Exhaust System
Pages : 1 2 3 4 5 6 [7] 8
  1. OffRoad Pipe
  2. What headers/ exhaust combo 95 Pontiac Formula
  3. Comparison LT's with true duals versus x-pipe?
  4. Flowmaster
  5. Kooks headers
  6. Cat, Bullet Muffle, or Resonator
  7. Making an exhaust system
  8. 4 inch Mufflex vs uncapped results inside
  9. Sound clip, new motor
  10. headers for my rebuild
  11. GMMG vs true duals dumped
  12. muffler NOT centered??
  13. Pacesetter Uncoated question
  14. Stock Manifold Down Pipe (Y-pipe) Stud...
  15. Are stage 8 locking header bolts really worth it?
  16. Picture: Stock or Not?
  17. How long should headers smoke?
  18. True duals without ground clearence issues . . ?
  19. New Muffler Suggestions?
  20. New Pics Of The "New" Exhuast
  21. Header question
  22. Where can i pick up some longtubes?
  23. What else should I get?
  24. Video of True Duals - LTs ORH
  25. True dual x-pipes for 98-02
  26. True dual or cat back
  27. Calling all Headers
  28. True dual/Lt header/knock sensor questions
  29. TD vs. Cat back numbers.
  30. AHR LT's and magnaflow-pics!
  31. Looking for a good exhaust system and long tube headers..
  32. 383 stealth ram -4" single w/ Dynatech split flow
  33. Stock Exhaust Manifold Bolts
  34. I want to get a cutout
  35. Rounded Manifold Bolt...
  36. Why get mids?
  37. what type of catback help need opinoins
  38. Stock Exhaust Manifold Gaskets
  39. The Headers are in!!!
  40. Are true duals what I want to do? Either way, what to do for Headers/Exhaust.
  41. emissions legal header clarification
  42. What the hell is rasp?
  43. LT ground clearance..?
  44. emissions question
  45. difference between LT1 and LS1 loudmouth?
  46. shorty vs long tubes
  47. Wrapped PS LT's
  48. TSP Rumbler exhaust clip
  49. Exhaust clip.
  50. Deep exhaust
  51. headers and exhaust?
  52. Exhaust Pops
  53. pacesette long tubes and plug acces on LT1
  54. Need some ideas. Show me your single-outs.
  55. Stock Exhaust Diameter
  56. Installing headers and have a question.
  57. Header upgrade, Florida emission laws
  58. Gains From Changing Mid Tube To Long Tube?
  59. diffence between ls1/lt1 mangaflow
  60. Exhaust Leak Detection
  61. my new x-pipe duals setup!
  62. not happy with magnaflow
  63. 383 HSR with 4inch single--dynomax ultraflo round
  64. Questions About SLP Mids for a 97 LT1
  65. Exhaust cut out question
  66. what kind of switch can I use for qtp cutout?
  67. Will 94-95 Jet hot headers/Y pipe Fit 97?
  68. Mustang cat back
  69. cut out
  70. Converting dual cat to single cat setup...retaining OBDII???
  71. Stock exhaust manifold question.....
  72. help should I be scared
  73. Exhaust clip request
  74. longtubes and mini starter?
  75. Bassani exhaust
  76. LT install question
  77. Quick Question: 2 Cats or just one on my Z28?
  78. blew a plug on a header
  79. dual exhaust
  80. Long tubes and catalytic converters...Options???
  81. Anyone running 3" duals with chassis mount Trq Arm??
  82. magnaflow true duals?
  83. Exhaust, Cat, O2 sensor issues
  84. How to expand 3" exhaust pipe to create a slip fit joint
  85. debating an idea for my exhaust. opinions please.
  86. What size O2 plug to seal up headers
  87. cutout sound clip
  88. I searched the forums but im runnung outta time
  89. Stock 97 SS Exhaust?
  90. LT1 long tube install need some help
  91. Muffler vs No Muffler
  92. exaust leak
  93. o2 sensor help
  94. header question
  95. SLP Loudmouth?
  96. Do I really need coated headers?
  97. cutout feedback
  98. going true exhaust but need to know first
  99. Question about Jet hot spit fit tube.....
  100. Need O2 extenders which ones and where from..
  101. Lt header O2 question.
  102. not sure which catback
  103. ORY vs. H-pipe... i know i know
  104. exhaust leak from headers
  105. Aftermarket Y-pipe with LTs?
  106. Cut out and intermediate pipe install cost?
  107. Cutout under rear seat. Do I need to protect underside?
  108. New true dual SLP exhaust!
  109. hp in relation to pipe size
  110. Settle a bet...
  111. Where to get? Larger Tail Pipe
  112. Passenger side heatshield removal?
  113. My cutout experience
  114. Need help ASAP, header install tonight
  115. Dynomax bullet exhaust street legal??
  116. 1998-2002 CORSA Power-Pulse Exhaust With Pro-Series 3-1/2" Tips
  117. Removing my cats?
  118. Quick manifold question
  119. Fuel line and header touching
  120. Hooker or Pacesetter??
  121. best exhaust for 89 Iroc
  122. Hooker super comp
  123. Rear mounted Cutout is Great!
  124. Needed a better looking exhaust setup...
  125. Hooker cat back with no cats...
  126. pacesetter LTs NEWB questions?
  127. dynomax DUAL 2.25" exhaust??
  128. Header exhaust leak
  129. EGR valve
  130. Installing LTs soon. Need help
  131. flowmaster or manaflow
  132. Cat question
  133. Typical LT1 Slow down backfire...
  134. SLP loudmouths or duel chamber which one is better
  135. Need headers with less ground clearance?
  136. Muffler for turbo app
  137. Dynomax Super Turbo
  138. kooks headers and mufflex Y
  139. SLP loudmouth on stock LT1
  140. new cat-back. clamps or weld?
  141. LT Headers
  142. SES + Rattle coming from inside the Y-pipe
  143. What exactly is AIR?
  144. Duals decible question
  145. Ceramic True Duals
  146. Exhuast gasket hole shape.
  147. Stock exhaust system.
  148. Best sounding Exhaust for 3.4L?
  149. info on borla exhaust
  150. opening cut out during 1/4 mile run
  151. These Walker Cats : Why the $100 difference between the two??
  152. New Magnaflow!!
  153. A Couple tips and tricks for Pace Setter LT install
  154. exhaust options
  155. Looking for help with factory cats
  156. Need opinions on Cat.
  157. are headers difficult to install
  158. Catalytic converter buying question
  159. Center mount exhaust
  160. Header Collector Ring Question
  161. shorties to long tubes
  162. Avoid Flowmasters 17133 kit if your looking for a bolt on catback....
  163. Loctite bolts
  164. coated pacesetters
  165. best exhaust hanger for a dumped exhaust??
  166. About an Exhaust System?
  167. moroso spiralflow
  168. Sound clips of SLP Dual/Dual exhaust on a cammed car?
  169. Quad exhaust pic
  170. Ineresting V6 camaro exhaust question!
  171. Cats?
  172. Need to find short glasspack or resonator
  173. flowmasters?
  174. QTP or DMH Elec Cutout
  175. exhaust question?
  176. X-pipe vs Y-pipe
  177. slp resonator
  178. O2 Tuning Q.
  179. True Dual--Elec Cutout?
  180. Help wit true dual setup!
  181. General Question - why you would do this?
  182. GMMG catback
  183. alternative to slp LM
  184. are Shorty Headers worth the money
  185. Corvette Manifolds vs F-Body Manifolds
  186. Stock exhaust info
  187. Putting true duals over the axle on my 95, exhaust shop failed
  188. flowmaster 40s 40buks new
  189. Need header ideas please!
  190. Dynomouth vs. Magnamouth
  191. Magnaflow install
  192. dynomax bullet muffler construction???
  193. 4" mufflex with dual out spintech
  194. For those with Kooks...
  195. 3.8 V6 Exhaust Questions/Opinions
  196. gutted cat
  197. Pacesetter Lt w/ TSP Catted Y
  198. cost of complete exhaust setup installed
  199. ls1 headers fit on lt1?
  200. good sound and power gains
  201. Just finished my Header Install
  202. Which would be better
  203. Need help with o2 sensor
  204. Bolt ons?
  205. Transverse or universal muffler??
  206. Flowmaster guys
  207. LT header rubbing
  208. Legal Db level in NJ
  209. help! 01 catalytic converter
  210. as&m with BMR K-Member random tech y clearance
  211. Car failed emissions.
  212. Question About True Duals
  213. 00' T/A Headers
  214. 02 sensor extentions
  215. 01 LS1 cat removal..?
  216. electric exhaust cutouts?
  217. LT/LS exhaust ?
  218. 02 Sims help
  219. Strange idea.. anyone done this?
  220. Need quick advice on which cats to use.
  221. Building y-pipe for stock manifolds, quick question
  222. No cats, or new system?
  223. Simple Question For Pacesetter Long Tube Header Owners
  224. pacesetter install HELP!!!!
  225. shorties stock y pipe?
  226. LT1 True Duals Q's
  227. new muffler
  228. 95z exhaust manifold gaskets
  229. Wondering if theres a difference between these headers
  230. what are these extra fittings?
  231. Plugging LT headers for !AIR and !EGR
  232. Header Length Question
  233. Normal LT vs. Stepped LT, gain?
  234. flowtech
  235. Summit Universal X-Pipe Kits
  236. 02 sensors?
  237. exhaust clamps
  238. Catalytic converter
  239. Aftermarket Y-pipe
  240. tell me plz.
  241. Magnaflow cat-back
  242. Question about BBK shorty headers.
  243. exhaust tips
  244. 1997 z28 SS Cat Converter
  245. whats needed for pace setter install?
  246. Exhaust leak from dealership
  247. Looking to quiet my Straight pipes down.
  248. I have 50 Dollars...
  249. What are the cylinder shaped components on my exhaust?
  250. 1997 I pipe for 1994 car?
