- LT4 Hotcam in 97 Vortec 350
- My 93 took a hit :-(
- What all can you determine option wise by the VIN?
- Looking to buy my first Camaro
- 96 opti issue
- Help...
- light problems
- Upgrade Speedometer
- pics of the 79z
- Bike Rack
- Low trac
- Z28 or not???
- Accy bracket Bolt Kit
- Ac
- So I locked my keys in my car
- T top latch
- still no cranking
- small block install
- knocking noise at highway speed
- ABS Hardline removal
- Boost gauge wiring problems
- b4c vs z28
- rattle under 2001 z28
- 94 Z28 Emissions
- how to get fuel filter off!?
- Factory stickers
- 86 Z, bogging.... what gives???
- Car won't start intermittently - What are the possible problems
- removed pass airbag, now car won't start?
- Skip Shift
- Lost RPO numbers
- Best source for side view mirror glass?
- Help me Un-bypass VATS (SECURITY light on, no fuel system function, on a bypass car)
- K & N Air Filter
- Car won't hold an idle could it be the battery?
- Cigarette lighter falls out!
- heater hoses
- Center console light type?
- will 94 z28 speed cluster work in 93 z28
- Trying to remove the A pillar trim...
- Testing EGR valve - Getting Smoke
- 1996 Body Control Module?
- 86 Z28 Wireing help
- 94 Camaro to 2002 Camaro Front end swap?
- 95 Camaro Z-28
- Wont star, The check engine does not blink
- No Crank - What have I done
- width of car question
- AC Compressor not turning on
- Aftermarket Guage Cluster?
- Major Fuel Problems (pump and gauge)
- X code question?
- Next step??
- '94 T56 Bobbing Like a Bobble Head
- How do i get to these damned vacume lines
- What color do you guys think this is????? PLEASE HELP
- Tow Hitch for Trailer on a Camaro?!
- 1985 TPI Iroc Z28 with 1989 L98 vette engine
- normal for lights to dim during wot?
- security light, need help!
- A/C throwing code 67, just reset or......?
- 1994 b4c camaro production number??
- Car starts every now and then
- Production number
- What could be the cause of a dead window motor?
- short throw shifter.. cheap
- Windshield wipers and indicators (4th gen)
- Odometer Problem
- Weight saving worth it???
- Whats it worth??
- Another starting issue thread...
- Just a couple quick ?'s
- what is this?
- breather question
- what's a fair price?
- Passenger side firewall grommet
- Priming the motor before firing...
- DTC Codes on a Switch?
- Vert Roof Fluid
- slippery steering wheel
- Small leak
- Gauges
- Cyberdyne Gauges ?
- Rear Lights inop on 87 IROC
- Z06 motor swap
- race car wiring
- 97 camaro guage lights not working
- radio problem
- Automatic trans shifts out of 1st gear when its 1st gear?
- Creaking noise and vibrating coming from the rear??
- ac/heater panel lights
- Anyone Else Give Up Changing Valve Springs With Heads In Car?
- Anyone ever have a oil pan rust out?
- rear window defroster problem
- How did my wheel studs shrink??
- So I just installed a strut tower brace...
- 02 Camaro Power Windows (both sides)
- Rock busted my AC condenser
- 1999 camaro parts
- window sticker
- firebird dash in a camaro?
- Replacing Check engine light 94 Z
- 1999 camaro ss
- Need Help!!! Lights won't come on.
- Looking for two nice Classics for Display
- Does a 96 lt1 trans am have a govener?
- Fog Lights
- after market guage help! 97 SS
- Are my local Chevy dealers lying??
- buy separate plug wires?
- Need info on sanding auto paint - prep
- Window Regulator & Motor Replacement Project
- 3800 & No burn out?? AHHHHHHH!!!
- 1987 Trans Am info???
- A/C Problems
- A/C hose cut in half
- I have no oil pressure!!!!
- 2000 camaro stalling and dieing
- I dunno what engine i have O_o
- 89 i-roc z
- Don't let the Camaro get voted out!
- No brake lights or hazards. Fuse is good
- How do I do this?
- high beams switch...99 camaro
- Replacing Oil Level Sensor
- Constant Voltage at PWR ACCY Fuse..
- Driver side window problem
- I'm replacing the opti, what else??
- A/C Troubleshooting Question
- time to pull the lt1 out
- ? on sitting rear wheels on front wheels during engine removal
- to all 4th gen lovers
- AC Repair
- '95 V6 3.4 5 Speed Clutch/Idle Problem
- Power Mirror
- Q on lumbar support
- Courtesy Key-Off Power
- 1995 Z28 easily passes CA smog with new cat.
- power mirror
- AIR check valve failure?
- Fuel Pressure Gauge Adapter?
- electrical problems
- I'm stumped-Is the motor gone??
- Which A/C seals let go?
- A/C compressor jump, installing freon
- heater hose assembly
- 1997 Z28 Radiator Hose
- Rubber Hood Stops
- Replacing a front oxygen sensor help
- Oil pressure gauge ?'s
- catilytic converter question
- automatic headlights module is ticking
- AC question
- Air Con Pump Noisy
- A word of warning about A/C compressors
- removing wiper arms.. on 99 camaro
- MAF Part #
- 1970 - thinking about buying
- 94 camaro z28 starter/ignition issue
- bypassing ingnitions switch and cylinder
- How do you remove the sunvisor mount from the sunvisor?
- Stock Hood Weight?
- Part # for odd ball part
- Pigtail in engine bay on DS
- Overheating?
- Heater / AC Control Vacuum Tank - what size vacuum hose?
- lt1 underdrive belt
- De-programming car for keyless entry
- 96 Roadmaster LT1 put in 95 Camaro
- Trunk rear speaker panel brackets
- Loose tilt wheel on 99 Camaro
- Was there ever a Gold Edition?
- Keyless Entry Q....
- Eibach Drag launch springs
- how to convert hardtop to t top
- window air leaks
- What is this button?
- Hood won't stay open
- Rear defroster
- Does Oil Lever Effect Oil Pressure (Assuming Oil Pickup Stays Submerged)
- Am I getting a good deal?
- ac evap sensor. where under the dash is it?
- What tool..
- New Camaro or upgrade current one?
- 12 fl oz. of miracle??? car seems to run better...any ideas?
- Do we have low pressure AC compressor cut off switch?
- Electrical problem
- Brought car our of storage after 4 years! What to check?
- Interior color
- A few quirks on my 98 Z28, any ideas??
- Vacuum Check Valve
- speedo issues....urghhh
- Headlight Upgrade
- Can a cat cause a stumble?
- Windshield Wipers
- RPM Gauge maxed out
- Help me locate the A/C Low Side (2000 LS1)....
- Is this a valuable car? What's it worth
- Odd lighting problem (signals and headlights)
- Help with Code 42
- Help ABS INOPT ASR OFF
- Part number for clutch/brake pedal clips?
- Turn signal stock broke off
- whats above the Panhard Bar
- Turn signal won't cancel, it's not the spring
- speedo past 150
- Testing the Speed Sensor
- AC clutch question
- driverside window problem
- totaled my camaro ss
- 97 Z28 Digital Odometer not Working
- LT-1 1LE A/C delete pulley
- check valve or leaky injector
- Alternator going bad?
- Pulling the harness, what do I need?
- Why does my oil change light keep coming on
- radiator's interchangeable?
- no low fuel light?
- Airbag light on after swap?
- How much $ for SLP takeoff SS wheels?
- should i pulley my firebird formula?
- Problem after battery relocation
- OK, I got 200 bucks left
- new(4th gen) camaro ss
- out of the usual problem
- oil leak from hell
- vibration with air
- Can you jack up the car with that plate that goes along the bottom of the motor?
- Fluid for 95Z Convertible Pump?
- Should I and how do I clean the MAF
- Air conditioner not turning on. Idea's?
- Aftermarket parts
- I think i might have a good deal
- AC compressor oil drain
- power(less) window motor fails half way up
- power window wiring
- 2002 Firebird, Headlights making loud grinding noises...
- I Need some help making a couple decisions..first post!
- Glowshift Gauges?
- Is It CA CARB Legal To Swap To LSx?
- Help! Ignition switch stuck on!! Car running.
- "Change Oil" light
- AC problems
- Airbag removal
- Port Under Throttle Body On Intake Mani?
- 2.73 to 3.23 in 98 A4 T/A
- MPG of a Lambo,power of a Geo
- Part Number for 2001 Shoulder Strap
- Wiper blade issue help!!!!!!
- What kind of performance should i expect?
