- pn# for auto dipstick?
- Best Way to build up LT1 Heads
- porting help advice
- Head cam combo for 383 guys
- ANYONE W/edelbrock shorties In here ASAP please
- 305 vs. 306 race!
- Egr Hard?
- Will a CC305 pass emissions?
- car wont idle
- Tranny noise
- what is this hose??
- 93 T/A - Wont shift into 2nd gear under WOT, bangs rev limiter
- LT5 Swap
- Keep hotcam, or go for the 306?? (convince me)
- 15/8 to 13/4 header gain?
- Help...I'm new with valves and P&P....
- Could EGR cause this?
- what exactly is top end and bottom end power when talking about cams??
- Rear 02 sensors
- milling question
- Will a 5speed center console work in our cars
- 30th Anniversary Stripe Question
- Hooker Shorty Install / Gasket Problem
- Lloyd Elliot
- CSI WP for 97 z28 ????
- '95 differences: Calif vs. the rest?
- Change gasket?
- Just got Myself a Multimeter
- Need A Dyno Graph with the cc305 installed?
- Longtube Header Install
- Low RPM Stumble - Possible Fix?
- Part No. for black Lug Nut caps.
- Does this sound right?
- new member exaust questions. Please help!
- Magnaflow hi flow cat
- Disabled air/egr w/95 opti
- 10-bolt vs. 12-bolt
- Cheapest Hookers
- just run
- where to find???????
- T-56 guys please help
- Car up and died on me...
- What is the fastest cam swap time???
- dynomax cat back
- Highest compress ratio w/ 92 octane
- Thinking of doing a heads and cam setup.
- Do I need to get O-ring gasket from SLP?
- guys need quick help here please,xcelerator muffler?
- stock 10 bolt is it series 3?
- ProForm Roller Rockers?
- air pump???
- Good alternator or starters out there??
- 383 pre-built?........or build it myself?
- PCMforLess trouble again, file not found?
- Car won't start, need help diagnosing the problem.
- Engine Dies and Dealer can't find problem
- directions for ZEX install please!!!
- Flexplate Question
- Need some info
- I think my shocks are gone
- installing ASP Pulley
- Man Just Cut Cats Off Aawesome! Got Question
- What all factory cd players will work in a 93 firebird?
- installing LT1 from the top
- lt1 swap
- M6 Gear Ratios
- Gains from Longtubes on a stock motor
- cooling question
- MAF question
- MAF home-porting success rate
- Things to look out for
- A couples of weird sounds from down under
- What Could This Be ???
- Deleting of rear 02s hurt/help performance?
- Production Numbers and RPO Codes
- !egr and!air
- bosch platinum +4s and nitrous
- walbro pump/fuel pump return hose not on?
- TB bypass on a 97
- Anything To Be Gained By Putting 3" Catback On A Stock LT1?
- Cooling system OVERHAULED, still running hot
- I think my opticrap went bad again
- is my advance right??
- A4 kick down two gear on the freeway????
- GM 1.6 Roller Rockers?????????
- set off codes
- CMotorsports Spring Set Impressions
- are 2 12in long bullet mufflers enough for my true duals?? Or should i buy more??
- OVC Wires?
- Question?
- Hot Cam Question-read this!!
- 1996 ss question???
- Strange or Moser 12 bolts???
- what did you pay for your Hot Cam kit?
- bad battery?
- Shocks?
- Show me your clips (of exhaust sounds)
- Fan Switch ?'s...93 A4
- Hotcam or CC306? RWHP difference?
- heads/cam/headers project ?'s
- ANYone put a cutout ON the cat?
- File named .... z28exhaust.mpeg
- Quick CC305 question
- Test the PCV valve?
- Size Dimensions for LT1 Intake Manifold
- Differential question
- FINALLY got my 3.73's installed!!!!!
- header gasket
- LT1 Computer & Wiring quesiton
- how is this sound to you?
- 5 speed LT1 in '93????
- 6speed swap problems
- HELP! Car wont start after garaged for winter.
- Bad cold starts
- Will 26" ET Streets fit? Lowered
- new to me 93 z28
- Head flow numbers... Finally! (AFR's done by Race Prep)
- Combo Motorsports Package
- Suspension....
- Question on unplugging my MAF.........
- alarm/starter kill bypass
- What kind of rear wheel are we seeing in 383's?
- remove cat??
- MSD Plug Wires?
- Engine opinions needed!
- fuel pump?
- Aftrmarket Starter Install Question
- Scanmaster work on 1993 Z28s?
- How do I know if I have a chip?
- what king or gains with just 1.6 roller rockers
- nitrous with 11:1 compression?
- Convo pro questions???
- Looking for inline fp install page.
- Low RPM, High Load Stumble
- Need P/N for bulbs that light up knobs for temp.
- Does 10w-40 oil can damage my engine?
- Worn computer plugs....
- Do BMW 3 and 5 series wheels fit Fbodies???
- what year out of 93-97 has teh biggest cam
- Anyone know the diameter of a stock MAF from LT1 T/A??
- 93 LT1 and O2 simulator ??
- 0w-30 or ow-40
- Transmission problems...Advice???
- What cam will give the most power at low RPM's? (2000-3000) 93 Z A4
- Help, Heater core
- rough running engine and lost power.
- Oil Leak Fix
- Need peace of mind...
- Where is a good place to buy a fuel pump?
- Evaporator Core Leak
- Cost of coolant sensor???
- best place to buy 396 stroker kit?
- which mod next!!!!!
- PCV Hose
- LT-1 Swap into a 3rd Gen
- Oil pressure
- hesitation
- power numbers
- Spring & Rocker arm question?
- 52mm TB....Holley vs. BBK
- csi water pump wiring
- Damn cats!
- lt1 conversion need help please
- temp went into the RED ZONE!!!!
- Z28 1/4 Mile Time
- pass side FRONT turn signal
- SLP Shorties Question
- Anyone running the MSD Digital box?
- How loud are Borla XR-1's...?
- LT1 VIN question
- How do you launch w/your 6-speed on slicks?
- How far away from 11s?
- LT4 Valve Covers
- Key lock cylinder or ignition switch?
- converter lock up switch
- Changing Wires and Plugs
- Long Tubes with GMMG cats or none?
- need a pic of right side motor mount on car
- need help? confused!
- Where can I buy a scan diagnostic tool for my 93Z?
- Obd?
- LT1 "Cadillac" custom grind dyno results
- Popping Sound ???
- 94 z28 sputter or miss
- Help Please--Rough Idle!!
- O2's, Wires&looms, plugs
- oil leak but I have narrowed down the possibilities
- Valve Spring Question
- max lift with stock valvesprings?
- Can someone explain cam numbers to me?
- Paging Injuneer: Is the stock length drive shaft......
- 4.10 motive gears new for 140
- air fitting size
- Clutch problem-Car is stranded
- cc305 or similar in cold weather
- will you get a little black smoke with out cats ??
- Hooker LTs and borla.. Y pipe???
- ACDelco or NGK's / MSD, ACCEL or Taylor wires
- Need new axle shafts - can't find em...
- noticable difference after PCMFORLESS???
- One Last Time: What Things Are Needed For Heads/Cam Etc...Swap???
- Chassis lubrication
- rev limiter
- Oil leak from oil cooler
- part number for plug wire in summit, please suggest me a good one
- HELP!! LPE’s cold air induction Issues....
- chromoly rust?
- Any hints on re-installig the timing chain??
- Fuel Injectors
- recalibrate spedo?????
- Pinging.
- question about little hole on lifters??
- Intake Elbow
- random multi cylinder missfire? help
- OBDII Diagnostic Tester
- Pulley
- Which rear end assembly should I choose?
- Just finished cam install! XE 230/236
- "Pushing" the powerband down
- Good flow numbers?
- Engine knocks
- Any Aftermarket LT1 Intakes?
- XE grinds and the need for new lifters.
- Should be in the 12's, right??
- Help with Clutch/shifting problem!!!!
- any 1 know where u can get a warbird hood for kinda cheap? throttle bod ? also
- Will I pass emissions?
- i was readin from the rear wheel 383 page and have a ?
- firehawk emblems
- Retard timing related to gear possible?
- welding in SFC...remove interior?
- Exhuast Thought
- Mufflex y-pipe install...MAJOR RATTLE!
- T/A Adjustable Headrests....fix?
- where can i look for camaros w/o engine?
- How bad does 100% humidity effect performance.
- avg. MPG lost with !CAT
- what the heck??? someone go try this....
- need soundclips of your "gear whine"
- Best Sway bar for Moser 12 bolt?
- adjusting R series lifters
- Help Needed
- heater core
- after new opti install
- TH400 Crossmember?
- EGR Valve
- A4L60E aftermarket Stage 3+ Transmissions. 383 Stroked LT1
- Is it Worth it to Swap in A LS1 Gas Tank?
- How many miles do stock springs last?
- DAMN Timing Cover!!!!
