  1. Is my Tranny or Clutch going out?
  2. Solid pinion spacer Setup
  3. trans question?
  4. Body Sag
  5. clunk when stopping
  6. CLUTCH WRITE UP (Stock, SPEC, Centerforce)
  7. clutch problems
  8. valve body diagram???
  9. Speedo Gear, or Re-code??
  10. Weird tranny problem a4
  11. Torsen and Limited slip differentials
  12. Who has the best deal for a Pro 5.0 Shifter for a 95 T-56?
  13. Need some trans wiring help m6 to auto
  14. Tranny won't shift well.
  15. Am I stepping in baby food?
  16. TH350 Need help with some info, 95 LT1 ---Speedo & Flexplate & Transbrake
  17. What stall to get?
  18. Help on my clutch
  19. clutch pedal assembly removal
  20. 2.73 conversion needs new posi unit??
  21. Which gears work best behind a M6?
  22. Tranny burned up again, 8th time.
  23. What all is need for a A4 to M6 swap?
  24. strut cartridges
  25. Manually downshifting?
  26. driveline (possible T56) problems.....long
  27. 10 bolt
  28. Rear End Swap Question
  29. T56 Troubles.....
  30. Shifters, Hurst or Pro 5.0?
  31. bad viberation after replacing tranny mount!
  32. auto tranny and rear be able to hold almost 400 HP and TQ?
  33. LS1 Drivetrain Books
  34. transmission...what could it be?
  35. flexplate? 153 tooth external balance?
  36. Strengthening the 10-bolt: worth it or no?
  37. Tranny PWM sol question
  38. Flexplate question
  39. Clutch turbo transmissions
  40. manual for rebuilding a 1994 T-56 transmission
  41. 4l60e Trans 1,2, and 3,4, nothing
  42. Moser 12 Bolt - Gear Whine Normal???
  43. How to tell if clutch is aftermarket?
  44. T56 input shaft and pilot bearing cleance ?
  45. Rearend Noise
  46. Transmission Codes
  47. Simple Question......
  48. Cant get 3rd in correctly
  49. 10 bolt and 12 bolt
  50. pedal stuck to floor in three
  51. quality/stregnth of B&M torkmaster converters???
  52. 95 auto trans problem
  53. Strange Engineering trans yoke / stock driveshaft u joint ??
  54. Shaking?!?
  55. Lost all my tranny fluid, car wouldn't move, came home on a flatbed.. a few ?'s.
  56. grrrrrr 700r4 swap done, won't shift at WOT
  57. Opinions and Facts on Tranny's for a Swap
  58. T56 syncros
  59. torque arm bushing please help!!!!!!
  60. What u-joint do I need to mate my 1le DS to an 8.8 ford??
  61. What paint do you use on a rear?
  62. T-56 Problems?
  63. clutch question
  64. Anyone know the length of a stock Driveshaft?
  65. Clutch disc swap?
  66. Why doesn't motive engrave the backlash?
  67. prob with camaro? need help tonight plz
  68. tranny puzzle
  69. tranny help please
  70. Lot of questions about a Stall converter!
  71. Strange or Moser 12-Bolt
  72. Valeo? Please read RE: Clutches
  73. Not letting me shift into gear
  74. 4L60E trans problem!
  75. Problem w/ 2nd Gear (t-56)
  76. Which Clutch Do You Recommand?
  77. Synchro ?
  78. Time for a tranny rebuild
  79. 4l60e to TH350
  80. can i replace my 7.5 rear with 8.5?
  81. 4l60e to TH350
  82. Anchor Tranny mount
  83. How hard to remove rear end
  84. Which tranny fluid and how much?
  85. transmission tragedy update - A4 guys inside please!
  86. Stock rear-end?
  87. Clutch install re: disconnect master cyclinder?
  88. Which clutch?
  89. Slipping clutch? Vibration?
  90. Swaped tq converter, few q's
  91. 4l60e rebuild?
  92. t56 rebuild
  93. Changing from 2:73 to 3:42 or 73
  94. those with HOME MADE 8.8 rears in your lt1...
  95. could it be my tranny?
  96. Netgearhead Tranny's...What have you heard?
  97. Just ordered SPEC stage III and bullit steel flywheel
  98. McLeod street twin: counter-weight/balancing question
  99. 98 up Moser 12 Bolt in a 97
  100. Str????
  101. TC problems above 3000
  102. Rearend Swap
  103. Will TH350 bellhousing bolt work with a 4L60E?
  104. What Year/gen T56 Was The Strongest??
  105. McLeod Street Twin-plz help
  106. Billet Flywheel
  107. TC or Tranny Problem?????
  108. tranny help
  109. Pilot Bushing or Bearing?
  110. 96 z28 wont take second
  111. Problem with false knock due to shifting. Please help.
  112. Fluid Capacity?
  113. MEssed up
  114. Any one ever deal with Carolina Clutch and Performance??
  115. break in for a spec 4?
  116. URGENT: Adjusting TV cable... what button?
  117. transmission or clutch?
  118. Runnign 33 spline axles cut down to 30s in 12 bolt
  119. What size stall should I get?
  120. 10 Bolt 3.90?
  121. Rear end Posi failing, or is it just me?
  122. do manuals have cruise?
  123. Stock pinion angle needed
  124. Gearvendor question?
  125. Should I upgrade my hydraulics?
  126. What's wrong with my rear end??
  127. Rear end gears question
  128. Rear Axel Leak 2000 TA ? Pinion ?
  129. Very weird tarnny prob inside...
  130. Replace my 4l60e for 700r4?
  131. could changing a u joint the wrong way kill a 10 bolt?
  132. Moser 12 bolt - Pinion Seal/Bearing Replacement Question
  133. Some ???'s on Torque Converters
  134. Clutch Replacement
  135. Torque Arm Question
  136. URGENT--Will this fit my car?
  137. URGENT Will this fit my car?
  138. A4 mis-shift?
  139. do 3:73 give you better pull on higher speeds too?
  140. 2.73 to 3.73 swap
  141. all you A4 guys?!?!
  142. to my v8 boys ,hows your rear doing
  143. Moser 9" rear end and LPE driveshaft
  144. spool?
  145. how do I remove U-Joints?
  146. All short sticks the same??
  147. solid shifting
  148. 12 bolt axle length...
  149. trans prob fixed?
  150. Serious Problem!!
  151. Will a Vigilante from a 95' A4 fit my 00' LS1 A4 ?
  152. midwest 3400 stall
  153. What spline is in the fourth gen rearend??
  154. Is there a difference...
  155. broke the carrier bearing race in the 8.5" 10 bolt!!
  156. bolt in side of transmission
  157. Best brand of TC...
  158. Which SPEC clutch is better?
  159. noise from rear end or what?
  160. Snapped driveshaft in half!
  161. replacing axle studs on stock 10 bolt
  162. How to go about putting in a short stick shifter?
  163. Does a A4 Tranny from a LT1 bolt up to a LS1?
  164. clutch
  165. Torsen rear end help
  166. bolt in or weld in lca relocation brackets
  167. trany swap
  168. Part Number Please
  169. What size stall can I run on street tires with 3:23's?
  170. Which High Performance disc with stock pressure plate?
  171. Any truth to the statement that all Richmond's hum in 10 bolts?
  172. DTC 28 trany code
  173. 4L60E Garbage????
  174. Quick question on shift kit
  175. Where to buy Lou's Short Stick?
  176. U.S. gear any good???
  177. B&M Shift improver kit
  178. Nitto Drag Radials on a stock LS1 Z
  179. 28 spline moser axles
  180. Broke my converter or my tranny?
  181. tranny fluid
  182. Need to shorten driveshaft with a Moser 12 bolt?
  183. Is my new converter behaving normally?
  184. SPEC stage III clutch and Billet Flywheel came in!
  185. Gear lube question
  186. hard to shift
  187. 4L60e Trans
  188. now what 12 bolt is in
  189. tci vs. midwest (converters)
  190. cost question
  191. How my tranny fluid in torque converter??
  192. What is a torque converter?
  193. spider gears
  194. Midwest stall
  195. Clutch feels like a four letter word that starts with 's'
  196. 350 turbo transmission
  197. vibration on Decelleration!
  198. Vibration RPM on park or neutral A4
  199. Vigilante 3000 Stall
  200. noise from the new 12 bolt
  201. LS1 vs. LT1 spec disk
  202. Wich car had TH350 trannys?
  203. 4.10 LS1 vs 3.42 LT1 for off idle torque
  204. installing a Moser 12 bolt in a LS1?
  205. Which flexplate do I need?
  206. losing power with a 9 inch?
  207. what happens
  208. T56 Borg Warner Tranny rebuild
  209. Which convertor for a TPI?
  210. clucth problem
  211. Weird clutch
  212. Will an LT1 t56 bolt up to a LS1 block
  213. Noise from rearend after new wheels. ???
  214. What torque converter to get?
  215. Flexplate - 168 to 153 ?
  216. Code 72 trans output speed sensor
  217. my transmission's crazy....
  218. stock 10 bolt 7.5 or 7.625?
  219. Weir Hot Rod aftermarket T56 bellhousing
  220. Corvette flywheel in TA??
  221. Valve Body for automatic
  222. manual transmission vendors
  223. Rattling from transmisson?
  224. trans.
  225. Torque converter install
  226. torque converter..bad?
  227. Ford 9" rear end
  228. will this rear end work?
  229. Reprogramming for a 3500 stall TC?
  230. So I'm about to install a new clutch...
  231. Tranny seems a little sticky when under WOT
  232. 4L60E or TH400??
  233. Trans Cooler? Odering tom. please help
  234. Gear Question
  235. 4l60e-th400
  236. need torque specs??
  237. SLP converter ? HELP!
  238. question about mid-west!
  239. Little help on a T56 install
  240. bolting TH400 to ls1???
  241. LT1 clutch bleeding ...
  242. aod for 6speed
  243. What gains with the Lockup switch?
  244. All automatic guys !!!! A4 guys !!!
  245. Tranny mod
  246. tranny mount
  247. Keep the B&M or go with 5.0?
  248. Tranmission problems on Vette...my friends.
  249. B&M Supercooler Transmission cooler...
  250. Needing 4L60E rebuild for 11's, who to use??
