- FE4 Suspension
- Rear Caliper Shim, GM Part vs Custom?
- Lowering Kits, Suggestions
- Anyone with a MAC TORQUE arm, please look inside.
- relocation brackets in, now car feels more loose???
- Weird noise help
- brake problem
- IRS Conversion!
- BMR or PA racing Kmember
- Banjo Bolt size
- ABS Delete with pic
- Anyone convert to 98+/LS1 rear brakes?
- LCA's and relocation brackets
- ABS Delete - how to?
- Rubber brake line...rounded the bolt!!
- Ad for PA Racing K member. What's the real deal?
- Low traction light flashing, and ABS inop, ASR off stay on...
- I just finished installing springs/shocks...
- .....bad ride quality......and lowering springs
- Noise commin from rear of car
- Brake Pads ...What do you use?
- Sub-Frame Install Costs?
- Rear wheel hub questions/help
- factory installed brakes with 50,000 miles??
- C5 Vette calipers direct bolt on to an f-body?
- SLP strut tower brace doesn't fit?
- bmr lowering springs
- Brake pads? Which ones?
- NEW Forum - PLEASE READ THIS FIRST
- lowering springs
- Brake Rotors? which ones?
- Brake conversion question
- Sweaking upper A-Arm
- Torque Arm Mount????
- To get good handling after lowering the car.
- Need new pads and rotors, suggestions...
- brake parts ( Oreilly or Autozone )
- Help...what should I buy first?
- my suspension squeeks like crazy
- torque arm
- sub frames
- Looking for advice
- What The Hell Type of Springs Are These?
- Adj. panrohd bar
- SSBC front brake kit, bolt on 1st gen....
- Possibility of blockage in brake line???
- cant afford expensive brake pads or slotted rotors should i have mine cut
- Inexpensive shock/spring package
- LG motorsports sway bars
- Swaybars
- BMR U&L Control Arms
- anyone make adjustable coilovers for 02 SS maros?
- Best way to Bleed Brakes
- Competitiom Engineering Adjustable Drag shocks?
- PowerSlots may be warped?
- sportlines?
- Just got jamex springs whats next?
- BMR K-member With Pinto Rack & pinion
- Who makes lowering springs for LS1's?
- Question about Rear Coilovers...
- Broken Sphon TA (Pictures)
- curb HOpping?? steering arm bent?
- which is more effective?
- Alignment
- Large capacity reservoirs?
- best suspension mods
- how to raise the back end a bit ?
- How well can it handle
- suspension lube < required?
- Car is suddenly feeling very unstable
- B4TB: traction devices
- sperical rod end question
- Front suspension: Are my shock mounts hosed? Pics...
- Pro Kit & Rotor Install..........
- weird noise! when i turn ??
- sittin crooked
- Big Brakes
- Sportline + roadcourse
- Those with lca relocation brackets inside please!
- Spring Rates, Which is best for YOUR application?
- what do you think of the stance?
- Car leaning to right side.
- Stock LT1 K-member weighs 40 lbs. Pic inside.
- Rear Swaybar/Stabilizer Bar bushings, just replace with OEMs?
- I have a sound coming from I think the rear passenger side, loud bonking/pop sound
- panhard rod relocation kit....?
- adjustable rear sway bar
- ls1 rear brake conversion
- Need new shocks and springs
- SLP subframe question
- Strut tower bar
- Want to add susp. mods but dont know where to start?
- Can cross drilled rotors be resurfaced?
- axle housing bent.. wtf?
- abs/parking brake ?
- chambered shocks and release valves...
- Which coil springs to get? HELP
- need quick help (cars down)
- Good, low dust pads?
- do i need a vacume pump?
- Is a new K member worth it?
- Which is stiffer DMS or PRO-KIT?
- Rear pads and rotors: LT1
- abs snapon scanner
- Sub-Frame welding
- The RS is going in tomorrow...
- Sub frame connector dimensions...
- watt link rear suspension
- Pop sound coming from the rear! please help
- Need Suspension Alignment for New Shocks Only?
- Help my car is twisting
- If you have a cage, PLEASE read
- With C5s in front are ls1 rear brakes are really worth it?
- clicking noise even after new rotors nd brakes
- does anyone know the length of a 96 camaro rear?
- Front end torque specs
- Caliper Frame Bolts
- Rear End CLUNK.... Could it be LCA's ???
- Problems:Upper and Lower Control Arm
- 2'' intrax lowering springs
- Kenny Brown sfc's and LT headers?
- How do you reseal the lower control arm grease boots?
- MAC subframes for 4th gen?
- Anyone thats installed springs/shocks inside please
- Power Slot's Pro Stop ???
- 96 Front Brake Calipers......
- New Brake Pads.......
- what shocks to get?
- car has no brakes
- Suspension upgrades, et streets = slower ET and mph
- Vette Brake Upgarde
- Pulling the rear wheel back and forth causes a clunk..what is that??
- Everyone with BMR torque arm, inside please
- Using Pickle Fork on Ball Joints?
- Baer Sport Kit replacement rotors???
- What shocks will work with mac lowering springs
- lowering springs ???
- Anyone here have airbags on a lowered car???
- BMR raear LCAs and Panhard rod
- QA1 front shock/spring owners
- Z06 braking news!!
- Ground control and koni package?
- Cage?
- Where is the best place to get suspention techniques lowering springs??
- lt1 suspension same as ls1?
- Squeak in rear suspension.
- best sfc's
- Hawk Brake Pads
- popping sound
- Pro Kit vs. SLP's Eibach Springs
- Can I cut off my bmr vert subframe connectors without serious damage??
- Strut Tower Brace and Sub Frames??
- Question on brake rotors...do these look arrite?
- WHAT BUSHINGS DO i NEED TO REPLACE?
- Bumpstop removal?
- The results of this thread makes it suit this forum, please help!!!
- Brake Rotor Install
- Sway Bar/Lowering Problem.
- clunk from front when wheels turned...
- popping in steering?
- Anyone do Bob Bishop's C5 upgrade?Please come in.
- QA1 install pictures
- anyone one have any opinions on spohn?
- panhard rod
- Rear springs for drag racing?
- Do I need new Ball joints?
- Question about ball joints
- Egads! NOT another Drilled/Slotted Rotor Post, I PROMISE!!!
- The RAOD drives my car..... how do I stop that?
- WTF!? 105-65 ruined my brakes????
- Loud front brakes
- Suspension Build-up.......
- lowering and front end alignment ???
- Has anyone used the edelbrock performer ias in front?
- those who painted their calipers ... come on in .
- best way to lower car?
- A-arm Removal
- Suspension Upgrades
- Where to get front LCA bushing inner sleeves at? :(
- Rear control arm?
- Why are Baer GT brakes more expensive for LS1 than LT1 cars?
- Build up question
- No torque arm
- Do new stock rubber front LCA bushings come with inner sleeves?
- 32mm Front Swaybar
- Broken torque arm!?
- Lower ed, now need help w/ adj. PHR
- Linelock Install
- Hotchkis STB
- It sags.......
- Need help with suspension install
- LCA relocation brackets and 60' times
- Irotors and pads questions
- abs/asr delete and EBCM question...
- Noise from rear...
- Jacking sub frame connectors
- Where can I get Moog Parts?
- Need Help w\ popping noise
- **Spohn TQ & FLPS**
- need help w/ rear brake pads
- DIY Subframe Connectors
- Purpose of Adjustable LCA's....
- One Last Problem !!! I Was So Close !!!
- SLP or Pro Kit Eibachs...???
- Shocks or springs... whats a better gain?
- brake line flaring kits
- Irotors and pads questions...
- BMR Tubular K - How do I line up my A-Arms?
- Ceramic Brake Pads--- Want LOW DUST
- Rear end Alignment??
- BMR Tubular K - How to line up A-Arms in slots?
- strut mount
- Sprint springs and shocks.... good or bad?
- 10point roll cage install....anybody got pics of theirs or tips?
- anyone that has installed front struts GET in here NOW!!!!!!
- BAD brake sound...HELP
- Bad rotors in Austin here...
- brake question?
- Possible ABS brake problem?
- Brake upgrade, proportioning valve? 95 LT1
- What's involved in an LS1 brake upgrade?
- ThirdGen Sway Bar on LS1 Rear End ??????
- my brakes picked a fight with my welds
- Wheel hop
- Questions whether on which lowering kit and ADJ PH
- Which brake pads?
- lowering springs
- Need help with brakes
- Brake Problems......HELP
- Brake fluid
- ride too bouncey .. help me adjust my shocks
- Instructions On Changing Brake Pads.
- Rusted Top Shock Nut!!!!!!!
- Can someone help me with adjusting PINION angle???
- Quick chasis quesetion inside.....
- What will make the car launch harder other then shocks??
- subframes on a drop top
- one more guy with spring ??
- Trans Am guys with boxed SFCs, inside!
- Stock size end links???
- Upper Ball Joints???!
- Tie rod Boot
- Need New Brakes!
- shaving weight?
- Mac Torque Arm?
- firehawk springs
- Best place to buy Earl's SS brake lines?
- How hard is it to replace the TIE ROD ENDS????
- Lower Ball Joint??
- Problem with rear braking again.
