- I need a strong trans mount. I keep breaking them
- Question about 95 formula stock drivetrain
- How to determine which carrier for these gears?
- Speedo Gear Housing, 40-45 stock?
- t56 troubles
- TH400 question
- who for a tranny rebuild?
- 97 A4 Tranny fluid question
- Manual Valve Body, No Electronics 4L60E
- Whats the best way to bleed slave cylinder?
- 95 z28 rear end replacement
- Clutch Recommendation?
- Flexplate to crank bolts keep coming loose.
- Vibration and noise problem 2001 SS M6
- Help with axle removal, need ASAP!
- 95 z28 26 or 28 spline axels
- clutch kit <$500
- replacing rear differential grears
- T56 Removal - 95 Z28 (So Close, Bell Housing Hiting Tunnel)
- No 2-3 shift at WOT. How do you fix it?
- Need help Fast
- Disengagement issues - Street Twin
- Sent the tranny to CPT today!
- hard to find 5th and 6th on t56 h-pattern gone??
- How Do My Syncro's Look (Pics)
- 98 Tranny To 94 Z-28
- where do I get slave cyl plastic "hat"?
- Swapping out carriers?
- VSS not working
- Clutch fork question
- Transmission interchange question
- Which do you feel is stronger?
- B&M shifter linkage help.
- T56 to A4 Swap. Help Needed!!
- Turbo 350 gear question
- Pinion run-out
- Vibrating, Grinding Noise From T56
- TH350 vs 4L60E
- Reusing a Disc?
- Replacing spider gears in Torsen unit
- Lock up function for torque converter not working: still OK to drive?
- My turn at a ticking thread. When braking hard and clutch not pushed in.
- T56 6 Speed Transmission Swap
- Turbo 400 trouble!!
- Vibrating BAD!
- new 2001 camaro ss rear end price?
- what gearing?
- Vss 4l60e
- Gears and speedo
- Transmission Trouble
- Amsoil Manual Transmission Fluid In M6
- Driveshaft Length Help
- Rear End about to blow??
- Driveshaft length with S60
- differential pinion shaft - removal tricks? need help quickly please
- A complete list of obd2 gm powertrain codes
- Pinion seal question (I searched)...
- Code 81 What Now Damn 4l60e Help Please.
- 94Z28 trans removal/clutch replacement
- new guy just want say hi and ask simple question
- axle bearing removal - need help soon...
- clutch will not press down
- Super t-10
- So ....?
- Odd noise wihle shifting
- 93 LT1 A4 wont shift
- What gears should i get?
- Loose pinion bearing???
- Did all SS's come with aluminum driveshafts?
- Questions for those with over 450RWHP AND 4L60E
- 1994 z 4l60e issues
- ok gear swap question?
- Poly trans mount
- Need a little Info on replacing the pinion seal.
- Manual question
- Help on a picking a new driveshaft!
- LT 4 pp & dual friction clutch not enough?
- Won't shify out of park!!
- Clutch kits
- turbo 400 swap
- Will a t5 5sp v6 transmission fit v8
- PerformaBuilt FATHERS DAY SALE !
- Problem setting proper backlash with Motive 4.11
- 2nd gear gone :(
- 12 bolt vs. 9 in.
- Need new flywheel
- How do you get over 125 mph on track with 4.10's?
- New rear end
- Will doing this mess something up?
- need HELP ASAP - how to remove c-clip on axle
- McLeod Twin Disc. LT1
- T-5
- Pressure plate balance
- Broken Clutch fork
- drive shaft diameter?
- stock z28 rear axles ring gear diameter?
- T-56 Shift Fork Replacment
- Slave cylinder 1995 camaro LT1!!
- got problem need help fast
- Something New From Performabuilt "restoration"
- clutch fork rubs on pressureplate. need help
- SPEC 3, or 3+?
- removing hydraulic throwout bearing on 01 3.8 t-5?
- B&M Hammer
- Wont shift
- Rear of car grinds when reversing?
- Fuddle
- Should I use this clutch?
- Clutch master slave cylinder help????
- Axel tubes seepage...
- Need help with transmission info
- broke 1 bolt on flywheel-I can still run it right?
- I think I ordered the wrong shifter
- Making your auto last longer?
- Best bang for the $ gears
- Wont start
- who can definitively tell me what it takes to use a 94/95 trans in a 96+
- What size / were to buy trans bolts?
- tranny cooler.
- Reverse Lockout Question
- Basic Shifting Question
- have a 9 inch rear end and it seems to ride heigher on one side?
- Piolet Bushing or Bearing?
- Converting drivetrain question(stupid)
- Hypertech shift firmness programming and tranny wear?
- anyone heard fom Frank Cahall from cpt?
- An appology for delays from CPT
- LT1 F-Body Clutch Review Write-Up
- having problems setting up Summit gears
- Doing 3.73 Gears, what to expect from stock 10 Bolt?
- finished 8.8!
- Will a ls1 4l60e work with a Lt1...
- transmission takes a while to shift? Why?
- Strange Dana S60 - truetrac owners
- Need a gear pattern check (pics inside)
- 'Drill mod" Pix?
- Gear whine and T/A Cover help
- Steel driveshafts & vibration?
- My Mosher gears whine bad, should they.
- Help with a problem trans or converter?
- HELP with T56 to T5 swap!?!?!?
- New Camaro; speedometer off
- LT1 4L60E difference 93-94 and 95-97?
- th400 fluid fill ?
- Burnout with a 4l60e
- 94 Rear end
- Whats the difference in a glide and turbo converter?
- Another 4L60E done!
- Serious moser 9'' problems... Any ideas?
- Will V6 rear axle fit V8?
- Play between the axles after rebuild - Torsen worn or something else?
- 4l60e from 95, put in 94. 2-3 wot no shift.
- Simple Ring & Pinion Question?
- 4L60E Trouble
- Dana S60 and Torque Arms
- lt1 clutch problems
- Talk to me about gear oil
- T56 donor cars
- Bent throwout bearing? (video)
- 10 bolt axle
- performance transmission builder??
- i need some help...'94 4L60E Z28
- 4L60E special tools
- Did my rearend go out?
- Vig3k sat in garage for a year, will it be ok?
- Strange drivetrain noise
- 4L60E Lo/Reverse Stack-up Question
- vibration and leak issues
- Can I use a 8.5 truck posi and 3.73 gears?
- 9" 3rd. member questions/info needed?
- how can i tell of my 10 bolt
- synthetic ATF in M6...not supposed to?
- Need Help - Axles and LSD
- Drag radials = broken 10 bolt...Yay/Nay?
- Break in Period for Strange 60?
- Tranny leak, any help would be great.
- Clutch Pedal Problems
- is it easy to switch from manual tranny to auto?
- Labor Cost/Size of Converter
- 3.73's
- Need pigtail for VSS on T-56
- shift solieniod
- Transmission replacement
- how do you convert a 95 Z28 4l60e to work in a 94 Z28
- Missed Shifts
- tuning in 700r4 shift patterns?
- Shift points on a TH350 swap?
- how to remove tailshaft 4l60e
- clutches gone in my auto?
- Ring and Pinion gear replacement
- Where to get mikronite process done
- loud 2.73's?
- bad tft sensor
- Hayden 679 cooler
- Will a 153 tooth flexplate bolt to a high performance torque converter?
- LT1 6 speed in LS1?
- 3200 stall driving questions
- 4l60e rebuild kit question...is this good enough?
- Th400 or 4L60E
- Rattling sound between gear changes.. 95 6speed
- 4.10 install what went wrong?
- How hard to rebuild McLeod master cylinder
- Fuddle Racing?
- trans problem
- Calling Frank Cahall CPT.
- crooked rearend
- 4L60E's weight comparison
- Best rear gear for the 1/4 mile
- annoying sqeaking noise
- cooler line/trans cooler help
- What is this transmission? Casting Number?
- M6 Atf Poll
- E-Brake Brackets
- Cutloose in 2ond @ 400 RPM
- lock up converter in a powerglide
- First gear jammed in an 4L60E
- What are my options with different vss? Please Help ASAP
- Is this a stock clutch disk?
- Whats broke? Throwout bearing or pilot bearing
- Need a little clutch help!
- Is there a clutch that can hold over 800HP?
- What could make my clutch engage/release point change while driving?
- 95 4L60E into 94 Z28
- quick clutch question
- Performabult Sale And More!
- Quick clutch and PP question
- What to use to flush cooler and lines?
- To much atf?
- Help me choose a posi for my 10bolt!
- T56 Conversion in a 1st Gen
- Check out our new website
- Textralia for LT1(383 Stroker)???
- break-in question
- 96 4l60e into a 95?
- clutch problem
- Installing a new shifter. ???'s
- transmission wont shift right
- S60 Owners, driveshaft length?
- Effects of Rear end Gear Ratio on Dyno #'s
- quick Torque arm question
- lost 3rd and 4th. Very upkept 4l60E. Suggestions?
- 94 4l60e transmision compatibility
- Noob question
- Converter not locking up in high gear?
- Help! Stuck Trans
- 9" Just bought NEED TIPS
- Replacing Rear differential gasket
- what converter should i use
- one & done!
- How can I tell if a gear is 2 series or 3 series?
