Pages : 1 2 3 4 5 [6]
  1. Plastic retainer clips on the stock fuel lines
  2. impediance converters?
  3. throttle body plate
  4. Prob starting
  5. Stumble+Backfire under moderate to heavy load, please help
  6. Opti Problem
  7. Hard start at way lower elevation
  8. ? about stainless steel being a good conductor
  9. Ignition problem
  10. No start, new ignition parts
  11. Fuel pump bucket
  12. Need help whats this part???
  13. Starts and quits randomly.
  14. Urgent help needed with racetronix fuel pump install
  15. need help
  16. All-Ignition Dragonfire Distributor(Opti-Spark)
  17. what kind of fuel pressure regulator?
  18. Racetronix Fuel Pump issues
  19. Car died while driving
  20. Lost power
  21. Mass-Flo fuel injection
  22. Faulty fuel pressure regulator ????
  23. Fuel guage problem
  24. Key Won't Turn
  25. ignition problem... please help
  26. Injector Rebuilds
  27. Fuel line removal...
  28. LT1 vs. LS1 steel fuel lines
  29. in-line fuel booster ?
  30. AN fittings on fuel rails
  31. Autolite AR 135 Spark Plugs?
  32. Boost gauge wiring problems
  33. Delteq ignition system?
  34. Car won't start: BAD VATS/Passkey bypass -> Fuel System problem!!!!
  35. fuel injector question
  36. Opti disappointment
  37. Wich wire and plug gap for ltcc install
  38. GMS fuel pump
  39. new ignition lock cylinder
  40. Car hesitating, don't know why
  41. Car hesitating to start Sometimes
  42. Alternate place for electric fuel press. sending unit?
  43. Dash light problem
  44. Bad gasoline?
  45. 94z28 Fuel leaking out of vent valve from tank?
  46. air fuel ratio gauge?
  47. mefi3 or 4
  48. i need plz quick
  49. 1994 Z28 Runs and Quits Randomly
  50. fuel or ignition
  51. need helps guys
  52. fuel smell
  53. i need help plz
  54. LT1 Fuel Line Questions?
  55. gas tank removal
  56. Fuel cooling
  57. adjustable fuel pressure regulator
  58. opti vent lines
  59. idle
  60. LT1 fuel lines
  61. fuel pump
  62. where can I get these parts im missing? Walbro install
  63. TPI Plenum Box
  64. IAC Test
  65. Demon tuning problems, need some major help.
  66. HOw do i removing ignition cylinder from my 1978 camaro z28
  67. question about leaking injector or w.e it is??
  68. Fair price to replace fuel pump?
  69. Long term fuel trim question......
  70. Opti install help.
  71. Aftermarket starter left gap in flywheel housing
  72. Fuel Gauge errors, Hesitation/Surge/Stall..
  73. L76 swap into 97 SS.
  74. Spark plug help
  75. Ran out of gas, now slow cold start...??
  76. 383 LT1 with SC Injector ?
  77. 93 z28 fuel schrader valvle
  78. slow start, does not fire right off 3800 camaro
  79. Fuel Pressure Test ?'s
  80. Good place to buy a new GM fuel pump??
  81. Fuel pressure bleed down.
  82. what is the best stock replacement fuel pump?
  83. LT1 Losing power at high RPM
  84. 93 fuel pressure regulator location
  85. rapid fuel pressure drop
  86. Misfire + black spark plugs on one side
  87. making spark plug wires
  88. Lt1 Bogging/bucking at low rpm....running rich PLEASE HELP
  89. Need some help guys...car will NOT fire!
  90. Are these fuel pressure readings ok with my 383 ???
  91. Spark plug gap
  92. Fuel Pump 97Z28
  93. What Can Stock 95Z28 Fuel Pump Handle?
  94. Help Chose My Fuel Pump - 383 LE2
  95. Autometer Fuel Pressure Gauge Problems
  96. Injector #1 not firing at idle
  97. whats best opti?
  98. Is Aftermarket Fuel Pump Wiring Really Needed?
  99. Rusty Fuel tank
  100. Max Fuel Pressure From Stock Pump
  101. DELTEQ, how hard is it to build your own Opti Box?
  102. Car has no power
  103. Conventional Billet distributor install in LT1
  104. fuel pressurse help'''
  105. Anyone familiar with GM fuel pump modules? Venturi pump Q.
  106. 96Z Fuel Pressure Proble
  107. Unknown Problem with z28... Seems to be fuel or ignition. Any ideas?
  108. 32 lb
  109. I plan to install flow matched injectors rebuilt in Cumming GA.
  110. Ignition ?
  111. LS2 coil boot/terminal p/n number and crimping tool
  112. LS1 coils going bad?
  113. Fuel Pressure probs, won't start
  114. fuel pump needed
  115. Factory high timing tune?
  116. my gas needle is stuck on full
  117. tach install
  118. Just changed fuel pump and fuel gauge is now off.
  119. wires and plugs?
  120. Crank sensor prob plz help
  121. 95' Z28 Coil
  122. [parts wanted content deleted]
  123. headers installed and now motor won't start
  124. lt1 sheet metal intake
  125. New Member - Opti Rant
  126. Fuel Pump "Trap Door" Tips + Convertable
  127. need help with plug choice
  128. Couple Ques with Big Fuel system
  129. wiring impedance converters
  130. opti-spark internal parts
  131. no crank
  132. fuel system issue
  133. MSD ignition misfire on 94 LT1
  134. Fuel Pump Bucket - Use or no?
  135. Replace Pump and Filter, and/or Regulator?
  136. fuel pump check valve or fpr
  137. Is there a write up for changing out the fuel pump?
  138. Erratic Sparking
  139. dtc 41 no start
  140. HELP!! What would cause an injector to stick open??
  141. pressure build up in fuel tank
  142. Lucas injectors too short
  143. Replaced Opti,timing chain, plugs/wires, coil, icm. Car STILL stumbles on face
  144. Should I change my plugs and wires?
  145. fuel pressure quickly falls to zero
  146. Car running rough and shutting off
  147. Starting Issue / Voltage
  148. walbro fuel pump problem
  149. Rough Idle, Possible O2 sensors?
  150. So what are the limits of a 255 Racetronix w/Hot Wire Kit?
  151. Aeromotive 17102 Kit
  152. Misfire #2 coil pack plz help!
  153. Help, mass airflow sensor
  154. 64psi fuel pressure after dual pump install...do I need an adjustable regulator?
  155. Fuel line pinhole leak / Replacement
  156. bad misfire and back fire
  157. MSD 8226 differences
  158. injector orings
  159. corvette injectors in camaro motor
  160. Fuel pump relay?
  161. No Start FIXED!
  162. Ebay 10.2mm plug wires.
  163. That p1351 icm code help please
  164. Slight stumble off idle.
  165. Fuel Shut Off@ High RPM Until I Let Off Thtottle 95 Z28
  166. high idle
  167. Walbro or Racetronix?
  168. possible vac leak
  169. Finally Running Right...was the ICM :)
  170. just got done installing my dual intank fuel pumps!!
  171. Racetronix Part Confirmation?
  172. 1996 Lt1 Coil test?
  173. Need 60# Fuel Injectors
  174. No Fire, Need Quick Help
  175. confused to whats going on
  176. engine warm no start condition
  177. Small line hanging over my rear driver axle(fuel?)
  178. Msd wires
  179. Rough time starting and running poor.
  180. fuel problem
  181. Is there ANY WAY that this is possible?
  182. Anyone ever ran a Hollet Innilerator
  183. Ford injectors?
  184. Fuel Pump
  185. MSD ignition coil harness for LT1??
  186. LT1 Miss Fire
  187. Which Plug Wires Fit in "Stock" Location
  188. high idle please help
  189. Are plug wires supposed to look like this?
  190. 95 LT1 fuel pump electrical connector
  191. lowering of fuel pressure
  192. rained hard, killed my starter, now bogging down
  193. TPI Air Intake Hose
  194. Too big injectors?
  195. TRE pump in place of stock one
  196. No Fuel Pressure diagnostic help inside please.
  197. Those with SLP Shorties on LT1 + Stock Plug Wires..
  198. #7 and #8 cylinders running cold?
  199. Backfiring
  200. Injectors at 110 DC
  201. 95 z28 fire problem
  202. DELTEQ, Any updates?
  203. Engine backfires and does not want to start
  204. Fuel Cell
  205. best plug wires to withstand heat?
  206. Fuel pump or relay??
  207. Mallory 685 on 97 Z28, cant connect to coil
  208. 700+rwhp fuel system
  209. Pontiac Timing Issues
  210. evac line from tank to cannister?
  211. Need some help.....
  212. injectors
  213. Zero fuel pressure
  214. no spark need help! car wont start!
  215. routing spark plug wires
  216. taylor 8mm or 10.4mm plug wires?
  217. What is the cause of the this sparking? help
  218. Spark plugs
  219. Cleaning injectors
  220. wet optispark?
  221. help identifying injectors
  222. Fuel system upgrade needed.
  223. GM Fuel Pump Manufacturer?
  224. OBD1 to OBD2 coil
