- Mass Air Flow Sensor
- car starts then dies 1997 Z-28
- Will these Racetronix injectors fit LT1
- installing injectors
- Fuel line(s) help!
- What size injectors in my 96 Z28
- Noob injector install
- My Fuel Injector Research
- Any difference between ebay and racetronix 60 lb injectors?
- aftermarket ecm?
- MSD cap and rotor compatibility?
- how to check for bad fuel regulator?
- MSD Crank Trigger ?
- will a bosh 420L/ph support 750ish @rw FI
- stand alone fi systems
- can opti's be repaired after coolant spray?
- Mallory Dead again???
- ford racing Red Top Fuel injectors?
- need some suggestions on electrical stuff.
- need injector help
- fuel pressure is dropping at wot
- Do you really NEED the racetronix kit?
- Ignition switch ?
- FMS 36lb injectors
- Fuel calculation Questions
- Fuel Pump Replacement for 1997 Z28
- Injector question
- Accel?
- Gas smell...cannister or tank?
- Fuel Sending Unit Issue
- Is the fuel pressure check valve inside the pump, or part of the bucket?
- What Fuel Pump???
- Crane HI-6R box
- Make me a fuel system
- Checking coils
- LTCC wire harness.
- identify my injectors please
- no spark, please help me guess
- slight hesitation :(
- Weird Opti Question...
- Fuel injector Question
- LTCC setup
- 2nd fuel pump turn on
- loss of comunication with MSD 6AL hooked up
- Fuel pressure drops to 0 after primimg pump
- Need Fuel Pump
- My battery relocation wiring diagram, and pics
- fuel pump replacement
- Tach problems
- No start after 685 install
- **URGENT** Rear black plastic fuel line damaged...
- help!! opti gurus
- how do I remove the hard feedline from the fuel rail?
- how to test fuel injectors
- Fuel pressure goes to zero after 30 minutes
- found random idle miss and dying problem
- Control Module or Optispark?
- I'm stumped.... no fuel pressure.
- which plugs should i get??
- High HP Fuel Systems - Q&A (4th Gen)
- LS1 Ignition Diagram
- Oil on spark plugs?!?
- -6AN adapter to stock fuel lines
- Y or T fittings for Fuel Rail setup.
- Started a small fire replacing battery
- Is it ok for me to use NGK Platinum???
- Fuel pump bucket
- Which coil delco or aftermarket
- Where to get stainless tubing?
- MSD Digital E curve on BB Chevy. Cant get advance ??
- Mallory 685 problems again
- otvc wires
- GM programs rich, cars run lean.
- stock lt1 fuel pressure vac line on and off
- cutting access door method on a 96 vert.........??
- where do you put your inline fuel pump (please show pics)
- too much fuel pressure help!!
- return vapor lines(fuel)
- Intake Modifications for Fuel Rails
- Anyone use one of these fule pumps?
- cyberdyne fuel pressure gauge
- Spark Plug suggestion
- walboro fuel pump been sitting for 7 yrs
- help please
- fuel pressure of a lt1?
- no fule pueresser
- Oh Crap
- Aero A1000, Where are you guys mounting your pump/filters
- I think my aermotive afpr has gone bad...what are my options
- Need expert opinions on fuel line rerouting/hookup
- 67' electric fuel pump help
- 1LE Fuel Tank
- Fuel rail fittings......
- Running rich as heck
- melted fuel pump wiring...what to do? PICS
- Looking for install tips for 6AL
- how to install the tach on an lt1
- Engine cranks, but won't start...
- How much hp will Walbro sopport
- When Opti goes...will the motor turn over at all?
- trap door location with plastic fuel tank
- Anybody done SS fuel lines to replace plastic junk?
- Fresh Air Line for MSD Opti
- help me identify these injectors!!
- Fuel Sending Unit
- Any ill effect from running bigger injectors w/o retuning?
- no power to fuel pump, new fuse, new pump, new relay...now what?
- Huge electrical problem
- Changing Ignition Coil....Change Wire Also?
- Ignition Box Died...spark now blowing out...is there too "small" of a gap?
- walbro wiring help!
- Not Starting
- Fuel in tank for one year...any good?
- Anyone know if the MSD cap & rotor any good?
- fuel problems with walbro 255
- fuel pressure problems
- Car died on the highway!! Coil?
- ls1 98 fuel pessure regulator location?
- Benefits of Delteq on an LT1 vs. a new Opti - Gas Mileage???
- plugs removal
- time for a fuel cell??
- bad opti?
- Moroso 8.5 wires
- Plug wire resistance
- Delteq alternate mounting
- OTVC wires?
- MSD Coil
- Z28 runnin 2 rich$$$$$
- Ltcc & Maft +
- Opti Problem
- To all running MSD 6A or 6 AL
- LTCC and LS1 Style Plug Wires - Dumb Question
- bad opti?
- which injector?
- Super Stumped! Fuel Tank Dilemma
- LS1 in 96 camaro, how to use fuel lines and bypass return?
- 98 Racetronix Plug N Play Kit
- Mixing Race Gas?
- Already tuned, but want to install...
- fueling problem hard start ect
- Emission failed. Please help
- Whats the part# for 37lb Racetronix injectors?
- Do i have a bad fuel pump or what?
- accell INJECTORS
- Opti problem
- Need -8 or -10 Y fitting
- NEW MEMBER HELP! Injectors, Fuel pump ACCKK
- opti question
- help!! racetronix kit quit working!
- Fuel pump assembly ground wire melted
- Quick injector question
- Backfiring on decelleration
- Is This An Opti Problem??
- Firing order from the distributor cap
- speed demon (running rich)
- centerbolt wire looms
- Z-28 need key code
- New Injectors---questions need help/advice
- 42# injectors ok for na 383?
- What injectors and size to use
- who makes a good fuel pump
- starting problems.??
- Injectors size?
- corvette injectors
- fuel pump or FPR ?
- I need to change the ignition lock & key on the steering column
- Can a failing opti cause your Delteq not to work correctly in the upper rpms?
- hydro octane booster?
- Seafoaming the baby tomorrow..I'm stoked
- getting new injectors.
- Buying a F.A.S.T. 30-116010 kit...anything to look out for?
- Can you have good fuel pressure with a bad pump?
- I know nothing about injectors, sizes, etc. help me out here
- fuel pump-where to buy?
- O2's reading .004 while cruising. Bad?
- Running rough
- how many guys here running e85
- No Fuel Pressure
- Aviation Fuel?
- Fuel Problem
- fuel pump
- Ignition timing tables for a stock 96 ss (z28)
- fuel pump going bad..
- LT1 Fuel Pump Prime Connector...... where does it go? What does it go to?
- Cyliders not there on start up
- Different SVO injector colors
- Test Injector Getting Signal
- Boxes similar to the Mallory Hyfire 685 VI?
- How Do I Know If Icm Is Bad
- Mallory HyFi 685 buttons won't work
- Where/what adapter to make the new style ford injectors work in my car
- stock fuel pump replacement??
- LTCC Tach signal not activating Shift light or Window Switch
- best spark plug
- My Z28 is dead!!!
- dual fuel pump setup?
- injector sizes?
- Injector Brands
- Hot wire kits/ fuel pump controllers
- Testing Ignition system input
- custom fuel lines for single plane...sizes?
- #7 DEAD, need help
- NGK Spark Plug part#'s
- optisensor going?
- which external pump will work
- Anyone have pics of dual intank fuel pumps
- fuel pump pigtail
- Ignition Pigtail Wire Plug-ins
- alternator issues with wiring
- msd wires
- Fuel lines
- gas problem
- Fuel line rec. size
- Would this be a hazard?
- fuel pressure regulator and cold weather starts
- is a 95 f body a obd 1 or 2
- A1000 Pump & Filters
- Ignition amps?
- MSD DIS 4 with Delteq.. Wiring diagram
- Caspers Electronics V-Plus Fuel Pump Voltage Boosters
- Fuel Pump
- Megasquirt! Anyone use this fuel injection?
- 26.8lb injectors to 28.8lb ???
- Too big of an injector
- Walbro fuel pump problems
- My 95 F Bird Hard Start An Goes Dead Sum Tymes Smell Gas
- Need a fuel line part Number...
- Those with F1 and cubes...build me a fuel system
- stupid question about removing...
- Pistons 6 and 8 have spark but no fuel
- which fuel pump to get?? i get to dicide by tonight
- Megasquirt II
- Would a New Battery Help Performance?
- Has anyone tried the new Racetronix imperdance converter
- running really rich...one light from completly rich
- Overloads And Dies After Repair..... HELP
- Racetronix Fuel Pump:Necessary to Mod the Bucket
- Anyone have any trouble getting 83# and higher injectors to idle correctly
- Will 02 ls1 fuel pump work in 97 z/28?
- ICM's keep going out
- Anyone tried repairing their fuel sending unit?
- fuel PSI with SVO 30's?
- Loss of power.
- what fuel pump
- Another Loss of Power
- Where to find this?
- fuel pump change and best pump?
- stock injectors??
- Spark Plug Threads
