- TCI's 6 speed auto
- Whining while turning 180º
- Clutch pedal soft after long WOT runs
- Transmission Mount (t-56) bolt size?
- Help please
- old tranny fluid in cooler with new tranny
- Performabuilt - 4L60E level 2 TC issues?
- Constant clanking noise after U Joint change
- TCI 6x 4L80E into a 97 Z (4L60E swap)
- Need a part # for reverse lockout
- high performance parts
- LT T56 clutch fork
- clutch problem
- Trans Dip Stick
- U.S. Attorney vs. CPT
- Tech info for replacing my Input Sprag in a 700r4
- LT4 / LT 1 Throw-Out Bearing Question
- "Paddle Kit" for Torsen?
- Help with Servo cover, it won't move.
- ZO6 clutch???
- Poor downshifting under moderate-full acceleration?
- Is my high dollar trans toast??
- Seafoam Trans Tune?
- No engine braking in overdrive
- 4l65E fit in 96 camaro
- B&M Ripper Shifter Length vs. Lou's Short Stick
- Anyone using a 4.56 gear with M6 and Spray?
- moser 9inch lt1...seal question?
- 700R4 in a 95 Trans Am? need help.
- No second gear in 4l60e 1994 z28
- 4L60e Loose Solenoid Video. Could this be why I lost 2nd gear?
- transmission issues..please help
- Driveshaft safety loop + true duals
- gearing
- driveshaft not balanced?
- 93 a4 to m6 conversion (is it different than 94 and up)
- Transmission cooler placement?
- Car won't shift when started - Right after a Clutch Swap - Help?
- Transmission Rebuilder in Western Canada
- New clutch advice, please.
- Lockup or no lockup stall converter???
- ring gear bolts
- Slave cylinder problem PLEASE HELP
- Moser 9"
- what is going on with this 60e
- clutch problems
- 4l60e pressure problem
- stall?
- Trans issue
- U-Joint tool
- Tranny questions
- If you have a Ram Clutch - Come In Please
- Need help with axle issue!
- Stock Stall speed 4l60e?
- Atf for trans
- Trans not engaging at WOT (700R4)
- Will 95 LT1 bolt to my 5 speed
- Gears upgrade?
- Vibration thread
- manual trans options for 5.7 3rd gen
- transmission leak
- Paging Frank @ CPT !
- rearend swap
- what kind of connection is the ****er
- Performabuilt Transmissions
- what is the factory clutch on manual ls1 trannys good for?
- Ripping Center out of clutch disc
- 95 and 96 4L60E's
- recommended stall
- 6 speed lunges forward with clutch in!
- 4l60E tranny problem
- Questions about M6 shifting & linkage
- who builds the best T-56
- Knocking.
- I need a tranny. Are they year-specific?
- A4 slipping badly in 3rd/4th
- Cpt dissolved ????
- stall converter
- Beater car transmission question
- Sticking in 2nd!!!
- 4l60e wont downshift
- Easy to go back to standard gearing from 3.73?
- t56 rebuilds
- Dropping The Rear End
- unblocking "blocked" accumulators?
- 4L60 question please help!!!!!!
- 94 z28 4l60e
- tail shaft on upside down...help
- where to shift
- help with z pack install
- Suddenly no 1st or 4th gear..A solinoid??? where to get?
- Pilot bearing or bushing, is one better than the other?
- LT1 stall in 3rd gen, good idea?
- Transmission
- Having a problem with my 4L60E.
- PerformaBuilt Post Labor Day SALE starts now through Friday1
- done hours worth of searches but still have questions.
- installing gears: should it be hard to rotate?
- Anyone with expierence drill/tapping aluminum deep pan for temp sensor?
- reverse??
- t56 no neutral!?!? help
- Recommendation on clutch, prob going with spec 2+ unless convinced otherwise...
- 4th gear grinds
- 1997 camaro z 28
- Stall
- grinding gears
- No 4th after rebuild.. help please
- 4th Gen Trans
- Which rear end- s60, 9in, 12bolt?
- Clutch help please....
- Vibrating from the rear
- HELP! installed hd2 now trans not working
- ring gear
- Gonna replace pinion seal...what sealant on splines?
- Shifting Hard and Small Leak (auto)
- Keep 3.42 or go with 3.73?
- 1980 camaro rear end
- Confused - Transmission Codes
- Howling during decel
- First question on this site:
- would an LS6 clutch work in my car?
- Rossler trans 4L60E
- Flywheel Help!
- Best trans cooler
- calibration of speedo
- best 4l60e mount?
- Front Pinion Nut Size
- '87 lsd in '02 housing
- Turbo'd TH350 owners using Vigilante TC
- where can i get c-clip eliminators?
- what shifter
- shifting ?
- How many splines on a...
- vibration!!!
- Best clutch/flywheel set up
- TH400 swap
- Taking off metal plate on Prothane Mount?
- Do rebuilt transmissions have a "break-in" period?
- Transmission "kicking"
- T-56 Clunk
- Flywheel help!!!!
- Bouncing burnout!!
- Clutch feels spongy?
- Flywheel knocking cause pulled timing?
- Clutch disk installed wrong ?
- T-56 HARD to get in gear
- What aftermarket Automatic Tranny cooler did you go with?
- Rhino clutch system?
- TH350 in a Turbo'd LT1. What Fluid?
- putting lt1 4l60e onto 5.3?
- Pinion Angle
- 12 bolt gear install
- U-joint removal
- Cost to replace rear end and brake lines
- 3k Stall
- Pulled the motor and tranny today...
- 4L60E pump questions
- rear shot?
- th400 and my 95 speedometer working together?
- 4l60e overflow question.
- 1999 Z28 6 Speed aftermarket shifter
- whose got a tranny with frank?
- which master slave to go with (clutch)
- 3.42's ?
- Annoying Gear Shifter Problem
- Adjusting driveline angles. Fixing driveline vibrations. Best info I have seen.
- any one have a complaint about the long tru cool LPD
- driviing car shifted it hard 1-2, now problem
- Worth convertion automatic to m6 93 z28
- Freakin' WHAAAAAA!
- Slave cylinder pushrod bent.
- transmission swap question...
- 97 Z28 rear end swap?(stock)
- Poor rear end install possibly? Need advice
- V6 to 2nd gen 350 drivers engine mount...
- clutch disengage problems
- Wierd... Clutch fork hitting pressure plate with all the same parts?
- t56 tail shaft housing
- converting the 4l60e to th350 pattern
- Punisher Pro-Street torqe converter
- trans line leaking after wheel hop?????
- Whos used a non F-body rear
- What gears are the proper gears
- knock coming from clutch i think?
- 4L60E Transmission Rebuild Price
- P1860 Code
- T56 Transmission Troubles?
- 4L60E to T56 What's needed?
- Fluid level - 4L60E, Vigilante, Lokar
- Which tranny in 93 Z28?
- More shift kit questions to those who have them
- Clutch Recommendations
- 4l60e/700r4 stall
- How to use the 6l50 in a 74 camaro.
- how to replace shifter cable
- auto zone throw out bearing??
- Trans cooler lines
- T56 Noise - what is it?
- Flywheel
- Eaton
- Clutch fork
- So long 10-bolt!
- Transmission Mount keeps breaking..
- 4l60e pump
- 4l60e what is this?
- 4l60 question
- After Clutch Install Problems
- Transmission problem
- B&M Mega shifter in 95 Z
- Help With 2-3 shift issues...
- question on rear end length
- Bent axles/axle tubes??
- T56 synchros maybe going out ?
- 4L60E problems
- Having 6speed envy lol
- Clutch fork install
- Flexplate bent!!!
- anyone running th 350
- output shaft question
- transmission problem?
- Gear stuck after WOT
- Clutch Slave and Master
- 6 point clutch?
- Tranny mount ?
- vibration
- Skip shift ?
- trans mount
- Who has done damage with their STREET TWIN
- 4th Gear issue..Help please..daily driver
- RAM cluch recommendation? Which grade?
- Automatic transmission options for a 93
- 4l60e wont shift past 2nd on startup
- 4l60e shifting trouble
- Home made Adjustable Master Cyl.
- 95 v6 rearend swap t 99 z28 rear..
- My CPT 700R4 is down again.
