- overtorqued pressure plate
- Has Fuddle Racing cleaned up it's act?
- tranny swappppppp
- how long will this tranny last???
- speedometer. help!
- 98 z28 6 speed tranny grind/rattle when in gear
- Trans Swap
- short shift
- t-56 part...
- Any diffrence between these 2 rear ends?
- Pressure Plate struggle
- Oil on my clutch... is it toast?
- Auburn diff in a 1994?
- White X on flywheel and yellow dot on pressure plate....
- Trouble with Reverse
- Reviews of the eBay Clutch?
- rebuild my m6 or buy one?
- driveshaft??
- Ever see a Throw Out bearing do this?
- Will a Nova big 10 rearend bolt up to a 68 Camaro?
- 3.73 motive install for first timer
- Stock Ls1 Clutch
- Clunking noise
- Transmission Blown??!!
- Trans cooler
- Do I still need additive with synthetic
- WHOOOO Gears
- Need used LT1 throw out bearing for project
- Removing clutch fork while tranny is still in?
- can't get my tranny out!
- Adapting M12 to my Camaro
- rear differential question
- 95 Z28 Trans Question?
- 91 4L80 tranny and 5.3L motor from a 2000 truck
- Currently driving a 3 speed :(
- M6 rebuild. What parts do I need?
- 2003 U-Joint Yoke Removal
- tranny jumping around...
- my rebuild 4l60e What Happened ?
- GM syncromesh in M6??
- Transmission stuck in third. Need fixed for work
- Never rebuilt 4l60e with 167k on it feels really sloppy...
- How is Centerforce Dual friction on LT1
- wot stick
- Rebuilding my T56.
- what else to do?
- ls1 throw out bearing question
- 10 bolt pinion seal question
- HELP! what gear do I have!?
- OK Guys......
- Could it be the pilot bearing?
- A4 shifting way too early
- Easiest way to fix speedo
- torque converter not locking
- Difference in the 1994 and 1995 tranny?
- After Market Shifter
- too much ls additive in rear?
- 700R4 Governor Calibration
- Simple question....
- torque of dif. cover bolts
- hitting rev limiter in 2-3rd with stall no tune yet
- New problem with stock 4L60E when stopping
- What would cause 4th gear (OD) to not engage ?
- 1995 Z28 sluggish, starts out 2nd gear (auto)
- i bought my fist camaro but......
- How much bottles of rearend fluid needed?
- For those of you going with a CPT Trans look inside !
- why the ..... did i one leg??
- SPEC Stage 3 throwout bearing...
- Rolling Stop 4l60e Slip
- How Does Lower Gears Affect Dyno Charts
- 4l60e to t-56 tranny swap?
- Flywheel resurfacing
- M6 clutches a crap shoot??
- Looking for someone running a 3800+ stall converter.
- 323 in a 94 v6!?!Will it help??
- vig/performabuilt converter
- '99 Camaro SS 4L60E shifting problem?
- 1994 Camaro 4L60E Downshift Problems
- How to get to bolt question.
- Clutch question?
- fly wheel resurface
- is it this disc???
- How to determin what gears/carrier i have
- What would it take to make ABS work on a 3 Channel 9 Inch?
- 700r4 trans brake
- help, need ideas for next trans in 67
- need help pls
- Official Autozone/Advance/Murray Flywheel Thread
- got the old clutch pessure plate and flywheel out
- Any word on CPT Transmission shipments?
- LS6 clutch kit?
- 4L60E or 700r4?!?!
- help clutch issue?
- how much ET gain from 3.42's to 4.10's?
- How much slip should a SS4000 have?
- Spec Stg 2 or 2+
- Quick T-56 Question
- Sound like the clutch or something more serious?
- 700r4-transbrake
- need help deciding on trans.
- SS SLP Zexel compaired to Z28 Zexel?
- T56 output seal: Is the Timkin one right?
- Which tranny should I got with
- M6 would barely shift into 1st or 2nd; found out why
- truetrac differential knocks when engaged
- New on here.Just bought a 98 z28. 2nd gear broke need help!
- t56 troubles
- torque converter
- Need a clutch?
- lt4 - 2800 stall
- 4000 stall too much?
- converter for cc306
- T56 Clutch help
- 4L60E trouble shifting to 2nd
- Anyone who's built a T56, look inside
- What diameter driveshaft
- Try a figure this out!
- what kind of fluid are you using in your M6?
- lt1 T56 in an ls1
- Problem with rear end
- URGENT! Need phone help about setting depth/backlast
- vibration
- Obd1 dtc 81
- 92 camaro rs rear end
- New 3000 rpm stall. Now car feels like a Dog!!
- RAM Powergrip HD LT1. Anyone use it?
- Important anouncement from PerformaBuilt
- stock gears
- 98 Clutch Question
- T56 Question
- stall
- 94 z28 gear ratio?
- Gear selector shaft seal
- What clutch for DD with not so much power
- tranny problems
- Whats a 4l60e worth these days?
- Frank @ CPT where is my trans?
- non lock up converter
- Loud Tail Shaft Noise after new susp.
- Auto to six speed How hard is it?
- Stall convertor ques?
- Rear Axle Moving!
- quick LT1 trans question
- Gm 12 bolt
- Bars in rearend don't know what they are.
- zoom clutch?
- Transmission difficulties!?!?
- Lots of trans problems need help asap!
- Is aftermarket really better?
- picking gears for my 81 z28
- A4 to M6 Swap clutch switch
- LT1:auto to manual tranny=> Chip programming
- rear end
- Has anyone swapped a 98-02 4 channel rear end into a 93-97 4 channel car successfully
- what transmission mount?
- Stall question.
- Stock 4L60E durability?
- lower gears??
- Torque Converter
- Bought used T56 questions concerns inside w/pics and video
- Clutch Won't Disengage, HELP
- Tips on removing plastic clip to be able to lock down shifter into 1st
- Deceleration Coast vibration
- M6 to TH400 Swap
- Converter Lock ?'s
- ticking noise
- i need help with gears
- Does the Street Twin require a special throwout bearing?
- Gear Ratio
- ls1 brakes on lt1 moser
- lock up issue?
- Will it hold?
- Looking to get Transgo HD2
- Servos for 4l60(700r4)
- Transmission LT1 , LS1
- 273 to 323 gears
- Rear Swap
- Rear Swap Question
- c-clip elimators
- Stock Output shaft on M6- how quick are people going?
- question
- converter question with head and cam swap
- Converter for a blown application.
- 1 Tire fire when turning right...
- Throwout bearing?
- Why would a stall TICK?
- Differences in a 1995 4L60e and a 1997 4L60e?
- Clutch reccomendation....
- new clutch no work
- Torque Arm Mount
- transmission
- Need help with clutch
- t56 to 4l60 swap
- Spec 4 cluch disk?
- 4l60e not engaging in gears
- 2.73 to 3.42'
- New Clutch Question??
- Broken rearend
- blowproof bellhousing for T-56
- 3.42 rear end posi?
- P1870 code
- 4 channel axel in a 3 channel car...
- Is it possible to rebuild the Posi-unit on a stock 10-bolt 3.23?
- pinion angle adjustment with BMR crossmount
- Gear rattle or imput shaft bearing
- Hitting rev limiter after tune (stalled auto)
- 4l60 swap wiring?
- wich drive shaft for drag racing tomorrow need help ASAP!!!!
- Please Answer!!!!
- Spohn torque arm set-up
- Car wouldnt go in gear!!
- Vigilante converter
- popping noise?
- Rear Torque Arm Mounting Bolts
- Do lightweight or aluminum rear ends exist?
- Trans crossmember necessary???
- 3.73 gears
- Street Twin Install Problems
- 4L60E.....help!!
- Need new axles - where to get?
- "shimmy" in the shifter when clutch is engaged and disengaged. . . . .
- Which clutch kit & flywheel setup is best?
- 2.73 to 3.42
- 94 4L60E in a 96
- Aftermarket Shifters
- Ring And Pinions ?'s
- t56 problems
- Car Wont Go Into Gear
- Downshifting
- Transmission Issues
- shifting issue
- Weird Observation
- trans removal
- 97 4l60e woes....
- 4l65 converter to lt1 4l60e?
- 4L60 in 94' Z28.
- Transmission front pump???
- Anyone interested in a TH350/TH400 vs 4L80e test?
- rebuild question..
- Starting my clutch install/replacement... **pics**
- trans issues(auto swap)
- A4 shift indicator
- Is there is big difference from 3:73 to 4:10 gears??
- Questions on rear end swap
- Slave Cylinder Broke??/
- Are these the correct bolts?
- Flexplate options.
- gears???
