  1. P1870 and a loud thump!
  2. Removing the universal joint in a 1999 Z28
  3. Weak link in the 12 bolt.
  4. bellhousing bolt sizes
  5. Tranmission noise
  6. 4l60e removal 95z
  7. 4L60E whining tranny problem
  8. 4L60E wierd transmission problem please help
  9. twin disk guys
  10. Look what I got from Strange
  11. changing 2-4 servos
  12. Ring and Pinion Question
  13. Wiring harness question...???
  14. shifter install walkthrough?
  15. 3000 stall
  16. Driveshaft removal??
  17. 92 700r4 for 93 700r4
  18. Transmission Disengaging???
  19. Clutch pedal vibration
  20. 2 step w/ 4l60e?
  21. driveshaft u joint conversion
  22. LS1 Torsen question
  23. reusing a stall converter
  24. 700r4 TV detent cable install?
  25. clutch or throwout bearing?!
  26. LT1 Clutch Bleed Question
  27. LT1 flywheel balance problems
  28. Dana S60 Pinion Bolt
  29. New clutch...and flywheel?
  30. is this the right fill plug for my cars rear end?
  31. Reverse engages only with car off?
  32. T56 Removal Issues
  33. Install positive traction
  34. T5 transmission question
  35. gear shift
  36. converter question ?
  37. installing tranny cooler, top or bottom line?
  38. Car lunges while starting ??
  39. Cpt
  40. 1995 4L60E compatibility
  41. replacing shift solenoid
  42. VSS causing limited on 1st gear shift?
  43. LT1/LS1 Torque Converter?
  44. LT1 slave cylinder came apart
  45. What is everyone here paying for gear installs?
  46. 4l60 (not 4l60e) hard shifts
  47. Bellhousing hitting body of car? (removing lt1 t56)
  48. looking at a converter
  49. Clutch problem really need some help
  50. need help on a 4l60e
  51. adjusting a shifter cable
  52. 3.42 to 3.73 gear upgrade.
  53. How to tell, PWM from non PWM Peformabuilt 4L60E??
  54. reverse lock out
  55. Is my tranny going out?
  56. 4l60E build question
  57. Who is running a TH350?
  58. Having problem with clutch plz help...
  59. How do I make my transmission shift a different rpm
  60. Heat Sink Transmission Fluid Cooler
  61. McLeod SFI bellhousing in car install pics & advice...
  62. Slipping Street Twin - Glazed or worn?
  63. stock vs Ws6 sway bars...good upgrade?
  64. Weird noise when making a turn
  65. Clutch Peddle Position?
  66. T56 Pro 5.0 Shifter
  67. Shift Improvement Module
  68. Driveshaft
  69. 1-2 accumulator spring
  70. manual tranny fluid
  71. Drive shaft angle question
  72. PerformaBuilt New warranty polices and other stuff
  73. leak
  74. skip shift
  75. rear end query
  76. CPT Cahall Performance Transmissions
  77. C6 Wheels + Lowering = Bad Vibration?
  78. Clutch Recommendations
  79. Bolt Size - Torque Arm Mount
  80. Reluctor ring position(3ch abs) question
  81. What is causing my annoying vibration? and will a Denny's Driveshaft help?
  82. Removing posi unit
  83. 3-4 Clutch failure (only top three???)
  84. 2-3 shift
  85. 96 Z28 convertible tranny not down shifting
  86. Trans fluid shooting from trans dipstick
  87. 4L60E,4l65e,4l70e,TECH THREAD,CODES,DIAGRAMS,HOW TOOS ETC.
  88. Jerking popping getting slower... help me :(
  89. no reverse
  90. Bullet proof 10 bolt
  91. tired? early 1-2 shift
  92. The 9" Install
  93. What's wrong here? Bad Master Cylinder?
  94. Almost new tranny. What fluid?
  95. Performabuilt Transmissions
  96. 1995 A4 Tranny wont go into gear
  97. Does this sound like a clutch master/slave prob to you?
  98. High pitched whine! Help!!
  99. ?'s about 4l60e install
  100. driveshaft making noise
  101. CPT Pro Race 4L60E: 2 year check-in
  102. Deep transmission pan.
  103. Strange 12 bolt differences.
  104. 4l60e help
  105. Broke 4 differential cover bolts...help!
  106. 4.11's in an Auto!!!
  107. 12 bolt brake lines different that 10 bolt?
  108. Car driveable without retune after installing stall?
  109. repair master and slave?
  110. Do I have a 3 or 4 channel abs Rearend?
  111. Where did you buy your rear end, and what?
  112. I have some questions about my 4l60E..
  113. Had to leave the Z at the airport this morning :/ (tranny problem)
  114. How do I know what kind of flex plate to buy?
  115. TH400 for my LT1
  116. Clutch fork or throwout problem?? (95 T56)
  117. Torque Converter
  118. 4l60e Install help...
  119. t56 transmission in 2 gen camaro
  120. Ram power grip install
  121. anybody run 3.90s in an M6 car with 10 bolt??
  122. Ratcheting noise in reverse.
  123. Power lock vs Tru track in s60?
  124. diff growling after gears
  125. Lost 3-4 at the track,now there back but slipping?
  126. shift points help
  127. possible 4L60E swap
  128. Topping off transmission fluid
  129. Where to get T-56 built?
  130. Torque converter destroyed
  131. A4 crossmember for T56?
  132. Suggestions on road racing clutch disc
  133. How tight should a pilot bushing be around the end of the input shaft?
  134. High bite
  135. Clutch Pedal stays on the floor
  136. Vibration-What drive shafts fit 95 m6?
  137. Tranny Cooler
  138. A4 only works when shifted manually
  139. Problems with my clutch!
  140. Will a 6L80E fit in a 4th gen?
  141. Transmission problem
  142. changing rear end fluid.
  143. Resurface flywheel?
  144. Vibration around center console?
  145. 4l60e issues! fired?
  146. "Moaning" noise from rear end while turning sharply
  147. th400 convertor help!
  148. Th400 vss?
  149. Will Oil On Clutch Place Ruin It Or Will It Burn Off?
  150. New clutch installed... problem with pedal stiffness
  151. Removing Pilot bushing?
  152. This is what your slave cylinder and clutch fork shouldn't look like...
  153. Low oil pressure after oil change
  154. Need help identifying 4l60e Convertor
  155. New clutch isn't the same
  156. Would You Use This Clutch (PICTURE)
  157. Wont go in gear...
  158. wiring night mare
  159. bellhousing slave cylinder stud size?
  160. Moser 9inch...stock ford 9inch center?
  161. Cleaning 4L60E coolant line question
  162. need a little help
  163. Poping in rear end?
  164. th400 swap issues (flexplate)
  165. If I use pusher fans how do I cool trans?
  166. got another tranny question
  167. Extreme vibration and "clunking"
  168. Who has an LT1 car with a 9-inch and WORKING 4-channel ABS ???
  169. A4 and M6 pedal assembly ?
  170. Need to know requirements to intall a 4L60E in a car equipped with a 4L60.
  171. 93 auto trans (4L60) in a 94 (4L60E)
  172. Need help-- burnt trans hose
  173. Tranny dripping a little out of the torque converter hole?
  174. Help now!! Torque arm
  175. slave hardware needed!
  176. Torque Converter
  177. clutch fork
  178. Pinion Bearing gone??
  179. New rear end parts questions
  180. Fluid coming out of vent at high speeds.
  181. T56 Rebuild Writeup.....
  182. 10 Bolt Advice Needed
  183. Grinding sound in my T56. Need suggestions.
  184. Rear axle/differential question
  185. What makes a tranny shift hard?
  186. Vibration Problems....HELP!!!
  187. Vibration above 3000 rpm.
  188. Is a Poly transmission mount necessary?
  189. Feels like taking off in 3rd
  190. And I say goodbye to you, Mr. 4L60E
  191. changing U-joint / yoke bearings on a 94'Camaro drive shaft
  192. delayed 2-3 shift..how to fix?
  193. trouble getting t56 lined up...
  194. under torqued' flywheel; by 9 lbs...
  195. Help!! tranny rebuild?/ blown head gaskets?
  196. Trans Swap
  197. t56 question
  198. auto to manual trans conversion
  199. trans rebuild needed ?
  200. could this be anything besides a tranny?
  201. Cluch for SC camaro
  202. Clutch change and no pedal pressure
  203. 4L60e Rebuild - How Many Quarts?
  204. 5.7 tpi auto to manual
  205. Grinding gears above 3,500 RPM shifts (manual tranny)
  206. GU5 replacment parts
  207. simple questions
  208. Is this clutch shot?
  209. clutch chatter question
  210. 3.73 gears?!?
  211. Grinding with full pedal movement (t56)
  212. Finding bearings for KTRE rear end???
  213. 94 z28 kickdown cable??
  214. Gears in rear end
  215. 4l60e problem
  216. bolts for vigilante converter
  217. PerformaBuilt July sales event 5-6 th
  218. TB/kickdown cable situation
  219. 4l60e issues - need help
  220. Good built 4l60e?
  221. strong vibration at 50 and above need help?
  222. 2004 silverado
  223. 97 firebird 3.8 trans question
  224. B-body 4L60E swap problem
  225. a transmission headache
  226. strange knock on slight accel or decel
  227. ls1 4l6e swap into a 94 lt1?
  228. clutch problems
  229. Slave cylinder rod bent?
  230. clutch disengagement problems
  231. 9 bolt rearend 3 series
  232. please help no 1 gear.
  233. 4l60e trouble
  234. Transmission Swap
  235. no shift at wot
  236. Possible to install reverse blocker backwards?
  237. 700R4 downshift Issue
  238. 4th gear downshift problem
  239. Clicking noise from slave cylinder (T56)
  240. Slave cylinder rebuildable?
  241. Clicking noise coming from clutch on release.
  242. PerformaBuilt LEVEL 3 weekly SPECIAL
  243. Poly Trans mount on M6
  244. 1995 B4C Differential - Different than other Z-28's?
  245. What Gears Does My 95Z have Now?.. Upgrade options?
  246. Aluminum Driveshaft?!?
  247. TCC lockup problem
  248. Swapping 12bolt fluid from dino to Redline Heavy Shockproof???
  249. lost 3rd gear
  250. Weird Clutch Failure
