problem
- pics of fogger setup?
- new seats?
- after warm up the engine sputters when i hit the gas??
- The new Vigilante 3200 is in!
- quick question about installing gauges(dash)
- stock hood vent...functional??
- cheapest header supplier
- Electrical Problems?
- Long Tubes with 1 inch drop will it work?
- 1.5 or 1.6 RR for my setup?
- How to bypass vats? (fuel pump)
- Where to get 9" for $1700-$1800
- lg motorsport cai
- Pinging - stumble on part acceleration and idle.
- What is the highest compression ratio you can go while still running on pump gas?
- New Muffler installed
- Possible screwup. I think. Info needed.
- dist. cap change please reply!!!
- Wheels...
- Condensation in valve cover cap?
- anybody with a Hooker Aerochamber sound clip---->
- AfterMkt Muffler: Do I want this?
- What happened to my t56?
- Intake Manifold ?
- Hot cam and spark plugs?
- Valve part numbers
- Alternatives to Jet Hot??
- Street Slicks
- Boxed VS Tubular
- lt1 rebuild
- transmission question
- big problem!!!!
- 2 ques. pulling the balancer and engine block drain plug.
- Heads off, T56 tranny, Hooker longtubes from the top, WONT GO IN!
- piston to valve clearance with LT-4 hot cam?
- Wiper motors are going?
- Converter
- Can you buy JUST a SPEC clutch disk???
- After running at SLP day yesterday I have decided that I need more than bolt-ons..
- Strange power steering leak
- Flowmaster catback exhaust 2.5"?or3"?
- 52mm Vs 58mm???
- Testing the market. What is this LT1 engine worth?
- NEW -- programming services for camaroz28.com users...
- Opti write up
- egr questions!!!!
- removing air pump , egr
- Fuel Systems
- M29 guys running 12 bolts?
- PCMforless yourself tuning problem
- Dumb Wheel Combo. Question!
- throttle body bypass
- new chrome wheel bent after only 1 day?
- 383 vs. 355 (need some info here)
- cold start internal motor noise help
- Opti and balancer install
- Gtech real simple question
- I need a part number for the PCM Temp. Sensor in the Water Pump...
- I need advise
- rear end is making a griding noise
- Why does my fog light fuse keep blowing?
- What do I need for posi?
- 93 z rpm jump untill warm ?
- 97 TA lowering spring q's
- Quick question about GM parts!
- 97 Transmitter Question
- Comp Cam 1.5 roller rocker arms?
- My SES light is GONE!!!
- overheating/SES
- Question about weird knock retard, exhaust leak???
- stock oil pan baffle
- Water pump change, how dangerous for the opti?
- For those of you upgrading your rear ends- Moser price quotes within
- Removing Stage 8 Bolts???
- brake ?
- Can you swap seat belt retractors?
- Axel Problems
- simple electrical ??...educate me
- When do you know its time for better injectors and a new throttle body?
- T-Tops leaking
- Hello, Bryan Herter
- gapping my plugs
- Can too much oil hurt an LT-1?
- Moroso CAI Guys
- Strong Driveshaft???
- Got True Duals done....Need host for vids..
- crunchy sound from tranny or motor or in between.
- 2-3 w.o.t. shift why wont it shift?
- Would This Work.
- are the 4 fuel rail bolts identical?
- SLP loudmouth
- crane 10308 springs seat pressure and supplied shims Q
- exhaust!!!!
- LT1 with open headers (racing)
- Plugs
- Ignition advance?
- A few quick seafoam questions
- SES light, blowing fuse
- Z28 Parts
- Going to buy Nitto DR for the rear, what should I run up front?
- Shift Plus
- Going to the Wreckers to pick up a few things. Anything else I should get?
- 94Z Not Running
- OBD I Laptop Cable
- Cat Warranty?
- Former 5.0 guy, gotta F body Now
- Longtube headers.
- The best bang for the buck for my 97 30th Anniversary totally stock!!!
- Rear main seal leak!
- cheapest place to get acdelco o2's
- Fuel Cell?
- something vibrating after new exuast
