- anyone know a formula for rearend gears
- ABS ring....
- Where to get a re-man flywheel
- adjusting stops on the Pro 5.0 shifter
- finishing rear....
- Price on 5th gear & syncro
- Recommend a Clutch
- tranny need help!!!
- Clutch Issues .....
- tci or midwest?
- A4 shifts EXTREMELY hard
- My transmission went out for the 5th time today.
- How to fix a squeaky clutch
- Trans. and Diff. fluid recommendations....
- Torqing Pinion Nut
- 4L60e + 450hp... ?
- Can I change my 1st gear ratio in my 700r4?
- Missing gear teeth driveablity question
- how tight?
- mcleod vs slp clutch question
- MALF 83: TCC Control Feedback Fault
- Kicking out of gear at stops?
- Shift Kit
- reliable clutch for higer HP ls1
- reassembling 12 bolt - silicone or not?
- Finishing clutch install, a few questions ASAP!
- 700r4 conversion q's
- Mushy Clutch Pedal
- Clutch Pedal woes...
- 12 bolt question
- Problems With Cluth/tranny Help!
- 12 Bolt vs 9 inch?
- Will this clutch hold my stroker
- truck nine inch rear end into 95 fbody... what do i need?
- Tranny Swapping
- Swapping from 3.23's to 4.10's. 6 speed
- 6 spd or auto?
- 9" Direct Bolt in
- Clutches?
- need help with torque converters
- Took cap off clutch fluid resivor. Do i need to bleed it?
- clutch chatter/shuddering HARMFUL?
- 8.5" in B-Bodys
- Two or three series question... (A4)
- 4l60E help
- How much does a 4L60E w/TQ cnvtr weigh Vs a T56 with Clutch&flywheel?
- Symptoms of Trans going out
- M6 hard to get into 1st sometimes, Normal??
- 4L60(700r4) to T56 Conversion Help
- 3.23 to 3.73 swap on an A4
- Anyone heard of this...
- Bolt in 9" or 12 bolts deal?
- Installing U-joints
- Please describe Clutch T-Stud
- 4l60e rebuild
- 11 sec. cars what clutch are you using?
- no 3rd or 4th, and it slips in 1st and 2nd?
- what are the differences between the 94 and 95-97 4l60e?
- 4L60E 2nd gear start
- Should I rebuild?
- tranny mount?
- weird prob w/ brakes/steering...please help!!!!!
- Tranny won't Kickdown
- can a tranny be running too cold?
- Lock-up speed?
- How to properly measure driveshaft length?
- Combination Motorsports Trannys??Good or Not good?
- Torque Converter install How hard??
- Clutch not fully disengaging after install.
- what parts to use in rebuild
- Axle Splines
- Thanks!
- turbo 400
- Tranny slipping or PCM tuning?
- Tranny gear "Multiplier" = Auto 8 Speed?
- Where to buy an A4 that will hold 400 rwhp?
- manually locking the converter in 3rd
- Need help FAST!
- Broken pinion gear, couple questions.....
- Grrr Dumb 'Ol Pinion gears! Help plz.
- What are the advantages to the Moser 9-inch versus the 12-bolt design?
- Tranny options for a 820ish rwhp car.
- Vibes up by the footwell....
- Hurst shifter won't fit
- Little Palstic Cup on Slave Cylinder?
- Perfection Hytest Clutch?
- perfection hytest clutch
- Best Replacement C-Clip Axles
- what is the best way to shift? I am new to this
- Best Bang For The Buck Conveter?
- Turbo 400 GUYS: temp sensor location?
- Dope Tranny Cooler Install
- Symptoms of broken clutch spring please?
- Clutch Chatter?
- who's runin the mcleod single disk and lt4 pp?
- AutoZone, O'reily's, Adavanced Auto
- Blew up my 4L60E
- Tranny Problems
- Clutch Slippage
- Speedo Calibration. How to do it on a 93??
- Picking out the right 9 inch
- Shimming the flywheel.
- Need a clutch
- 2600-2800 stall not enough?
- 4L60E (no action in reverse)
- Do I have a disaster on my hands?
- Another SPEC grenades, need opinions
- Post about clutches
- Driveshaft help
- Hurt T56 3-4 slider assmbly? racing 2 03 Cobras. Cheapest T56 Vendor?
- Will a PY3400 eat up a stock tranny?
- T56 inout shaft sizes
- Still vibrating
- tire wear
- Tranny problem
- What is a "lockup" torque cinverter?
- What other cars is the short 700r4 in?
- speedo problems
- Will my stock shifter work on a TH350?
- Non-Posi to POSI
- 4l60E reliability?????
- Weird noise from right rear?
- T56 rebuild?
- "Solid" pinion shim for 7.5"?
- Transmission Rebuilds- Who Does Good Work?
- how to make a 700R4 converter not lockup??
- torque arm bar removal, help please!
- 4L60 shifting problems
- Noise from rear of car when going over bumps or dips ?
- Stock cooler enough for TH350?
- spohn torque arm which to get
- What Tranny Do I Have?
- need A4 help
- Any thoughts on this converter?
- Will a stall converter hurt a high mileage motor?
- Tranny staying in first for too long. help?
- Why is my clutch slipping?
- Does my car have subframe connectors?
- Help with installing Autometer electric trans temp gauge
- gear change and correcting speedo
- ls diff install,how to help!
- T56 vibrations?
- Borg-Warner Differential?
- 12 bold fluid capacity
- A4 problems
- LS1 rear into LT1... any Problems?
- Transmission is out
- Stock torque arm on 9" Moser?
- 700R4?s
- Differance in LT1 and LS1 6 speed tranny?
- 6sp conversion wiring questions
- Best Clutch To Buy
- Can I drop a full second with ET Streets!? High Stall & Gears
- TV cable?
- banging noise in rear end. rattle..
- Clutch Swap
- 3.23 to 3.73 what do i need?
- T56 problems
- 12-bolts
- Best place to buy a SPEC Clutch
- 1st gear synchro in T56 is shot
- 3.42's + 3000 stall... good or bad?
- rear end gears and top speed...would this be a logical assumption?
- th350 rebuild
- tranny is out! help on parts though?
- any auto guys ever broken the rearend?
- Vibration at 60 or 70 mph ?
- Guys with clutch experience
- Transmission stuck in gear fix from GM
- Clutch Won't Engage
- Jegster torque arm + Eibach sportline question.
- 6spd popping out of gear
- a4 to m6 swap
- broken clutch and motor is locked
- Narrowing front track width with skinnies?
- Swapping Out Gear Sets
- 12 bolt setup tips ?
- Need a custom driveshaft...
- Clutch release point changing after it ges warmed up, normal?
- T5 VSS versus T56 VSS - I need guru's help
- ATI Transmissions?
- synthetic ATF
- to bearing??
- clutch disc question
- Rearend Whining!!!
- clutch slipping slightly, due to cold weather?
- Clutch Or Tranny
- Who sells Boxed SFC's made for your jack?
- Prescribed Pointless?!?!? or Problem?!?!?
- stall to match XE 230/236
- DS safety loop for long tubes
- tranny question
- Time to install SFC's
- differental question
- Tmission Problems
- Tmission Problems
- Which spec stage III?
- Willa T-5 grenade behind a 400CID???
- Shifts are slipping on auto transmissionon
- Slipping gear shifts in auto transmission
- Quick opinion. Tranny failure related.
- Width of GM 10 bolt?
- Gear Break In
- What causes a transmission to burn up 7 times in a month and a half?
- F-Body Driveshafts???
- Clutch install: Any tips?
- NV4500 5 sp.
- How much Tranny Fluid
- Slp short throw shifter
- The ins and outs of slipper clutches
- 2002 Camaro SS
- MPH doesnt add up
- What to do with my TH400?
- Does anyone sell a T-56 REBUILD VIDEO
- speedo and 3.73
- Pinion Bearings/Pinion Seal
- Dyno results
- Need Opinions on Midwest Converters
- weird noise
- whine at 40-50 mph.. my guess, would like input.
- 5th gear not always there, or grind when cold....
- A4 to M6
- grinding..???
- raptor trannies
- Edge TC
- Help me with Ford 9" install???
- strange 12 bolt
- 8.8 rears
- tranny coolers...
- A "rearend" question.
- T56 Flywheel thickness?
- clutch disks
- Best Tranny fluid
- Street Twin break in question please...
- During WOT, does the TQ supposed to Lock up? or not?
- cant disengadge the clutch
- This cant be good
- upgrading to a stage 3 ?!?!
- Wooshing Sound?
- Auto to Manual Conversion
- A4 to M6 Crossmember?
- Is there a break in period for new stall converters.
- driveshaft length for th400 and 9 inch
- clutch disks
- Problems with my 700R4 in my Truck. NEED HELP!!!
- Where is Pin A on the VSS?
- rearend problems
- 4L60E Prolblems
- Help with drive and driven gear
- rearend about to go???
